      freeman6555 @coyote last edited by freeman6555
      @coyote
      Okay, danke für die schnelle Antwort 🙂
      Hier das Log:
      shuttercontrol.0	2020-05-07 16:45:00.016	debug	(6638) Sun Elevation: 37.9°
      shuttercontrol.0	2020-05-07 16:45:00.014	debug	(6638) Sun Azimut: 248.4°
      shuttercontrol.0	2020-05-07 16:41:20.120	debug	(6638) Shutdown shutters sleep area: 18:00
      shuttercontrol.0	2020-05-07 16:41:20.111	debug	(6638) Shutdown shutters living area: 21:28
      shuttercontrol.0	2020-05-07 16:41:20.105	debug	(6638) Starting up shutters sleep area: 09:00
      shuttercontrol.0	2020-05-07 16:41:20.098	debug	(6638) Starting up shutters living area: 07:00
      shuttercontrol.0	2020-05-07 16:41:20.064	debug	(6638) Shutdown shutters Sunset area: 21:28
      shuttercontrol.0	2020-05-07 16:41:20.063	debug	(6638) Starting up shutters Sunrise area: 06:06
      shuttercontrol.0	2020-05-07 16:41:20.062	debug	(6638) Shutdown shutters GoldenHour area: 20:41
      shuttercontrol.0	2020-05-07 16:41:20.061	debug	(6638) Starting up shutters GoldenHour area: 06:54
      shuttercontrol.0	2020-05-07 16:41:20.058	debug	(6638) Sunset today: 20:58
      shuttercontrol.0	2020-05-07 16:41:20.056	debug	(6638) Sunrise today: 05:51
      shuttercontrol.0	2020-05-07 16:41:20.055	debug	(6638) current day: 4
      shuttercontrol.0	2020-05-07 16:41:20.054	debug	(6638) goldenHour today: 20:11
      shuttercontrol.0	2020-05-07 16:41:20.052	debug	(6638) goldenHourEnd today: 06:39
      shuttercontrol.0	2020-05-07 16:41:19.055	debug	(6638) Sun Elevation: 38.4°
      shuttercontrol.0	2020-05-07 16:41:19.050	debug	(6638) Sun Azimut: 247.5°
      shuttercontrol.0	2020-05-07 16:41:17.104	debug	(6638) save current height: 100% from Arbeitszimmer
      shuttercontrol.0	2020-05-07 16:41:17.104	debug	(6638) save current height: 0% from Küche-Rechts
      shuttercontrol.0	2020-05-07 16:41:17.103	debug	(6638) save current height: 100% from Küche-Links
      shuttercontrol.0	2020-05-07 16:41:17.103	debug	(6638) save current height: 0% from Terrasse
      shuttercontrol.0	2020-05-07 16:41:17.102	debug	(6638) save current height: 69% from Schlafzimmer
      shuttercontrol.0	2020-05-07 16:41:17.102	debug	(6638) save current height: 0% from Martha
      shuttercontrol.0	2020-05-07 16:41:17.101	debug	(6638) save current height: 0% from Bad Unten
      shuttercontrol.0	2020-05-07 16:41:17.101	debug	(6638) save current height: 52% from Wohnzimmer
      shuttercontrol.0	2020-05-07 16:41:17.085	debug	(6638) save current height: 0% from Esszimmer
      shuttercontrol.0	2020-05-07 16:41:17.068	debug	(6638) Shutter State: tahoma.0.devices.Arbeitszimmer.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.066	debug	(6638) Shutter State: tahoma.0.devices.Küche_Rechts.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.064	debug	(6638) Shutter State: tahoma.0.devices.Küche_Links.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.062	debug	(6638) Shutter State: tahoma.0.devices.Terrasse.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.060	debug	(6638) Shutter State: tahoma.0.devices.Schlafzimmer.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.058	debug	(6638) Shutter State: tahoma.0.devices.Martha.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.056	debug	(6638) Shutter State: tahoma.0.devices.Bad.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.054	debug	(6638) Shutter State: tahoma.0.devices.Wohnzimmer.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:17.051	debug	(6638) Shutter State: tahoma.0.devices.Esszimmer.states.core:ClosureState
      shuttercontrol.0	2020-05-07 16:41:16.992	info	(6638) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v12.16.2, js-controller: 3.0.20
      shuttercontrol.0	2020-05-07 16:41:12.161	info	(6400) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      shuttercontrol.0	2020-05-07 16:41:12.159	info	(6400) terminating
      shuttercontrol.0	2020-05-07 16:41:12.158	info	(6400) cleaned everything up...
      shuttercontrol.0	2020-05-07 16:41:12.157	info	(6400) Got terminate signal TERMINATE_YOURSELF
      Und so war die Einstellung bei erreichen vom Azimut 248:
      Ich mache die Sonnenrichtungs Einstellung immer bei 2 Rollos, der Küche Links und Terrasse. Terrasse ist offen und Küche Links ist geschlossen. Man weiß ja nicht wo der Fehler liegt 💁‍♂️
      coyote 2 Replies Last reply Reply Quote 0
      • coyote
        coyote Most Active @freeman6555 last edited by coyote
        @freeman6555 ja moment, da müsste aber doch noch mehr im Log kommen, laut deiner Einstellung in dem Bild soll er bei 249 auslösen.
