    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Вопросы по написанию скриптов
      Lstt last edited by
      Дело в скрипте, это работает чётко:
      var fs = require('fs'),
      request = require('request');
      var download = function(uri, filename, callback){
        var r = request({
          url: uri,
          headers: {
            'accept': 'image/*',
            'user-agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_10_2) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.118 Safari/537.36',
        }).pipe(fs.createWriteStream(filename));
        r.on('error', function(err) {console.log(err)})
        r.on('close', callback);
      on({id:"admin.1.send_cameras", change: 'any'}, function (obj) {
      download('http://192.168.0.222:10000/Streaming/channels/1/picture?snapShotImageType=JPEG?auth=YWRtaW46MTIzNDU=', 'C:/Users/User/Pictures/camera1.jpg', function(){
        console.log('Сamera 1 copying done');
        sendTo("telegram.0", 'C:/Users/User/Pictures/camera1.jpg');
       download('http://192.168.0.222:11000/Streaming/channels/1/picture?snapShotImageType=JPEG?auth=YWRtaW46MTIzNDU=', 'C:/Users/User/Pictures/camera2.jpg', function(){
          console.log('Camera 2 copying done!');
          sendTo("telegram.0", 'C:/Users/User/Pictures/camera2.jpg');
       download('http://192.168.0.222:13000/Streaming/channels/1/picture?snapShotImageType=JPEG?auth=YWRtaW46MTIzNDU=', 'C:/Users/User/Pictures/camera3.jpg', function(){
          console.log('Camera 3 copying done!');
          sendTo("telegram.0", 'C:/Users/User/Pictures/camera3.jpg');
        download('http://192.168.0.222:14000/Streaming/channels/1/picture?snapShotImageType=JPEG?auth=YWRtaW46MTIzNDU=', 'C:/Users/User/Pictures/camera4.jpg', function(){
          console.log('Camera 4 copying done!');
          sendTo("telegram.0", 'C:/Users/User/Pictures/camera4.jpg');
        Haus last edited by
        Записываю в log_heat.txt "log_heat", может как то по другому надо ? ( log_heat может быть много, в зависимости от условий по скрипту)
        function getTimeAsString(d) {
            var date = d || new Date();
            return ('0' + (date.getMonth() + 1)).slice(-2) + '/' + ('0' + date.getDate()).slice(-2) + ' '+ ('0' + date.getHours()).slice(-2) + ':' + ('0' + date.getMinutes()).slice(-2) + ':' +  ('0' + date.getSeconds()).slice(-2);
        function script (addTimestamp) {
            var fs = require('fs');
            var log_heat;
            log_heat = ( getTimeAsString() + ' ' + 'Температура бака');
            fs.appendFileSync('//opt//log_heat.txt', log_heat + "\n");
            log_heat = ( getTimeAsString() + ' ' + 'Температура бакаaaaaaaaaaaaaa');
        function start () {
            var request = require ( 'request' );
            request ( 'http://192.168.1.11/avr_temp_out.php', function ( error, response, body ) {
                if ( !error && response.statusCode == 200 ) {
                    //setState ( toaid, body );
                    log('1 avr_temp_out: ' + body);
                setTimeout ( function () {
                    script ();
                    }, 1000 );
        setInterval ( function () {
            start ();
        }, 30000 );
          spectrekr last edited by
          Хочу заставить бота слать информацию об обновлении, подписываюсь на драйвер, а он либо undefined присылает, либо вообще молчит.
          on({id: 'admin.0.info.updatesList', change: 'any'}, function (obj) {
              if (getState('admin.0.info.updatesNumber').val > 0){
                  sendTo('telegram', obj.val);
                  log(obj.val);
          • aurodionov
            aurodionov last edited by
            @spectrekr:
                    log(obj.val);
            Вроде id: лишние
            Пишу с пульта….
              Так везде и всегда так подписываюсь на изменения, и в примерах так описано. Да и он отслеживает изменения и запускает на выполнение, только вот, насколько я понял, значение объекта в текст не может перевести.
              • I
                instalator last edited by
                @spectrekr:
                Так везде и всегда так подписываюсь на изменения, и в примерах так описано. Да и он отслеживает изменения и запускает на выполнение, только вот, насколько я понял, значение объекта в текст не может перевести. `
                Obj.val.toString()
                • I
                  @spectrekr:
                          log(obj.val);
                  on({id: 'admin.0.info.updatesNumber', change: 'any'}, function (obj) {
                      if (obj.newState.val > 0){
                          sendTo('telegram', (obj.newState.val).toString());
                          log(obj.newState.val);
                  А если так?
