    3. Entwicklung
    4. [Neuer Adapter] Xiaomi Luftfilter
    • Z
      zottel last edited by
      Hi, ich hab den 3H bekomme ihn aber nicht in den ioBroker ...
      miio.0	2020-03-13 15:20:12.571	info	(26954) 282466473 becomes unavailable.
      miio.0	2020-03-13 15:19:42.100	info	(26954) Create state object devices.282466473.illuminance
      miio.0	2020-03-13 15:19:42.100	info	(26954) Create state object devices.282466473.motor1Speed
      miio.0	2020-03-13 15:19:42.099	info	(26954) Create state object devices.282466473.filterUsedTime
      miio.0	2020-03-13 15:19:42.099	info	(26954) Create state object devices.282466473.filterLife
      miio.0	2020-03-13 15:19:42.099	info	(26954) Create state object devices.282466473.aqi
      miio.0	2020-03-13 15:19:42.099	info	(26954) Create state object devices.282466473.ledBrightnessLevel
      miio.0	2020-03-13 15:19:42.099	info	(26954) Create state object devices.282466473.buzzer
      miio.0	2020-03-13 15:19:42.099	info	(26954) Create state object devices.282466473.childLock
      miio.0	2020-03-13 15:19:42.098	info	(26954) Create state object devices.282466473.led
      miio.0	2020-03-13 15:19:42.098	info	(26954) Create state object devices.282466473.mode
      miio.0	2020-03-13 15:19:42.098	info	(26954) Create state object devices.282466473.power
      miio.0	2020-03-13 15:19:42.098	info	(26954) Create state object devices.282466473.model
      miio.0	2020-03-13 15:19:42.097	info	(26954) Create state object devices.282466473.connected
      miio.0	2020-03-13 15:19:42.092	info	(26954) New device: zhimi.airpurifier.mb3. ID 282466473
      miio.0	2020-03-13 15:19:42.031	info	(26954) new airpurifier device
      miio.0	2020-03-13 15:19:42.012	info	(26954) All defined devices are created
      miio.0	2020-03-13 15:19:41.995	info	(26954) 192.168.1.56 added.
      miio.0	2020-03-13 15:19:41.752	info	(26954) starting. Version 0.0.13 in /opt/iobroker/node_modules/iobroker.miio, node: v8.15.0
        paul.honka last edited by paul.honka
        ich bekomme den Xiaomiairpurifier Adapter nicht installiert.
        Installation über die Katze mit https://github.com/JoJ123/ioBroker.xiaomiairpurifier
        Dann passiert erstmal ne ganze Weile nichts,
        dann kommt im Log folgendes
        host.IOBroker-Sted1 2020-03-19 12:37:39.224 info iobroker exit 25
        host.IOBroker-Sted1 2020-03-19 12:37:38.211 error iobroker host.IOBroker-Sted1 Cannot install https://github.com/JoJ123/ioBroker.xiaomiairpurifier/tarball/eb7806dabcbcdb88d127c9f18fcd8af34357dc8a: null
        Im Adapterfenster steht folgendes
        Fertig mit Fehler: host.IOBroker-Sted1 Cannot install https://github.com/JoJ123/ioBroker.xiaomiairpurifier/tarball/eb7806dabcbcdb88d127c9f18fcd8af34357dc8a: null
        Ist der Link falsch oder was anderes?
        Beste Grüsse paul
          Kueppert @paul.honka last edited by Kueppert
          @paul-honka Warum gehst du über die Katze wenn du den Adapter über die AdapterListe installieren kannst?
            Hallo
            Über die Katze weil im ersten Beitrag so stand, das mit der Adapterliste habe ich wohl überlesen.
            Jetzt über die Adapterliste installiert. Wenn ich die Instanz über den Schraubenschlüssel
            öffne, kommt File index_m.html not found
            JS ist 2.2.9 , Admin ist 3.7.8
            Wat issen dat.
            Beste Grüsse paul
              @paul-honka ich hoffe, dir kann jmd helfen. Wenn ich mir die Historie beim Ersteller des Adapters anschaue, ist er nicht mehr (so) aktiv...
                haenk93 @derBonsaii last edited by
                @derBonsaii würde mich auch interessieren meiner kommt heute
                  haenk93 @zottel last edited by
                  @zottel Lösung gefunden ? Bekomme meinen heute
                  SpikeNbg 1 Reply Last reply Reply Quote 0
                  • SpikeNbg
                    SpikeNbg @haenk93 last edited by
                    @haenk93 Guten Morgen! Gibts Neuigkeiten bzw. Erfolge bei euch bezüglich des 3H?
                    Und bekommt ihr das 0.1.0 Update installiert? Bei mir versucht er zu installieren, bleibt aber auf der 0.0.6 Version stehen und zeigt das Update weiterhin an..
                      ChrisXY last edited by
                      stimmt funktioniert mit dem letzten Update das mit dem token auslesen wieder?
                        A Former User last edited by
                        Token kannste doch auf andere Wege auch auslesen. Mit der Mi Home App
                        iOS = iBackupViewer
                        Android habe ich nicht, sollte aber einfach sein.
                        https://www.smarthomeassistent.de/token-auslesen-roborock-s6-roborock-s5-xiaomi-mi-robot-xiaowa/
                        Bin jetzt Besitzer eines 2H. Würde auch bei Tests unterstützen und bei der Entwicklung helfen, wenn nötig/möglich.
