    4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
    • dontobi
      dontobi last edited by
      Ich wollte gerade den Adapter installieren. Leider hat das nicht geklappt. Hier die Ausgabe im Admin:
      $ ./iobroker add vodafone-speedtest  --host smarthome
      NPM version: 6.14.5
      npm install iobroker.vodafone-speedtest@0.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
      Could not run curl-config, please make sure libcurl dev package is installed.Output: /bin/sh: 1: curl-config: not found
      gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/tools/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp
       ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR!
      stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.97-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v12.16.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp
      ERR! stack     at ChildProcess.emit (events.js:310:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
      node-pre-gyp ERR! System Linux 4.19.97-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v12.16.3node-pre-gyp ERR! node-pre-gyp -v v0.14.0node-pre-gyp ERR! not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1npm
      ERR! node-libcurl@2.1.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-06T16_57_53_232Z-debug.log
      ERROR: host.smarthome Cannot install iobroker.vodafone-speedtest@0.0.4: 1
      ERROR: process exited with code 25
      Die Log kann ich gerne nachreichen, wenn diese benötigt wird. Vielleicht kann mir ja jemand sagen, was das Problem ist.
        Hab das selbe Problem.....
        $ ./iobroker install vodafone-speedtest
        NPM version: 6.11.3
        gyp
        gyp ERR! stack Error: gyp failed with exit code: 1gyp
        ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
        node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.14.0node-pre-gyp ERR! not ok
        npm
        errno 1npm ERR! node-libcurl@2.1.1 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-08T09_49_04_651Z-debug.log
        ERROR: host.raspberrypi Cannot install iobroker.vodafone-speedtest@0.0.4: 1
        peterbaumert 1 Reply Last reply Reply Quote 0
        • peterbaumert
          peterbaumert Developer @Guest last edited by
          @tobi83 @dontobi das muss wohl an euren namen liegen 😛
          Ne quatsch, was habt ihr denn für Betriebssystem?
          apt install libcurl-dev
          sollte dies unter debian und ubuntu beheben.
          @dos1973 Bekommst du auf der Vodafone Speedtest seite oben denn deine "soll" Geschwindigkeit angezeigt?
          @arteck wie oft lässt du den denn laufen? Habe bei Vodafone die Vermutung, wenn man es zu oft macht blockieren die einen, hatte ich während meinen Tests auch.
          Pete
          dontobi D 2 Replies Last reply Reply Quote 0
          • dontobi
            dontobi @peterbaumert last edited by
            @peterbaumert Ich wollte gerade das von dir erwähnte Paket installieren. Nun kommt das...
            root@smarthome:~# apt install libcurl-dev
            Paket libcurl-dev ist ein virtuelles Paket, das bereitgestellt wird von:
              libcurl4-openssl-dev 7.64.0-4+deb10u1
              libcurl4-nss-dev 7.64.0-4+deb10u1
              libcurl4-gnutls-dev 7.64.0-4+deb10u1
            Sie sollten eines explizit zum Installieren auswählen.
            E: Für Paket »libcurl-dev« existiert kein Installationskandidat.
              A Former User last edited by
              Ähmja irgendwie kein Erfolg....
              pi@raspberrypi:~ $ apt install libcurl-dev
              E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open ( 13: Keine Berechtigung)
              E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are y ou root?
              E: Sperrdatei /var/lib/dpkg/lock-frontend konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
              E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                @tobi83
                sudo apt install libcurl-dev
                  A Former User @Thomas Braun last edited by A Former User
                  🤦‍♂️ Danke
                  Aber trotzdem nicht....
                  NPM version: 6.11.3
                  Could not run curl-config, please make sure libcurl dev package is installed.Output: /bin/sh: 1: curl-config: not foundgyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/tools/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                  gyp ERR! configure error gyp ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)
                  gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
                  npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! node-libcurl@2.1.1 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-08T12_31_03_537Z-debug.log
                  • peterbaumert
                    @tobi83 @dontobi
                    apt install libcurl4-openssl-dev
                    Ich muss das dann noch in die readme mit aufnehmen. Dachte eigentlich das würde mit curl mit installiert.
