    4. js-controller 3.0/3.1 jetzt im Latest!
    • Dr. Bakterius
      Dr. Bakterius Most Active @apollon77 last edited by Dr. Bakterius
      @apollon77 sagte in js-controller 3.0/3.1 jetzt im Latest!:
      @karlo-enzo bei was bzw wann kommt die meldung denn? Kannst mal "iobroker upload admin" und "iobroker upload"web" versuchen
      Die Meldung kommt wenn man ein Backup mit dem BackItUp-Adapter durchführt.
      2020-05-12 07:59:06.630 - debug: backitup.0 (13392) [iobroker/mount] mount successfully completed
      2020-05-12 07:59:06.632 - debug: backitup.0 (13392) [iobroker/mount] done
      2020-05-12 07:59:09.047 - debug: backitup.0 (13392) [iobroker/iobroker] host.iobroker 10483 states saved
      2020-05-12 07:59:09.074 - debug: backitup.0 (13392) [iobroker/iobroker] host.iobroker 8931 objects saved
      2020-05-12 07:59:09.872 - warn: host.iobroker Objects 127.0.0.1:32890 Error from InMemDB: Error: ERROR readDir id=0_userdata.0: Not exists
      2020-05-12 07:59:09.876 - warn: host.iobroker Objects 127.0.0.1:32890 Error from InMemDB: Error: ERROR readDir id=admin.0: Not exists
      2020-05-12 07:59:09.882 - warn: host.iobroker Objects 127.0.0.1:32890 Error from InMemDB: Error: ERROR readDir id=web.0: Not exists
      2020-05-12 07:59:12.776 - debug: backitup.0 (13392) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_05_12-07_59_06_backupiobroker.tar.gz
      2020-05-12 07:59:13.819 - debug: backitup.0 (13392) [iobroker/iobroker] done
      2020-05-12 07:59:39.143 - debug: backitup.0 (13392) [iobroker/mysql] Packed 19MB so far...
      2020-05-12 07:59:46.817 - debug: backitup.0 (13392) [iobroker/mysql] done
      2020-05-12 07:59:46.917 - debug: backitup.0 (13392) [iobroker/cifs] done
      2020-05-12 07:59:46.920 - debug: backitup.0 (13392) [iobroker/clean] done
      2020-05-12 07:59:46.932 - debug: backitup.0 (13392) sendTo "send" to system.adapter.pushover.0 from system.adapter.backitup.0
      2020-05-12 07:59:46.934 - debug: backitup.0 (13392) [iobroker/pushover] done
      Ein "iobroker upload admin" und "iobroker upload web" hat nichts geändert.
        A Former User @Nordischerjung last edited by
        @Nordischerjung Hi,
        also wenn ich mir die Konsolenausgabe von iobroker rebuild s7 bei dir ansehe, dann stelle ich fest, dass du einen js-controller benutzt, der kein "rebuild" enthält.
        Welche Version hast du denn vom js-controller installiert??
        Das hat nix mit der Node-Version zu tun...
          apollon77 @Dr. Bakterius last edited by
          @Dr-Bakterius Am Ende ist das ein Logging weil das Backup die Ordner durchgeht wo es Objekte gibt aber scheinbar existiert das Verzeichnis nicht ... erstmal könnt Ihr das ignorieren. Ich überlege mal ob wir da jetzt noch was tun
            apollon77 @Nordischerjung last edited by
            @Nordischerjung Wenn das Rebuild Kommando nicht tut hast Du keinen controller 3.1 drauf! geht erst ab controller 3
              @Dr-Bakterius Ok, am Ende ists ja nur ein"warn" 🙂 Hat auch mit Backitup nichts zu tun sondern liegt am Backup an sich
              • Dr. Bakterius
                @apollon77 Okay, klappt ja auch alles. Aber halt unschön in einem sonst fehlerfreien Log. 😊
                  @Dr-Bakterius Jupp, die Frage ist ob das nochmal eine neue Version rechtfertigt 🙂
                  • Dr. Bakterius
                    @apollon77 Welchen Ordner genau vermisst er denn eigentlich? Also wie lautet der Pfad. Dann kann man wenigstens die Ordner anlagen, oder?
