    4. Beta Test js-controller 3.0.x auf GitHub
      apollon77 last edited by
      aahhhh mist ... my fault ... WARTEN BITTE!!
        Jan1 @apollon77 last edited by
        @apollon77
        Ok, ich warte mal 5 Minuten und versuche es noch mal 🙂
          Ja bitte alle die eine 3.0.21 bekommen haben, nochmal update ... die letzten Dinge waren in nem Branch gelandet 🙂 Jetzt ist GitHub aktuell!
            Thomas Braun Most Active @apollon77 last edited by
            @apollon77
            pi@raspberrypi:~ $ iobroker version
            3.0.21
            pi@raspberrypi:~ $ nodejs -v
            v14.2.0
            Der amazon2-Adapter klemmt:
            2020-05-09 13:47:46.526  - info: host.raspberrypi "system.adapter.alexa2.0" enabled
            2020-05-09 13:47:46.599  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 10253
            2020-05-09 13:47:49.033  - info: alexa2.0 (10253) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.2.0, js-controller: 3.0.21
            2020-05-09 13:47:49.250  - info: alexa2.0 (10253) Proxy IP not set, use first network interface (192.168.178.50) instead
            2020-05-09 13:47:50.092  - warn: alexa2.0 (10253) Exception: TypeError: Cannot read property 'end' of null
            2020-05-09 13:47:50.095  - error: alexa2.0 (10253) uncaught exception: Cannot read property 'end' of null
            2020-05-09 13:47:50.097  - error: alexa2.0 (10253) TypeError: Cannot read property 'end' of null
                at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36)
                at IncomingMessage.emit (events.js:327:22)
                at IncomingMessage.EventEmitter.emit (domain.js:485:12)
                at endReadableNT (_stream_readable.js:1225:12)
                at processTicksAndRejections (internal/process/task_queues.js:84:21)
            2020-05-09 13:47:50.142  - info: alexa2.0 (10253) terminating
            2020-05-09 13:47:50.146  - info: alexa2.0 (10253) Terminated (NO_ERROR): Without reason
            2020-05-09 13:47:50.648  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'end' of null
            2020-05-09 13:47:50.649  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36)
            2020-05-09 13:47:50.649  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.emit (events.js:327:22)
            2020-05-09 13:47:50.649  - error: host.raspberrypi Caught by controller[0]:     at IncomingMessage.EventEmitter.emit (domain.js:485:12)
            2020-05-09 13:47:50.650  - error: host.raspberrypi Caught by controller[0]:     at endReadableNT (_stream_readable.js:1225:12)
            2020-05-09 13:47:50.650  - error: host.raspberrypi Caught by controller[0]:     at processTicksAndRejections (internal/process/task_queues.js:84:21)
            2020-05-09 13:47:50.651  - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              apollon77 @Thomas Braun last edited by
              @Thomas-Braun Alexa 2 liegt an nodejs 14 ... Du bist sehr experimentell unterwegs 🙂 Da ist was inkompatibel, kommt mit als nächstes. Aber nix mit controller zu tun
                Thomas Braun Most Active @apollon77 last edited by Thomas Braun
                @apollon77 Das weiß ich. Deswegen hatte ich die node-Version extra bekannt gegeben. Ich schnall mal flugs node 12 drauf...
                Im Admin wird
                Verfügbar: 3.0.20
                Installiert: 3.0.21
                vermeldet.
                  Jan1 @Thomas Braun last edited by
                  @Thomas-Braun
                  Machs noch mal, jetzt ist 3.1 online 😉
                    Wie gesagt wer eine 3.0.21 bekommen hat bitte nochmal installieren, dann sollte eine 3.1.0 kommen
                    J Thomas Braun 3 Replies Last reply Reply Quote 0
                      @apollon77
                      IOBroker Start ohne Fehler im Log mit 3.1.0 👍
                        guergen last edited by
                        Der unifi-Adapter kommt mit folgendem Fehler im Log:
                        unifi.0	2020-05-09 14:11:56.948	error	(3567) Error: api.err.Invalid
                        unifi.0	2020-05-09 14:11:56.037	debug	(3567) Update started
                        unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted WLANs: []
                        unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted networks: []
                        unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted health: []
                        unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted devices: []
                        unifi.0	2020-05-09 14:11:56.036	debug	(3567) Blacklisted clients: []
                        unifi.0	2020-05-09 14:11:56.035	debug	(3567) updateInterval = 60
                        unifi.0	2020-05-09 14:11:56.035	debug	(3567) controller = 192.168.1.208:8443
                        unifi.0	2020-05-09 14:11:56.032	info	(3567) Unifi adapter is ready
                        unifi.0	2020-05-09 14:11:56.018	info	(3567) starting. Version 0.5.0-beta.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.16.3, js-controller: 3.1.0
                        unifi.0	2020-05-09 14:11:55.956	debug	(3567) Plugin sentry Initialize Plugin (enabled=true)
                        apollon77 3 Replies Last reply Reply Quote 0
                          @apollon77
                          3.1.0
                          v12.16.3
                          alexa2:
                          Alexa startet jetzt.
                          tado:
                          Klemmt im Moment, da werde ich aber immer von deren Servern abgewiesen. Hatte das aber schon mit vorherigen Softwareständen. Hat wohl nicht mit dem controller zu tun.
                          ble:
                          Bei 'ble' musste ich die capabilities wieder manuell setzen. Wie immer bei node-Wechseln.
                          Ansonsten so auf den ersten Blick alles i.O. , das logfile bleibt auch ruhig.
                            @apollon77
                            2020-05-09 14:03:58.851  - warn: iot.0 (12964) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                            was compiled against a different Node.js version using
                            NODE_MODULE_VERSION 83. This version of Node.js requires
                            NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                            the module (for instance, using `npm rebuild` or `npm install`).
                            canvas hatte ich mal selber gebaut. Das versuche ich jetzt mit einem rebuild gerade zu zupfen.
                            Sonst keine Auffälligkeiten im log.
                              apollon77 @guergen last edited by
                              @guergen Adapterproblem bitte beim Adapte rmelden. Keine Ahnung wie das am controller liegen könnte
                                @Thomas-Braun sagte in Beta Test js-controller 3.0.x auf GitHub:
                                "iobroker fix" nach einem nodejs update is your friend
                                  @Thomas-Braun Jupp liegt an deinem "Nodejs Downgrade". Sag mal ob die rebuild Kommandos getan haben
                                    guergen @apollon77 last edited by
                                    @apollon77 ICH habe doch keine Ahnung, an was das liegt... lief nur vorher. Die 0.4.3 startet auch nicht durch....
                                      sigi234 Forum Testing Most Active @Jan1 last edited by
                                      @Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                      @apollon77
                                      Dito
                                        @apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
                                        Ich dachte es mir fast... 😉
                                        Manchmal mache ich aber auch gerne manuell im System herum. (Mit Vorsicht und (mehr oder weniger) Sinn und Verstand).
                                          @guergen AM besten mal in dem Thread der aktuellen Beta version melden
                                            @apollon77 Mache ich, schmeisse den Adapter grade einmal komplett runter und teste dann noch einmal!
                                            js-controller
                                            39
                                            416
                                            64604
