    4. JavaScript
    5. [Vorlage] Denon HEOS Script
    • Meister Mopper
      Meister Mopper @Meister Mopper last edited by
      @Meister-Mopper sagte in [Vorlage] Denon HEOS Script:
      @withstu Ich nutze eine alte Version aus dem vorigen Jahr, weil ich die neue (aus dem ersten Beitrag) nicht zum Laufen bekomme (s. log)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:177:10)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:305:12)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:139:32)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:241:10)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:280:11)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:298:12)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at DerivedLogger.emit (events.js:203:15)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:681:20)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at NotifierTransport.Writable.write (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:334:11)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at writeOrBuffer (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:417:5)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at doWrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:428:64)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at NotifierTransport._write (/opt/iobroker/node_modules/winston-transport/index.js:81:19)
      javascript.0	2020-04-15 10:08:10.949	error	(834) at NotifierTransport.log (/opt/iobroker/node_modules/iobroker.js-controller/lib/logger.js:55:9)
      javascript.0	2020-04-15 10:08:10.948	error	(834) at WritableState.onwrite (/opt/iobroker/node_modules/readable-stream/lib/_stream_writable.js:180:5)
      javascript.0	2020-04-15 10:08:10.948	error	(834) script.js.java.sonstige.Heos_neu: RangeError: Maximum call stack size exceeded
      javascript.0	2020-04-15 10:08:10.865	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.861	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.861	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.857	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.857	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.854	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.854	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.852	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.852	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.849	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.849	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.841	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.841	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.838	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.838	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.835	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.835	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.830	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.830	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.828	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.828	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.825	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.825	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.822	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.822	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.820	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.819	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.811	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.811	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.809	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.808	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.806	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.806	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.803	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.803	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.801	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.801	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.798	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.798	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.795	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.795	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.790	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.790	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.778	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.778	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.776	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.776	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.773	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.773	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.770	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.770	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.767	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.767	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.765	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.765	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.762	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.762	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.760	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.760	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.752	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.752	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.749	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.749	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.746	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.746	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.744	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.744	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.741	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.741	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.739	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.739	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.736	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.736	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.734	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.734	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.726	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.726	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.723	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.723	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.720	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.720	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.718	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.718	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.715	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.715	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.713	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.713	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.710	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.710	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.708	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.707	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.699	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.699	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.696	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.696	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.694	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.694	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.691	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.691	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.689	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.689	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.686	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.686	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.684	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.684	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.681	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.681	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.673	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.673	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.670	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.670	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.667	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.667	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.665	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.665	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.662	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.662	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.660	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.660	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.657	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.657	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.654	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.654	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.646	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.646	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.644	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.643	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.641	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.641	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.638	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.638	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.635	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.635	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.633	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.633	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.630	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.630	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.628	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.628	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.620	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.620	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.617	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.617	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.615	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.615	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.612	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.612	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.610	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.610	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.607	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.607	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.605	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.605	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.602	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.602	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.595	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.595	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.592	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.592	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.589	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.589	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.587	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.587	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.585	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.584	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.582	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.582	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.580	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.580	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.577	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.577	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.569	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.569	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.567	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.567	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.564	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.564	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.562	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.562	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.560	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.560	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.557	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.557	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.555	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.555	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.552	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.552	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.544	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      javascript.0	2020-04-15 10:08:10.544	error	(834) script.js.java.sonstige.Heos_neu: [Heos] Error: This socket has been ended by the other party
      javascript.0	2020-04-15 10:08:10.542	info	(834) script.js.java.sonstige.Heos_neu: [Heos] disconnecting from HEOS ...
      Änderung: Jetzt habe ich das neue Script in einer zweiten JS-Instanz auf dem Slave-System gestartet, und es funktioniert bisher problemfrei. Das beobachte ich mal.
        chrisblu last edited by
        @withstu Hi, das Skript läuft bei mir sehr schön stabil, thumbs up.
        Das einzige, was nicht immer klappt, ist der Start mit einem Neustart vom Broker.
        Von Zeit zu Zeit stoppe ich meinen Broker manuell, führe die Updates der Adapter durch und starte wieder.