                    Pete
                      dos1973 @peterbaumert last edited by
                      @peterbaumert sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                      Nein, da steht nichts von „soll“.
                      Kann es sein, dass ich ehemals Unitymedia bin?
                      Die werte und alles passen gut.
                        A Former User @peterbaumert last edited by
                        @peterbaumert
                        bei mir musste noch sudo davor dann kam würden Dateien fehlen
                        Hab danach apt-get update wie in Konsole stand gemacht und dann nochmal installiert ohne Fehler.
                        Hab dann den Adapter installiert, er warf jede Menge Meldungen, war danach noch nicht in den Instanzen, hab dann nochmal den Adapter installiert aber über die Adapter Page und nicht über Info und neue Adapter und dann ging es ohne Fehlermeldungen und der Adapter ist da.....
                        Unten dran die Fehlermeldungen bei der Installation über die Info Page
                        Tobias
                        NPM version: 6.11.3
                        In file included from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
                        In file included from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:../src/node_libcurl.cc: At global scope:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^../src/node_libcurl.cc:58:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(node_libcurl, Init); ^
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:../../nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                        In file included from ../src/Easy.h:11, from ../src/Easy.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                        ../src/Easy.cc: In member function ‘void NodeLibcurl::Easy::CallSocketEvent(int, int)’:../src/Easy.cc:241:30: warning: variable ‘returnValueCallback’ set but not used [-Wunused-but-set-variable] Nan::MaybeLocalv8::Value returnValueCallback = asyncResource.runInAsyncScope( ^~~~~~~~~~~~~~~~~~~
                        ../src/Easy.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE NodeLibcurl::Easy::GetInfo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/Easy.cc:1640:69: warning: ignoring return value of ‘v8::Maybe<bool> v8::Object::Set(v8::Localv8::Context, uint32_t, v8::Localv8::Value)’, declared with attribute warn_unused_result [-Wunused-result] Nan::Newv8::String(curr->data).ToLocalChecked()); ^
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Easy.h:11, from ../src/Easy.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:3252:37: note: declared here V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                        In file included from ../src/Share.h:12, from ../src/Share.cc:8:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Share.h:12, from ../src/Share.cc:8:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                        In file included from ../src/Curl.h:13, from ../src/Multi.h:10, from ../src/Multi.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Multi.h:10, from ../src/Multi.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                        In file included from ../src/Curl.h:13, from ../src/Curl.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Curl.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                        In file included from /usr/include/c++/8/vector:64, from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:23, from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Curl.cc:7:/usr/include/c++/8/bits/stl_vector.h: In constructor ‘std::vector<_Tp, _Alloc>::vector(std::initializer_list<_Tp>, const allocator_type&) [with _Tp = NodeLibcurl::CurlConstant; _Alloc = std::allocatorNodeLibcurl::CurlConstant]’:/usr/include/c++/8/bits/stl_vector.h:515:7: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 vector(initializer_list<value_type> __l, ^~~~~~
                        ../src/Curl.cc: In function ‘(static initializers for ../src/Curl.cc)’:../src/Curl.cc:24:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionNotImplemented = { ^~../src/Curl.cc:87:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionInteger = { ^../src/Curl.cc:292:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionString = { ^~../src/Curl.cc:438:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionFunction = { ^~../src/Curl.cc:459:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionLinkedList = { ^~../src/Curl.cc:481:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionHttpPost = { ^~../src/Curl.cc:487:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionSpecific = { ^~../src/Curl.cc:492:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionNotImplemented = { ^../src/Curl.cc:503:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionInteger = { ^~../src/Curl.cc:518:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionStringArray = { ^~../src/Curl.cc:525:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoNotImplemented = { ^~../src/Curl.cc:539:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoString = { ^~../src/Curl.cc:553:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoOffT = { ^~../src/Curl.cc:579:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoDouble = { ^~../src/Curl.cc:595:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoInteger = { ^../src/Curl.cc:631:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoSocket = { ^~../src/Curl.cc:637:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoLinkedList = { ^~~~~~~~
