    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    • opossum
      opossum last edited by
      Hallo, @tombox ,
      mache ich, melde mich gleich noch einmal.
      • opossum
        opossum last edited by opossum
        immer noch das gleiche Verhalten. Hier mal das Log:
        host.iobrokerprod	2020-05-09 18:15:24.221	info	"system.adapter.vw-connect.0" disabled
        host.iobrokerprod	2020-05-09 18:15:23.574	info	Restart adapter system.adapter.vw-connect.0 because enabled
        host.iobrokerprod	2020-05-09 18:15:23.574	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
        vw-connect.0	2020-05-09 18:15:23.548	error	(22894) [object Object]
        vw-connect.0	2020-05-09 18:15:23.548	error	(22894) 400
        vw-connect.0	2020-05-09 18:15:23.055	info	(22894) Terminated (NO_ERROR): Without reason
        vw-connect.0	2020-05-09 18:15:23.055	info	(22894) terminating
        vw-connect.0	2020-05-09 18:15:23.052	info	(22894) cleaned everything up...
        vw-connect.0	2020-05-09 18:15:23.051	error	at processTicksAndRejections (internal/process/task_queues.js:98:32)
        vw-connect.0	2020-05-09 18:15:23.051	error	at processPromiseRejections (internal/process/promises.js:209:33)
        vw-connect.0	2020-05-09 18:15:23.051	error	at process.emit (events.js:310:20)
        vw-connect.0	2020-05-09 18:15:23.051	error	at process.exceptionHandler (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8238:17)
        vw-connect.0	2020-05-09 18:15:23.051	error	(22894) TypeError: Cannot read property 'stack' of undefined
        vw-connect.0	2020-05-09 18:15:23.050	error	(22894) uncaught exception: Cannot read property 'stack' of undefined
        vw-connect.0	2020-05-09 18:15:23.050	error	(22894) uncaught exception: undefined
        vw-connect.0	2020-05-09 18:15:23.049	error	(22894) 406
        vw-connect.0	2020-05-09 18:15:20.054	info	(22894) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.16.3, js-controller: 3.0.20
        host.iobrokerprod	2020-05-09 18:15:18.958	info	instance system.adapter.vw-connect.0 started with pid 22894
        host.iobrokerprod	2020-05-09 18:15:18.933	info	"system.adapter.vw-connect.0" enabled
        Schicke Dir mal die Zugangsdaten per Chat.
          tombox last edited by
          @opossum @Ultor ist gefixt im latest und im github
          • opossum
            Hallo, @tombox ,
            vielen Dank für den schnellen Fix, jetzt bleibt der Adapter grün.
            • U
              Ultor last edited by Ultor
              Hallo, @tombox,
              bei mir bleibt der Adapter in der neuen Version (js-controller 3.1.2) ebenfalls grün. Leider bekomme ich jetzt eine neue Fehlermeldung (Invalid Trip Type). Das Loggen der Fahrdaten habe ich im Adapter ausgeschaltet.
              Außerdem scheint die Funktion "Position in Adresse umwandeln" nicht mehr zu funktionieren, die entsprechenden Datenpunkte werden hier nicht mehr eingerichtet.
              EDIT: Adress-Daten werden doch noch aufgebaut und alle anderen Daten aktualisiert, daher wohl kein großes Problem.
              Gruß, Daniel
              vw-connect.0	2020-05-10 16:20:02.276	error	(21405) {"error":{"errorCode":"gw.error.parameter","description":"Invalid Trip Type"}}
                tombox @Ultor last edited by
                @Ultor das mit dem trip data habe ich nochmal deaktiviert
                V 2 Replies Last reply Reply Quote 0
                • V
                  vernichter04 @tombox last edited by vernichter04
                  @tombox
                  He, ich habe das Update auf 0.0.13 gemacht, seitdem habe ich folgenden Fehler:
                  vw-connect.0	2020-05-11 19:33:16.202	error	(753) status update Failed
                  vw-connect.0	2020-05-11 19:33:16.199	error	(753) 502
                  vw-connect.0	2020-05-11 19:27:29.737	error	(32737) Login Failed
                  vw-connect.0	2020-05-11 19:27:29.734	error	(32737) 400
                  Es handelt sich um Skoda. Vorher ging das mit 0.0.11 problemlos.
