    4. HS100 Adapter Fehlermeldungen
    UNSOLVED HS100 Adapter Fehlermeldungen
      Berchemer last edited by
      In 17 Stunden insgesamt 5 Fehler. Immer die Gleichen, wie unten angegeben 😢
      2020-05-13 02:29:16.795 - debug: hs100.0 (15163) HS Plug 192.1.1.132
      2020-05-13 02:29:16.797 - debug: hs100.0 (15163) HS Plug 192.1.1.131
      2020-05-13 02:29:17.044 - debug: hs100.0 (15163) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 02:29:17
      2020-05-13 02:29:17.124 - debug: hs100.0 (15163) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 02:29:17
      2020-05-13 02:29:18.206 - debug: hs100.0 (15163) Refresh Data HS110 192.1.1.131
      2020-05-13 02:29:18.287 - debug: hs100.0 (15163) Refresh Data HS110 192.1.1.132
      2020-05-13 02:29:19.078 - debug: hs100.0 (15163) Month value Model : HS110(EU) IP : 192.1.1.131
      2020-05-13 02:29:19.163 - debug: hs100.0 (15163) Month value Model : HS110(EU) IP : 192.1.1.132
      2020-05-13 02:29:19.513 - debug: hs100.0 (15163) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
      2020-05-13 02:29:19.594 - debug: hs100.0 (15163) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.132
      2020-05-13 02:31:16.799 - debug: hs100.0 (15163) HS Plug 192.1.1.132
      2020-05-13 02:31:16.800 - debug: hs100.0 (15163) HS Plug 192.1.1.131
      2020-05-13 02:31:17.086 - debug: hs100.0 (15163) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 02:31:17
      2020-05-13 02:31:17.121 - debug: hs100.0 (15163) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 02:31:17
      2020-05-13 02:31:18.249 - debug: hs100.0 (15163) Refresh Data HS110 192.1.1.131
      2020-05-13 02:31:19.120 - debug: hs100.0 (15163) Month value Model : HS110(EU) IP : 192.1.1.131
      2020-05-13 02:31:19.556 - debug: hs100.0 (15163) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
      2020-05-13 02:31:23.103 - error: hs100.0 (15163) uncaught exception: TCP Socket Closed. segment:0 hadError:false
      2020-05-13 02:31:23.103 - error: hs100.0 (15163) Error: TCP Socket Closed. segment:0 hadError:false
      at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
      at Object.onceWrapper (events.js:417:26)
      at Socket.emit (events.js:310:20)
      at TCP. (net.js:672:12)
      2020-05-13 02:31:23.104 - debug: hs100.0 (15163) Error getDevice192.1.1.131
      2020-05-13 02:31:23.106 - info: hs100.0 (15163) terminating
      2020-05-13 02:31:23.106 - info: hs100.0 (15163) Terminated (NO_ERROR): Without reason
      2020-05-13 02:31:23.617 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
      2020-05-13 02:31:23.617 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at Socket.emit (events.js:310:20)
      2020-05-13 02:31:23.618 - error: host.SERVER Caught by controller[2]: at TCP. (net.js:672:12)
      2020-05-13 02:31:23.618 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
      2020-05-13 02:31:23.618 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
      2020-05-13 02:31:53.638 - info: host.SERVER instance system.adapter.hs100.0 started with pid 27783
      2020-05-13 02:31:53.893 - debug: hs100.0 (27783) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2020-05-13 02:31:53.903 - debug: hs100.0 (27783) Objects client ready ... initialize now
      2020-05-13 02:31:53.903 - debug: hs100.0 (27783) Objects create System PubSub Client
      2020-05-13 02:31:53.904 - debug: hs100.0 (27783) Objects create User PubSub Client
      2020-05-13 02:31:53.904 - debug: hs100.0 (27783) Objects client initialize lua scripts
      2020-05-13 02:31:53.912 - debug: hs100.0 (27783) Objects connected to redis: 0.0.0.0:9001
      2020-05-13 02:31:53.915 - debug: hs100.0 (27783) objectDB connected
      2020-05-13 02:31:53.916 - debug: hs100.0 (27783) Redis States: Use Redis connection: 0.0.0.0:9000
      2020-05-13 02:31:53.920 - debug: hs100.0 (27783) States create User PubSub Client
      2020-05-13 02:31:53.920 - debug: hs100.0 (27783) States create System PubSub Client
      2020-05-13 02:31:53.928 - debug: hs100.0 (27783) States connected to redis: 0.0.0.0:9000