                        In file included from ../src/Curl.h:13, from ../src/CurlVersionInfo.h:10, from ../src/CurlVersionInfo.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
                        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/CurlVersionInfo.h:10, from ../src/CurlVersionInfo.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:../../nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                        ../src/CurlVersionInfo.cc: At global scope:../src/CurlVersionInfo.cc:19:6: warning: ‘void NodeLibcurl::{anonymous}::SetObjPropertyToNullOrValue(v8::Localv8::Object, std::__cxx11::string, TValue) [with TValue = v8::Localv8::Primitive]’ defined but not used [-Wunused-function] void SetObjPropertyToNullOrValue<v8::Localv8::Primitive>(v8::Localv8::Object obj, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                        host.raspberrypi install adapter vodafone-speedtest
                        upload [4] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/words.js words.js application/javascript
                        upload [3] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/vodafone-speedtest.png vodafone-speedtest.png image/png
                        upload [2] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/style.css style.css text/css
                        upload [1] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/index_m.html index_m.html text/html
                        upload [0] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/admin.d.ts admin.d.ts video/mp2t
                        host.raspberrypi object system.adapter.vodafone-speedtest created/updated
                        process exited with code 0
                        peterbaumert A 2 Replies Last reply Reply Quote 0
                        • peterbaumert
                          @tobi83 super dass es nun geht und danke für die fehlermeldungen etc. muss ich mir in Ruhe mal anschauen.
                          @dos1973 Ja habe noch nicht so ganz verstanden was genau es ausmacht wann man da infos bekommt. Denke mal hat irgendwas damit zu tun ob Vodafone deine IP/MAC einem Account zuordnen kann 🤷‍♂️
                          • Dr. Bakterius
                            Dr. Bakterius Most Active last edited by
                            Leider war ich mit den Ergebnissen auch bei diesem Adapter nicht glücklich. Zwar besser als beim anderen (der aufgrund des Single-Test zu wenig gemessen hat), aber bei Vodafone werden zu optimistische Werte angezeigt. Für eine Tendenz reicht es zwar, aber ich habe mich trotzdem nach einer anderen Lösung umgesehen - und für mich gefunden.
                            Ich habe mir mit folgendem Befehl ein speedtest-Skript heruntergeladen und ausführbar gemacht:
                            wget -O speedtest https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py
                            chmod +x speedtest
                            Dann habe ich mir ein Bash-Skript gebastelt, dass den Speedtest zu einem vorgegebenen Server durchführt und das Ergebnis in Datenpunkte von ioBroker schreibt:
                            #!/bin/bash
                            # Speedtest durchführen
                             Erg=$(/usr/local/bin/speedtest --server <SERVERNUMMER> --simple)
                            # Ergebnis in Variable schreiben
                            # Dabei den Wert korrigieren und runden
                             Ping=$(echo "$Erg" | grep "Ping: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2/3+1}')
                             DL=$(echo "$Erg" | grep "Download: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2*1.09}')
                             UL=$(echo "$Erg" | grep "Upload: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2}')
                            # In Datenpunkte von ioBroker schreiben
                             Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_DL>?value=$DL)
                             Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_PING>?value=$Ping)
                             Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_UL>?value=$UL)
                            Das Skript lasse ich per cron einmal in der Stunde laufen. Mit den Korrekturen komme ich auf sehr ähnliche Werte wie bei speedtest.net mit meinem PC und somit auf realistische Werte die meinem Produkt entsprechen. Diese lasse ich mir in VIS anzeigen:
                            peterbaumert 1 Reply Last reply Reply Quote 1
                            • peterbaumert
                              peterbaumert Developer @Dr. Bakterius last edited by
                              @Dr-Bakterius Hey, ja die Werte werden durchaus von Vodafone zum besseren geschönt. Ich wollte aber so nah wie möglich am „Original“ bleiben. Ich kann ja noch zusätzlich meine eigenen Messwerte in einen extra Datenpunkt schreiben. Wäre das interessant?
