    4. js-controller 3.0/3.1 jetzt im Latest!
    • Holger76
      Holger76 last edited by Holger76
      bei mir leider nicht. Es streikt der Unifi - Adapter, bleibt gelb (0.5, aber auch ein downgrade auf den vorigen läuft nicht) Meldung im LOG :
      (3030) Error: api.err.Invalid
      Ansonsten streikt auch der Discovergy Adapter, bleibt rot. (Login-Daten stimmen, nochmal kontrolliert, ging ja vorher auch)
      LOG:
      2020-05-10 00:02:01.030 - info: discovergy.0 (3267) starting. Version 0.5.4 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.16.3, js-controller: 3.1.2
      2020-05-10 00:02:01.044 - info: discovergy.0 (3267) Discovergy Adapter startet, trying to discover meters associated with your account
      2020-05-10 00:02:01.209 - error: discovergy.0 (3267) Connection_Failed at meter indication run, check your credentials !
      2020-05-10 00:02:01.211 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-05-10 00:02:01.211 - error: discovergy.0 (3267) unhandled promise rejection: 401 - "401 Unauthorized: Invalid email or password supplied in the HTTP Authorization header"
      2020-05-10 00:02:01.214 - error: discovergy.0 (3267) StatusCodeError: 401 - "401 Unauthorized: Invalid email or password supplied in the HTTP Authorization header"
      at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
      at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
      at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
      at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      at Request.emit (events.js:310:20)
      at Request.EventEmitter.emit (domain.js:482:12)
      at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
      at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
      2020-05-10 00:02:01.214 - info: discovergy.0 (3267) cleaned everything up...
      2020-05-10 00:02:01.266 - info: discovergy.0 (3267) terminating
      2020-05-10 00:02:01.267 - info: discovergy.0 (3267) Terminated (NO_ERROR): Without reason
      2020-05-10 00:02:01.789 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: StatusCodeError: 401 - "401 Unauthorized: Invalid email or password supplied in the HTTP Authorization header"
      2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: at new StatusCodeError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:32:15)
      2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:104:33)
      2020-05-10 00:02:01.790 - error: host.ioBroker Caught by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
      2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request.emit (events.js:310:20)
      2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request.EventEmitter.emit (domain.js:482:12)
      2020-05-10 00:02:01.791 - error: host.ioBroker Caught by controller[1]: at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
      2020-05-10 00:02:01.792 - error: host.ioBroker Caught by controller[1]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
      2020-05-10 00:02:01.792 - info: host.ioBroker instance system.adapter.discovergy.0 terminated with code 0 (NO_ERROR)
      2020-05-10 00:02:01.792 - info: host.ioBroker Restart adapter system.adapter.discovergy.0 because enabled
      Alle Adapter sind latest.
      Debian 10, NodeJS12
      apollon77 2 Replies Last reply Reply Quote 0
        apollon77 @Holger76 last edited by
        @Holger76 dann bitte die Fehler bei beiden Adaptern melden, haben beide nichts direkt mit dem Controller zu tun. Am besten in den einschlägigen Forum Threads bzw als GitHub-Issue
          @Holger76 Versuch mal im Admin die Passwörter neu zu einzugeben bei den beiden Adaptern.
          Holger76 1 Reply Last reply Reply Quote 0
          • Holger76
            Holger76 @apollon77 last edited by
            @apollon77 hatte ich natürlich schon getestet, bevor ich sowas hier melde 😉
            ok ich meld mich bei den Adaptern direkt...
              @Holger76 Ich habe gerade die 3.1.3 released die deine Probleme beheben sollte. Habe mich entschieden nach Check das ganze im js-controller zu fixen. Es lag daran das die Passwörter falsch entschlüsselt wurden. Bitte checke mal die 3.1.3 sobald Sie für dich da ist
              S Holger76 2 Replies Last reply Reply Quote 0
                Marty56 last edited by
                Version 3.1.3. zeigt bei mir keine Fehler. Super Arbeit!
                  skokarl @apollon77 last edited by skokarl
                  @apollon77
                  Moin,
                  ich habe jetzt gerade das Gefühl, dass der Sonos Adapter das JS-Controller Update nicht vertragen hat.