                  • V
                    @tombox
                    Hab nochmal den gesamten Pi neugestartet:
                    vw-connect.0	2020-05-11 19:36:31.105	error	(1290) get vehicle data Failed
                    vw-connect.0	2020-05-11 19:36:31.103	error	(1290) {"error":{"errorCode":"mbbc.promoter.backendInaccessible","description":"BackendMBB-Exceptionlist access failed!"}}
                    vw-connect.0	2020-05-11 19:36:31.101	error	(1290) 500
                    vw-connect.0	2020-05-11 19:36:11.170	error	(1290) status update Failed
                    vw-connect.0	2020-05-11 19:36:11.167	error	(1290) 502
                    vw-connect.0	2020-05-11 19:36:11.094	error	(1290) status update Failed
                    vw-connect.0	2020-05-11 19:36:11.090	error	(1290) 502
                    info.0	2020-05-11 19:35:56.997	info	(1271) Popup news was read...
                      tombox @vernichter04 last edited by
                      @vernichter04 ich kann mich bei skoda einloggen. Funktioniert bei dir die app ohne probleme?
                      • V
                        @tombox
                        Ja, die App geht. Hab nochmal neugestartet, wieder Login Failed.
                        • V
                          @tombox
                          Hab jetzt den Adapter nochmal neugestartet, jetzt ist wieder grün, scheint also verbunden, nun kommt wieder:
                          vw-connect.0	2020-05-11 19:49:11.310	error	(1978) get vehicle data Failed
                          vw-connect.0	2020-05-11 19:49:11.307	error	(1978) {"error":{"errorCode":"mbbc.promoter.backendInaccessible","description":"BackendMBB-Exceptionlist access failed!"}}
                          vw-connect.0	2020-05-11 19:49:11.305	error	(1978) 500
                          vw-connect.0	2020-05-11 19:48:51.564	error	(1978) status update Failed
                          vw-connect.0	2020-05-11 19:48:51.561	error	(1978) 502
                          vw-connect.0	2020-05-11 19:48:51.445	error	(1978) status update Failed
                          vw-connect.0	2020-05-11 19:48:51.441	error	(1978) 502
                            @vernichter04 502 deutet auf ein Fehler bei vw hin. Bitte morgen nochmal testen.
                            • V
                              @tombox
                              Ok, geht klar. Wobei die App, wie gesagt, geht. Ich schau morgen nach der Arbeit nochmal, da müssten ja dann die Daten aktualisiert wurden sein.
                              Danke vorerst für deine Mühe und schönen Abend. 🙂
                              Edit: Jetzt kam der hier:
                              vw-connect.0	2020-05-11 20:04:48.122	error	(1978) {"error":{"errorCode":"gw.error.timeout","description":"Backend Connection Timeout"}}
                              vw-connect.0	2020-05-11 20:04:48.107	error	(1978) 504
                              • V
                                @tombox
                                Was heißt das, stimmt der Token nicht?
                                vw-connect.0	2020-05-11 21:21:29.744	error	(3838) 400
                                vw-connect.0	2020-05-11 21:21:29.726	error	(3838) Failing to refresh token.
