    4. [Tablet Control] Tablet Steuerung möchte getestet werden
    • Issi
      Issi Developer @jackblackson last edited by
      @jackblackson werde ich mal schauen wie ich das am besten einbauen kann da ich z.B. nicht bei Sonnenaufgang und Sonnenuntergang die zeit eingestellt habe. Ich werde das auch mal auf die liste setzen.
      Issi 1 Reply Last reply Reply Quote 0
      • Issi
        Issi Developer @Chaot last edited by
        @Chaot
        Hier mal ein Widget als Muster mit allen Batterieständen:
        [{"tpl":"tplStatefulImage8","data":{"oid":"fully-tablet-control.0.device.eingang.state_of_charge_vis","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","count":"20","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_11":"/icons-open-icon-library-png/status/battery-060.png","src_10":"/icons-open-icon-library-png/status/battery-charging-050.png","src_9":"/icons-open-icon-library-png/status/battery-050.png","src_8":"/icons-open-icon-library-png/status/battery-charging-040.png","src_7":"/icons-open-icon-library-png/status/battery-040.png","src_6":"/icons-open-icon-library-png/status/battery-charging-030.png","src_5":"/icons-open-icon-library-png/status/battery-030.png","src_4":"/icons-open-icon-library-png/status/battery-charging-020.png","src_3":"/icons-open-icon-library-png/status/battery-020.png","src_2":"/icons-open-icon-library-png/status/battery-charging-010.png","src_1":"/icons-open-icon-library-png/status/battery-010.png","src_0":"/icons-open-icon-library-png/status/battery-000.png","src_13":"/icons-open-icon-library-png/status/battery-070.png","src_15":"/icons-open-icon-library-png/status/battery-080.png","src_17":"/icons-open-icon-library-png/status/battery-090.png","src_19":"/icons-open-icon-library-png/status/battery-100.png","src_20":"/icons-open-icon-library-png/status/battery-charging-100.png","src_18":"/icons-open-icon-library-png/status/battery-charging-090.png","src_16":"/icons-open-icon-library-png/status/battery-charging-080.png","src_14":"/icons-open-icon-library-png/status/battery-charging-070.png","src_12":"/icons-open-icon-library-png/status/battery-charging-060.png"},"style":{"left":"177px","top":"76px","width":"44px","height":"43px"},"widgetSet":"basic"}]
        Verwendet habe ich dabei die open icons library
        danke für das Beispiel Widget werde ich dann auch in die README eintragen.
        • Issi
          Issi Developer @calliou1234 last edited by
          @calliou1234 in einer späteren Version von den Adapter werden die commands von dem fullybrowser drin sein da kann man dann den Bildschirm ein und ausschalten.
          denn kann man dann per script schalten z.B. Anwesenheits Erkennung script.
          • JohGre
            JohGre last edited by
            Hallo, habe eben den Adapter installiert und bekomme folgende Fehlermeldung:
            Fully läuft auf einem Samsung Galaxy Tab 4 Android 5.02
            2020-05-13 14:23:55.523 - error: fully-tablet-control.0 (5891) [manualStates] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
            at FullyTabletControl.manualStates (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:623:50)
            at FullyTabletControl.create_state (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:1322:9)
            at processTicksAndRejections (internal/process/task_queues.js:97:5)
            at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:3)
            2020-05-13 14:23:55.524 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
            at FullyTabletControl.dayBri (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:669:37)
            at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:84:34)
            2020-05-13 14:25:00.006 - error: fully-tablet-control.0 (5891) [dayBri] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
            at CronJob. (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:570:9)
            at CronJob.fireOnTick (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:600:23)
            at Timeout.callbackWrapper [as _onTimeout] (/opt/iobroker/node_modules/iobroker.fully-tablet-control/node_modules/cron/lib/cron.js:667:10)
            at listOnTimeout (internal/timers.js:549:17)
            at processTimers (internal/timers.js:492:7)
            • Issi
              Issi Developer @JohGre last edited by
              @JohGre
              hast du vorher schon eine frühere version installiert gehabt ?
