Beta Test js-controller 3.0.x auf GitHub
Ja bitte alle die eine 3.0.21 bekommen haben, nochmal update ... die letzten Dinge waren in nem Branch gelandet
Jetzt ist GitHub aktuell! -
pi@raspberrypi:~ $ iobroker version 3.0.21 pi@raspberrypi:~ $ nodejs -v v14.2.0Der amazon2-Adapter klemmt:
2020-05-09 13:47:46.526 - info: host.raspberrypi "system.adapter.alexa2.0" enabled 2020-05-09 13:47:46.599 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 10253 2020-05-09 13:47:49.033 - info: alexa2.0 (10253) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.2.0, js-controller: 3.0.21 2020-05-09 13:47:49.250 - info: alexa2.0 (10253) Proxy IP not set, use first network interface (192.168.178.50) instead 2020-05-09 13:47:50.092 - warn: alexa2.0 (10253) Exception: TypeError: Cannot read property 'end' of null 2020-05-09 13:47:50.095 - error: alexa2.0 (10253) uncaught exception: Cannot read property 'end' of null 2020-05-09 13:47:50.097 - error: alexa2.0 (10253) TypeError: Cannot read property 'end' of null at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36) at IncomingMessage.emit (events.js:327:22) at IncomingMessage.EventEmitter.emit (domain.js:485:12) at endReadableNT (_stream_readable.js:1225:12) at processTicksAndRejections (internal/process/task_queues.js:84:21) 2020-05-09 13:47:50.142 - info: alexa2.0 (10253) terminating 2020-05-09 13:47:50.146 - info: alexa2.0 (10253) Terminated (NO_ERROR): Without reason 2020-05-09 13:47:50.648 - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'end' of null 2020-05-09 13:47:50.649 - error: host.raspberrypi Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36) 2020-05-09 13:47:50.649 - error: host.raspberrypi Caught by controller[0]: at IncomingMessage.emit (events.js:327:22) 2020-05-09 13:47:50.649 - error: host.raspberrypi Caught by controller[0]: at IncomingMessage.EventEmitter.emit (domain.js:485:12) 2020-05-09 13:47:50.650 - error: host.raspberrypi Caught by controller[0]: at endReadableNT (_stream_readable.js:1225:12) 2020-05-09 13:47:50.650 - error: host.raspberrypi Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:84:21) 2020-05-09 13:47:50.651 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) -
@Thomas-Braun Alexa 2 liegt an nodejs 14 ... Du bist sehr experimentell unterwegs
Da ist was inkompatibel, kommt mit als nächstes. Aber nix mit controller zu tun -
@apollon77 Das weiß ich. Deswegen hatte ich die node-Version extra bekannt gegeben. Ich schnall mal flugs node 12 drauf...
Im Admin wird
Verfügbar: 3.0.20 Installiert: 3.0.21vermeldet.
@Thomas-Braun
Machs noch mal, jetzt ist 3.1 online
Wie gesagt wer eine 3.0.21 bekommen hat bitte nochmal installieren, dann sollte eine 3.1.0 kommen
@apollon77
IOBroker Start ohne Fehler im Log mit 3.1.0
Der unifi-Adapter kommt mit folgendem Fehler im Log:
unifi.0 2020-05-09 14:11:56.948 error (3567) Error: api.err.Invalid unifi.0 2020-05-09 14:11:56.037 debug (3567) Update started unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted WLANs: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted networks: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted health: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted devices: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted clients: [] unifi.0 2020-05-09 14:11:56.035 debug (3567) updateInterval = 60 unifi.0 2020-05-09 14:11:56.035 debug (3567) controller = 192.168.1.208:8443 unifi.0 2020-05-09 14:11:56.032 info (3567) Unifi adapter is ready unifi.0 2020-05-09 14:11:56.018 info (3567) starting. Version 0.5.0-beta.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.16.3, js-controller: 3.1.0 unifi.0 2020-05-09 14:11:55.956 debug (3567) Plugin sentry Initialize Plugin (enabled=true) -
pi@raspberrypi:~ $ iobroker version 3.1.0 pi@raspberrypi:~ $ nodejs -v v12.16.3alexa2:
Alexa startet jetzt.
tado:
Klemmt im Moment, da werde ich aber immer von deren Servern abgewiesen. Hatte das aber schon mit vorherigen Softwareständen. Hat wohl nicht mit dem controller zu tun.
ble:
Bei 'ble' musste ich die capabilities wieder manuell setzen. Wie immer bei node-Wechseln.Ansonsten so auf den ersten Blick alles i.O. , das logfile bleibt auch ruhig.
2020-05-09 14:03:58.851 - warn: iot.0 (12964) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 83. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).canvas hatte ich mal selber gebaut. Das versuche ich jetzt mit einem rebuild gerade zu zupfen.
Sonst keine Auffälligkeiten im log.
@guergen Adapterproblem bitte beim Adapte rmelden. Keine Ahnung wie das am controller liegen könnte
@Thomas-Braun sagte in Beta Test js-controller 3.0.x auf GitHub:
"iobroker fix" nach einem nodejs update is your friend
@Thomas-Braun Jupp liegt an deinem "Nodejs Downgrade". Sag mal ob die rebuild Kommandos getan haben
@apollon77 ICH habe doch keine Ahnung, an was das liegt... lief nur vorher. Die 0.4.3 startet auch nicht durch....
@Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
@apollon77
Dito
@apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
Ich dachte es mir fast...
Manchmal mache ich aber auch gerne manuell im System herum. (Mit Vorsicht und (mehr oder weniger) Sinn und Verstand). -
@guergen AM besten mal in dem Thread der aktuellen Beta version melden
@apollon77 Mache ich, schmeisse den Adapter grade einmal komplett runter und teste dann noch einmal!
@apollon77
Bei mir bleibt das Update unten mit blinkendem Cursor hängen.
Sollte da nicht noch etwas kommen?
Bin dann mit STRG C raus und iobroker neugestartet.
Startet trotzdem und Läuft.rockpro64@rockpro64:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller > iobroker.js-controller@3.1.0 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.5 > iobroker.js-controller@3.1.0 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first object system.certificates updated -
@Yetiberg Interessant. hast Du file oder reids oder so? Am Ende ist das die Stelle wo er zur Objekt/States DB verbindet (oder eine öffnet) und Dinge prüft und so. ALso ist garantiert irgendwas das er da nicht hin verbinden konnte oder so. Aber wenns läuft erstmal ok