                                  @vernichter04 Es kann der login nicht aktuell gehalten werden. einfach adapter deaktivieren und morgen erneut probieren
                                  • Wszene
                                    Wszene last edited by
                                    Ich habe auch gerade das Update gemacht aber leider auch ohne Erfolg
                                    Dann Habe ich die Instanz gelöscht und wieder neu hinzugefügt gleiches Problem
                                    Hier mal das Log
                                    2020-05-12 06:07:40.772  - info: host.ioBroker-NUC iobroker upgrade vw-connect
                                    2020-05-12 06:07:42.328  - info: host.ioBroker-NUC iobroker Update vw-connect from @0.0.11 to @0.0.13
                                    2020-05-12 06:07:42.688  - info: host.ioBroker-NUC iobroker NPM version: 6.14.4
                                    2020-05-12 06:07:42.691  - info: host.ioBroker-NUC iobroker npm install iobroker.vw-connect@0.0.13 --loglevel error --prefix "/opt/iobroker" (System call)
                                    2020-05-12 06:08:18.018  - info: host.ioBroker-NUC iobroker upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
                                    2020-05-12 06:08:18.081  - info: host.ioBroker-NUC iobroker Update "system.adapter.vw-connect.0"
                                    2020-05-12 06:08:18.152  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 20030
                                    2020-05-12 06:08:18.252  - info: host.ioBroker-NUC iobroker upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
                                    2020-05-12 06:08:18.312  - info: host.ioBroker-NUC iobroker upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
                                    2020-05-12 06:08:18.373  - info: host.ioBroker-NUC iobroker upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
                                    2020-05-12 06:08:18.434  - info: host.ioBroker-NUC iobroker upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
                                    2020-05-12 06:08:18.493  - info: host.ioBroker-NUC iobroker Adapter "vw-connect" updated
                                    2020-05-12 06:08:18.859  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:08:18.860  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:08:18.861  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:08:18.862  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:08:18.863  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:08:18.864  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:08:18.864  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:08:18.864  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2020-05-12 06:08:19.500  - info: host.ioBroker-NUC iobroker exit 0
                                    2020-05-12 06:08:50.636  - info: host.ioBroker-NUC Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                    2020-05-12 06:09:28.240  - info: web.0 (15961) ==>Connected system.user.admin from ::ffff:192.168.10.196
                                    2020-05-12 06:09:41.767  - info: web.0 (15961) <==Disconnect system.user.admin from ::ffff:192.168.10.196 vis.0
                                    2020-05-12 06:09:42.233  - info: web.0 (15961) ==>Connected system.user.admin from ::ffff:192.168.10.196
                                    2020-05-12 06:09:48.875  - info: web.0 (15961) ==>Connected system.user.admin from ::ffff:192.168.10.196
                                    2020-05-12 06:10:00.039  - info: host.ioBroker-NUC instance system.adapter.dwd.0 started with pid 20501
                                    2020-05-12 06:10:01.992  - info: dwd.0 (20501) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
                                    2020-05-12 06:10:05.273  - info: dwd.0 (20501) Terminated (NO_ERROR): Without reason
                                    2020-05-12 06:10:05.789  - info: host.ioBroker-NUC instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                                    2020-05-12 06:11:54.671  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 21008
                                    2020-05-12 06:11:55.387  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:11:55.388  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:11:55.389  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:11:55.390  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:11:55.391  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:11:55.392  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:11:55.393  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2020-05-12 06:15:22.606  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 21952
                                    2020-05-12 06:16:16.383  - info: host.ioBroker-NUC "system.adapter.vw-connect.0" disabled
                                    2020-05-12 06:16:21.817  - info: host.ioBroker-NUC "system.adapter.vw-connect.0" enabled
                                    2020-05-12 06:16:21.873  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 22217
                                    2020-05-12 06:16:22.593  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:16:22.594  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:16:22.595  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:16:22.596  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:16:22.597  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:16:22.597  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:16:22.597  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:16:22.598  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2020-05-12 06:29:12.472  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 25660
                                    2020-05-12 06:29:13.192  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:29:13.193  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:29:13.193  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:29:13.193  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:29:13.194  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:29:13.195  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:29:13.196  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:29:13.197  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2020-05-12 06:29:49.681  - info: host.ioBroker-NUC Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                    2020-05-12 06:30:01.961  - info: dwd.0 (25891) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.0.20
                                    2020-05-12 06:30:02.875  - info: host.ioBroker-NUC iobroker restart
                                    2020-05-12 06:30:03.247  - info: host.ioBroker-NUC iobroker iobroker controller daemon is not running
                                    2020-05-12 06:30:03.253  - info: host.ioBroker-NUC iobroker Starting iobroker controller daemon...