        Nee Kommando zurück, hast ja +/- 2 drin
        • coyote
          @freeman6555 Schick mal noch einen Screenshot von den Extra Einstellungen und noch einen von den Objekten, heißt unter Objekte/shuttercontrol.0/shutters/autoSun
            @coyote
            • coyote
              @freeman6555 sieht soweit eigentlich alles gut aus. Da bin ich jetzt auch raus, hab erst mal keine Idee mehr. Seltsam ist, dass es ja vorher mit dem Homebridge Adapter ging und jetzt eben nur die offen/geschlossen Datenpunkte umgekehrt sind. Vllt findet sich noch jemand, bei dem es auch so ist, wie gesagt, ich hab nur Wired Aktoren.
                @coyote
                Vielen Dank 🙂 Ich habe auch schon ein paar Wochen lang immer wieder experimentiert, aber auch keine Lösung gefunden, ich bin aber auch kein Experte 😉
                • simatec
                  simatec Developer Most Active @2hot4you last edited by
                  @2hot4you
                  Dein VIS für Shuttercontrol sieht klasse aus
                  2 1 Reply Last reply Reply Quote 0
                  • simatec
                    simatec Developer Most Active @freeman6555 last edited by
                    @freeman6555
                    Shuttercontrol setzt aktuell voraus, dass 100% offen und 0% geschlossen sind.
                    Ich bin noch am überlegen ob und wie ich eine Konvertierung machen werde.
                    Du kannst aber das ganze mit ein paar Datenpunkten und JavaScript auch machen.
                      Malz1902 last edited by Malz1902
                      bei mir will das mit dem Sonnenschutz auch noch nicht so ganz. Ich hbe ein Rollos so eingesellt, dass es bei Außentemperatur und Himmelsrictuntung auslösen soll, Rollo ist auch auf 25% gefahren aber ist nicht wieder hochgefahfen.
                      Beim runter fahren macht es ja Sinn wenn Temperatur >= 25°C und Himmelsrichtung >= 155 und <= 265 aber beim wieder hochfahren sollte es doch reichen wenn entweder die Temperatur kleiner ist oder die Himmelsrichtung außerhalb vom Wert ist oder?azimut.JPG sonnenschutz.JPG
                      Das Problem ist der Außentemp Sensor meldet momentan noch eine Temp. von 26°C, Rollo sollte aber dennoch hochfahren
                        freeman6555 @simatec last edited by
                        @simatec
                        Ich könnte die Sonnenschutz Funktion auch mit einem eigenen Skipt machen, das hätte aber nicht zur eventuellen klärung dieses Problems beigetragen 🙂
                        So lang das noch nicht geht, werde ich mal ein paar Blockly´s machen, vielen Dank für deine Arbeit 👍
                        • 2
                          2hot4you @MartyBr last edited by
                          @MartyBr
                          Hallo Martin,
                          kein Problem, bekomme gerade die VIEW Seite nicht exportiert, daher alle Widgets.
                          rollo_widgets.txt
                          Gruß Michael
                          • 2
                            2hot4you @simatec last edited by
                            @simatec
                            Danke für die Blumen 😊
                            Ich habe mal ne Frage zum Sonnenschutz, er funktioniert ganz gut, nur wann die Rollos wieder hoch fahren, habe ich noch nicht so ganz verstanden. Ich steuere den Sonnenschutz über ein Luxmeter. Bei 4000 lux fahren sie runter, eigentlich sollten Sie doch bei unter 4000 lux wieder hoch fahren, was Sie auch irgendwann machen. Wahrscheinlich hängt es mit der Hysterese zusammen, wie lange wird hier geprüft
                            Gruß Michael
                            • simatec
                              @2hot4you
                              Die Hysterese arbeitet in Prozent.
                              Wenn du bei 4000 z.B. 10 % eingestellt hast, fahren sie unter 3600 Lux wieder hoch
                                @simatec kannst du was zu meinem problem sagen?