                  Fehler im Log kamen direkt nach dem Update auf 3.13
                  Ist aber für mich kein Problem, entsorge den jetzt sowieso, sollte nur als Info für Dich sein.
                  sonos.0	2020-05-10 06:20:01.791	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                  sonos.0	2020-05-10 06:20:01.791	error	at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                  sonos.0	2020-05-10 06:20:01.791	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  sonos.0	2020-05-10 06:20:01.791	error	at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93234
                  sonos.0	2020-05-10 06:20:01.791	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5012:26
                  sonos.0	2020-05-10 06:20:01.791	error	at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68)
                  sonos.0	2020-05-10 06:20:01.791	error	(30381) TypeError: Cannot read property 'state' of undefined
                  sonos.0	2020-05-10 06:20:01.790	error	(30381) uncaught exception: Cannot read property 'state' of undefined
                  sonos.0	2020-05-10 06:20:01.771	error	(30381) unknown user "undefined"
                  MichMein apollon77 3 Replies Last reply Reply Quote 0
                  • MichMein
                    MichMein @skokarl last edited by MichMein
                    Ich habe anscheinend das gleiche Problem wie @skokarl mit dem Sonos Adapter 😞 nach Update auf 3.1.3
                    host.raspberrypi	2020-05-10 06:50:57.059	info	Restart adapter system.adapter.sonos.0 because enabled
                    host.raspberrypi	2020-05-10 06:50:57.058	info	instance system.adapter.sonos.0 terminated with code 0 (NO_ERROR)
                    sonos.0	2020-05-10 06:50:56.855	error	(16270) TypeError: Cannot read property 'state' of undefined at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68) at /opt/iobroker/node_modules/iobroker.js-
                    sonos.0	2020-05-10 06:50:56.854	error	(16270) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:50:56.831	error	(16270) unknown user "undefined"
                    sonos.0	2020-05-10 06:50:56.401	error	(16270) TypeError: Cannot read property 'state' of undefined at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68) at /opt/iobroker/node_modules/iobroker.js-
                    sonos.0	2020-05-10 06:50:56.400	error	(16270) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:50:56.357	info	(16270) Terminated (NO_ERROR): Without reason
                    sonos.0	2020-05-10 06:50:56.356	info	(16270) terminating
                    sonos.0	2020-05-10 06:50:56.350	error	(16270) unknown user "undefined"
                    sonos.0	2020-05-10 06:50:56.275	info	(16270) terminating
                    sonos.0	2020-05-10 06:50:56.272	error	(16270) TypeError: Cannot read property 'state' of undefined at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68) at /opt/iobroker/node_modules/iobroker.js-
                    sonos.0	2020-05-10 06:50:56.269	error	(16270) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:50:56.256	error	(16270) unknown user "undefined"
                    sonos.0	2020-05-10 06:50:55.620	info	(16270) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.sonos, node: v12.16.3, js-controller: 3.1.3
                    host.raspberrypi	2020-05-10 06:50:54.368	info	instance system.adapter.sonos.0 started with pid 16270
                    host.raspberrypi	2020-05-10 06:50:24.346	info	Restart adapter system.adapter.sonos.0 because enabled
                    host.raspberrypi	2020-05-10 06:50:24.345	info	instance system.adapter.sonos.0 terminated with code 0 (NO_ERROR)
                    sonos.0	2020-05-10 06:50:23.819	info	(15535) Terminated (NO_ERROR): Without reason
                    sonos.0	2020-05-10 06:50:23.817	info	(15535) terminating
                    sonos.0	2020-05-10 06:50:23.777	error	(15535) TypeError: Cannot read property 'state' of undefined at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68) at /opt/iobroker/node_modules/iobroker.js-
                    sonos.0	2020-05-10 06:50:23.776	error	(15535) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:50:23.775	error	(15535) TypeError: Cannot read property 'state' of undefined at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68) at /opt/iobroker/node_modules/iobroker.js-
                    sonos.0	2020-05-10 06:50:23.775	error	(15535) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:50:23.744	error	(15535) unknown user "undefined"
                    sonos.0	2020-05-10 06:50:23.726	info	(15535) terminating
                    sonos.0	2020-05-10 06:50:23.723	error	(15535) TypeError: Cannot read property 'state' of undefined at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68) at /opt/iobroker/node_modules/iobroker.js-