      2020-05-13 02:31:53.928 - debug: hs100.0 (27783) statesDB connected
      2020-05-13 02:31:54.074 - info: hs100.0 (27783) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
      2020-05-13 02:31:54.081 - debug: hs100.0 (27783) Host = SERVER
      2020-05-13 02:31:54.102 - debug: hs100.0 (27783) create state
      2020-05-13 02:31:54.104 - debug: hs100.0 (27783) undefined generated 192.1.1.131
      2020-05-13 02:31:54.105 - debug: hs100.0 (27783) create state
      2020-05-13 02:31:54.105 - debug: hs100.0 (27783) undefined generated 192.1.1.132
      2020-05-13 02:31:54.260 - debug: hs100.0 (27783) HS Plug 192.1.1.132
      2020-05-13 02:31:54.261 - debug: hs100.0 (27783) HS Plug 192.1.1.131
      2020-05-13 02:31:54.426 - debug: hs100.0 (27783) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 02:31:54
      2020-05-13 02:31:54.717 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.132
      2020-05-13 02:31:55.152 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.132
      2020-05-13 02:31:55.418 - debug: hs100.0 (27783) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 02:31:55
      2020-05-13 02:31:56.000 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.131
      2020-05-13 02:31:56.314 - debug: hs100.0 (27783) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.132
      2020-05-13 02:31:57.017 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.131
      2020-05-13 02:31:57.452 - debug: hs100.0 (27783) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
      2020-05-13 05:13:54.499 - debug: hs100.0 (27783) HS Plug 192.1.1.132
      2020-05-13 05:13:54.500 - debug: hs100.0 (27783) HS Plug 192.1.1.131
      2020-05-13 05:13:54.681 - debug: hs100.0 (27783) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 05:13:54
      2020-05-13 05:13:55.843 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.131
      2020-05-13 05:13:56.715 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.131
      2020-05-13 05:13:57.150 - debug: hs100.0 (27783) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
      2020-05-13 05:14:00.827 - debug: hs100.0 (27783) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 05:14:00
      2020-05-13 05:14:01.989 - debug: hs100.0 (27783) Refresh Data HS110 192.1.1.132
      2020-05-13 05:14:02.861 - debug: hs100.0 (27783) Month value Model : HS110(EU) IP : 192.1.1.132
      2020-05-13 05:14:12.864 - error: hs100.0 (27783) uncaught exception: TCP Timeout
      2020-05-13 05:14:12.865 - error: hs100.0 (27783) Error: TCP Timeout
      at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
      at listOnTimeout (internal/timers.js:549:17)
      at processTimers (internal/timers.js:492:7)
      2020-05-13 05:14:12.866 - info: hs100.0 (27783) terminating
      2020-05-13 05:14:12.867 - info: hs100.0 (27783) Terminated (NO_ERROR): Without reason
      2020-05-13 05:14:13.385 - error: host.SERVER Caught by controller[0]: TCP 192.1.1.132:9999 Error: TCP Timeout
      2020-05-13 05:14:13.386 - error: host.SERVER Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
      2020-05-13 05:14:13.386 - error: host.SERVER Caught by controller[0]: at listOnTimeout (internal/timers.js:549:17)
      2020-05-13 05:14:13.386 - error: host.SERVER Caught by controller[0]: at processTimers (internal/timers.js:492:7)
      2020-05-13 05:14:13.386 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
      2020-05-13 05:14:13.386 - info: host.SERVER Restart adapter system.adapter.hs100.0 because enabled
      2020-05-13 05:14:43.410 - info: host.SERVER instance system.adapter.hs100.0 started with pid 24105
      2020-05-13 05:14:43.590 - debug: hs100.0 (24105) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2020-05-13 05:14:43.600 - debug: hs100.0 (24105) Objects client ready ... initialize now
      2020-05-13 05:14:43.602 - debug: hs100.0 (24105) Objects create System PubSub Client
      2020-05-13 05:14:43.602 - debug: hs100.0 (24105) Objects create User PubSub Client
      2020-05-13 05:14:43.602 - debug: hs100.0 (24105) Objects client initialize lua scripts