        Dabei wird nicht immer das Heos-Skript neu gestartet. Manchmal bekomme ich die Meldung, dass der Socket beendet wurde:
        javascript.1	2020-04-20 07:33:11.020	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:32:56.020	warn	(21921) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Retries exceeded
        javascript.1	2020-04-20 07:32:56.019	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:32:41.018	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:32:26.029	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:32:11.016	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:31:56.018	warn	(21921) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Retries exceeded
        javascript.1	2020-04-20 07:31:56.017	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:31:41.017	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:31:26.016	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:31:11.016	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:56.016	warn	(21921) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Retries exceeded
        javascript.1	2020-04-20 07:30:56.015	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:41.015	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:26.015	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:11.014	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:06.030	info	(21921) script.js.Steuerung.heos: [HeosPlayer xxxxxxxxxxx] starting HEOS player with pid xxxxxxxxxxx (192.168.111.23)
        javascript.1	2020-04-20 07:30:06.027	info	(21921) script.js.Steuerung.heos: [HeosPlayer yyyyyyyyyyyy] starting HEOS player with pid yyyyyyyyyyyy (192.168.111.20)
        javascript.1	2020-04-20 07:30:06.023	info	(21921) script.js.Steuerung.heos: [HeosPlayer zzzzzzzzzzz] starting HEOS player with pid zzzzzzzzzzz (192.168.111.22)
        javascript.1	2020-04-20 07:30:01.047	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:01.042	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:30:01.030	error	(21921) script.js.Steuerung.heos: [Heos] Error: This socket has been ended by the other party
        javascript.1	2020-04-20 07:29:57.180	warn	(21921) script.js.Steuerung.heos: [Heos] HEOS closed the connection to 192.168.111.22
        javascript.1	2020-04-20 07:29:56.024	info	(21921) script.js.Steuerung.heos: [HeosPlayer xxxxxxxxxxx] creating HEOS player with pid xxxxxxxxxxx (192.168.111.23)
        javascript.1	2020-04-20 07:29:56.023	info	(21921) script.js.Steuerung.heos: [HeosPlayer yyyyyyyyyyyy] creating HEOS player with pid yyyyyyyyyyyy (192.168.111.20)
        javascript.1	2020-04-20 07:29:56.020	info	(21921) script.js.Steuerung.heos: [HeosPlayer zzzzzzzzzzz] creating HEOS player with pid zzzzzzzzzzz (192.168.111.22)
        javascript.1	2020-04-20 07:29:56.010	info	(21921) script.js.Steuerung.heos: [Heos] connected to HEOS (192.168.111.22)
        javascript.1	2020-04-20 07:29:56.006	info	(21921) script.js.Steuerung.heos: [Heos] connecting to HEOS (192.168.111.22) ...
        javascript.1	2020-04-20 07:29:55.881	info	(21921) script.js.Steuerung.heos: registered 1 subscription and 0 schedules
        javascript.1	2020-04-20 07:29:55.715	info	(21921) script.js.Steuerung.heos: [Heos] searching for HEOS devices ...
        javascript.1	2020-04-20 07:29:55.641	info	(21921) Start javascript script.js.Steuerung.heos
        javascript.1	2020-04-20 07:29:55.162	info	(21921) received all states
        javascript.1	2020-04-20 07:29:55.114	info	(21921) received all objects
        javascript.1	2020-04-20 07:24:25.123	info	(27211) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        javascript.1	2020-04-20 07:24:24.989	info	(27211) Got terminate signal TERMINATE_YOURSELF
        javascript.1	2020-04-20 07:24:24.971	info	(27211) script.js.Steuerung.heos: [Heos] disconnected from HEOS
        javascript.1	2020-04-20 07:24:24.953	info	(27211) script.js.Steuerung.heos: [HeosPlayer xxxxxxxxxxx] stopping HEOS player with pid xxxxxxxxxxx (192.168.111.23)
        javascript.1	2020-04-20 07:24:24.939	info	(27211) script.js.Steuerung.heos: [HeosPlayer yyyyyyyyyyyy] stopping HEOS player with pid yyyyyyyyyyyy (192.168.111.20)
        javascript.1	2020-04-20 07:24:24.864	info	(27211) script.js.Steuerung.heos: [HeosPlayer zzzzzzzzzzz] stopping HEOS player with pid zzzzzzzzzzz (192.168.111.22)
        javascript.1	2020-04-20 07:24:24.860	info	(27211) script.js.Steuerung.heos: [Heos] [HEARTBEAT] Stop interval
        javascript.1	2020-04-20 07:24:24.857	info	(27211) script.js.Steuerung.heos: [Heos] disconnecting from HEOS ...
        javascript.1	2020-04-20 07:24:24.725	info	(27211) Stop script script.js.Steuerung.heos
        Nach einem weiteren Neustart des Javascript-Adapters startet das Skript dann normal.