                      @Dr-Bakterius am Ende könntest Du das tun. Der Fehler kommt nur bei einer Objects File D. Damit liegt das dann unter iobroker-data/files im iobroekr Verzeichnis
                      Diginix Dr. Bakterius 2 Replies Last reply Reply Quote 0
                      • Diginix
                        Diginix @apollon77 last edited by
                        @apollon77 Bei mir vermisst er da zB auch admin.1 und ich habe nur eine admin.0 Instanz. Die 1 hatte ich nur mal ganz kurz vor Monaten. Wo ist das denn derart persistent gespeichert?
                          apollon77 @Diginix last edited by
                          @Diginix Dann könntest DU noch ein Objekt "admin.1" vom Typ Meta als überbleibsel behalten ... schau mal.
                          • Diginix
                            @apollon77 Korrekt, dem ist so. Kann ich sicher löschen? Und beim nächsten Backup ist eine Meldung weniger.
                            • Dr. Bakterius
                              Hat geholfen. Jetzt keine Warnungen mehr. 😉
                              bergjet 1 Reply Last reply Reply Quote 0
                              • UweRLP
                                UweRLP last edited by
                                Danke! Mal ne' Positivmeldung: Es läuft auch unter Windows
                                  karlo enzo last edited by
                                  @Dr-Bakterius / @apollon77
                                  Wo bzw. welche Verzeichnisse müssen denn angelegt werden damit die Warnungen
                                  nicht mehr hochkommen. Mein Log-File ist nämlich ansonsten auch sauber.
                                  • Dr. Bakterius
                                    Dr. Bakterius Most Active @karlo enzo last edited by Dr. Bakterius
                                    @karlo-enzo Hat @apollon77 ja eh geschrieben. Bei einer Standardinstallation unter:
                                    '/opt/iobroker/iobroker-data/files/'
                                    Da dann z.B. einen neuen Ordner mit Namen 'admin.0' erstellen. Und das machst du für alle Ordner die im Log bemängelt werden. Bei mir waren das noch 'web.0' und '0_userdata.0'.
                                    • JB_Sullivan
                                      JB_Sullivan last edited by JB_Sullivan
                                      Kurze Frage am Rand . Ich beobachte seit dem Update des js-controller auf die Vesion 3.1.20, das mqtt Rückmeldungen z.T. extrem verzögert im VIS dargestellt werden.
                                      Konkret geht es um den Sonoff Adapter. EIN-Schalthandlungen die man über das VIS vornimmt, werden sofort ausgeführt und auch über die eingestellten Farbumschläge visualisiert.
                                      Schaltet man dann aber wieder AUS, wird zwar der Aktor ausgeschaltet, das Objekt geht auch auf FALSE aber im VIS kommt das vorerst nicht an. Auch eine zeitnahe Aktualisierung des VIS Bildes zeigt einem nach wie vor den falschen Status des Aktor an.
                                      Aktualisiert man nach 10 - 15 Minuten noch einmal, wir der Status wieder richtig angezeigt.
                                      Da ich nur den js-controller auf 3.1.20 geändert habe, würde ich dieses neue verhalten ggf. dem js-controller zuordnen, denn das state des Aktors wird unter Objekt ja sofort nach dem Ausschalten auf FALSE gesetzt, nur kommt dieses im VIS extrem Zeitverzögert an.
                                      • O
                                        oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
                                        @oFbEQnpoLKKl6mbY5e13 sonst mir mit Verweis aufs GitHub issue an iobroker@fischer-ka.de schicken.
                                        Vielen Dank für den neuen HmIP-Adapter v1.0.0!
                                        Er stürzt nun nicht mehr ab, wenn sich der Schutz-Status ändert. Es kommen nun bei Änderung die folgenden Ausgaben im Log:
                                        warn: hmip.0 (29961) No home in SECURITY_JOURNAL_CHANGED: {"pushEventType":"SECURITY_JOURNAL_CHANGED"}
                                          @Dr-Bakterius
                                          Danke für die Hilfe.
                                          Hat ohne Probleme geklappt und das Logfile ist jetzt nach dem Backup ebenfalls
                                          wieder ohne Meldungen.
                                          • bergjet
                                            bergjet @Dr. Bakterius last edited by
                                            @Dr-Bakterius said in js-controller 3.0/3.1 jetzt im Latest!:
                                            Was genau hast du gemacht, habe das auch?
                                            js-controller
                                            127
                                            1340
                                            434925