                              Pete
                              • Dr. Bakterius
                                Dr. Bakterius Most Active @peterbaumert last edited by
                                Wie meinst du das? Blicke gerade nicht durch... 🤔
                                • peterbaumert
                                  peterbaumert Developer @peterbaumert last edited by
                                  @peterbaumert said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                                  Danke @Dr-Bakterius für das Feedback,
                                  ja der Adapter und auch Vodafone speedtest Seite haben sehr interessante Messverhalten 😉
                                  Es werden x Werte genommen und dann an Vodafone Server gesendet, welcher dir dann deinen Speed ausrechnet und zurückschickt. Ich habe extra nicht selbst ausgerechnet, weil ich das Messverfahren so nah wie möglich am original lassen wollte.
                                  Das mit dem Geld und Grün kommt in einer neueren Version dann 🙂
                                  Pete
                                  @Dr-Bakterius
                                  Ich rechne nicht selbst die Geschwindigkeit aus, da ich es 1zu1 so haben wollte wie der Original Vodafone Speedtest. Nun war meine Frage on ich es selbst ausrechnen soll und in einem zusätzlichen Datenpunkt speichern.
                                  Pete
                                  C Dr. Bakterius 2 Replies Last reply Reply Quote 0
                                    Coffeelover @peterbaumert last edited by
                                    @peterbaumert Ich fände das ja tatsächlich ganz interessant.
                                    • Dr. Bakterius
                                      Kommt darauf an wie realistisch der Wert dann ist. In meinem Skript passe ich die gemessenen Werte ja auch an. So ist der Downspeed den ich auf meinem PC erreiche rund 9% höher als ihn das speedtest-Skript misst. Und der Ping nur etwas mehr als ein Drittel dessen. Wenn das so konstant ist, kann man das natürlich leicht anpassen. Allerdings weiß ich nicht, ob diese Korrektur auf einem anderen Rechner auch so passen würde...
                                      • Chaot
                                        Chaot @Dr. Bakterius last edited by
                                        @Dr-Bakterius Das wird nichts nutzen.
                                        Der Speedtest von Vodafone funktioniert bei jeder Bandbreite scheinbar anders.
                                        Früher bei 200er Leitung hat er dauernd leich erhöhte Werte angezeigt.
                                        Bei der 400er Leitung waren die Werte meist minimal niedriger,
                                        aber jetzt bei der Gigabit Leitung zeigt er ständig zu wenig an.
                                        Ich habe als Referenz immer http://breitbandmessung.de verwendet. Die scheinen schnelle Server zu haben die auch die Gigabit Leitungen korrekt ausmessen.
                                          dos1973 last edited by
                                          @peterbaumert
                                          bei mir beendet sich der adapter nicht mehr, sonst war der nur für die Dauer des Test ca. 20 Sekunden alive.
                                          system.adapter.vodafone-speedtest.0.uptime: 14000 seconds
                                          es hilft auch nicht den adapter zu stoppen
                                          der Wert
                                          system.adapter.vodafone-speedtest.0.alive
                                          bleibt permanent auf true
                                          • peterbaumert
                                            peterbaumert Developer @dos1973 last edited by
                                            @dos1973 Ich überprüfe nochmal alle timeouts, eigentlich sollte das nicht passieren.
                                            @Dr-Bakterius naja realistisch ist es wenn du etwas anpasst auch nicht mehr 😄 aber so ist das eben mit dem Internet du wirst da nie konstant immer genau das angezeigt bekommen, was du auch wirklich gebucht hast. In so eine vollkommenen Welt leben wir nicht 😉
                                            @Coffeelover ich bau das mal ein
                                            Pete
                                            31.7k
                                            79.8k
                                            vodafone speedtest
                                            42
                                            202
                                            25326