                                    2020-05-12 06:30:04.141  - info: host.ioBroker-NUC instance system.adapter.daswetter.0 started with pid 25948
                                    2020-05-12 06:30:03.749  - info: host.ioBroker-NUC iobroker.js-controller version 3.0.20 js-controller starting
                                    2020-05-12 06:30:04.225  - info: host.ioBroker-NUC iobroker iobroker controller daemon started. PID: 25933
                                    2020-05-12 06:30:04.242  - info: host.ioBroker-NUC iobroker exit 0
                                    2020-05-12 06:30:03.754  - info: host.ioBroker-NUC Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    2020-05-12 06:30:03.755  - info: host.ioBroker-NUC hostname: ioBroker-NUC, node: v12.16.3
                                    2020-05-12 06:30:03.756  - info: host.ioBroker-NUC ip addresses: 192.168.10.211 fe80::3c7e:77ff:fe42:6fc4
                                    2020-05-12 06:30:04.103  - info: host.ioBroker-NUC  Error inMem-objects listening on port 9001
                                    2020-05-12 06:30:04.168  - info: host.ioBroker-NUC  Error inMem-states listening on port 9000
                                    2020-05-12 06:30:04.262  - info: host.ioBroker-NUC connected to Objects and States
                                    2020-05-12 06:30:05.076  - info: host.ioBroker-NUC 37 instances found
                                    2020-05-12 06:30:05.169  - info: host.ioBroker-NUC starting 33 instances
                                    2020-05-12 06:30:05.302  - info: host.ioBroker-NUC instance system.adapter.admin.0 started with pid 25987
                                    2020-05-12 06:31:38.160  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:31:38.163  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:31:38.164  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                    2020-05-12 06:31:38.164  - info: host.ioBroker-NUC iobroker rebuild vw-connect
                                    2020-05-12 06:31:38.565  - info: host.ioBroker-NUC iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:31:39.501  - info: host.ioBroker-NUC iobroker npm-rebuild:
                                    2020-05-12 06:31:39.502  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:31:40.515  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:31:40.536  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 28467
                                    2020-05-12 06:31:41.208  - info: host.ioBroker-NUC instance system.adapter.deconz.0 started with pid 28496
                                    2020-05-12 06:31:41.320  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:31:41.321  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:31:41.322  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:31:41.323  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:31:41.325  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:31:41.325  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:31:41.326  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:31:41.327  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:31:41.327  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:31:41.327  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                    2020-05-12 06:31:41.328  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
                                    2020-05-12 06:31:41.752  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:32:02.200  - info: host.ioBroker-NUC iobroker npm-rebuild:
                                    2020-05-12 06:32:02.201  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:32:03.208  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:32:03.223  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 28657
                                    2020-05-12 06:32:03.982  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:32:03.983  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:32:03.983  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:32:03.984  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:32:03.985  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:32:03.986  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:32:03.987  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:32:03.987  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:32:03.987  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:32:03.987  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:32:03.988  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:32:03.988  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                    2020-05-12 06:32:03.988  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
                                    2020-05-12 06:32:04.456  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:34:16.368  - info: iot.0 (914) starting. Version 1.4.18 in /opt/iobroker/node_modules/iobroker.iot, node: v12.16.3, js-controller: 3.1.4
                                    2020-05-12 06:34:17.440  - warn: iot.0 (914) Cannot initialize getImage: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:35:17.865  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1424
                                    2020-05-12 06:35:18.644  - info: ical.0 (1347) Terminated (NO_ERROR): Without reason
                                    2020-05-12 06:35:18.695  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:35:18.696  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:35:18.697  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:35:18.698  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:35:18.699  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:35:18.699  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:35:18.702  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:35:18.703  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                    2020-05-12 06:35:18.703  - info: host.ioBroker-NUC iobroker rebuild vw-connect
                                    2020-05-12 06:35:19.161  - info: host.ioBroker-NUC iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:35:19.170  - info: host.ioBroker-NUC instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                    2020-05-12 06:35:20.078  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:35:21.070  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:35:21.109  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1461
