    4. [Tablet Control] Tablet Steuerung möchte getestet werden
    • Chaot
      Chaot @Issi last edited by Chaot
      @Issi
      Leider mit ein paar Fehlermeldungen:
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:34)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:16)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at JSON.parse (<anonymous>)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	(27245) [dayBri] : Unexpected token u in JSON at position 0, stack: SyntaxError: Unexpected token u in JSON at position 0
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:3)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.create_state (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:1322:9)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:15)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at JSON.parse (<anonymous>)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	(27245) [manualStates] : Unexpected token u in JSON at position 0, stack: SyntaxError: Unexpected token u in JSON at position 0
      fully-tablet-control.0	2020-05-13 08:41:56.662	info	(27245) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.fully-tablet-control, node: v12.16.3, js-controller: 3.1.4
      Hast du auch noch aufgeschlüsselt wie die State_of_charge jetzt aussehen?
      Edit:
      Die Fehlermeldung kam wenn bei beiden Helligkeitseinstellungen kein Haken gesetzt war.
      Sind beide aktiv kommt kein Fehler.
      Issi 1 Reply Last reply Reply Quote 0
      • jackblackson
        jackblackson last edited by
        @Issi Ich bin grad mit der Helligkeitssteuerung am Tablet am spielen. Hier hast du ja einen Tag und einen Nachtmodus. Meinst du, du könntest hier statt der Uhrzeit auch Sonnenaufgang sowie Sonnenuntergang anbieten? Die Datenpunkte solltest du bekommen können (getAstroDate). Glaub das würde Sinn machen, nicht? Weil sonst muss man es ja je nach Jahreszeit anpassen.
        • Chaot
          Chaot last edited by Chaot
          @Issi
          Die letzte Frage hat sich erledigt. Ich habe für das View 8 die Zustände des Akkus zum Laden selbst gefunden.
          0= 0%
          1= 10%
          2= 10% laden an
          3= 20%
          4= 20% laden an
          5= 30%
          6= 30% laden an
          7= 40%
          8= 40% laden an
          9= 50%
          10= 50% laden an
          11= 60%
          12= 60% laden an
          13= 70%
          14= 70% laden an
          15= 80%
          16= 80% laden an
          17= 90%
          18= 90% laden an
          19= 100%
          20= 100% laden an
          Danke für die Änderung. Klappt perfekt!
          Hier mal ein Widget als Muster mit allen Batterieständen:
          [{"tpl":"tplStatefulImage8","data":{"oid":"fully-tablet-control.0.device.eingang.state_of_charge_vis","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","count":"20","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_11":"/icons-open-icon-library-png/status/battery-060.png","src_10":"/icons-open-icon-library-png/status/battery-charging-050.png","src_9":"/icons-open-icon-library-png/status/battery-050.png","src_8":"/icons-open-icon-library-png/status/battery-charging-040.png","src_7":"/icons-open-icon-library-png/status/battery-040.png","src_6":"/icons-open-icon-library-png/status/battery-charging-030.png","src_5":"/icons-open-icon-library-png/status/battery-030.png","src_4":"/icons-open-icon-library-png/status/battery-charging-020.png","src_3":"/icons-open-icon-library-png/status/battery-020.png","src_2":"/icons-open-icon-library-png/status/battery-charging-010.png","src_1":"/icons-open-icon-library-png/status/battery-010.png","src_0":"/icons-open-icon-library-png/status/battery-000.png","src_13":"/icons-open-icon-library-png/status/battery-070.png","src_15":"/icons-open-icon-library-png/status/battery-080.png","src_17":"/icons-open-icon-library-png/status/battery-090.png","src_19":"/icons-open-icon-library-png/status/battery-100.png","src_20":"/icons-open-icon-library-png/status/battery-charging-100.png","src_18":"/icons-open-icon-library-png/status/battery-charging-090.png","src_16":"/icons-open-icon-library-png/status/battery-charging-080.png","src_14":"/icons-open-icon-library-png/status/battery-charging-070.png","src_12":"/icons-open-icon-library-png/status/battery-charging-060.png"},"style":{"left":"177px","top":"76px","width":"44px","height":"43px"},"widgetSet":"basic"}]
          Verwendet habe ich dabei die open icons library
            calliou1234 @Issi last edited by
            @Issi
            Hallo Issi,
            gute Idee mit dem Adapter und mille grazie hierfür. Ich bin gerade dabei meine Scripts durch deinen Adapter zu ersetzen.
            Ich schalte aktuell wenn niemand zu Hause ist das Display des Tablets aus.
            Wäre sowas integrierbar?
            Link auf ein Anwesenheits-Object (Bool), wenn jemand da, dann Display an, wenn niemand da aus.
            Thomas
            • Issi
              Issi Developer @Chaot last edited by Issi
              @Chaot sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
              @Issi
              das passiert nur dann wen du bereits Geräte angelegt hast und das update drüber installierst da wird die spalte erstellt in der Tabelle aber kein state drin da einfach bei beiden den haken rein und dann speichern dann kommt das nicht mehr wen du eine Geräte anlegst ist da ein Default wert drin
              die Beschreibung habe ich noch nicht gemacht war gestern schon spät werde noch die README ergänzen in den state kann man das auch schnell erkennen da er ein mal eine normale zahl 55% und einmal ein charge 55% gibt charge kommt immer dann wen geladen wird
              • Issi
                Issi Developer @jackblackson last edited by
                @jackblackson werde ich mal schauen wie ich das am besten einbauen kann da ich z.B. nicht bei Sonnenaufgang und Sonnenuntergang die zeit eingestellt habe. Ich werde das auch mal auf die liste setzen.