                    Сейчас поставил по-первому способу, если не пойдет, буду пробовать вторым способом. Осталось дождаться какого нибудь обновления 🙂
                    • Bluefox
                      Bluefox last edited by
                      @spectrekr:
                      Сейчас поставил по-первому способу, если не пойдет, буду пробовать вторым способом. Осталось дождаться какого нибудь обновления 🙂 `
                      Как instalator написал: obj.newState.val правильно
                      Также работает obj.state.val
                        Блин, уже мозг взрывается. Пытаюсь выполнить команду через exec
                        var cmd = "'/usr/src/git/git_upd.sh "+ obn + ' ' + date_obn + "'";
                                log(cmd);
                                child = exec (cmd,
                                    function (error, stdout, stderr){
                                        if (error !== null) {
                                            log(error);
                        В логе получаю
                        ! 11:14:16.421 [info] javascript.0 script.js.Скрипт1: '/usr/src/git/git_upd.sh sayit 2016.5.16'
                        ! 11:14:16.422 [info] javascript.0 script.js.Скрипт1: Error: Command failed: /bin/sh -c '/usr/src/git/git_upd.sh sayit 2016.5.16' /bin/sh: 1: /usr/src/git/git_upd.sh sayit 2016.5.16: not found
                        В консоле от этого же юзера, под которым работает сервер, эта команда без проблем выполняется.
                        ! cubie@Cubian:/usr/src/git$ /bin/sh -c '/usr/src/git/git_upd.sh sayit 2016.5.12'
                        ! GermanBluefox, Sat May 14 15:39:12 2016 +0200 : ### 1.0.0 (2016-05-14) * (bluefox) Make the type of mp3 as file
                        upd: Разобрался, сделал обходным путем.
                          делаю функцию.
                          var get_ver_upd = function (drv){
                          var path_upd = 'iobroker\node_modules\iobroker.js-controller\conf\sources-dist.json';
                          if (fs.existsSync(path_upd)) {
                          fs.readFile(path_upd, function (error, data) {
                          if (!error) {
                          var result;
                          try {
                          result = JSON.parse(data);
                          } catch (err) {
                          log("Не парсится!");
                          result = null;
                          // log(result[drv].meta);
                          request(result[drv].meta, function (error, response, body) {
                          if (!error && response.statusCode == 200) {
                          var result_ver;
                          try {
                          result_ver = JSON.parse(body)
                          } catch (err) {
                          result_ver = null;
                          // log(result_ver.common.version);
                          return result_ver.common.version;
                          и пытаюсь вернуть в основную программу
                          ver_n = get_ver_upd(obn);
                          log(ver_n);
                          ver_n объявлена глобально.
                          • I
                            @spectrekr:
                            делаю функцию.
                            if (!error) {
                            var result;
                            try {
                            } catch (err) {
                            result = null;
                            var result_ver;
                            try {
                            } catch (err) {
                            result_ver = null;
                            log(ver_n);
                            ver_n объявлена глобально. `
                            function get_ver_upd (drv){
                            if (!error) {
                            var result;
                            try {
                            } catch (err) {
                            result = null;
                            var result_ver;
                            try {
                            } catch (err) {
                            result_ver = null;
                            • I
                              ! function get_ver_upd (drv, callback){ var path_upd = 'iobroker\\node_modules\\iobroker.js-controller\\conf\\sources-dist.json'; if (fs.existsSync(path_upd)) { fs.readFile(path_upd, function (error, data) { if (!error) { var result; try { result = JSON.parse(data); } catch (err) { log("Не парсится!"); result = null; } // log(result[drv].meta); request(result[drv].meta, function (error, response, body) { if (!error && response.statusCode == 200) { var result_ver; try { result_ver = JSON.parse(body) } catch (err) { log("Не парсится!"); result_ver = null; } // log(result_ver.common.version); callback (result_ver.common.version); } }); } }); } } ! get_ver_upd(obn, function(n){ log(n); }); !
                                Возник другой вопрос, а как заставить цикл ждать отработки всех функций внутри цикла?
                                for (var i = 0; i < obn.length; i++) { get_info(obn[i], function(readme, ver_c){ log(readme); log(ver_c); }); get_ver_upd(obn[i], function(ver_n){ log(ver_n); });
                                а выводит как попало
                                ! >! ~~[spoiler]~~16:35:56.441 [info] javascript.0 script.js.update: https://github.com/ioBroker/ioBroker.mq ... /README.md
                                ! 16:35:56.442 [info] javascript.0 script.js.update: 1.0.3
                                ! 16:35:56.442 [info] javascript.0 script.js.update: https://github.com/iobroker/ioBroker.ja ... /README.md
                                ! 16:35:56.442 [info] javascript.0 script.js.update: 2.0.6
                                ! 16:35:56.705 [info] javascript.0 script.js.update: 2.1.0
                                ! 16:35:56.713 [info] javascript.0 script.js.update: 1.0.3[/spoiler]
                                И еще попутно, почему не присваивает значение?