                                    2020-05-12 06:35:21.938  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:35:21.938  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:35:21.939  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:35:21.939  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                    2020-05-12 06:35:21.939  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
                                    2020-05-12 06:35:22.729  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:35:24.340  - info: deconz.0 (1476) starting. Version 1.3.7 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.16.3, js-controller: 3.1.4
                                    2020-05-12 06:35:24.450  - info: deconz.0 (1476) deConz Version: 2.5.75; API version: 1.16.0
                                    2020-05-12 06:35:24.523  - info: deconz.0 (1476) Code 404: Ressource not found get devices: []
                                    2020-05-12 06:35:34.448  - info: host.ioBroker-NUC iobroker npm-rebuild:
                                    2020-05-12 06:35:34.449  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:35:35.458  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:35:35.497  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1573
                                    2020-05-12 06:35:36.261  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:35:36.261  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:35:36.262  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:35:36.263  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:35:36.264  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:35:36.264  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:35:36.265  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:35:36.265  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                    2020-05-12 06:35:36.265  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
                                    2020-05-12 06:35:36.666  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:35:45.648  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:35:46.618  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:35:46.653  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 1666
                                    2020-05-12 06:35:47.443  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:35:47.443  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:35:47.443  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:35:47.444  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:35:47.445  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:35:47.446  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:35:47.446  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2020-05-12 06:38:36.253  - info: host.ioBroker-NUC iobroker del vw-connect.0
                                    2020-05-12 06:38:37.594  - info: host.ioBroker-NUC iobroker Delete adapter "vw-connect.0"
                                    2020-05-12 06:38:37.626  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 1 instances of vw-connect.0
                                    2020-05-12 06:38:37.638  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 1 devices of vw-connect.0
                                    2020-05-12 06:38:37.647  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 1 channels of vw-connect.0
                                    2020-05-12 06:38:37.768  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 2198 states of vw-connect.0
                                    2020-05-12 06:38:37.777  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Counted 14 states of system.adapter.vw-connect.0
                                    2020-05-12 06:38:38.886  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Deleting 2215 object(s). Be patient...
                                    2020-05-12 06:38:39.782  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 2200 objects left to be deleted.
                                    2020-05-12 06:38:51.538  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 2000 objects left to be deleted.
                                    2020-05-12 06:39:03.506  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1800 objects left to be deleted.
                                    2020-05-12 06:39:14.493  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1600 objects left to be deleted.
                                    2020-05-12 06:39:24.513  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1400 objects left to be deleted.
                                    2020-05-12 06:39:34.609  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1200 objects left to be deleted.
                                    2020-05-12 06:39:45.465  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 1000 objects left to be deleted.
                                    2020-05-12 06:39:56.760  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 800 objects left to be deleted.
                                    2020-05-12 06:40:00.028  - info: host.ioBroker-NUC instance system.adapter.dwd.0 started with pid 2752
                                    2020-05-12 06:40:01.966  - info: dwd.0 (2752) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.16.3, js-controller: 3.1.4
                                    2020-05-12 06:40:05.388  - info: dwd.0 (2752) Terminated (NO_ERROR): Without reason
                                    2020-05-12 06:40:05.903  - info: host.ioBroker-NUC instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                                    2020-05-12 06:40:07.367  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 600 objects left to be deleted.
                                    2020-05-12 06:40:17.911  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 400 objects left to be deleted.
                                    2020-05-12 06:40:28.820  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC: Only 200 objects left to be deleted.