                    sonos.0	2020-05-10 06:50:23.720	error	(15535) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:50:23.717	error	(15535) unknown user "undefined"
                    sonos.0	2020-05-10 06:50:23.683	error	(15535) unknown user "undefined"
                    sonos.0	2020-05-10 06:50:22.987	info	(15535) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.sonos, node: v12.16.3, js-controller: 3.1.3
                    host.raspberrypi	2020-05-10 06:50:21.520	info	instance system.adapter.sonos.0 started with pid 15535
                    host.raspberrypi	2020-05-10 06:49:51.453	info	Restart adapter system.adapter.sonos.0 because enabled
                    host.raspberrypi	2020-05-10 06:49:51.452	info	instance system.adapter.sonos.0 terminated with code 0 (NO_ERROR)
                    sonos.0	2020-05-10 06:49:51.251	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                    sonos.0	2020-05-10 06:49:51.251	error	at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                    sonos.0	2020-05-10 06:49:51.251	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    sonos.0	2020-05-10 06:49:51.251	error	at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93234
                    sonos.0	2020-05-10 06:49:51.251	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5012:26
                    sonos.0	2020-05-10 06:49:51.251	error	at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68)
                    sonos.0	2020-05-10 06:49:51.251	error	(14829) TypeError: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:49:51.250	error	(14829) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:49:51.228	error	(14829) unknown user "undefined"
                    sonos.0	2020-05-10 06:49:50.987	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                    sonos.0	2020-05-10 06:49:50.987	error	at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                    sonos.0	2020-05-10 06:49:50.987	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    sonos.0	2020-05-10 06:49:50.987	error	at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93234
                    sonos.0	2020-05-10 06:49:50.987	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5012:26
                    sonos.0	2020-05-10 06:49:50.987	error	at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68)
                    sonos.0	2020-05-10 06:49:50.987	error	(14829) TypeError: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:49:50.986	error	(14829) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:49:50.936	info	(14829) Terminated (NO_ERROR): Without reason
                    sonos.0	2020-05-10 06:49:50.935	info	(14829) terminating
                    sonos.0	2020-05-10 06:49:50.924	error	(14829) unknown user "undefined"
                    sonos.0	2020-05-10 06:49:50.858	info	(14829) terminating
                    sonos.0	2020-05-10 06:49:50.856	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                    sonos.0	2020-05-10 06:49:50.856	error	at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                    sonos.0	2020-05-10 06:49:50.856	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    sonos.0	2020-05-10 06:49:50.856	error	at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93234
                    sonos.0	2020-05-10 06:49:50.856	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5012:26
                    sonos.0	2020-05-10 06:49:50.856	error	at checkState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4904:68)
                    sonos.0	2020-05-10 06:49:50.856	error	(14829) TypeError: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:49:50.852	error	(14829) uncaught exception: Cannot read property 'state' of undefined
                    sonos.0	2020-05-10 06:49:50.839	error	(14829) unknown user "undefined"
                    EDIT: Das kam nach dem abschalten des Adapters dazu,
                    host.raspberrypi	2020-05-10 06:51:28.854	info	Do not restart adapter system.adapter.sonos.0 because disabled or deleted
                    host.raspberrypi	2020-05-10 06:51:28.853	error	instance system.adapter.sonos.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                    sonos.0	2020-05-10 06:51:28.315	warn	(16988) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                    sonos.0	2020-05-10 06:51:28.303	error	(16988) adapter disabled
                    host.raspberrypi	2020-05-10 06:51:12.560	info	"system.adapter.sonos.0" disabled
                      skokarl @MichMein last edited by
                      @MichMein
                      mach ihn weg..... der geht sowieso schon lange nicht mehr richtig.
                      oder stell nen Issue auf Github ein.
