    • simatec
      simatec Developer Most Active @Holzlenkrad last edited by simatec
      @Holzlenkrad
      Zeige mal bitte die Logausgaben vom manuellen Backup.
      Und poste mal die json deiner Config.
      Welche Version ist aktuell installiert?
      Hast du ein Update von node oder dem js-controller durchgeführt gehabt oder lief das Backup noch nie?
        Holzlenkrad @simatec last edited by
        @simatec said in Test Adapter Backitup v1.5.x:
        Config
        Das dürfte die Config sein oder?
         "native": {
           "minimalTime": "08:00",
           "minimalEveryXDays": "2",
           "minimalDeleteAfter": "10",
           "minimalNameSuffix": "",
           "ccuTime": "01:30",
           "ccuEveryXDays": "3",
           "ccuDeleteAfter": "5",
           "ccuNameSuffix": "",
           "ccuHost": "",
           "ccuUser": "Admin",
           "ccuPassword": "",
           "dropboxAccessToken": "",
           "dropboxMinimalDir": "/backupDir/iobroker",
           "dropboxCcuDir": "/backupDir/ccu",
           "dropboxDir": "/backupDir",
           "googledriveAccessJson": "",
           "googledriveMinimalDir": "/backupDir/iobroker",
           "googledriveCcuDir": "/backupDir/ccu",
           "googledriveDir": "/backupDir",
           "mySqlHost": "localhost",
           "mySqlPort": "3306",
           "mySqlName": "iobroker",
           "mySqlUser": "",
           "mySqlPassword": "",
           "mySqlDumpExe": "",
           "cifsMount": "",
           "cifsUser": "",
           "cifsPassword": "",
           "cifsDomain": "",
           "cifsDir": "sharename/backupDir",
           "cifsCcuDir": "sharename/backupDir",
           "cifsMinimalDir": "sharename/backupDir",
           "connectType": "CIFS",
           "smbType": "vers=1.0",
           "macAd": "20:DE:20:DE:20:DE",
           "wolWait": "25",
           "ftpHost": "",
           "ftpPort": "21",
           "ftpDir": "/backupDir",
           "ftpUser": "",
           "ftpPassword": "",
           "ftpCcuDir": "/backupDir/ccu",
           "ftpMinimalDir": "/backupDir/iobroker",
           "redisPath": "/var/lib/redis",
           "historyPath": "media/usb/history",
           "notificationsType": "Telegram",
           "telegramInstance": "",
           "telegramNoticeType": "longTelegramNotice",
           "telegramWaitToSend": "0",
           "pushoverInstance": "",
           "pushoverNoticeType": "longPushoverNotice",
           "pushoverDeviceID": "",
           "pushoverWaitToSend": "0",
           "emailReceiver": "xxx@xxx.com",
           "emailSender": "xxx@xxx.com",
           "emailInstance": "",
           "emailNoticeType": "longEmailNotice",
           "emailWaitToSend": "0",
           "historyEntriesNumber": "25",
           "restoreSource": "local",
           "mySqlDeleteAfter": 5,
           "minimalEnabled": true,
           "redisMinimalEnabled": false,
           "mysqlMinimalEnabled": false,
           "mysqlQuick": false,
           "mysqlSingleTransaction": false,
           "ccuEnabled": false,
           "dropboxEnabled": false,
           "dropboxDeleteOldBackup": false,
           "dropboxOwnDir": false,
           "googledriveEnabled": false,
           "googledriveDeleteOldBackup": false,
           "googledriveOwnDir": false,
           "mySqlEnabled": false,
           "cifsEnabled": false,
           "cifsOwnDir": false,
           "cifsDeleteOldBackup": false,
           "sudoMount": false,
           "wakeOnLAN": false,
           "ftpEnabled": false,
           "ftpOwnDir": false,
           "ftpDeleteOldBackup": false,
           "redisEnabled": false,
           "historyEnabled": false,
           "zigbeeEnabled": true,
           "notificationEnabled": true,
           "telegramSilentNotice": false,
           "telegramOnlyError": false,
           "pushoverSilentNotice": false,
           "pushoverOnlyError": false,
           "emailOnlyError": false,
           "debugLevel": true,
           "startAllRestore": false,
           "telegramUser": null
        Backitup ist Version 1.5.6, js-controller 3.1.4.
        Das Backup lief schon mal 3-5 mal automatisch, hab den Adapter aber auch erst seit letztem Monat installiert. Ich weiß nicht genau, ob ich seitdem schon mal den js-controller aktualisiert habe, denke aber schon, gab ja eine Menge Updates in letzter Zeit. Bin übrigens im Repo latest.