      2020-05-13 05:14:43.611 - debug: hs100.0 (24105) Objects connected to redis: 0.0.0.0:9001
      2020-05-13 05:14:43.612 - debug: hs100.0 (24105) objectDB connected
      2020-05-13 05:14:43.613 - debug: hs100.0 (24105) Redis States: Use Redis connection: 0.0.0.0:9000
      2020-05-13 05:14:43.618 - debug: hs100.0 (24105) States create User PubSub Client
      2020-05-13 05:14:43.619 - debug: hs100.0 (24105) States create System PubSub Client
      2020-05-13 05:14:43.626 - debug: hs100.0 (24105) States connected to redis: 0.0.0.0:9000
      2020-05-13 05:14:43.626 - debug: hs100.0 (24105) statesDB connected
      2020-05-13 05:14:43.788 - info: hs100.0 (24105) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.hs100, node: v12.16.3, js-controller: 3.0.20
      2020-05-13 05:14:43.795 - debug: hs100.0 (24105) Host = SERVER
      2020-05-13 05:14:43.823 - debug: hs100.0 (24105) create state
      2020-05-13 05:14:43.824 - debug: hs100.0 (24105) undefined generated 192.1.1.131
      2020-05-13 05:14:43.825 - debug: hs100.0 (24105) create state
      2020-05-13 05:14:43.826 - debug: hs100.0 (24105) undefined generated 192.1.1.132
      2020-05-13 05:14:44.060 - debug: hs100.0 (24105) HS Plug 192.1.1.132
      2020-05-13 05:14:44.061 - debug: hs100.0 (24105) HS Plug 192.1.1.131
      2020-05-13 05:14:45.369 - debug: hs100.0 (24105) Refresh 192.1.1.131 Model = HS110(EU) state = true update = 2020.5.13 05:14:45
      2020-05-13 05:14:46.087 - debug: hs100.0 (24105) Refresh Data HS110 192.1.1.131
      2020-05-13 05:14:47.249 - debug: hs100.0 (24105) Month value Model : HS110(EU) IP : 192.1.1.131
      2020-05-13 05:14:47.685 - debug: hs100.0 (24105) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.131
      2020-05-13 05:14:48.934 - debug: hs100.0 (24105) Refresh 192.1.1.132 Model = HS110(EU) state = true update = 2020.5.13 05:14:48
      2020-05-13 05:14:51.260 - debug: hs100.0 (24105) Refresh Data HS110 192.1.1.132
      2020-05-13 05:14:52.131 - debug: hs100.0 (24105) Month value Model : HS110(EU) IP : 192.1.1.132
      2020-05-13 05:14:52.567 - debug: hs100.0 (24105) Day value for Model : HS110(EU) Energy : 0 IP : 192.1.1.132
        skokarl @Berchemer last edited by
        @Berchemer sagte in HS100 Adapter Fehlermeldungen:
        @skokarl
        Ok, ok, ok... 😉
        Versuche es mal morgen, wenn ich mehr Zeit und Muße habe 🙂
        Habe jetzt mal beide Steckdosen vertauscht.
        Die aus der Küche im Erdgeschoss ins Schlafzimmer im Obergeschoss und umgekehrt.
        Alles neu gestartet, aber noch js-controller 3.1.4
        Mal schauen, was das System bis morgen sagt 🙂
        wichtig ist ja nur ob die Streckdose die gleiche bleibt, dann ist es vermutlich echt die Dose.
          Berchemer @skokarl last edited by
          @skokarl sagte in HS100 Adapter Fehlermeldungen:
          Mag sein. Wobei in der Vergangenheit der Fehler auch mal von der .132er Steckdose ausgelöst wurde.
          Und ansonsten funktioniert die Dose ja eigentlich. Zumindest was das Schalten angeht.
          Müsste man den Fehler nicht trotzdem abfangen können/müssen und statt dessen ggf. mit einer Warnmeldung versehen?
          Wodurch kommt eigentlich so ein Timeout zustande? Der Adapter erwartet eine Meldung von der Steckdose. Diese bleibt aus und dann kommt ein Timeout oder? Bei schlechten WLAN könnte so etwas immer mal wieder auftauchen und sollte eigentlich nicht zu einem Abbruch der API mit einem Fehler führen. Meine ich zumindest.
          Nicht dass ich an der Stecke klebe...
          Wenn die weiter muckt, wird sie durch eine innr ersetzt und gut ist 😉
            arteck Developer Most Active @Berchemer last edited by arteck
            @Berchemer nicht der Adapter erwartet dieRrückmeldung sondern die Zwischenschicht.. auf der baut der Adapter auf ..
            hier knallts
              Berchemer @arteck last edited by Berchemer
              @arteck sagte in HS100 Adapter Fehlermeldungen:
              hier knallts
              Yeppp. Ist mir schon klar. Meinte ich ja auch mit
              " ... nicht zu einem Abbruch der API mit einem Fehler führen."
