    4. js-controller 3.0/3.1 jetzt im Latest!
      apollon77 @steimi last edited by
      @steimi Die 3.1.4 sollte nachher auch das fixen
      • wendy2702
        wendy2702 @Steff last edited by
        @Steff wie sieht das log jetzt aus
        Steff 1 Reply Last reply Reply Quote 0
          apollon77 @Steff last edited by
          @Steff Alao da ist irgend ein kleiner bug im javascript adapter und dann wird aber dein ganzes iobroker mit einem SIGTERM scheinbar vom Betriebssystem gekillt. Reboote mal bzw schau mal ob /var/log/syslog was hergibt
          • Steff
            Steff @wendy2702 last edited by
            @wendy2702
            Hier mal ein Log vom Start und ein anschliessender Restart
            2020-05-10 11:35:32.142  - info: host.Smarthome "system.adapter.javascript.0" enabled
            2020-05-10 11:35:32.174  - info: host.Smarthome instance system.adapter.javascript.0 started with pid 20479
            2020-05-10 11:35:33.677  - info: javascript.0 (20479) starting. Version 4.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.16.3, js-controller: 3.0.20
            2020-05-10 11:35:33.729  - info: javascript.0 (20479) requesting all states
            2020-05-10 11:35:33.730  - info: javascript.0 (20479) requesting all objects
            2020-05-10 11:35:34.699  - info: javascript.0 (20479) received all objects
            2020-05-10 11:35:34.833  - info: javascript.0 (20479) received all states
            2020-05-10 11:35:35.481  - error: javascript.0 (20479) uncaught exception: Cannot read property 'ts' of undefined
            2020-05-10 11:35:35.482  - error: javascript.0 (20479) TypeError: Cannot read property 'ts' of undefined
               at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
               at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
               at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
               at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
               at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
               at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2020-05-10 11:35:35.494  - info: javascript.0 (20479) terminating
            2020-05-10 11:35:35.495  - info: javascript.0 (20479) Terminated (NO_ERROR): Without reason
            2020-05-10 11:35:36.022  - error: host.Smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2020-05-10 11:35:36.023  - error: host.Smarthome Caught by controller[1]: TypeError: Cannot read property 'ts' of undefined
            2020-05-10 11:35:36.023  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
            2020-05-10 11:35:36.023  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
            2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
            2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
            2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
            2020-05-10 11:35:36.024  - error: host.Smarthome Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2020-05-10 11:35:36.025  - info: host.Smarthome instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2020-05-10 11:35:36.025  - info: host.Smarthome Restart adapter system.adapter.javascript.0 because enabled
            2020-05-10 11:36:06.053  - info: host.Smarthome instance system.adapter.javascript.0 started with pid 20503
            2020-05-10 11:36:07.714  - info: javascript.0 (20503) starting. Version 4.5.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.16.3, js-controller: 3.0.20
            2020-05-10 11:36:07.766  - info: javascript.0 (20503) requesting all states
            2020-05-10 11:36:07.767  - info: javascript.0 (20503) requesting all objects
            2020-05-10 11:36:08.683  - info: javascript.0 (20503) received all objects
            2020-05-10 11:36:08.824  - info: javascript.0 (20503) received all states
            2020-05-10 11:36:09.468  - error: javascript.0 (20503) uncaught exception: Cannot read property 'ts' of undefined
            2020-05-10 11:36:09.469  - error: javascript.0 (20503) TypeError: Cannot read property 'ts' of undefined
            2020-05-10 11:36:09.477  - info: javascript.0 (20503) terminating
            2020-05-10 11:36:09.477  - info: javascript.0 (20503) Terminated (NO_ERROR): Without reason
            2020-05-10 11:36:10.010  - error: host.Smarthome Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2020-05-10 11:36:10.011  - error: host.Smarthome Caught by controller[1]: TypeError: Cannot read property 'ts' of undefined
            2020-05-10 11:36:10.011  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
            2020-05-10 11:36:10.011  - error: host.Smarthome Caught by controller[1]:     at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
            2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22
            2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at /opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23
            2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
            2020-05-10 11:36:10.012  - error: host.Smarthome Caught by controller[1]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
            2020-05-10 11:36:10.013  - info: host.Smarthome instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2020-05-10 11:36:10.013  - info: host.Smarthome Restart adapter system.adapter.javascript.0 because enabled
            2020-05-10 11:36:14.480  - info: host.Smarthome "system.adapter.javascript.0" disabled
            • Steff
              Steff @apollon77 last edited by
              @apollon77
              Ja da steht ziemlich viel drinne, was soll ich hier posten?
                @Steff Bitte GitHub Issue zum javasctipt adapter anlegen und ggf erstmal das mirroring auschalten. Muss ich heute abend prüfen. Bzw welche javascript Version?
                Steff 2 Replies Last reply Reply Quote 0
                • Steff
                  @apollon77
                  Mach ich gern, wie schalte ich das Mirroring aus und was ist das überhaupt??
                    @Steff In den Adapter-Einstellungen vom JavaScript Adapter ist eine EInstellung. Da gibst Du auch einen Pfad an ... Was hast Du da stehen?
                    Das Feature synct die Skripte als Datein ins Dateisystem das man sie mit einem anderen Editor ändern kann
                    • Steff
                      @apollon77
                      Ach so, das hatte ich erst vor ca. 2 Wochen aktiviert, da gab es keine Probleme damit.