        Und so sieht ein manuelles Backup aus:
        Gestartet...
        [DEBUG] [iobroker] start with {"type":"creator","time":"08:00","debugging":true,"everyXDays":"2","deleteBackupAfter":0,"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/var/lib/redis"},"historyDB":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"media/usb/history"},"zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"local","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker","user":"","pass":"****","port":"21"},"cifs":{"enabled":false,"mountType":"CIFS","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":false,"cifsDomain":"","deleteOldBackup":false,"ownDir":false,"dir":"sharename/backupDir","dirMinimal":"sharename/backupDir","user":"","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"local","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"path":"/opt/iobroker/iobroker-data"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":null,"onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
        [DEBUG] [iobroker] - host.iobroker-docker 757 states saved
        [DEBUG] [iobroker] - host.iobroker-docker 938 objects saved
        [DEBUG] [iobroker] - readFile will not read this file (css/vis-common-user.css) in future versions: vis is not an object of type "meta"
        [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2020_05_11-22_11_44_backupiobroker.tar.gz
        [DEBUG] [iobroker] - done
        • simatec
          @Holzlenkrad
          Dein Backup wird so wie ich das sehe nicht ordentlich beendet.
          Was mir aufgefallen ist, dass du zigbee aktiviert hast.
          Hast du eine zigbee Instanz laufen?
          Z.B. Zigbee.0 oder zigbee.1
            @simatec
            Tatsächlich derzeit nicht, weil ich meine Zigbee Geräte noch neu anlernen muss.
            Könnten die Probleme denn daher kommen, dass Zigbee schon im Backup-Adapter angeklickt wurde? Mit der Einstellung wurden ja schon ein paar Backups angelegt...
            Und woran kann ich sehen, dass das Bacup nicht ordentlich durchgelaufen ist? Da steht ja
            [DEBUG] [iobroker] - Backup created: X und
            simatec 2 Replies Last reply Reply Quote 0
            • simatec
              @Holzlenkrad
              Ja da muss ich mir den Backupprozess fü zigbee mal anschauen.
              Hatte gestern gerade eine Meldung dazu bekommen ...
              Deaktiviere zigbee in backitup und es sollte durchlaufen.
              Das das Backup nicht beendet wurde sieht man daran, dass am Ende kein "exit 0" kam.
              • simatec
                @Holzlenkrad
                Könntest du mal testen, ob es jetzt mit gesetzten Häckchen bei zigbee trotzdem läuft und auch beendet wird?
                Installation über Github:
                https://github.com/simatec/ioBroker.backitup/tarball/dev
                Den Link direkt in der Katze unter Adaptern einfügen.
                Am besten auch mal die debug Ausgaben hier posten
                • JB_Sullivan
                  JB_Sullivan last edited by
                  Hallo zusammen - ist die Meldung etwas worüber man sich Gedanken machen muss?
                  Es steht zwar nicht kritisch, aber trotzdem ist es ein Fehler.
                  • simatec
                    simatec Developer Most Active @JB_Sullivan last edited by
                    @JB_Sullivan
                    Nein musst du dir keine Gedanken machen.
                    Glaube das wurde in einem der neuen js-controller Versionen auch gefixt.
                    • JB_Sullivan
                      JB_Sullivan @simatec last edited by
                      @simatec
                      Naja, neuer als 3.1.4 geht glaube ich nicht und den habe ich drauf 😉
                      • simatec
                        @JB_Sullivan
                        OK ... wie gesagt, ich dachte das wurde geändert.
                        Aber wie die Meldungen auch aussagen, ist das nicht kritisch
                        • JB_Sullivan
                          @simatec - OK Danke für die Info.
                            @simatec
                            Zigbee war wohl die richtige Spur. Wenn ich das Zigbee-Backup deaktiviere, dann läuft das Backup richtig durch.
                            Mit der Version von Github funktioniert das Backup auf mit aktiviertem Zigbee, im Log steht dann:
                            [DEBUG] [zigbee] - undefined backup done
                            Allerdings ist mir aufgefallen, dass der Datenpunkt backitup.0.history.iobrokerLastTime den Wert "Error: Datum Uhrzeit" hat, und unter .html steht, dass nur ein lokales Backup gemacht wurde. Reicht das schon aus, dass ein Error geworfen wird?
                            Bei mir kümmert sich ein Cronjob auf dem Host-System darum, dass die Backup-Files entsprechend extern gesichert werden... Also eigentlich ist das so aus meinen Augen ein fehlerfreies Verhalten.