        Ich könnte mir vorstellen, dass das Skript gestartet wird, bevor irgend eine Abhängigkeit geladen wurde?
        Ich verwende dein Skript vom 10. April, das trat aber bei der vorhergehenden Version auch schon auf.
        Viele Grüße
        Christian
          withstu @chrisblu last edited by
          @chrisblu Der Fehler ist mir am Wochenende auch aufgefallen. Konnte ihn aber nicht mehr reproduzieren. Ich habe aber auf Verdacht in der reconnect Methode die stateCONNECTED Prüfung rausgenommen. An der könnte es gelegen haben, dass das Script sich nicht sauber beendet hat: heos.js
          In dem Zug habe ich auch die Events für Shuffle und Repeat korrigiert. Die haben bis jetzt noch nie funktioniert. Zudem habe ich zwei Commands hinzugefügt, die alle Player gruppieren bzw. alle Gruppen auflösen. Vielleicht benötigt sie ja jemand:
          group/group_all
          group/ungroup_all
            @withstu danke, ich habe es eingespielt und werde das Verhalten mal beobachten.
            Die group all und ungroup all finde ich sehr praktisch. Werden die in dem übergeordneten command angegeben oder bei dem command der einzelnen Boxen?
            Gibt es sowas wie wie ungroup all auch für play? Vor allem Pause all oder Stopp all wäre für mich interessant, weil ich einen Knopf neben der Haustür habe, mit dem ich alle HEOS auschalten kann.
            LG Christian
              withstu @chrisblu last edited by withstu
              @chrisblu Gute Idee. Ich hatte das bisher über ein anderes Script gelöst und habe es nun integriert: heos.js Es gibt jetzt drei neuen Commands, die sich über den übergeordneten Command steuern lassen:
              "group/ungroup_all" : Löst alle Player Gruppen auf.
              "group/group_all" : Gruppiert alle Player in einer Gruppe.
              "player/cmd": Sendet den Command cmd an alle Player.
              Bsp:
              player/set_play_state&state=pause
              player/set_play_state&state=play
              player/set_play_state&state=stop
                chrisblu @withstu last edited by
                @withstu Cool, das werde ich gleich mal ausprobieren. Vielen Dank.
                Zu deiner Info: Skript läuft seit der letzten Version stabil, Probleme beim Neustart sind bisher nicht mehr aufgetreten.
                Viele Grüße
                Christian
                  chrisblu @chrisblu last edited by
                  @withstu Mir ist da gerade noch was aufgefallen. Bei mir kam gerade beim Starten die Meldung "
                  script.js.Steuerung.heos: [Heos] result=fail, User_not_logged_in
                  Im Objekt taucht das in der Fehlermeldung auf, und in dem Feld last_error auf, in error steht aber false. Das Interpretiere ich jetzt mal so, dass die Anmeldung danach scheinbar geklappt hat? Aber sehen kann ich dass nirgends, oder?
                  Wie wäre es mit einem Objekt "logged_in"?
                  Viele Grüße,
                  Christian
                    @chrisblu Das hing damit zusammen, dass die Favoriten bereits abgerufen wurden, obwohl die HEOS Anmeldung noch nicht abgeschlossen war. Habe die zwei neuen States signed_in und signed_in_user hinzugefügt: heos.js
                    EDIT: In der Auswertung des übergeordneten Commands gab es noch einen Bug.
                      @withstu super, danke, habe das Skritpt eingespielt.
                      Vielleicht kurzer Erfahrungsbericht: Skript (also letzte Version) lief sehr stabil. Ich hatte Zwischenzeitlich mal einen Lautsprecher abgeschaltet (vom Strom getrennt). Wurde später wieder gefunden. Läuft alles gut.
                      Im neuen Skript zeigt er jetzt den Loginnamen und Status an... Prima
                      Lustigerweise ist mir noch Folgendes aufgefallen, ist aber ein Fehler der Heos-App:
                      Ich habe ein Verzeichnisse mit Hörspielen, jedes eine mp3, die ein Cover drinnen gespeichert hat. Wenn ich mir die über DLNA-Ordneransicht zeigen lasse, haben alle das selbe Bild - da wird scheinbar nur das erste gelesen, im Verzeichnis selber liegt kein Bild. Auch wenn ich die Titel abspiele, wird mir ein falsches Bild angezeigt. In VIS zeige ich mir die URL zum Cover an, da wird das richtige Cover angezeigt. Aber das nur so nebenbei.
