    4. [Tablet Control] Tablet Steuerung möchte getestet werden
    • Issi
      Issi Developer @Chaot last edited by Issi
      @Chaot sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
      @Issi
      Leider mit ein paar Fehlermeldungen:
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:34)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:16)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	at JSON.parse (<anonymous>)
      fully-tablet-control.0	2020-05-13 08:41:57.584	error	(27245) [dayBri] : Unexpected token u in JSON at position 0, stack: SyntaxError: Unexpected token u in JSON at position 0
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:3)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.create_state (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:1322:9)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:15)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	at JSON.parse (<anonymous>)
      fully-tablet-control.0	2020-05-13 08:41:57.582	error	(27245) [manualStates] : Unexpected token u in JSON at position 0, stack: SyntaxError: Unexpected token u in JSON at position 0
      fully-tablet-control.0	2020-05-13 08:41:56.662	info	(27245) starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.fully-tablet-control, node: v12.16.3, js-controller: 3.1.4
      das passiert nur dann wen du bereits Geräte angelegt hast und das update drüber installierst da wird die spalte erstellt in der Tabelle aber kein state drin da einfach bei beiden den haken rein und dann speichern dann kommt das nicht mehr wen du eine Geräte anlegst ist da ein Default wert drin
      Hast du auch noch aufgeschlüsselt wie die State_of_charge jetzt aussehen?
      die Beschreibung habe ich noch nicht gemacht war gestern schon spät werde noch die README ergänzen in den state kann man das auch schnell erkennen da er ein mal eine normale zahl 55% und einmal ein charge 55% gibt charge kommt immer dann wen geladen wird
      • Issi
        Issi Developer @jackblackson last edited by
        @jackblackson werde ich mal schauen wie ich das am besten einbauen kann da ich z.B. nicht bei Sonnenaufgang und Sonnenuntergang die zeit eingestellt habe. Ich werde das auch mal auf die liste setzen.
        Issi 1 Reply Last reply Reply Quote 0
        • Issi
          @Chaot
          Hier mal ein Widget als Muster mit allen Batterieständen:
          [{"tpl":"tplStatefulImage8","data":{"oid":"fully-tablet-control.0.device.eingang.state_of_charge_vis","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","count":"20","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_11":"/icons-open-icon-library-png/status/battery-060.png","src_10":"/icons-open-icon-library-png/status/battery-charging-050.png","src_9":"/icons-open-icon-library-png/status/battery-050.png","src_8":"/icons-open-icon-library-png/status/battery-charging-040.png","src_7":"/icons-open-icon-library-png/status/battery-040.png","src_6":"/icons-open-icon-library-png/status/battery-charging-030.png","src_5":"/icons-open-icon-library-png/status/battery-030.png","src_4":"/icons-open-icon-library-png/status/battery-charging-020.png","src_3":"/icons-open-icon-library-png/status/battery-020.png","src_2":"/icons-open-icon-library-png/status/battery-charging-010.png","src_1":"/icons-open-icon-library-png/status/battery-010.png","src_0":"/icons-open-icon-library-png/status/battery-000.png","src_13":"/icons-open-icon-library-png/status/battery-070.png","src_15":"/icons-open-icon-library-png/status/battery-080.png","src_17":"/icons-open-icon-library-png/status/battery-090.png","src_19":"/icons-open-icon-library-png/status/battery-100.png","src_20":"/icons-open-icon-library-png/status/battery-charging-100.png","src_18":"/icons-open-icon-library-png/status/battery-charging-090.png","src_16":"/icons-open-icon-library-png/status/battery-charging-080.png","src_14":"/icons-open-icon-library-png/status/battery-charging-070.png","src_12":"/icons-open-icon-library-png/status/battery-charging-060.png"},"style":{"left":"177px","top":"76px","width":"44px","height":"43px"},"widgetSet":"basic"}]
          Verwendet habe ich dabei die open icons library
          danke für das Beispiel Widget werde ich dann auch in die README eintragen.
          • Issi
            Issi Developer @calliou1234 last edited by
            @calliou1234 in einer späteren Version von den Adapter werden die commands von dem fullybrowser drin sein da kann man dann den Bildschirm ein und ausschalten.
            denn kann man dann per script schalten z.B. Anwesenheits Erkennung script.
            • JohGre
              JohGre last edited by
              Hallo, habe eben den Adapter installiert und bekomme folgende Fehlermeldung:
              Fully läuft auf einem Samsung Galaxy Tab 4 Android 5.02
              2020-05-13 14:23:55.523 - error: fully-tablet-control.0 (5891) [manualStates] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
              at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:50)
              2020-05-13 14:23:55.524 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
              at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:37)
              2020-05-13 14:25:00.006 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
              at CronJob. (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:570:9)
              at CronJob.fireOnTick (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:600:23)
              at Timeout.callbackWrapper [as _onTimeout] (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:667:10)
              at listOnTimeout (internal/timers.js:549:17)
              at processTimers (internal/timers.js:492:7)
              • Issi
                Issi Developer @JohGre last edited by
                @JohGre
                hast du vorher schon eine frühere version installiert gehabt ?
                JohGre 1 Reply Last reply Reply Quote 0
                • JohGre
                  JohGre @Issi last edited by
                  @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                  frühere version
                  Hi, von was? Adapter oder Fully Browser
                  • Issi
                    @JohGre den Fully Tablet Control dieser Fehler kommt nur dann wen der Adapter vorher schon mal installiert war und eingerichtet wurde bei einem ganz frischen Installation kommt er nicht hab ich grade getestet
                    • JohGre
                      So, habe nun die Instanz gelöscht und eine neue hinzugefügt. Nun kommt der Fehler nicht mehr.
                      Diese Datenpunkte wurden angelegt, schaut eigentlich ganz gut aus.