                            Außerdem ist mir aufgefallen, dass nach Änderungen der Adapter-Einstellungen unter dem Tab "Wiederherstellen" nach "Backups abrufen" keine vorhandenen Backups angezeigt werden. Man muss dann erst einmal die Konfiguration von Backitup schließen und neu öffnen, dass die Liste der Backups geladen wird.
                              smartysmart last edited by
                              Weiss jemand warum die mysql Datei nur als "." (PUNKT) in der zip gespeichert wird ?
                              Es ist nicht weiter schlimm, weil ich sie beim Entpacken umbenennen muss dann kann ich die Datei öffnen und hab alle Daten aber "just nice to know" ob man das fixen kann.
                              • simatec
                                simatec Developer Most Active @smartysmart last edited by
                                @smartysmart
                                Ist so gewollt und gür den Restore mit Backitup gedacht
                                S J 2 Replies Last reply Reply Quote 0
                                  smartysmart @simatec last edited by
                                  @simatec sagte in Test Adapter Backitup v1.5.x:
                                  @smartysmart
                                  Achso, der Import macht dann keine Probleme? Ja dann ist ja eh super. Dachte das wird beim Import Probleme machen.
                                  Top ... danke
                                    Jan1 @simatec last edited by
                                    @simatec
                                    Gestern kam die Frage auf warum eigentlich mit CIFS arbeiten wenn doch auch NFS zur Verfügung steht. Ich konnte mich dran erinnern, dass in der Adapter Doku dazu mal ein Vergleich gestanden hatte und da ich mich weder mit dem einen noch mit dem anderen ausgekannt hatte, hab ich mich nach dem Lesen dieses Vergleich für CIFS entschieden, nur finde ich besagten Vergleich im Zusammenhang mit dem Backitup Adapter nicht mehr.
                                    Lange Rede kurzer Sinn, was ist denn nun die bessere Wahl wenn man von IOBroker der unter Linux läuft ein Backup auf ein NAS (in meinem Fall die Fritz) der auch unter Linux läuft sichern möchte?
                                    SMB sprich CIFS ist ja eigentlich ne Windows Geschichte, was dann eher für NFS sprechen würde wenn man das unter Linux macht. Gibts hier überhaupt große Unterschiede oder Vor- und Nachteile?
                                    • simatec
                                      simatec Developer Most Active @Jan1 last edited by
                                      @Jan1
                                      Grundsätzlich finde ich NFS die bessere Wahl.
                                      Allerdings unterstützen nicht alle NAS Laufwerke NFS. Daher gibt es beide Varianten.
                                      Ich glaube die Fritzbox unterstützt nur CIFS.
                                      Es sei denn, du hast sie gepatcht und Freetz drauf laufen
                                        deMarvin last edited by
                                        bin etwas ratlos, mein SQL-Restore will einfach nicht.
                                        Meine Daten:
                                        • Node.js v12.18.0
                                        • js-controller 3.14
                                        • NPM v6.14.4
                                        Mit Backitup 1.4.5 und auch 1.5.8 getestet.
                                        [DEBUG] [mysql] Start mysql Restore ...
                                        [ERROR] [mysql] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/mysql_restore_backupiobroker.sql'
                                        [ERROR] [mysql] mysql Restore not completed
                                        [EXIT] undefined **** Restore completed successfully!! ****
                                        Den Fixer hab ich schon mehrfach ausgeführt. System ist ganz frisch und auf dem neusten Stand. MariaDB-User hat alle Rechte.
                                        Weiß jemand weiter?
                                        • simatec
                                          simatec Developer Most Active @deMarvin last edited by
                                          @deMarvin
                                          Hast du mysqldump installiert und in Backitup den Pfad zur mysqldump angegeben?
                                            deMarvin last edited by deMarvin
                                            @simatec
                                            Nein und um ehrlich zu sein weiß ich auch nicht wo. Dumme Frage: Wo find ich das?
                                            [edit1]
                                            Ist wohl doch installiert, wie bekommt der User iobroker jetzt Rechte dafür?
                                            Das Backup macht er übrigens Problemlos.
                                            [edit2]
                                            Hab mal den Pfad noch eingetragen, auch kein Erfolg. Selber Fehler wenn ich die Datenbank wiederherstellen will.
                                            pi@iobroker:~ $ ls -la /usr/bin/mysqldump
                                            -rwxr-xr-x 1 root root 3593164 Feb  2 14:33 /usr/bin/mysqldump
                                            Jeder User hat aber Rechte zum ausführen.
                                            170
                                            2780
                                            2346189