                      Ich habe da als Pfad das hier drin stehen --> /opt/iobroker/jscript/
                        @Steff Scheinbar gefällt Ihn irgendein Skript nicht. Aber das muss ich im Code suchen. Welche Javascript Version hast Du denn nun?
                          Maverick78 @Jan1 last edited by Maverick78
                          @Jan1 Ich finde solche großkotzigen Bemerkungen echt daneben.
                          Ich habe mein Script gerade mit 3.0.20 und 3.1.3 überprüft und es läuft fehlerfrei, genau wie auch bei 2.2.9. Wenn es bei @TH-G mit 3.0.20 nicht läuft, liegt der verdacht nahe, das es sich hier um ein Problem mit 3.0.22 und seiner Node Version handelt. Meine Node Version ist 10.20.1
                            Hi All,
                            Version 3.1.4 vom js-controller der die oben genannten Fehler bzw "User undefined Meldungen" bei Nutzung von Binär-States ist auf dem Web ins Latest Repository. Sorry für die Umstände 😞
                            Ingo
                            S Feuersturm 2 Replies Last reply Reply Quote 0
                            • Steff
                              @apollon77
                              ich hatte vor dem Upgrade heute morgen den Controllere V3.0.20 und die JSE 4.5.1 drauf, und da bin ich dank meinem Backup wieder.
                                @Steff Hat er denn die Files bei Dir ins Filesystem gesynct? Hat das für alle geklappt? Aber ok, ich checke heute abend. An sich gab es da maximal Fixes und keine Änderungen in dem Sinne. Vllt hast Du ein altes Objekt was er nciht mag und bisher ignoriert hat oder so. ich checke mal. Bitte GitHub issue bei javascript mit dem Log.Danke!
                                • Steff
                                  @apollon77
                                  Mache ich später bin gerade am schrittweise Auftstarten meiner Scripte
                                  • Steff
                                    @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                    @Steff .... erstmal das mirroring auschalten.
                                    Kurzer Zwischenstand, Mirroring ist aus JSController läuft wieder bin nun am Aufstarten meiner ganzen Scripte
                                      @Steff Also controller wieder auf 3.1.4? 🙂
                                      Steff BBTown 3 Replies Last reply Reply Quote 0
                                      • Steff
                                        @apollon77
                                        Hmm...
                                        hab noch die Hosen voll 😊
                                        Mal schauen, vielleicht im Laufe der Woche
                                          skokarl @apollon77 last edited by
                                          Hi All,
                                          Ingo
                                          Mach Dir doch keinen Kopf.
                                          Ohne Dich würde die Hälfte aller Installationen schon lange gar nicht mehr laufen.
                                          Schön dass es Dich gibt !!!
                                          • Diginix
                                            Diginix last edited by
                                            Hatte im javascript adapter auch die Skript Spiegelung aktiv und mit 3.0.20 gab es keine Probs, aber nach Update auf 3.1.4 startet der javascript adapter 4.5.1 ständig neu:
                                            javascript.0	2020-05-10 12:26:55.969	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                            javascript.0	2020-05-10 12:26:55.969	error	at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
                                            javascript.0	2020-05-10 12:26:55.969	error	at adapter.getObjectView (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23)
                                            javascript.0	2020-05-10 12:26:55.969	error	at scanDB.list (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22)
                                            javascript.0	2020-05-10 12:26:55.969	error	at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
                                            javascript.0	2020-05-10 12:26:55.969	error	at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
                                            javascript.0	2020-05-10 12:26:55.969	error	(963768) TypeError: Cannot read property 'ts' of undefined
                                            javascript.0	2020-05-10 12:26:55.968	error	(963768) unhandled promise rejection: Cannot read property 'ts' of undefined
                                            Unhandled	2020-05-10 12:26:55.968	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            host.BT3-PRO	2020-05-10 12:25:16.934	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                            host.BT3-PRO	2020-05-10 12:25:16.933	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
                                            host.BT3-PRO	2020-05-10 12:25:16.933	error	Caught by controller[0]: at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:116731)
                                            host.BT3-PRO	2020-05-10 12:25:16.933	error	Caught by controller[0]: at adapter.getObjectView (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:553:23)
                                            host.BT3-PRO	2020-05-10 12:25:16.933	error	Caught by controller[0]: at scanDB.list (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:49:22)
                                            host.BT3-PRO	2020-05-10 12:25:16.928	error	Caught by controller[0]: at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:207:22)
                                            host.BT3-PRO	2020-05-10 12:25:16.927	error	Caught by controller[0]: at Mirror.sync (/opt/iobroker/node_modules/iobroker.javascript/lib/mirror.js:214:92)
                                            host.BT3-PRO	2020-05-10 12:25:16.927	error	Caught by controller[0]: TypeError: Cannot read property 'ts' of undefined
                                            host.BT3-PRO	2020-05-10 12:25:16.926	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
                                            javascript.0	2020-05-10 12:25:15.492	info	(962631) terminating
                                            Nach Deaktivieren des Spiegelns in der Instanz, läuft es anscheinend.
                                            apollon77 2 Replies Last reply Reply Quote 0
                                            js-controller
                                            127
                                            1340
                                            434418
