    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
      vodafone-speedtest.0	2020-05-04 14:02:01.268	error	(11810) init_sbc: Unknown Error
      krieg ich als Fehlermeldung geschmissen
        dos1973 last edited by
        toller Adapter!
        funktioniert und die Werte passen.
        zur Info bei werden einige DP (Modem) nicht gepflegt.
        ich habe eine Fritzbox und dann ein USG.
        • dontobi
          dontobi last edited by
          Ich wollte gerade den Adapter installieren. Leider hat das nicht geklappt. Hier die Ausgabe im Admin:
          $ ./iobroker add vodafone-speedtest  --host smarthome
          NPM version: 6.14.5
          npm install iobroker.vodafone-speedtest@0.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
          Could not run curl-config, please make sure libcurl dev package is installed.Output: /bin/sh: 1: curl-config: not found
          gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/tools/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          gyp
           ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR!
          stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp
          ERR! stack     at ChildProcess.emit (events.js:310:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
          node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v12.16.3node-pre-gyp ERR! node-pre-gyp -v v0.14.0node-pre-gyp ERR! not ok
          npm
           ERR! code ELIFECYCLEnpm ERR! errno 1npm
          ERR! node-libcurl@2.1.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-06T16_57_53_232Z-debug.log
          ERROR: host.smarthome Cannot install iobroker.vodafone-speedtest@0.0.4: 1
          ERROR: process exited with code 25
          Die Log kann ich gerne nachreichen, wenn diese benötigt wird. Vielleicht kann mir ja jemand sagen, was das Problem ist.
            Hab das selbe Problem.....
            $ ./iobroker install vodafone-speedtest
            NPM version: 6.11.3
            gyp
            gyp ERR! stack Error: gyp failed with exit code: 1gyp
            ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
            node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
            node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.14.0node-pre-gyp ERR! not ok
            npm
            errno 1npm ERR! node-libcurl@2.1.1 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-08T09_49_04_651Z-debug.log
            ERROR: host.raspberrypi Cannot install iobroker.vodafone-speedtest@0.0.4: 1
            peterbaumert 1 Reply Last reply Reply Quote 0
            • peterbaumert
              peterbaumert Developer @Guest last edited by
              @tobi83 @dontobi das muss wohl an euren namen liegen 😛
              Ne quatsch, was habt ihr denn für Betriebssystem?
              apt install libcurl-dev
              sollte dies unter debian und ubuntu beheben.
              @dos1973 Bekommst du auf der Vodafone Speedtest seite oben denn deine "soll" Geschwindigkeit angezeigt?
              @arteck wie oft lässt du den denn laufen? Habe bei Vodafone die Vermutung, wenn man es zu oft macht blockieren die einen, hatte ich während meinen Tests auch.
              Pete
              dontobi D 2 Replies Last reply Reply Quote 0
              • dontobi
                dontobi @peterbaumert last edited by
                @peterbaumert Ich wollte gerade das von dir erwähnte Paket installieren. Nun kommt das...
                root@smarthome:~# apt install libcurl-dev
                Paket libcurl-dev ist ein virtuelles Paket, das bereitgestellt wird von:
                  libcurl4-openssl-dev 7.64.0-4+deb10u1
                  libcurl4-nss-dev 7.64.0-4+deb10u1
                  libcurl4-gnutls-dev 7.64.0-4+deb10u1
                Sie sollten eines explizit zum Installieren auswählen.
                E: Für Paket »libcurl-dev« existiert kein Installationskandidat.
                  A Former User last edited by
                  Ähmja irgendwie kein Erfolg....
                  pi@raspberrypi:~ $ apt install libcurl-dev
                  E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open ( 13: Keine Berechtigung)
                  E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are y ou root?
                  E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
                  E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                    @tobi83
                    sudo apt install libcurl-dev
                      A Former User @Thomas Braun last edited by A Former User
                      🤦‍♂️ Danke
                      Aber trotzdem nicht....
                      NPM version: 6.11.3
                      Could not run curl-config, please make sure libcurl dev package is installed.Output: /bin/sh: 1: curl-config: not foundgyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/tools/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                      gyp ERR! configure error gyp ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)
                      gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
                      npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! node-libcurl@2.1.1 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-08T12_31_03_537Z-debug.log
                      • peterbaumert
                        @tobi83 @dontobi
                        apt install libcurl4-openssl-dev
                        Ich muss das dann noch in die readme mit aufnehmen. Dachte eigentlich das würde mit curl mit installiert.
                        Pete
                          dos1973 @peterbaumert last edited by
                          @peterbaumert sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                          Nein, da steht nichts von „soll“.
                          Kann es sein, dass ich ehemals Unitymedia bin?
                          Die werte und alles passen gut.
                            A Former User @peterbaumert last edited by
                            @peterbaumert
                            bei mir musste noch sudo davor dann kam würden Dateien fehlen
                            Hab danach apt-get update wie in Konsole stand gemacht und dann nochmal installiert ohne Fehler.