                • Issi
                  @Chaot
                  danke für das Beispiel Widget werde ich dann auch in die README eintragen.
                  • Issi
                    Issi Developer @calliou1234 last edited by
                    @calliou1234 in einer späteren Version von den Adapter werden die commands von dem fullybrowser drin sein da kann man dann den Bildschirm ein und ausschalten.
                    denn kann man dann per script schalten z.B. Anwesenheits Erkennung script.
                    • JohGre
                      JohGre last edited by
                      Hallo, habe eben den Adapter installiert und bekomme folgende Fehlermeldung:
                      Fully läuft auf einem Samsung Galaxy Tab 4 Android 5.02
                      2020-05-13 14:23:55.523 - error: fully-tablet-control.0 (5891) [manualStates] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                      at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:50)
                      2020-05-13 14:23:55.524 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                      at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:37)
                      2020-05-13 14:25:00.006 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                      at CronJob. (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:570:9)
                      at CronJob.fireOnTick (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:600:23)
                      at Timeout.callbackWrapper [as _onTimeout] (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:667:10)
                      at listOnTimeout (internal/timers.js:549:17)
                      at processTimers (internal/timers.js:492:7)
                      • Issi
                        Issi Developer @JohGre last edited by
                        @JohGre
                        hast du vorher schon eine frühere version installiert gehabt ?
                        JohGre 1 Reply Last reply Reply Quote 0
                        • JohGre
                          JohGre @Issi last edited by
                          @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                          frühere version
                          Hi, von was? Adapter oder Fully Browser
                          • Issi
                            @JohGre den Fully Tablet Control dieser Fehler kommt nur dann wen der Adapter vorher schon mal installiert war und eingerichtet wurde bei einem ganz frischen Installation kommt er nicht hab ich grade getestet
                            • JohGre
                              So, habe nun die Instanz gelöscht und eine neue hinzugefügt. Nun kommt der Fehler nicht mehr.
                              Diese Datenpunkte wurden angelegt, schaut eigentlich ganz gut aus.
                              Eine Änderung des Datenpunkts level.dimmer bewirkt jedoch nichts.
                              • Issi
                                @JohGre Bitte lese die einleitung auf der GitHub seite da ist vieles beschriben wie dises problem von dir auch GitHub link
                                • JohGre
                                  @Issi
                                  Danke, wer lesen kann , ist klar im Vorteil 😉
                                  • JohGre
                                    @Issi Hätte da einen Featurewunsch:
                                    Für mich wäre es super wenn die Umschaltung zwischen Tag- und Nachthelligkeit über entsprechende Astrozeiten zu steuern wären.
                                    zB: Tagwert-->bei sunriseEnd, goldenhourEnd,..., Nachtwert --> bei sunsetStart , sunset,...
                                    Natürlich könnte man das auch per Script lösen, aber wenn schon eine Zeitsteuerung eingebaut ist 😉
                                    • Issi
                                      Issi Developer @Issi last edited by Issi
                                      @JohGre
                                      wie ich schon weiter oben sagte werde ich das auf die liste setzen da ich da erst schauen muss wie genau ich das einbaue da ich z.B. nicht nach der Astrozeiten eingestellt habe
                                      • Issi
                                        Issi Developer last edited by
                                        so neue Version 0.2.5 ist auf GitHub verfügbar:
                                        hab den FullyBrowser Adapter implementiert und paar bugs behoben
                                        siggi85 1 Reply Last reply Reply Quote 0
                                        • siggi85
                                          siggi85 @Issi last edited by siggi85
                                          @Issi Erste Tests sehen gut aus. Durch die Kommandos wäre es mir jetzt wirklich möglich den alten Fully Adapter mit diesem zu ersetzen. Da dieser noch in Entwicklung ist, ware ich aber noch etwas damit. Schon Mal danke für die Arbeit an diesem Adapter! 👍
                                          EDIT: Etwas zu früh gefreut. 😉 habe ein paar Fehler im Log:
                                          fully-tablet-control.0	2020-05-17 08:04:48.267	warn	(20790) Wohnzimmer charger not specified
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6814:25)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7117:22)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.emit (events.js:198:13)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:92:14)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.initialization (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:184:50)
                                          fully-tablet-control.0	2020-05-17 08:04:45.829	error	(20790) [initialization] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                                          Meine Konfiguration ist ganz simpel (Eintrag für Ladegerät habe ich gelöscht, ist das der Fehler?!)
                                            ich hab auch ..direkt nach neu installation und start..
                                            es sind nicht alle Datenpunkte gefüllt.. klar logisch. hab ja nur die erste seite gefüllt.. also nur die ip eingetragen
                                            muttu abfangen
                                            das warning würde ich auch abschalten. oder schaltbar machen.. mehr Infos weniger infos.
                                            ich will es nicht nutzen.. und so bekomme ich ständig das warning ..
                                            hier währe eigener Datenpunkt nützlich.. ich stuere meine helligkeit abhängig vom aussen Helligkeitsensor
                                            mit Schwellwert (als Anregung)
                                            ansonsten TOP..
                                            adapter fully kiosk browser fullybrowser tablet tablet-control test testen
                                            50
                                            512
                                            80097