                      Viele Grüße,
                      Christian
                        beowulf123456 @chrisblu last edited by
                        ich interessiere mich auch sehr für das HEOS Script. Leider klappt es bei mir nicht.
                        Die States ließt er mir Korrekt in die Objekte aus.
                        Aber einen Command zur Steuerung absetzen klappt nicht z.b. Lauter Leiser Mute, so wie im Kommentar beschrieben!!
                        Im Script zeigt er mir auch mehrere Fehler an u.a. Findet der anscheinend das node-ssdp nicht. Obwohl ich es unter den Zusätzlichen npm Modulen im Script Adapter hinterlegt habe.
                        Was mache ich Falsch?
                        Viele Grüße
                        • Meister Mopper
                          Meister Mopper @beowulf123456 last edited by
                          @beowulf123456 zeig mal bitte die Adapterkonfiguration.
                            Hallo, das ist meine Konfiguration.
                            Die Version des Javascript Adapters die neueste. screenshot-192.168.178.244_8081-2020.05.11-17_48_01.png
                            Das ganze läuft auf Raspian auf einem Raspi 4
                            Danke sehr
                            • Meister Mopper
                              @beowulf123456 Sieht amtlich aus. Wie und wo setzt Du den command ab (in Objekten oder vis)?
                                Ich habe es bisher direkt über das Object versucht, als auch über blocky. Siehe Screenshot
                                Beides scheint jedoch nicht zu funktionieren.
                                VIS benutze ich nicht. Sondern eine eigene GUI.
                                Das Script selbst, habe ich versucht sowohl in den Ordner global, als auch in einen anderen Ordner zu packen. Jedoch sind die angezeigten Script Fehler immer die selben.
                                • Meister Mopper
                                  @beowulf123456 bist Du dir sicher, dass Du das neueste script verwendest? Bei mir sehen die Geräte so aus:
                                    Ahh jetzt klappt es, vielen vielen Dank...
                                    Ich hatte zuerst ein älteres HEOS Script verwendet gehabt. Das stand bei mir unter den Objekten im javascript.0 Adapter drinnen, da vermutlich mein Javascript Adapter nicht aktuell war, ging es anfangs nicht.
                                    Daraufhin habe ich das HEOS Script und den Javascript Adapter aktualisiert.
                                    Weil die neue HEOS Script Version sich allerdings unter userdata.0 schreibt, kann ich mit dem alten Objekt Datenpunkten lange rum probieren. Vermutlich hat es als schon die ganze Zeit schon funktioniert...
                                    Aber vielen Dank nochmal für den Hinweis mit dem Screenshot.
                                    Vielleicht hilft dies ja jemandem weiter der ein ähnliches Problem hat.
                                    • andre
                                      andre Developer last edited by
                                      ich wollte heute auch mal das HEOS Script ausprobieren, leider findet das Script mein HEOS Device (AVR) nicht. 😞
                                      10:24:31.840	info	javascript.0 (23262) script.js.Heos.heos: [Heos] still searching for HEOS devices ...
                                      Fehlermeldungen habe ich im Log keine. Script Version: 2.0/2020-04-02
                                      Auch wenn ich über meine HEOS App steuere wird nichts erkannt. Liegt es daran dass ich HEOS auf meinem AVR nutze und keinen HEOS Lautsprecher habe?
                                      Hat jemand einen Tipp was ich noch versuchen kann?
                                      Danke!
                                      MfG,
                                      André
                                      • Meister Mopper
                                        Meister Mopper @andre last edited by
                                        @andre was meinst Du? Was steuerst Du über die HEOS App? Was ist das für ein AVR?
                                        • andre
                                          andre Developer @Meister Mopper last edited by
                                          @Meister-Mopper
                                          Ich habe einen Denon-AVR-X1400H. Das ist eine 7.1 Anlage mit HEOS. Lässt sich über die App ganz normal steuern.
                                          • andre
                                            andre Developer @andre last edited by
                                            Ich glaub ich weiß wo es hängt. Auf meinem Livesystem wird der AVR nicht gefunden. Mache ich das Ganze auf meinem Testsystem läuft es... Kann mir jemand sagen wie ich prüfen kann ob node-ssdp ordnungsgemäß tut?
                                            MfG,
                                            André
                                            81.1k
                                            javascript template
                                            47
                                            350
                                            73071