                                    2020-05-12 06:40:40.001  - info: host.ioBroker-NUC object deleted system.adapter.vw-connect.0
                                    2020-05-12 06:40:41.072  - info: host.ioBroker-NUC iobroker exit 0
                                    2020-05-12 06:41:15.758  - info: host.ioBroker-NUC iobroker url "https://github.com/TA2k/ioBroker.vw-connect/tarball/master" vw-connect
                                    2020-05-12 06:41:17.014  - info: host.ioBroker-NUC iobroker install https://github.com/TA2k/ioBroker.vw-connect/tarball/master
                                    2020-05-12 06:41:17.393  - info: host.ioBroker-NUC iobroker NPM version: 6.14.4
                                    2020-05-12 06:41:17.393  - info: host.ioBroker-NUC iobroker npm install https://github.com/TA2k/ioBroker.vw-connect/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                                    2020-05-12 06:41:48.841  - info: host.ioBroker-NUC iobroker upload [5] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
                                    2020-05-12 06:41:48.941  - info: host.ioBroker-NUC iobroker upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
                                    2020-05-12 06:41:48.998  - info: host.ioBroker-NUC iobroker upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/tsconfig.json tsconfig.json application/json
                                    2020-05-12 06:41:49.056  - info: host.ioBroker-NUC iobroker upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
                                    2020-05-12 06:41:49.112  - info: host.ioBroker-NUC iobroker upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
                                    2020-05-12 06:41:49.169  - info: host.ioBroker-NUC iobroker upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
                                    2020-05-12 06:41:50.306  - info: host.ioBroker-NUC iobroker exit 0
                                    2020-05-12 06:41:50.410  - info: host.ioBroker-NUC Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                    2020-05-12 06:42:57.910  - info: host.ioBroker-NUC iobroker add vw-connect  --host ioBroker-NUC
                                    2020-05-12 06:42:59.233  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC create instance vw-connect
                                    2020-05-12 06:42:59.247  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object vw-connect.0.info.connection created
                                    2020-05-12 06:42:59.285  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object vw-connect.0.info created
                                    2020-05-12 06:42:59.321  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.sigKill created
                                    2020-05-12 06:42:59.353  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.eventLoopLag created
                                    2020-05-12 06:42:59.386  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.outputCount created
                                    2020-05-12 06:42:59.422  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.inputCount created
                                    2020-05-12 06:42:59.457  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.uptime created
                                    2020-05-12 06:42:59.493  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.memRss created
                                    2020-05-12 06:42:59.530  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.memHeapTotal created
                                    2020-05-12 06:42:59.563  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.memHeapUsed created
                                    2020-05-12 06:42:59.597  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.cputime created
                                    2020-05-12 06:42:59.635  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.cpu created
                                    2020-05-12 06:42:59.669  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.compactMode created
                                    2020-05-12 06:42:59.702  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.connected created
                                    2020-05-12 06:42:59.736  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0.alive created
                                    2020-05-12 06:42:59.766  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC Set default value of vw-connect.0.info.connection: false
                                    2020-05-12 06:42:59.809  - info: host.ioBroker-NUC iobroker host.ioBroker-NUC object system.adapter.vw-connect.0 created
                                    2020-05-12 06:43:00.816  - info: host.ioBroker-NUC iobroker exit 0
                                    2020-05-12 06:43:02.858  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3623
                                    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:43:03.599  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:03.600  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:03.601  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:03.602  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:43:03.602  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:43:03.602  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:43:03.603  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                    2020-05-12 06:43:03.604  - info: host.ioBroker-NUC iobroker rebuild vw-connect
                                    2020-05-12 06:43:03.961  - info: host.ioBroker-NUC iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:43:04.735  - info: host.ioBroker-NUC iobroker npm-rebuild:
                                    2020-05-12 06:43:04.735  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:43:05.744  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:43:05.827  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3660
                                    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:43:06.601  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:06.602  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:06.603  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:43:06.604  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:43:06.604  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:43:06.604  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                    2020-05-12 06:43:06.604  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
                                    2020-05-12 06:43:06.965  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:43:27.882  - info: host.ioBroker-NUC iobroker npm-rebuild:
                                    2020-05-12 06:43:27.884  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:43:28.893  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:43:28.934  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3788
                                    2020-05-12 06:43:29.684  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:43:29.685  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:43:29.685  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:43:29.685  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:43:29.686  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:43:29.687  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:29.687  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:29.687  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:43:29.688  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:43:29.689  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:29.689  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:29.689  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:43:29.689  - info: host.ioBroker-NUC Adapter system.adapter.vw-connect.0 needs rebuild and will be restarted afterwards.