                                ~~[code]~~get_ver_upd(obn, function(n){ ver_n = n; }); [/code][/i][/i]
                                • Bluefox
                                  `var ready = 0;
                                              ready++;
                                                  log(readme);
                                                  log(ver_c);
                                                  if (!--ready) {
                                                       log('finished');
                                              ready++;
                                                  log(ver_n);
                                                  if (!--ready) {
                                                       log('finished');
                                  }`[/i][/i]
                                    Странно отрабатывает, да еще и 1 раз только finished пишет.
                                    ! 17:35:17.349 [info] javascript.0 script.js.update: https://github.com/ioBroker/ioBroker.mq … /README.md
                                    ! 17:35:17.349 [info] javascript.0 script.js.update: 1.0.3
                                    ! 17:35:17.349 [info] javascript.0 script.js.update: https://github.com/iobroker/ioBroker.ja … /README.md
                                    ! 17:35:17.349 [info] javascript.0 script.js.update: 2.0.6
                                    ! 17:35:17.612 [info] javascript.0 script.js.update: 2.1.0
                                    ! 17:35:17.613 [info] javascript.0 script.js.update: 1.0.3
                                    ! 17:35:17.613 [info] javascript.0 script.js.update: finished
                                    А по поводу передать значение не подскажешь?
                                    • Bluefox
                                      Давай весь скрипт. Хватит кусками выдавать. 🙂
                                      Там функции get_ver_upd и get_info надо менять
                                        @Bluefox:
                                        Там функции get_ver_upd и get_info надо менять `
                                        `var request = require('request');
                                        var path, obn, readme, ver_c, ver_n;
                                        ! function get_info(obn){
                                        path = 'iobroker\node_modules\iobroker.' + obn;
                                        if (fs.existsSync(path)) {
                                        fs.readFile(path + "\io-package.json", function (error, data) {
                                        if (!error) {
                                        var result;
                                        try {
                                        } catch (err) {
                                        result = null;
                                        return result.common.readme, result.common.version;
                                        ! function get_ver_upd (drv){
                                        if (!error) {
                                        var result;
                                        try {
                                        } catch (err) {
                                        result = null;
                                        var result_ver;
                                        try {
                                        result_ver = JSON.parse(body);
                                        } catch (err) {
                                        result_ver = null;
                                        ! function get_chang(readme, ver_c, ver_n, callback){
                                        log(readme);
                                        log(ver_c);
                                        log(ver_n);
                                        ! on({id: 'admin.0.info.updatesList', change: 'any'}, function (obj) {
                                        var str = 'Доступно обновления для:\n';
                                        if (getState('admin.0.info.updatesNumber').val > 1){
                                        obn = obj.state.val.split(',');
                                        /* for (var i = 0; i < obn.length; i++) {
                                        log(readme);
                                        log(ver_c);
                                        log(ver_n);
                                        var ready = 0;
                                        ready++;
                                        get_info(obn[i], function(r, v){
                                        // log(r);
                                        readme = r;
                                        // log(v);
                                        ver_c = v;
                                        if (!--ready) {
                                        log('finished');
                                        ready++;
                                        get_ver_upd(obn[i], function(v){
                                        log(ver_n);
                                        ver_n = v;
                                        if (!--ready) {
                                        log('finished');
                                        if (getState('admin.0.info.updatesNumber').val == 1){
                                        obn = obj.state.val;
                                        get_info(obn, function(r, v){
                                        // log(r);
                                        readme = r;
                                        // log(v);
                                        ver_c = v;
                                        get_ver_upd(obn, function(v){
                                        // log(v);
                                        ver_n = v;
                                        get_chang(readme, ver_c, ver_n);
                                        Это то что на данный момент. Соответственно в function get_chang будет дальнейшая обработка.[/i][/i][/i][/i]
                                        • Bluefox
                                          Не жалей букв на названия 😉
                                          ! function get_info(obn, cb){
                                          path = 'iobroker/node_modules/iobroker.' + obn;
                                          	fs.readFile(path + "/io-package.json", function (error, data) {
                                          		if (!error) {
                                          			var result;
                                          			try {
                                          			} catch (err) {
                                          				console.error("Не парсится!");
                                          				return cb(obn);
                                          			cb(obn, result.common.readme, result.common.version);
                                          		} else {
                                          			console.error(error);
                                          			cb(obn);
                                          } else {