              JohGre 1 Reply Last reply Reply Quote 0
              • JohGre
                JohGre @Issi last edited by
                @Issi sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                frühere version
                Hi, von was? Adapter oder Fully Browser
                • Issi
                  @JohGre den Fully Tablet Control dieser Fehler kommt nur dann wen der Adapter vorher schon mal installiert war und eingerichtet wurde bei einem ganz frischen Installation kommt er nicht hab ich grade getestet
                  • JohGre
                    So, habe nun die Instanz gelöscht und eine neue hinzugefügt. Nun kommt der Fehler nicht mehr.
                    Diese Datenpunkte wurden angelegt, schaut eigentlich ganz gut aus.
                    Eine Änderung des Datenpunkts level.dimmer bewirkt jedoch nichts.
                    • Issi
                      @JohGre Bitte lese die einleitung auf der GitHub seite da ist vieles beschriben wie dises problem von dir auch GitHub link
                      • JohGre
                        @Issi
                        Danke, wer lesen kann , ist klar im Vorteil 😉
                        • JohGre
                          @Issi Hätte da einen Featurewunsch:
                          Für mich wäre es super wenn die Umschaltung zwischen Tag- und Nachthelligkeit über entsprechende Astrozeiten zu steuern wären.
                          zB: Tagwert-->bei sunriseEnd, goldenhourEnd,..., Nachtwert --> bei sunsetStart , sunset,...
                          Natürlich könnte man das auch per Script lösen, aber wenn schon eine Zeitsteuerung eingebaut ist 😉
                          • Issi
                            Issi Developer @Issi last edited by Issi
                            @JohGre
                            wie ich schon weiter oben sagte werde ich das auf die liste setzen da ich da erst schauen muss wie genau ich das einbaue da ich z.B. nicht nach der Astrozeiten eingestellt habe
                            • Issi
                              Issi Developer last edited by
                              so neue Version 0.2.5 ist auf GitHub verfügbar:
                              hab den FullyBrowser Adapter implementiert und paar bugs behoben
                              siggi85 1 Reply Last reply Reply Quote 0
                              • siggi85
                                siggi85 @Issi last edited by siggi85
                                @Issi Erste Tests sehen gut aus. Durch die Kommandos wäre es mir jetzt wirklich möglich den alten Fully Adapter mit diesem zu ersetzen. Da dieser noch in Entwicklung ist, ware ich aber noch etwas damit. Schon Mal danke für die Arbeit an diesem Adapter! 👍
                                EDIT: Etwas zu früh gefreut. 😉 habe ein paar Fehler im Log:
                                fully-tablet-control.0	2020-05-17 08:04:48.267	warn	(20790) Wohnzimmer charger not specified
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6814:25)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7117:22)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.emit (events.js:198:13)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.onReady (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:92:14)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	at FullyTabletControl.initialization (/opt/iobroker/node_modules/iobroker.fully-tablet-control/main.js:184:50)
                                fully-tablet-control.0	2020-05-17 08:04:45.829	error	(20790) [initialization] : Cannot read property 'enabledBrightness' of undefined, stack: TypeError: Cannot read property 'enabledBrightness' of undefined
                                Meine Konfiguration ist ganz simpel (Eintrag für Ladegerät habe ich gelöscht, ist das der Fehler?!)
                                  ich hab auch ..direkt nach neu installation und start..
                                  es sind nicht alle Datenpunkte gefüllt.. klar logisch. hab ja nur die erste seite gefüllt.. also nur die ip eingetragen
                                  muttu abfangen
                                  das warning würde ich auch abschalten. oder schaltbar machen.. mehr Infos weniger infos.
                                  ich will es nicht nutzen.. und so bekomme ich ständig das warning ..
                                  hier währe eigener Datenpunkt nützlich.. ich stuere meine helligkeit abhängig vom aussen Helligkeitsensor
                                  mit Schwellwert (als Anregung)
                                  ansonsten TOP..
