    4. Test Adapter mihome-vacuum v2.0.x
      A Former User @Coffeelover last edited by
      @Coffeelover sagte in Test Adapter mihome-vacuum v2.0.x:
      Gibt es denn jemanden hier, bei dem die Karte gerade funktioniert?
      NPM 6.14.x
      NodeJs V12.x
      VG
      ja, hier 🙂
      • Diginix
        Diginix @Coffeelover last edited by Diginix
        @Coffeelover Bei mir funktioniert die Karte auch mit Modell 1S.
        Adapter 2.0.9
        JS-Controller 3.1.4
        nodejs 10.20.1
          eXectiX last edited by
          @Coffeelover Bei mir funktioniert die Karte ebenso über cloud
          Adapter 2.0.9
          JS-Controller 3.1.4
          nodejs 12.16.3
          Roborock S6
            Kueppert last edited by Kueppert
            Gibts das? bei misch net 😕
            Adapter 2.0.9
            JS-COntroller 3.1.4
            nodejs 12.16.3
            Roborock v1 New generation or new fw(3.5.4,004007) detected
            Lasse gerade den Adapter im Debug laufen. Wenn ich das richtig lese, findet der Mappointer irgendwas. Aber das Objekt für die Map unter Objekte wird bei mir nicht aktualisiert (letztes Update 26.02.2020):
            mihome-vacuum.0	2020-05-14 15:19:37.956	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2171,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
            mihome-vacuum.0	2020-05-14 15:19:37.955	debug	(30087) Receive <<< {"partner_id":"","id":62,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-47},"netif":{"local
            mihome-vacuum.0	2020-05-14 15:19:37.948	debug	(30087) Next WiFi check: 14.05 15:20
            mihome-vacuum.0	2020-05-14 15:19:37.948	debug	(30087) sendMsg[1] >>> {"id":62,"method":"miIO.info"}
            mihome-vacuum.0	2020-05-14 15:19:37.947	debug	(30087) sendMsg[1] >>> {"id":61,"method":"get_status"}
            mihome-vacuum.0	2020-05-14 15:19:17.954	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2170,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
            mihome-vacuum.0	2020-05-14 15:19:17.946	debug	(30087) sendMsg[1] >>> {"id":60,"method":"get_status"}
            mihome-vacuum.0	2020-05-14 15:18:57.952	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2169,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
            mihome-vacuum.0	2020-05-14 15:18:57.944	debug	(30087) sendMsg[1] >>> {"id":59,"method":"get_status"}
            mihome-vacuum.0	2020-05-14 15:18:37.950	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2168,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
            mihome-vacuum.0	2020-05-14 15:18:37.949	debug	(30087) Receive <<< {"partner_id":"","id":58,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-47},"netif":{"local
            mihome-vacuum.0	2020-05-14 15:18:37.943	debug	(30087) Next WiFi check: 14.05 15:19
            mihome-vacuum.0	2020-05-14 15:18:37.943	debug	(30087) sendMsg[1] >>> {"id":58,"method":"miIO.info"}
            mihome-vacuum.0	2020-05-14 15:18:37.942	debug	(30087) sendMsg[1] >>> {"id":57,"method":"get_status"}
            mihome-vacuum.0	2020-05-14 15:18:17.946	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2167,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
            mihome-vacuum.0	2020-05-14 15:18:17.940	debug	(30087) sendMsg[1] >>> {"id":56,"method":"get_status"}
            mihome-vacuum.0	2020-05-14 15:17:57.951	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2166,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
            mihome-vacuum.0	2020-05-14 15:17:57.940	debug	(30087) sendMsg[1] >>> {"id":55,"method":"get_status"}
            mihome-vacuum.0	2020-05-14 15:17:53.089	debug	(30087) system.adapter.admin.0: logging true
            mihome-vacuum.0	2020-05-14 15:17:52.649	debug	(30087) Mappointer_updated
            mihome-vacuum.0	2020-05-14 15:17:52.649	debug	(30087) Receive <<< {"result":["roboroommap%2F82487762%2F12"],"id":54}
            mihome-vacuum.0	2020-05-14 15:17:52.643	debug	(30087) 1. Mappointer_nomap___retry
            mihome-vacuum.0	2020-05-14 15:17:52.642	debug	(30087) sendMsg[1] >>> {"id":54,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-14 15:17:52.140	debug	(30087) Receive <<< {"result":["retry"],"id":53}
            mihome-vacuum.0	2020-05-14 15:17:52.135	debug	(30087) 0. Mappointer_nomap___retry
            mihome-vacuum.0	2020-05-14 15:17:52.134	debug	(30087) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
            mihome-vacuum.0	2020-05-14 15:17:51.633	debug	(30087) Receive <<< {"result":["retry"],"id":52}
            mihome-vacuum.0	2020-05-14 15:17:51.628	debug	(30087) sendMsg[1] >>> {"id":52,"method":"get_map_v1"}
              Hyperbit last edited by
              Adapter 2.0.9
              JS-Controller 2.2.9 (warum habt ihr eigentlich da ne Version 3.x?)
