Beta Test js-controller 3.0.x auf GitHub
pi@raspberrypi:~ $ iobroker version 3.0.21 pi@raspberrypi:~ $ nodejs -v v14.2.0Der amazon2-Adapter klemmt:
2020-05-09 13:47:46.526 - info: host.raspberrypi "system.adapter.alexa2.0" enabled 2020-05-09 13:47:46.599 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 10253 2020-05-09 13:47:49.033 - info: alexa2.0 (10253) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.2.0, js-controller: 3.0.21 2020-05-09 13:47:49.250 - info: alexa2.0 (10253) Proxy IP not set, use first network interface (192.168.178.50) instead 2020-05-09 13:47:50.092 - warn: alexa2.0 (10253) Exception: TypeError: Cannot read property 'end' of null 2020-05-09 13:47:50.095 - error: alexa2.0 (10253) uncaught exception: Cannot read property 'end' of null 2020-05-09 13:47:50.097 - error: alexa2.0 (10253) TypeError: Cannot read property 'end' of null at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36) at IncomingMessage.emit (events.js:327:22) at IncomingMessage.EventEmitter.emit (domain.js:485:12) at endReadableNT (_stream_readable.js:1225:12) at processTicksAndRejections (internal/process/task_queues.js:84:21) 2020-05-09 13:47:50.142 - info: alexa2.0 (10253) terminating 2020-05-09 13:47:50.146 - info: alexa2.0 (10253) Terminated (NO_ERROR): Without reason 2020-05-09 13:47:50.648 - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'end' of null 2020-05-09 13:47:50.649 - error: host.raspberrypi Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/alexa-cookie2/alexa-cookie.js:110:36) 2020-05-09 13:47:50.649 - error: host.raspberrypi Caught by controller[0]: at IncomingMessage.emit (events.js:327:22) 2020-05-09 13:47:50.649 - error: host.raspberrypi Caught by controller[0]: at IncomingMessage.EventEmitter.emit (domain.js:485:12) 2020-05-09 13:47:50.650 - error: host.raspberrypi Caught by controller[0]: at endReadableNT (_stream_readable.js:1225:12) 2020-05-09 13:47:50.650 - error: host.raspberrypi Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:84:21) 2020-05-09 13:47:50.651 - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 1 (JS_CONTROLLER_STOPPED) -
@Thomas-Braun Alexa 2 liegt an nodejs 14 ... Du bist sehr experimentell unterwegs
Da ist was inkompatibel, kommt mit als nächstes. Aber nix mit controller zu tun -
@apollon77 Das weiß ich. Deswegen hatte ich die node-Version extra bekannt gegeben. Ich schnall mal flugs node 12 drauf...
Im Admin wird
Verfügbar: 3.0.20 Installiert: 3.0.21vermeldet.
@Thomas-Braun
Machs noch mal, jetzt ist 3.1 online
Wie gesagt wer eine 3.0.21 bekommen hat bitte nochmal installieren, dann sollte eine 3.1.0 kommen
@apollon77
IOBroker Start ohne Fehler im Log mit 3.1.0
Der unifi-Adapter kommt mit folgendem Fehler im Log:
unifi.0 2020-05-09 14:11:56.948 error (3567) Error: api.err.Invalid unifi.0 2020-05-09 14:11:56.037 debug (3567) Update started unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted WLANs: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted networks: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted health: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted devices: [] unifi.0 2020-05-09 14:11:56.036 debug (3567) Blacklisted clients: [] unifi.0 2020-05-09 14:11:56.035 debug (3567) updateInterval = 60 unifi.0 2020-05-09 14:11:56.035 debug (3567) controller = 192.168.1.208:8443 unifi.0 2020-05-09 14:11:56.032 info (3567) Unifi adapter is ready unifi.0 2020-05-09 14:11:56.018 info (3567) starting. Version 0.5.0-beta.1 in /opt/iobroker/node_modules/iobroker.unifi, node: v12.16.3, js-controller: 3.1.0 unifi.0 2020-05-09 14:11:55.956 debug (3567) Plugin sentry Initialize Plugin (enabled=true) -
pi@raspberrypi:~ $ iobroker version 3.1.0 pi@raspberrypi:~ $ nodejs -v v12.16.3alexa2:
Alexa startet jetzt.
tado:
Klemmt im Moment, da werde ich aber immer von deren Servern abgewiesen. Hatte das aber schon mit vorherigen Softwareständen. Hat wohl nicht mit dem controller zu tun.
ble:
Bei 'ble' musste ich die capabilities wieder manuell setzen. Wie immer bei node-Wechseln.Ansonsten so auf den ersten Blick alles i.O. , das logfile bleibt auch ruhig.
2020-05-09 14:03:58.851 - warn: iot.0 (12964) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 83. This version of Node.js requires NODE_MODULE_VERSION 72. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`).canvas hatte ich mal selber gebaut. Das versuche ich jetzt mit einem rebuild gerade zu zupfen.
Sonst keine Auffälligkeiten im log.
@guergen Adapterproblem bitte beim Adapte rmelden. Keine Ahnung wie das am controller liegen könnte
@Thomas-Braun sagte in Beta Test js-controller 3.0.x auf GitHub:
"iobroker fix" nach einem nodejs update is your friend
@Thomas-Braun Jupp liegt an deinem "Nodejs Downgrade". Sag mal ob die rebuild Kommandos getan haben
@apollon77 ICH habe doch keine Ahnung, an was das liegt... lief nur vorher. Die 0.4.3 startet auch nicht durch....
@Jan1 sagte in Beta Test js-controller 3.0.x auf GitHub:
@apollon77
Dito
@apollon77 sagte in Beta Test js-controller 3.0.x auf GitHub:
Ich dachte es mir fast...
Manchmal mache ich aber auch gerne manuell im System herum. (Mit Vorsicht und (mehr oder weniger) Sinn und Verstand). -
@guergen AM besten mal in dem Thread der aktuellen Beta version melden
@apollon77 Mache ich, schmeisse den Adapter grade einmal komplett runter und teste dann noch einmal!
@apollon77
Bei mir bleibt das Update unten mit blinkendem Cursor hängen.
Sollte da nicht noch etwas kommen?
Bin dann mit STRG C raus und iobroker neugestartet.
Startet trotzdem und Läuft.rockpro64@rockpro64:/opt/iobroker$ npm install ioBroker/ioBroker.js-controller > iobroker.js-controller@3.1.0 preinstall /opt/iobroker/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.5 > iobroker.js-controller@3.1.0 install /opt/iobroker/node_modules/iobroker.js-controller > node iobroker.js setup first object system.certificates updated -
@Yetiberg Interessant. hast Du file oder reids oder so? Am Ende ist das die Stelle wo er zur Objekt/States DB verbindet (oder eine öffnet) und Dinge prüft und so. ALso ist garantiert irgendwas das er da nicht hin verbinden konnte oder so. Aber wenns läuft erstmal ok
Ich hab den Fixer drüber gejagt und 'canvas' aus den sourcen selber gebaut.
startup-log vom broker ist jetzt unauffällig.
Nur eine Meldung vom firetv, aber das hängt damit zusammen, das ich zu doof bin den adb-Server richtig einzustellen.
Und von tado, aber das hängt am Adapter und/oder an den tado-Servern.Ansonsten:
iobroker status iobroker is running on this host. At least one iobroker host is running. Objects type: file States type: redis