                            Hab dann den Adapter installiert, er warf jede Menge Meldungen, war danach noch nicht in den Instanzen, hab dann nochmal den Adapter installiert aber über die Adapter Page und nicht über Info und neue Adapter und dann ging es ohne Fehlermeldungen und der Adapter ist da.....
                            Unten dran die Fehlermeldungen bei der Installation über die Info Page
                            Tobias
                            NPM version: 6.11.3
                            In file included from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
                            In file included from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:../src/node_libcurl.cc: At global scope:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^../src/node_libcurl.cc:58:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(node_libcurl, Init); ^
                            In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^
                            /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:../../nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                            In file included from ../src/Easy.h:11, from ../src/Easy.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                            ../src/Easy.cc: In member function ‘void NodeLibcurl::Easy::CallSocketEvent(int, int)’:../src/Easy.cc:241:30: warning: variable ‘returnValueCallback’ set but not used [-Wunused-but-set-variable] Nan::MaybeLocalv8::Value returnValueCallback = asyncResource.runInAsyncScope( ^~~~~~~~~~~~~~~~~~~
                            ../src/Easy.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE NodeLibcurl::Easy::GetInfo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/Easy.cc:1640:69: warning: ignoring return value of ‘v8::Maybe<bool> v8::Object::Set(v8::Localv8::Context, uint32_t, v8::Localv8::Value)’, declared with attribute warn_unused_result [-Wunused-result] Nan::Newv8::String(curr->data).ToLocalChecked()); ^
                            In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Easy.h:11, from ../src/Easy.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:3252:37: note: declared here V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~
                            /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            In file included from ../src/Share.h:12, from ../src/Share.cc:8:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                            In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Share.h:12, from ../src/Share.cc:8:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            In file included from ../src/Curl.h:13, from ../src/Multi.h:10, from ../src/Multi.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                            In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Multi.h:10, from ../src/Multi.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            In file included from ../src/Curl.h:13, from ../src/Curl.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                            In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Curl.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            In file included from /usr/include/c++/8/vector:64, from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:23, from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Curl.cc:7:/usr/include/c++/8/bits/stl_vector.h: In constructor ‘std::vector<_Tp, _Alloc>::vector(std::initializer_list<_Tp>, const allocator_type&) [with _Tp = NodeLibcurl::CurlConstant; _Alloc = std::allocatorNodeLibcurl::CurlConstant]’:/usr/include/c++/8/bits/stl_vector.h:515:7: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 vector(initializer_list<value_type> __l, ^~~~~~
                            ../src/Curl.cc: In function ‘(static initializers for ../src/Curl.cc)’:../src/Curl.cc:24:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionNotImplemented = { ^~../src/Curl.cc:87:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionInteger = { ^../src/Curl.cc:292:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionString = { ^~../src/Curl.cc:438:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionFunction = { ^~../src/Curl.cc:459:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionLinkedList = { ^~../src/Curl.cc:481:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionHttpPost = { ^~../src/Curl.cc:487:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionSpecific = { ^~../src/Curl.cc:492:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionNotImplemented = { ^../src/Curl.cc:503:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionInteger = { ^~../src/Curl.cc:518:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionStringArray = { ^~../src/Curl.cc:525:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoNotImplemented = { ^~../src/Curl.cc:539:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoString = { ^~../src/Curl.cc:553:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoOffT = { ^~../src/Curl.cc:579:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoDouble = { ^~../src/Curl.cc:595:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoInteger = { ^../src/Curl.cc:631:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoSocket = { ^~../src/Curl.cc:637:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoLinkedList = { ^~~~~~~~
                            In file included from ../src/Curl.h:13, from ../src/CurlVersionInfo.h:10, from ../src/CurlVersionInfo.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                            In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/CurlVersionInfo.h:10, from ../src/CurlVersionInfo.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:../../nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                            ../src/CurlVersionInfo.cc: At global scope:../src/CurlVersionInfo.cc:19:6: warning: ‘void NodeLibcurl::{anonymous}::SetObjPropertyToNullOrValue(v8::Localv8::Object, std::__cxx11::string, TValue) [with TValue = v8::Localv8::Primitive]’ defined but not used [-Wunused-function] void SetObjPropertyToNullOrValue<v8::Localv8::Primitive>(v8::Localv8::Object obj, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            host.raspberrypi install adapter vodafone-speedtest
                            upload [4] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/words.js words.js application/javascript
                            upload [3] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/vodafone-speedtest.png vodafone-speedtest.png image/png
                            upload [2] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/style.css style.css text/css
                            upload [1] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/index_m.html index_m.html text/html
                            upload [0] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/admin.d.ts admin.d.ts video/mp2t
                            host.raspberrypi object system.adapter.vodafone-speedtest created/updated
                            process exited with code 0
                            peterbaumert A 2 Replies Last reply Reply Quote 0
                            • peterbaumert
                              @tobi83 super dass es nun geht und danke für die fehlermeldungen etc. muss ich mir in Ruhe mal anschauen.