              Node 10.20.1
              Roborock V1
              Die Map geht bei mir auch nach ```
              curl -sL http://iobroker.net/fix.sh | bash -
                dirkhe Developer @MattinK last edited by
                @MattinK das sind 2 verschiedene Clouds, glaube ich. Soweit ich weiss, muss man den robbi sogar zurücksetzen, wenn man die App wechselt, bin aber nicht 100% sicher. Ich weiss auch nicht, ob die Karte von der roborock Cloud abgerufen werden kann.
                  dirkhe Developer last edited by
                  Es könnte aber auch eine Frage der robbi Firmware sein. Da wurde doch jetzt mehretagenreinigung implementiert, kann es sein, dass dass sich die API da geändert hat?
                  • Diginix
                    Diginix @Hyperbit last edited by
                    @Hyperbit sagte in Test Adapter mihome-vacuum v2.0.x:
                    Weil der JS-Controller im latest repo bereits auf Version 3 ist. Vermutlich bist du auf stable und da ist es noch die 2.2.9.
                      Also bei mir Funktioniert es wieder.
                      Kann jedoch nicht sagen welche Lösung ich genau angewendet habe.
                      Ich habe folgende schritte gemacht:
                      • JS-Controller von 2.2.8 auf 2.2.9 geupdatet
                      • in Putty folgenden befehl abgesetzt
                      • IOBroker nochmal neustarten
                      • Ruud2019
                        Ruud2019 last edited by Ruud2019
                        @dirkhe
                        Hi, erstmal vielen Dank für diesen tollen Adapter!
                        Ich habe einen Roborock S5 mit Valetudo RE.
                        Leider funktioniert dort der DP des Wassertanks nicht. Dieser steht dauerhaft auf false.
                        Ist das schon bekannt oder funktioniert das mit dem S5 nicht?
                        D Meistertr 2 Replies Last reply Reply Quote 0
                          dirkhe Developer @Ruud2019 last edited by
                          @Ruud2019 bei meinem s6 funktioniert der wassertank. Müssen wir dann mal schauen, ob der bei dir anders übertragen wird. Du könntest mal auf Trace stellen und den Wassertank rausnehmen und wieder reinpacken. Aber denke daran, dass die Statusabfrage je nach Einstellungen etwas dauert
                          • Meistertr
                            Meistertr Developer @Ruud2019 last edited by
                            @Ruud2019 der S5 unterstützt das noch nicht
                              seppel786 last edited by
                              Hi zusammen,
                              ich habe heute den Standardadapter Version 1.1.5 nun auf die Version 2.0.9 geupdated.
                              Soweit so gut...Die States werden mir in den Objekten richtig dargestellt.
                              Nur im Ordner map bleiben alle Felder leer. Valetudo ist soweit im Adapter aktiviert und liefert in der App auch die Map.