                        • dontobi
                          dontobi last edited by
                          Hallo zusammen
                          Ich habe seit heute einen Air Purifier 2H und ich würde diesen gerne über den ioBroker steuern. Leider unterstützt der Adapter derzeit nur den 2 und den 2S.
                          Ich Frage mich, wie man dem Entwickler dabei helfen kann auch den 2H zu unterstützen?!?
                          Gruß und bleibt gesund.
                          Tobi
                            maxpd last edited by
                            Wie schaut's mit dem 3H?
                            Möchte ihn nach Fenster xschließen 10 min auf Hochtouren laufen lassen.
                            • dontobi
                              Es scheint so, dass die Entwicklung nicht mehr fortgesetzt wird.
                                Mooo @dontobi last edited by
                                @dontobi said in [Neuer Adapter] Xiaomi Luftfilter:
                                Hallo zusammen
                                Tobi
                                Hi schon mal eine ältere Adapterversion ausprobiert? Ich habe ein Purifier Pro und der funktioniert auch nicht.
                                Wenn ich allersings die 0.1.4 installiere kann ich ihn problemlos ansteuern.
                                dontobi 1 Reply Last reply Reply Quote 0
                                • dontobi
                                  dontobi @Mooo last edited by
                                  @Mooo Danke für den Hinweis. Mit der 0.1.4 kann ich meinen AirPurifier 2h steuern. Werde das im Github Issue mal dokumentieren. Jetzt muss ich nur schauen, wie ich das Updaten des Adapters unterbinden kann. Lasse einmal in der Woche die Adapter aktualisieren (per Commandozeile).
                                    MrLee @dontobi last edited by
                                    Moin,
                                    Gibt es Neuigkeiten bez. Des 3H?
                                    Irgendein weg den mit iobroker zu steuern?
                                    Liebe Grüße
                                    Mr.Lee
                                      Wildbill last edited by
                                      An alle, die einen Air purifier (bei mir der Air purifier 3H) haben, der nicht vom Adapter unterstützt wird ein kleiner Tipp, wie man die Daten doch in iobroker bekommt, ohne, dass man auf irgendein Update hier noch hoffen muss:
                                      1. Installiert den iobroker-Adapter mihome-vacuum
                                      2. Tragt dort Eure Kontodaten ein und lest die Geräte aus, schon habt ihr den Token vom Air Purifier
                                      3. Installiert Euch FHEM (als VM, als LXC, nativ auf Raspi oder sonstwie), wenn ihr es, wie ich, nicht eh schon laufen habt
                                      4. Richtet den Air Purifier in FHEM ein. Im FHEM-Forum ist alles beschrieben, das meiste gleich im ersten Thread. Wichtig: Wählt den richtigen subType, bei mir z.B. Airpurifier3H. IP-Adresse solltet ihr eh haben, den Token kopiert ihr aus dem mihome-vacuum-Adapter in iobroker
                                      5. Nach kurzer Zeit ist alles in FHEM eingerichtet und die Daten zu Filter, Status, 2.5ppm usw. tauchen auf
                                      6. Weisst in FHEM dem airpurifier den Raum iobroker zu. Das ist wichtig, da nur solche Geräte nach iobroker kommen. Macht man das nicht, hat man ALLES aus FHEM anschliessend in iobroker, braucht man nicht wirklich
                                      7. Installiert in iobroker den FHEM-Adapter, tragt dort die nötigen Daten ein und schon habt ihr den Air Purifier in iobroker.
                                      Ob zur Verbindung FHEM-iobroker zusätzliche Dinge nötig sind, weiss ich nicht, läuft bei mir seit Jahren. Im Zweifel steht das sicher beim FHEM-Adapter in iobroker irgendwo.
                                      Viel Erfolg.
                                      Gruss, Jürgen
                                      M K 2 Replies Last reply Reply Quote 1
                                        MrLee @Wildbill last edited by
                                        Moin!
                                        Klasse tip...ich bin einen anderen weg gegangen.
                                        Habe den homebridge adapter installiert und dieses plugin geladen:
                                        https://github.com/rgavril/homebridge-xiaomi-air-purifier3#readme
                                        Habe damit Zugriff auf den Ventilator.
                                        Leider kann ich nur zwischen auto und manual umschalten.
                                        Die direkte Steuerung des Ventialators funktioniert leider nicht. Sehe die aktuelle Drehzahl in % aber leider kann ich diese nicht ändern.
                                        Hat jemand diesen Weg probiert?
                                        Mr.Lee
                                          kamikazemimmi @Wildbill last edited by
                                          @Wildbill weißt du noch mit welcher Version du das gemacht hast ? Und du hast wahrscheinlich einen Acc in der Mii Home App erstellt ?! Wir versuchen gerade den Token unserer Mi Air Puriffer 2H auszulesen... Mein Mann hat sich allerdings in der Mi Home App mit seinen Apple-Daten angemeldet.. Fürchte, dass es hierfür dann nicht klappen wird.
                                          Danke und Gruß
                                            kamikazemimmi @kamikazemimmi last edited by
                                            @kamikazemimmi ok - also für die Xiaomi App haben wir Acc erstellt und token wurde angezeigt. Hatten jetzt versucht damit versucht die mihome-plug zu füttern, aber unser Purifier 2H lässt sich leider nicht ansteuern...
                                            Den Weg über FHEM finde ich etwas umständlich...Kennt noch jemand einen Weg ?
                                            Danke und Gruß
                                            188
                                            27993