              Oder sollte man statt API eher Socket sagen?
              Ist wohl so, dass Du vielleicht doch ein Issue bei dem API-Ersteller (oder so) machen solltest.
              Wenn nicht schon geschehen 😉
              Danke auch dafür 🙂 👍
                Berchemer last edited by Berchemer
                Habe den .131'er seit 23 Stunden offline.
                Zwischendurch gab es auch mal einen Neustart des Servers.
                Keine Fehlermeldung seither.
                Warte aber lieber bis morgen 🙂
                S B 2 Replies Last reply Reply Quote 0
                  @Berchemer
                  offline ?
                  ist das jetzt ein gutes oder schlechtes Zeichen ?
                    Berchemer @Berchemer last edited by
                    Keine Fehlermeldungen mehr 🙂
                      Habe die Stecke also erst einmal außer Betrieb genommen und durch eine innr ersetzt.
                      Hebe sie jedoch noch auf, um ggf. bei einer Änderung der API/Socket erneut überprüfen zu können, ob der Fehler abgefangen wird.
                      @arteck Ok???
                        @Berchemer
                        was hat der für ein HW und Software Version ?
                        Ich hab z.b. HW 1 und HW 2
                          Berchemer @skokarl last edited by Berchemer
                          @skokarl
                          Du stellst Fragen 😉
                          Ich schaue nochmal nach...
                          Beide haben HW 2.0 und bei beiden ist die Firmware die als Aktuellste über die App angebotene (1.5.6 Build 191125 Rel 083657).
                          Und wo wir gerade dabei sind. Seitdem ich den .131er abgestöpselt hatte, gab es keine Fehlermeldungen...
                          Bis gerade eben. Da hat sich der .132er gemeldet 😞
                          Da ich das Debuggen in den Log abgestellt hatte, hier nur ein kurzer Auszug aus dem Log:
                          2020-05-15 09:45:54.706 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2020-05-15 09:45:54.706 - error: hs100.0 (5402) unhandled promise rejection: TCP Socket Closed. segment:0 hadError:false
                          2020-05-15 09:45:54.706 - error: hs100.0 (5402) Error: TCP Socket Closed. segment:0 hadError:false
                          2020-05-15 09:45:54.708 - info: hs100.0 (5402) terminating
                          2020-05-15 09:45:54.709 - info: hs100.0 (5402) Terminated (NO_ERROR): Without reason
                          2020-05-15 09:45:55.226 - error: host.SERVER Caught by controller[1]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[1]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[1]: at Object.onceWrapper (events.js:417:26)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[1]: at Socket.emit (events.js:310:20)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[1]: at TCP. (net.js:672:12)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[2]: TCP 192.1.1.132:9999 Error: TCP Socket Closed. segment:0 hadError:false
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[2]: at Socket.emit (events.js:310:20)
                          2020-05-15 09:45:55.228 - error: host.SERVER Caught by controller[2]: at TCP. (net.js:672:12)
                          2020-05-15 09:45:55.228 - info: host.SERVER instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
                            Übrigens zur Ergänzung:
                            Ich habe seit gestern früh auch den ganz aktuellen js-controller installiert. Müsste der 3.1.4er sein.
                              @Berchemer
                              hattest du die 132 gerade geschaltet ?
                              oder kam der Fehler jetzt weil Du die 131 wieder kurz am Netz hattest ? ( wg mir,....sorry )
                                @skokarl
                                Nö...
                                Die .131er liegt noch in der Dose und es gibt kein Skript, was versuchen würde die .132er, die ja jetzt wieder den Fehler bringt, an- oder auszuschalten.
                                Die HW hatte ich noch in Erinnerung und insbesondere noch im Datenpunkt der .131er 😉
                                Einfach strange...