                              Anbei noch das Log zum Adapter:
                              mihome-vacuum.0	2020-05-16 17:39:38.730	warn	(26286) Could not receive Mappointer, giving up
                              mihome-vacuum.0	2020-05-16 17:30:48.293	info	(26286) set nächster Timer: Nicht verfügbar
                              mihome-vacuum.0	2020-05-16 17:30:47.854	info	(26286) Connected
                              mihome-vacuum.0	2020-05-16 17:30:47.835	info	(26286) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:30:47.807	info	(26286) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                              mihome-vacuum.0	2020-05-16 17:30:47.785	info	(26286) Cloud control disabled
                              mihome-vacuum.0	2020-05-16 17:30:47.784	info	(26286) Expert mode enabled, states created
                              mihome-vacuum.0	2020-05-16 17:30:47.759	info	(26286) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                              mihome-vacuum.0	2020-05-16 17:30:44.975	info	(26226) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              mihome-vacuum.0	2020-05-16 17:30:44.975	info	(26226) terminating
                              mihome-vacuum.0	2020-05-16 17:30:44.975	info	(26226) Got terminate signal TERMINATE_YOURSELF
                              mihome-vacuum.0	2020-05-16 17:28:20.841	warn	(26226) Could not receive Mappointer, giving up
                              mihome-vacuum.0	2020-05-16 17:28:15.541	info	(26226) create state for carpet_mode
                              mihome-vacuum.0	2020-05-16 17:28:14.535	info	(26226) Connected
                              mihome-vacuum.0	2020-05-16 17:28:09.516	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:27:49.515	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:27:29.517	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:27:09.515	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:26:49.527	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:26:29.513	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:26:09.512	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:25:49.510	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:25:29.508	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:25:09.508	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:24:50.890	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:24:30.010	info	(26226) set nächster Timer: Nicht verfügbar
                              mihome-vacuum.0	2020-05-16 17:24:29.551	info	(26226) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:24:29.525	info	(26226) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                              mihome-vacuum.0	2020-05-16 17:24:29.499	info	(26226) Cloud control disabled
                              mihome-vacuum.0	2020-05-16 17:24:29.499	info	(26226) Expert mode enabled, states created
                              mihome-vacuum.0	2020-05-16 17:24:29.446	info	(26226) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                              mihome-vacuum.0	2020-05-16 17:24:26.151	info	(26211) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              mihome-vacuum.0	2020-05-16 17:24:26.151	info	(26211) terminating
                              mihome-vacuum.0	2020-05-16 17:24:26.150	info	(26211) Got terminate signal TERMINATE_YOURSELF
                              mihome-vacuum.0	2020-05-16 17:24:11.812	warn	(26211) Could not receive Mappointer, giving up
                              mihome-vacuum.0	2020-05-16 17:24:06.568	info	(26211) create state for carpet_mode
                              mihome-vacuum.0	2020-05-16 17:24:05.978	info	(26211) set nächster Timer: Nicht verfügbar
                              mihome-vacuum.0	2020-05-16 17:24:05.561	info	(26211) Connected
                              mihome-vacuum.0	2020-05-16 17:24:05.528	info	(26211) connecting, this can take up to 10 minutes ...
                              mihome-vacuum.0	2020-05-16 17:24:05.494	info	(26211) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                              mihome-vacuum.0	2020-05-16 17:24:05.470	info	(26211) Cloud control disabled
                              mihome-vacuum.0	2020-05-16 17:24:05.469	info	(26211) Expert mode enabled, states created
                              mihome-vacuum.0	2020-05-16 17:24:05.443	info	(26211) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                              mihome-vacuum.0	2020-05-16 17:24:02.121	info	(24195) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                              mihome-vacuum.0	2020-05-16 17:24:02.121	info	(24195) terminating
                              mihome-vacuum.0	2020-05-16 17:24:02.120	info	(24195) Got terminate signal TERMINATE_YOURSELF
                              mihome-vacuum.0	2020-05-16 17:22:16.758	warn	(24195) Could not receive Mappointer, giving up
                              An was könnte das liegen?
                              Danke für Eure Hilfe und noch einen schönen Samstag,
                              Seppel
                                MattinK @dirkhe last edited by
                                Ja das muss man machen... zurücksetzen und das ist das Nervige an der Sache. Da ich die Roborock App angenehmer finde, würde ich diese auch weiter nutzen wollen. Problem ist dann nur, dass der Adapter den Saugi nicht mehr findet.