                                          	cb(obn);
                                          ! function get_ver_upd (drv, cb) {
                                          var path_upd = 'iobroker/node_modules/iobroker.js-controller/conf/sources-dist.json';
                                          if (!error) {
                                          var result;
                                          try {
                                          } catch (err) {
                                          return cb(drv);
                                          var result_ver;
                                          try {
                                          } catch (err) {
                                          return cb(drv);
                                          cb(drv, result_ver.common.version);
                                          } else {
                                          cb(drv);
                                          } else {
                                          cb(drv);
                                          } else {
                                          cb(drv);
                                          log(readme);
                                          log(ver_c);
                                          log(ver_n);
                                          callback && callback();
                                          ! function processData(data, callback) {
                                          if (data && !data instanceof Array) {
                                          // convert data
                                          var arr = [];
                                          for (var a in data) {
                                          data[a].name = a;
                                          arr.push(data[a]);
                                          data = arr;
                                          if (!data || !data.length) {
                                          	return;
                                          var task = data.pop();
                                          get_chang(task.readme, task.version, task.versionUpdate, function () {
                                          	setTimeout(function () {
                                          		processData(data, callback);
                                          	}, 0);
                                          if (getState('admin.0.info.updatesNumber').val) {
                                          var ready = 0;
                                          var data = {};
                                          ready++;
                                          get_info(obn[i], function(adapter, r, v){
                                          if (r) {
                                          data[adapter] = data[adapter] || {};
                                          data[adapter].readme = r;
                                          data[adapter].version = v;
                                          ! if (!--ready) {
                                          processData(arr);
                                          ready++;
                                          get_ver_upd(obn[i], function(adapter, v){
                                          if (v) {
                                          data[adapter].versionUpdate = v;
                                          if (!--ready) {
                                          processData(data);
                                          ! });`[/i][/i]
                                            electric last edited by
                                            Ребят, такой вопрос.
                                            В скрипте создаю переменную и ниже по тексту на нее же подписываюсь.
                                            Первый раз скрипт не запускается, вываливается с ошибками типа таких:
                                            ! ReferenceError: 05 18:56:57.056 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12) ReferenceError: 05 18:56:57.056 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10) ReferenceError: 05 18:56:57.056 error at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) ReferenceError: 05 18:56:57.056 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30) ReferenceError: 05 18:56:57.056 error at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2036:80) ReferenceError: 05 18:56:57.056 error at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17) ReferenceError: 05 18:56:57.056 error at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:537:17) ReferenceError: 05 18:56:57.056 error at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2624:45) ReferenceError: 05 18:56:57.056 error at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:541:48 ReferenceError: 05 18:56:57.056 error at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1207:48) ReferenceError: 05 18:56:57.056 error at Object. (script.js.common.cubietruck:224:23) ReferenceError: 05 18:56:57.056 error poll_ac is not defined message 05 18:56:57.053 error javascript.0.cubietruck.ac.poolinterval [object Object] poll_ac is not defined javascript-0 05 18:56:56.885 error at script.js.common.cubietruck:248:82 javascript-0 05 18:56:56.885 error script.js.common.cubietruck: TypeError: Cannot read property 'val' of null javascript-0 05 18:56:56.874 warn State "javascript.0.cubietruck.ac.poolinterval" not found !
                                            Второй раз запускаю, все ОК.
                                            Как заставить сначала создавать, потом подписываться?
                                            Или есть вариант, что я не правильно понял ошибку?
                                            Скрипт примерно такой:
                                            var pool_ac = null; //интервал опроса переменных AC
                                            createState('cubietruck.ac.poolinterval',10000);
                                            //Изменение интервала опроса
                                            on({id: 'javascript.0.cubietruck.ac.poolinterval', change: 'any'}, function (obj) {
                                                if (obj.newState.val !== '' || typeof obj.newState.val !== "undefined" || parseInt(obj.newState.val) >= 1000){
                                                    clearInterval(poll_ac);
                                                    poll_ac = setInterval(poolAC, parseInt(obj.newState.val));
                                                } else {
                                            function poolAC () {
                                               log("test");
                                            poll_ac = setInterval(poolAC, getState('javascript.0.cubietruck.ac.poolinterval').val);
                                            Ошибка по идее на последнюю строчку, т.е. не может получить getState().val хотя в createState('cubietruck.ac.poolinterval',10000); значение по-умолчанию прописано.
                                            358
                                            104170