                      Alternative
                      MichMein 1 Reply Last reply Reply Quote 0
                      • MichMein
                        @skokarl du bist ja ne Marke. Lässt mich nen riesigen Thread lesen und kurz vor Schluss kommt dann das 😂
                        @skokarl sagte in Sonos-HTTP-API Installation für Newbies, Dummies und mich:
                        ACHTUNG DAS UPDATE SONOS S2 MACHT DIE API EVTL. UNBRAUCHBAR
                        S2 Update
                        Danke, es hätte ja vielleicht tatsächlich ne Alternative sein können. Aber Ich warte erstmal ab was da nich so alles kommt. Sowohl der Adapter als auch die API stellt nicht die für mich interessanten zu automatisierenden Funktionen bereit. Abwarten und Kaffee trinken.
                        • Holger76
                          @apollon77 Alles i.O . mit der neuen Version, beide Adapter sind grün !! TOP
                          • JB_Sullivan
                            JB_Sullivan last edited by
                            Mal eine kurze Frage am Rande. Ich war jetzt eine Woche nicht aktiv und sehe heute, das schon wieder 9 Adapter Updates und ein js-controller Update anstehen.
                            In welcher Reihenfolge machte man es am "Richtigsten"?
                            Erst den js-controller und dann die Adapter Updates oder anders herum?
                            Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @JB_Sullivan last edited by Thomas Braun
                              @JB_Sullivan Erst die Adapter, dann der controller. So mache ich es jedenfalls immer.
                              Und das darunter liegende System halte ich auch auf Stand.
                                Jan1 @Thomas Braun last edited by
                                @Thomas-Braun
                                Da hätte ich jetzt exakt anderes rum getippt. Zuerst das System dann das was drauf aufbaut. Wobei ich das schon so und so gemacht hatte und weder noch ein Problem damit 😉
                                • JB_Sullivan
                                  Ja ich habe auch schon beides gemacht, aber eigentlich habe ich immer Probleme ( siehe hier: https://forum.iobroker.net/topic/32892/update-prozess-unendlich-lang-iob-defekt/7 )
                                  Darum dachte ich das es ggf. eine zwingende Reihenfolge geben sollte.
                                  Thomas Braun J 2 Replies Last reply Reply Quote 0
                                    @JB_Sullivan Empfohlen wird es wohl so:
                                    Die folgenden Adapter müssen auf die genannten Minimalversionsnummern aktualisiert werden, da diese sonst nicht mit dem js-controller 3.0/3.1 funktionieren. Diese Updates am besten vorher ausführen, weil alle genannten Versionen auch mit den alten js-controller Versionen funktionieren.
                                      Jan1 @JB_Sullivan last edited by
                                      @JB_Sullivan
                                      Du bist auf nem Windows System mit IOBroker, da ist eh wieder alles anderes und nicht ganz so optimal.
                                        Thomas Braun Most Active @Jan1 last edited by
                                        @Jan1 @JB_Sullivan
                                        Bei Windows-Installer soll man auf einen aktualisierten Installer warten, hab ich irgendwo gelesen. Aber da ich kein Windows fahre...
                                        • JB_Sullivan
                                          JB_Sullivan @Thomas Braun last edited by
                                          @Thomas-Braun
                                          Bei meinem Produktiv System würde ich das auch tun, aber ich kann die Finger nicht von diesen latest Updates auf meinem Testsystem lassen. Wenn das dann man baden geht, ist es prinzipell nicht schlimm, aber es Fuckt mich dann trotzdem immer wieder ab, wenn ich das Testsystem neu aufsetzten muss.
                                            @JB_Sullivan
                                            Na bei Linux ist das schon nicht der große Aufwand. Hatte gerade vor 2 Tagen gemeint, ich muss mal Bullseye testen und ich habe kein Testsystem (warum auch). Es lief, allerdings ohne Unterstürzung für Node 12, eigentlich auch kein Problem, aber trotzdem zurück zu Buster mit einer kompletten Debian Neuinstallation hat der Spaß, bis IOBroker wieder mit allem wie vorher lief, 1:45 Stunden gedauert. Also doch recht überschaubar 😉
                                            js-controller
                                            127
                                            1340
                                            434211