                                Meine Frage an dich, könntest du mal schauen ob du den Zugriff auf die anderer Cloud hinbekommst. Das wäre cool. Somit könnte man die MiHome App und die Roborock App nutzen.
                                @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                • Diginix
                                  Diginix @MattinK last edited by
                                  @MattinK Für was nutzt du denn die App im Alltag noch?
                                  Seit mein Sauger komplett in ioBroker inkl Karte integriert ist, nutze ich die App gar nicht mehr.
                                  Üblicherweise starte ich ihn per Alexa oder über MaterialUI am Smartphone.
                                    Ist bei mir auch so, ich habe die App nur genutzt, um die Räume einzuteilen. Die Karte habe ich mir auch nur einmal runtergeladen, damit ich hinter mal in die Karte klicken kann, um ihn an eine bestimmte Stelle zu schicken, ist aber noch nicht fertig... Daher darf der robbi auch nicht mehr ins Internet
                                      TemPeck last edited by
                                      Hat es schon jemand hinbekommen bzw. ist es überhaupt möglich, die Räume des zweiten Geschosses (bei neuer Firmware und Mehretagenmodus) auch integrieren zu können?
                                      Ich habe bei mir über iobroker ein Reinigungsscript nach Anwesenheit erstellt, damit er jeden Tag ausgewählte Räume im Erdgeschoss säubert. Nachdem er einmal im Obergeschoss gewesen ist und dementsprechend die zweite Karte geladen war, ist er beim Reinigen über das Scrip nur umher geirrt und hat sich nicht mehr zurecht gefunden.
                                      Es wäre daher zumindest gut, wenn man per Befehl eine bestimmte Karte laden könnte...
                                      • O
                                        ompi last edited by ompi
                                        ich habe einen Roborock S5 max und verbinde den gerade mit dem mihome-vacuum Adapter V2.0.9 vom GIT. Bei den Räumen ist mir aufgefallen, dass wenn ich über den roomClean-Button die Raumreinigung starte und ich das Feld "roomFanPower" leer lasse. Stürzt der Adapter ab. Debug-Log-File habe ich angehängt. Die Raumreinigung startet trotzdem und nach ner halben Minute ist das Adapter neugestartet.
                                        mihome-vacuum.0	2020-05-18 21:40:54.007	info	(11511) Connected
                                        mihome-vacuum.0	2020-05-18 21:40:53.998	debug	(11511) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                        mihome-vacuum.0	2020-05-18 21:40:53.996	debug	(11511) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3746,"state":18,"battery":100,"clean_time":30,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"
                                        mihome-vacuum.0	2020-05-18 21:40:53.989	debug	(11511) sendMsg[1] >>> {"id":1,"method":"get_status"}
                                        mihome-vacuum.0	2020-05-18 21:40:53.911	debug	(11511) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                        mihome-vacuum.0	2020-05-18 21:40:53.911	info	(11511) connecting, this can take up to 10 minutes ...