                                    2020-05-12 06:43:29.689  - info: host.ioBroker-NUC system.adapter.vw-connect.0 will be rebuilt
                                    2020-05-12 06:43:29.690  - warn: host.ioBroker-NUC adapter "vw-connect" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                    2020-05-12 06:43:29.690  - info: host.ioBroker-NUC iobroker rebuild vw-connect --install
                                    2020-05-12 06:43:30.034  - info: host.ioBroker-NUC iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.vw-connect"
                                    2020-05-12 06:43:39.092  - info: host.ioBroker-NUC iobroker npm-rebuild:
                                    2020-05-12 06:43:39.094  - info: host.ioBroker-NUC iobroker npm-rebuild: Rebuild vw-connect done
                                    2020-05-12 06:43:40.102  - info: host.ioBroker-NUC iobroker npm-rebuild: exit 0
                                    2020-05-12 06:43:40.137  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3874
                                    2020-05-12 06:43:40.843  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:43:40.844  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:40.845  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:40.846  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:43:40.847  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                    2020-05-12 06:43:55.455  - info: host.ioBroker-NUC instance system.adapter.vw-connect.0 started with pid 3949
                                    2020-05-12 06:43:56.201  - error: host.ioBroker-NUC Caught by controller[0]: internal/modules/cjs/loader.js:1183
                                    2020-05-12 06:43:56.202  - error: host.ioBroker-NUC Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                    2020-05-12 06:43:56.203  - error: host.ioBroker-NUC Caught by controller[0]:                  ^
                                    2020-05-12 06:43:56.203  - error: host.ioBroker-NUC Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                    2020-05-12 06:43:56.203  - error: host.ioBroker-NUC Caught by controller[0]: was compiled against a different Node.js version using
                                    2020-05-12 06:43:56.205  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                    2020-05-12 06:43:56.206  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:1019:19)
                                    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:77:18)
                                    2020-05-12 06:43:56.207  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:977:32)
                                    2020-05-12 06:43:56.208  - error: host.ioBroker-NUC Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                    2020-05-12 06:43:56.209  - error: host.ioBroker-NUC instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    2020-05-12 06:43:56.209  - info: host.ioBroker-NUC Rebuild for adapter system.adapter.vw-connect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                      tombox @Wszene last edited by tombox
                                      @Wszene sieht nach einem canvas problem aus
                                      cd /opt/iobroker
                                      npm install canvas --unsafe-perm --production --save --prefix
                                      schon probiert?
                                      bzw sieht nach einem node update ohne npm rebuild aus
                                      cd /opt/iobroker
                                      npm rebuild
                                      • Wszene
                                        @tombox
                                        Danke das war genau das Problem
                                        Jetzt geht es wieder
                                        • V
                                          vernichter04 @tombox last edited by
                                          @tombox
                                          Hallo, also ich bin deinem Rat gefolgt. Die Aktualisierung klappt gelegentlich. Die Fehler sind trotzdem da.
                                          • U
                                            Ultor last edited by Ultor
                                            Hi @tombox ,
                                            Bei mir spuckt der Adapter (Version 0.0.15) leider gelegentlich immer noch Fehler aus und wird dann vom Host neu gestartet. Ich habe leider kein vollständiges Log zur Hand, das kann ich aber gerne nachreichen. Die JS-Controller-Version ist 3.1.2. Die Datenpunkte aktualisiert der Adapter scheinbar trotzdem korrekt (mit Skoda-App abgeglichen).
                                            Die Fehlermeldung Error 400 / Failing to refresh token habe ich übrigens ebenfalls, und zwar bei jeder Aktualisierung (über mehrere Tage getestet). Auch das scheint bei mir keine großartigen Auswirkungen zu haben, auch nach dieser Fehlermeldung sind alle Datenpunkte aktuell.
                                            host.ioBroker-RasPi4	2020-05-18 14:37:05.703	info	instance system.adapter.vw-connect.0 started with pid 14810
                                            host.ioBroker-RasPi4	2020-05-18 14:36:35.626	info	Restart adapter system.adapter.vw-connect.0 because enabled
                                            host.ioBroker-RasPi4	2020-05-18 14:36:35.626	info	instance system.adapter.vw-connect.0 terminated with code 0 (NO_ERROR)
                                            host.ioBroker-RasPi4	2020-05-18 14:36:35.625	error	Caught by controller[1]: undefined
                                            host.ioBroker-RasPi4	2020-05-18 14:36:35.620	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejecte
                                            vw-connect.0	2020-05-18 14:36:34.917	error	(32413) unhandled promise rejection: undefined
                                            Unhandled	2020-05-18 14:36:34.917	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                            81.1k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1603175