                              @dos1973 Ja habe noch nicht so ganz verstanden was genau es ausmacht wann man da infos bekommt. Denke mal hat irgendwas damit zu tun ob Vodafone deine IP/MAC einem Account zuordnen kann 🤷‍♂️
                              • Dr. Bakterius
                                Dr. Bakterius Most Active last edited by
                                Leider war ich mit den Ergebnissen auch bei diesem Adapter nicht glücklich. Zwar besser als beim anderen (der aufgrund des Single-Test zu wenig gemessen hat), aber bei Vodafone werden zu optimistische Werte angezeigt. Für eine Tendenz reicht es zwar, aber ich habe mich trotzdem nach einer anderen Lösung umgesehen - und für mich gefunden.
                                Ich habe mir mit folgendem Befehl ein speedtest-Skript heruntergeladen und ausführbar gemacht:
                                wget -O speedtest https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py
                                chmod +x speedtest
                                Dann habe ich mir ein Bash-Skript gebastelt, dass den Speedtest zu einem vorgegebenen Server durchführt und das Ergebnis in Datenpunkte von ioBroker schreibt:
                                #!/bin/bash
                                # Speedtest durchführen
                                 Erg=$(/usr/local/bin/speedtest --server <SERVERNUMMER> --simple)
                                # Ergebnis in Variable schreiben
                                # Dabei den Wert korrigieren und runden
                                 Ping=$(echo "$Erg" | grep "Ping: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2/3+1}')
                                 DL=$(echo "$Erg" | grep "Download: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2*1.09}')
                                 UL=$(echo "$Erg" | grep "Upload: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2}')
                                # In Datenpunkte von ioBroker schreiben
                                 Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_DL>?value=$DL)
                                 Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_PING>?value=$Ping)
                                 Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_UL>?value=$UL)
                                Das Skript lasse ich per cron einmal in der Stunde laufen. Mit den Korrekturen komme ich auf sehr ähnliche Werte wie bei speedtest.net mit meinem PC und somit auf realistische Werte die meinem Produkt entsprechen. Diese lasse ich mir in VIS anzeigen:
                                peterbaumert 1 Reply Last reply Reply Quote 1
                                • peterbaumert
                                  peterbaumert Developer @Dr. Bakterius last edited by
                                  @Dr-Bakterius Hey, ja die Werte werden durchaus von Vodafone zum besseren geschönt. Ich wollte aber so nah wie möglich am „Original“ bleiben. Ich kann ja noch zusätzlich meine eigenen Messwerte in einen extra Datenpunkt schreiben. Wäre das interessant?
                                  Pete
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active @peterbaumert last edited by
                                    Wie meinst du das? Blicke gerade nicht durch... 🤔
                                    • peterbaumert
                                      peterbaumert Developer @peterbaumert last edited by
                                      @peterbaumert said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                      Danke @Dr-Bakterius für das Feedback,
                                      ja der Adapter und auch Vodafone speedtest Seite haben sehr interessante Messverhalten 😉
                                      Es werden x Werte genommen und dann an Vodafone Server gesendet, welcher dir dann deinen Speed ausrechnet und zurückschickt. Ich habe extra nicht selbst ausgerechnet, weil ich das Messverfahren so nah wie möglich am original lassen wollte.
                                      Das mit dem Geld und Grün kommt in einer neueren Version dann 🙂
                                      Pete
                                      @Dr-Bakterius
                                      Ich rechne nicht selbst die Geschwindigkeit aus, da ich es 1zu1 so haben wollte wie der Original Vodafone Speedtest. Nun war meine Frage on ich es selbst ausrechnen soll und in einem zusätzlichen Datenpunkt speichern.
                                      Pete
                                      C Dr. Bakterius 2 Replies Last reply Reply Quote 0
                                        Coffeelover @peterbaumert last edited by
                                        @peterbaumert Ich fände das ja tatsächlich ganz interessant.
                                        • Dr. Bakterius
                                          Kommt darauf an wie realistisch der Wert dann ist. In meinem Skript passe ich die gemessenen Werte ja auch an. So ist der Downspeed den ich auf meinem PC erreiche rund 9% höher als ihn das speedtest-Skript misst. Und der Ping nur etwas mehr als ein Drittel dessen. Wenn das so konstant ist, kann man das natürlich leicht anpassen. Allerdings weiß ich nicht, ob diese Korrektur auf einem anderen Rechner auch so passen würde...
                                          • Chaot
                                            Chaot @Dr. Bakterius last edited by
                                            @Dr-Bakterius Das wird nichts nutzen.
                                            Der Speedtest von Vodafone funktioniert bei jeder Bandbreite scheinbar anders.
                                            Früher bei 200er Leitung hat er dauernd leich erhöhte Werte angezeigt.
                                            Bei der 400er Leitung waren die Werte meist minimal niedriger,
                                            aber jetzt bei der Gigabit Leitung zeigt er ständig zu wenig an.
                                            Ich habe als Referenz immer http://breitbandmessung.de verwendet. Die scheinen schnelle Server zu haben die auch die Gigabit Leitungen korrekt ausmessen.
                                            vodafone speedtest
                                            42
                                            202
                                            26773