                                        mihome-vacuum.0	2020-05-18 21:40:53.910	warn	(11511) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                        mihome-vacuum.0	2020-05-18 21:40:53.910	debug	(11511) Receive <<< Helo <<< 2131002000000000132d559d5ec2e4c6ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0	2020-05-18 21:40:53.898	info	(11511) New generation or new fw(3.5.8,0780) detected, create new states goto and zoneclean
                                        mihome-vacuum.0	2020-05-18 21:40:53.868	debug	(11511) server started on 0.0.0.0:53421
                                        mihome-vacuum.0	2020-05-18 21:40:53.858	info	(11511) Create state clean_home for controlling by cloud adapter
                                        mihome-vacuum.0	2020-05-18 21:40:53.858	info	(11511) Expert mode enabled, states created
                                        mihome-vacuum.0	2020-05-18 21:40:53.848	debug	(11511) Xiaomi Cloud: Logging in
                                        mihome-vacuum.0	2020-05-18 21:40:53.846	debug	(11511) load Map creator... true
                                        mihome-vacuum.0	2020-05-18 21:40:53.716	info	(11511) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.20.1
                                        mihome-vacuum.0	2020-05-18 21:40:51.680	debug	(11511) statesDB connected
                                        mihome-vacuum.0	2020-05-18 21:40:51.679	debug	(11511) States connected to redis: 127.0.0.1:9000
                                        mihome-vacuum.0	2020-05-18 21:40:51.638	debug	(11511) States create System PubSub Client
                                        mihome-vacuum.0	2020-05-18 21:40:51.636	debug	(11511) States create User PubSub Client
                                        mihome-vacuum.0	2020-05-18 21:40:51.612	debug	(11511) Redis States: Use Redis connection: 127.0.0.1:9000
                                        mihome-vacuum.0	2020-05-18 21:40:51.609	debug	(11511) objectDB connected
                                        mihome-vacuum.0	2020-05-18 21:40:51.604	debug	(11511) Objects connected to redis: 127.0.0.1:9001
                                        mihome-vacuum.0	2020-05-18 21:40:51.544	debug	(11511) Objects client initialize lua scripts
                                        mihome-vacuum.0	2020-05-18 21:40:51.543	debug	(11511) Objects create User PubSub Client
                                        mihome-vacuum.0	2020-05-18 21:40:51.542	debug	(11511) Objects create System PubSub Client
                                        mihome-vacuum.0	2020-05-18 21:40:51.539	debug	(11511) Objects client ready ... initialize now
                                        mihome-vacuum.0	2020-05-18 21:40:51.076	debug	(11511) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        mihome-vacuum.0	2020-05-18 21:40:18.877	info	(31264) Terminated (NO_ERROR): Without reason
                                        mihome-vacuum.0	2020-05-18 21:40:18.875	info	(31264) terminating
                                        mihome-vacuum.0	2020-05-18 21:40:18.864	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                        mihome-vacuum.0	2020-05-18 21:40:18.864	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                        mihome-vacuum.0	2020-05-18 21:40:18.864	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                        mihome-vacuum.0	2020-05-18 21:40:18.864	error	at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:572:33)
                                        mihome-vacuum.0	2020-05-18 21:40:18.864	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:177:68
                                        mihome-vacuum.0	2020-05-18 21:40:18.864	error	(31264) TypeError: Cannot read property 'val' of null
                                        mihome-vacuum.0	2020-05-18 21:40:18.862	error	(31264) uncaught exception: Cannot read property 'val' of null
                                        mihome-vacuum.0	2020-05-18 21:40:18.832	debug	(31264) sendMsg[1] >>> {"id":764,"method":"app_segment_clean","params":[18]}
                                        mihome-vacuum.0	2020-05-18 21:40:18.831	info	(31264) trigger cleaning segment 18
                                        mihome-vacuum.0	2020-05-18 21:40:18.824	debug	(31264) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                        mihome-vacuum.0	2020-05-18 21:40:18.821	debug	(31264) stateChange mihome-vacuum.0.rooms.756001011138.roomClean {"val":true,"ack":false,"ts":1589830818817,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589815704045}
                                        ompi
                                          dirkhe Developer @ompi last edited by
                                          @ompi das ist in der Tat ein Bug, schaue ich mir an
                                          • V
                                            Vocaris last edited by
                                            Moin.
                                            ich habe noch den Xiaomi Sauger der 1. Generation.
                                            Habe die Integration soweit hinbekommen. Er läuft also. Habe auch Szenen erstellt und habe im EG z.B. drei Bereich "Spots" mit der FloleVac App definiert, um diese mittels Szenen anzusteuern.
                                            Leider ist es aber irgendwie so, dass die Koordinaten nach geraumer Zeit nicht mehr stimmen.
                                            Ich habe das mit der Karte auch nicht verstanden. Kann ich irgendwie nicht eine Referenzkarte erstellen, die 1x fix gespeichert wird und an der ich dann die Spot Koordinaten 1x festlegen kann.
                                            Zudem trage ich den Sauger nach der Reinigung im EG ins OG. Für den Ort würde ich dann auch gerne eine Karte erstellen. etc. Geht das?
                                            Im Adapter gibt es ja auch einen Reiter Karteneinstellung. Dort habe ich noch nie eine KArte gesehen.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            495419