                      Eine Änderung des Datenpunkts level.dimmer bewirkt jedoch nichts.
                      • Issi
                        @JohGre Bitte lese die einleitung auf der GitHub seite da ist vieles beschriben wie dises problem von dir auch GitHub link
                        • JohGre
                          @Issi
                          Danke, wer lesen kann , ist klar im Vorteil 😉
                          • JohGre
                            @Issi Hätte da einen Featurewunsch:
                            Für mich wäre es super wenn die Umschaltung zwischen Tag- und Nachthelligkeit über entsprechende Astrozeiten zu steuern wären.
                            zB: Tagwert-->bei sunriseEnd, goldenhourEnd,..., Nachtwert --> bei sunsetStart , sunset,...
                            Natürlich könnte man das auch per Script lösen, aber wenn schon eine Zeitsteuerung eingebaut ist 😉
                            • Issi
                              Issi Developer @Issi last edited by Issi
                              @JohGre
                              wie ich schon weiter oben sagte werde ich das auf die liste setzen da ich da erst schauen muss wie genau ich das einbaue da ich z.B. nicht nach der Astrozeiten eingestellt habe
                              • Issi
                                Issi Developer last edited by
                                so neue Version 0.2.5 ist auf GitHub verfügbar:
                                hab den FullyBrowser Adapter implementiert und paar bugs behoben
                                siggi85 1 Reply Last reply Reply Quote 0
                                • siggi85
                                  siggi85 @Issi last edited by siggi85
                                  @Issi Erste Tests sehen gut aus. Durch die Kommandos wäre es mir jetzt wirklich möglich den alten Fully Adapter mit diesem zu ersetzen. Da dieser noch in Entwicklung ist, ware ich aber noch etwas damit. Schon Mal danke für die Arbeit an diesem Adapter! 👍
                                  EDIT: Etwas zu früh gefreut. 😉 habe ein paar Fehler im Log:
                                  fully-tablet-control.0	2020-05-17 08:04:48.267	warn	(20790) Wohnzimmer charger not specified
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6814:25)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7117:22)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.emit (events.js:198:13)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:92:14)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.initialization (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:184:50)
                                  fully-tablet-control.0	2020-05-17 08:04:45.829	error	(20790) [initialization] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                                  Meine Konfiguration ist ganz simpel (Eintrag für Ladegerät habe ich gelöscht, ist das der Fehler?!)
                                    ich hab auch ..direkt nach neu installation und start..
                                    es sind nicht alle Datenpunkte gefüllt.. klar logisch. hab ja nur die erste seite gefüllt.. also nur die ip eingetragen
                                    muttu abfangen
                                    das warning würde ich auch abschalten. oder schaltbar machen.. mehr Infos weniger infos.
                                    ich will es nicht nutzen.. und so bekomme ich ständig das warning ..
                                    hier währe eigener Datenpunkt nützlich.. ich stuere meine helligkeit abhängig vom aussen Helligkeitsensor
                                    mit Schwellwert (als Anregung)
                                    ansonsten TOP..
                                    • Issi
                                      Issi Developer @arteck last edited by
                                      @arteck @siggi85
                                      @arteck sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                                      muttu abfangen
                                      die Ladefunktion kan man ganz abschalten dan kommt auch kein warning im log
                                      das mit dem error hab ich zwar schon was drin zum abfangen und in den test hat es funktioniert aber ich schau es mir noch mal an.
                                      hier währe eigener Datenpunkt nützlich.. ich steure meine helligkeit abhängig vom aussen Helligkeitsensor
                                      dafür gibt es auch ein eigenen Datenpunkt in den objekten
                                      Nr. 1 auf User einstellen und bei 2 kannst du die Helligkeit in 0% bis 100% einstehlen.
                                      dieser Funktion sorgt nur das der Bildschirm nicht ausgeschaltet werden kann über den Knopf am Tablett oder automatisch da manche Tabletts die Wlan Verbindung abschalten wen der Bildschirm länger ausgeschaltet ist.
                                      PS. hab glaub das Problem mit den error gefunden werde es beheben und dann bescheid sagen
                                      • Issi
                                        so hab nun die Helligkeitssteuerung etwas angepasst jetzt kann man sie komplett auf manuelle Steuerung oder auf zeit + manuell einstellen
                                        wenn sie über Nr.10 die Steuerung auf manuell geschaltet haben braucht man keine Tabelle unten erstellen
                                        wenn sie es auf Konfigurationsseite geschaltet haben MUSS die Tabelle angelegt werden für jedes Tablet das auf der Login Seite erstellt wurde wer bei einem oder mehreren Tabletts die zeit Steuerung nicht nutzen will kann über die Nr. 8 auf manuell Steuerung schalten nur für dieses Tablett.
                                        die Version 0.2.6 ist auf GitHub verfügbar
                                        • Issi
                                          Issi Developer last edited by Issi
                                          neue Version 0.2.7 auf GitHub verfügbar:
                                          @JohGre @jackblackson Hab die Astro Funktion nun eingebaut hat etwas gedauert da es nicht so einfach ist wie z.B. über (getAstroDate) da getAstroDate eine unter Funktion vom JavaScript Adapter ist musste ich erst mal schauen wie ich das einbauen kann.
                                          unter Nr. 11 kann man jetzt entscheiden was für eine zeit Steuerung verwendet wird Standard ist Astro Zeit.
                                          unter 12 kommt die Astro Zeit für den Tages beginn rein als wann das Tablett hoch dimmen soll und unter 13 dann wann er ab dimmen soll.
                                          • JohGre
                                            @Issi Danke dafür, werd ich morgen gleichmal austesten.
                                            adapter fully kiosk browser fullybrowser tablet tablet-control test testen
                                            50
                                            512
                                            80212