                                  • Issi
                                    Issi Developer @arteck last edited by
                                    @arteck @siggi85
                                    @arteck sagte in [Tablet Control] Tablet Steuerung möchte getestet werden:
                                    muttu abfangen
                                    die Ladefunktion kan man ganz abschalten dan kommt auch kein warning im log
                                    das mit dem error hab ich zwar schon was drin zum abfangen und in den test hat es funktioniert aber ich schau es mir noch mal an.
                                    hier währe eigener Datenpunkt nützlich.. ich steure meine helligkeit abhängig vom aussen Helligkeitsensor
                                    dafür gibt es auch ein eigenen Datenpunkt in den objekten
                                    Nr. 1 auf User einstellen und bei 2 kannst du die Helligkeit in 0% bis 100% einstehlen.
                                    dieser Funktion sorgt nur das der Bildschirm nicht ausgeschaltet werden kann über den Knopf am Tablett oder automatisch da manche Tabletts die Wlan Verbindung abschalten wen der Bildschirm länger ausgeschaltet ist.
                                    PS. hab glaub das Problem mit den error gefunden werde es beheben und dann bescheid sagen
                                    • Issi
                                      so hab nun die Helligkeitssteuerung etwas angepasst jetzt kann man sie komplett auf manuelle Steuerung oder auf zeit + manuell einstellen
                                      wenn sie über Nr.10 die Steuerung auf manuell geschaltet haben braucht man keine Tabelle unten erstellen
                                      wenn sie es auf Konfigurationsseite geschaltet haben MUSS die Tabelle angelegt werden für jedes Tablet das auf der Login Seite erstellt wurde wer bei einem oder mehreren Tabletts die zeit Steuerung nicht nutzen will kann über die Nr. 8 auf manuell Steuerung schalten nur für dieses Tablett.
                                      die Version 0.2.6 ist auf GitHub verfügbar
                                      • Issi
                                        Issi Developer last edited by Issi
                                        neue Version 0.2.7 auf GitHub verfügbar:
                                        @JohGre @jackblackson Hab die Astro Funktion nun eingebaut hat etwas gedauert da es nicht so einfach ist wie z.B. über (getAstroDate) da getAstroDate eine unter Funktion vom JavaScript Adapter ist musste ich erst mal schauen wie ich das einbauen kann.
                                        unter Nr. 11 kann man jetzt entscheiden was für eine zeit Steuerung verwendet wird Standard ist Astro Zeit.
                                        unter 12 kommt die Astro Zeit für den Tages beginn rein als wann das Tablett hoch dimmen soll und unter 13 dann wann er ab dimmen soll.
                                        • JohGre
                                          @Issi Danke dafür, werd ich morgen gleichmal austesten.
                                          • Feuersturm
                                            Feuersturm last edited by Feuersturm
                                            Hallo @Issi , danke für deine Arbeit 🙂
                                            Ich habe mir gerade einmal den Adapter in der Version 0.2.7 installiert und spiele gerade mit der Ladesteuerung.
                                            Ich habe einen Homematic IP Aktor (HMIP-FSM) verbaut, welcher dafür sorgt, das das Tablet geladen wird oder nicht. Gesteuert wird das ganze über diesen Datenpunkt "hm-rpc.0.00089A4992EC3D.2.STATE"
                                            Wenn ich den Aktor über die Homematic WebUI einschalte und dann eine niedrigere Schwelle im Adapter einstelle als der aktuelle Ladestatus ist, dann wird der Aktor ausgeschaltet. Sieht somit gut aus.
                                            Wenn der Aktor ausgeschaltet ist und ich den Wert für "Ladestop" auf 90% setze (Akku hat aktuell 80%) und den Adapter neu starte, dann wird der Datenpunkt nicht auf true gesetzt und der HMIP Aktor bleibt aus.
                                            EDIT 23:37
                                            Auch wenn ich den Lademodus auf Dauerstrom schalte wird der HMIP Aktor (ist im Zustand Aus) nicht auf EIN geschaltet.
                                            adapter fully kiosk browser fullybrowser tablet tablet-control test testen
                                            50
                                            512
                                            80209