                                Fahren die Rollos bei der Sonnenschutzeinstrellung erst wieder hoch wenn die Himmelsrichtung überschritten ist und die Außentemp wieder unter dem Soll Wert ist?
                                • simatec
                                  simatec Developer Most Active @Malz1902 last edited by
                                  @Malz1902
                                  Wenn deinen Himmelsrichtung größer 275 oder deine Außentemperatur kleiner 22,5 ist, sollte der Rolladen hochfahren
                                    Siehe Bilder aus meinem Post weiter oben die Himmelsrichtung war bei über 300 die Temp aber bei über 25°C, das Rollo ist dennoch nicht hochgefahren
                                    • simatec
                                      @Malz1902
                                      Mache mal bitte ein Issue auf, damit ich mir das anschauen kann
                                        @simatec said in Test Adapter shuttercontrol v0.5.x:
                                        @Malz1902
                                        wenn du mir sagst wie das geht 😄
                                          Ich habe bei 3 Rollos die gleiche Sonnenschutzeinstellung, 2 sind runtergefahren, 1 nicht.
                                          shuttercontrol.0	2020-05-08 12:35:00.009	debug	(14669) Sun Elevation: 53.9°
                                          shuttercontrol.0	2020-05-08 12:35:00.007	debug	(14669) Sun Azimut: 157.1°
                                          shuttercontrol.0	2020-05-08 12:34:54.343	debug	(14669) insidetemperature changed: zigbee.0.00158d000410c77b.temperature
                                          shuttercontrol.0	2020-05-08 12:34:45.949	debug	(14669) insidetemperature changed: zigbee.0.00158d00044b332b.temperature
                                          shuttercontrol.0	2020-05-08 12:33:53.992	debug	(14669) insidetemperature changed: zigbee.0.00158d000410c77b.temperature
                                          shuttercontrol.0	2020-05-08 12:33:50.205	debug	(14669) system.adapter.admin.0: logging true
                                          shuttercontrol.0	2020-05-08 12:33:35.269	debug	(14669) outsidetemperature changed: zigbee.0.00158d00045c07b2.temperature
                                          shuttercontrol.0	2020-05-08 12:32:53.946	debug	(14669) system.adapter.admin.0: logging false
                                          shuttercontrol.0	2020-05-08 12:32:26.411	debug	(14669) shutter state changed: hm-rpc.1.00111A4991DE15.4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:32:02.450	debug	(14669) shutter state changed: hm-rpc.1.00111A4991DE15.4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:32:02.289	debug	(14669) shutter state changed: hm-rpc.1.00111A4991DE15.4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:32:02.281	debug	(14669) save current height: 0% from RolloKindRechtsSeite00111A4991DE15:4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:32:02.280	info	(14669) Set ID: RolloKindRechtsSeite00111A4991DE15:4.LEVEL value: 0%
                                          shuttercontrol.0	2020-05-08 12:32:02.280	debug	(14669) Sunprotect for RolloKindRechtsSeite00111A4991DE15:4.LEVEL is active
                                          shuttercontrol.0	2020-05-08 12:31:54.804	debug	(14669) system.adapter.admin.0: logging true
                                          shuttercontrol.0	2020-05-08 12:30:50.696	debug	(14669) shutter state changed: hm-rpc.1.00111A49915663.4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:30:32.340	debug	(14669) shutter state changed: hm-rpc.1.00111A49915663.4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:30:32.151	debug	(14669) shutter state changed: hm-rpc.1.00111A49915663.4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:30:32.144	debug	(14669) save current height: 25% from RolloEsszimmer00111A49915663:4.LEVEL
                                          shuttercontrol.0	2020-05-08 12:30:32.143	info	(14669) Set ID: RolloEsszimmer00111A49915663:4.LEVEL value: 25%
                                          shuttercontrol.0	2020-05-08 12:30:32.143	debug	(14669) Sunprotect for RolloEsszimmer00111A49915663:4.LEVEL is active
                                          Kannst Du mir sagen warum?
                                          Und dann hab ich noch ein Rollo im Schlafzimmer, das hat die gleiche Einstellung bzgl Sonnenschutz wie das Rollo Ankleide, dies ist auch nicht runtergefhren, dies war aber auch nicht komplett offen bei 100% sondern stand bei 50 % ist es deswegen nicht runter gefahren?
                                          • simatec
                                            @Malz1902 sagte in Test Adapter shuttercontrol v0.5.x:
                                            genau das ist der Grund. Laut Doku bewirkt manuelles eingreifen ein deaktivieren der Automatik bis zum nächsten runterfahren.
                                            zu dem anderen Problem müsste ich deine Config sehen
                                            332
                                            7411
                                            10616361