                                  PatrickFro last edited by
                                  Moin zusammen,
                                  hab gestern den js-controller (3.1.4) und HS100 (1.1.5) upgedatet, seitdem habe ich regelmäßig Fehler:
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[5]: at processTimers (internal/timers.js:492:7)
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[5]: at listOnTimeout (internal/timers.js:549:17)
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[5]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[5]: TCP 192.168.178.69:9999 Error: TCP Timeout
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[4]: at processTimers (internal/timers.js:492:7)
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[4]: at listOnTimeout (internal/timers.js:549:17)
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[4]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                  host.Linux	2020-05-31 12:28:36.606	error	Caught by controller[4]: TCP 192.168.178.69:9999 Error: TCP Timeout
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[3]: at processTimers (internal/timers.js:492:7)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[3]: at listOnTimeout (internal/timers.js:549:17)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[3]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[3]: TCP 192.168.178.69:9999 Error: TCP Timeout
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[2]: at processTimers (internal/timers.js:492:7)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[2]: at listOnTimeout (internal/timers.js:549:17)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[2]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[2]: TCP 192.168.178.69:9999 Error: TCP Timeout
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[1]: at processTimers (internal/timers.js:492:7)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
                                  host.Linux	2020-05-31 12:28:36.605	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                  host.Linux	2020-05-31 12:28:36.604	error	Caught by controller[1]: TCP 192.168.178.69:9999 Error: TCP Timeout
                                  hs100.0	2020-05-31 12:28:36.084	info	(25975) Terminated (NO_ERROR): Without reason
                                  hs100.0	2020-05-31 12:28:36.084	info	(25975) terminating
                                  hs100.0	2020-05-31 12:28:36.078	error	(25975) Error: TCP Timeout at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22) at listOnTimeout (internal/timers.js:549:17) at processTi
                                  hs100.0	2020-05-31 12:28:36.078	error	(25975) unhandled promise rejection: TCP Timeout
                                  hs100.0	2020-05-31 12:28:36.078	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[2]: at TCP.<anonymous> (net.js:672:12)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[2]: at Socket.emit (events.js:310:20)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[2]: at Object.onceWrapper (events.js:417:26)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[2]: at Socket.<anonymous> (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[2]: TCP 192.168.178.52:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[1]: at processTimers (internal/timers.js:492:7)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[1]: at listOnTimeout (internal/timers.js:549:17)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[1]: at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:62:22)
                                  host.Linux	2020-05-31 12:30:20.987	error	Caught by controller[1]: TCP 192.168.178.69:9999 Error: TCP Timeout
                                  Teils startet der Adapter nicht erneut. Schalten kann ich aber noch jede Dose.
                                  • Negalein
                                    Negalein Global Moderator @PatrickFro last edited by Negalein
                                    @PatrickFro sagte in HS100 Adapter Fehlermeldungen:
                                    HS100 1.1.6
                                    bei mir auch seit JS-Controller 3.1.4
                                    Heute 12:06	error	host.iobroker	Caught by controller[0]: TCP 10.0.1.79:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                    Heute 12:06	error	hs100.0	Error: TCP Socket Closed. segment:0 hadError:false at Socket.socket.once.hadError (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19) at Object.onceWrapper (events.js:286:20) at Socket.emit (events.js:198:13) at TCP._handle.close (net.js:607:12)
                                    Heute 12:06	error	hs100.0	unhandled promise rejection: TCP Socket Closed. segment:0 hadError:false
                                    Heute 12:06	error	hs100.0	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    Heute 12:04	error	host.iobroker	Caught by controller[1]: TCP 10.0.1.80:9999 Error: TCP Socket Closed. segment:0 hadError:false
                                    Heute 12:04	error	hs100.0	Error: TCP Socket Closed. segment:0 hadError:false at Socket.socket.once.hadError (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:113:19) at Object.onceWrapper (events.js:286:20) at Socket.emit (events.js:198:13) at TCP._handle.close (net.js:607:12)
                                    Heute 12:04	error	hs100.0	unhandled promise rejection: TCP Socket Closed. segment:0 hadError:false
                                    Heute 12:04	error	hs100.0	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      sigi234 Forum Testing Most Active @Negalein last edited by
                                      @Negalein sagte in HS100 Adapter Fehlermeldungen:
                                      Habe 1.1.6
                                      JS 3.1.4
                                      Keine Fehler
                                        stenmic last edited by
                                        Bei mir sind ebenfalls die Fehlermeldung im Log vorhanden nach dem JS update.
                                        v1.1.6
                                        JS 3.1.4
                                        • Negalein
                                          Negalein Global Moderator @stenmic last edited by
                                          @stenmic sagte in HS100 Adapter Fehlermeldungen:
                                          Ich hab mal ein Issue eröffnet
                                            da kann ich nix machen.. da scheint eine Dose nicht zu antworten und läuft auf timeout..
                                            und die Abhängigkeit wirft ein Error
                                            im Adapter ist alles abgefangen an Errors was geht..
                                            Probiert mal
                                            die Datei /opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js zu Editieren und auszukommentieren
                                            hier
                                            und hier
                                            adapter neu starten nicht vergessen
                                            fehler im log hs100 adapter
                                            23
                                            190
                                            19711
