    4. Fehlermeldung im Log
      gifftstaub @Thomas Braun last edited by
      @Thomas-Braun
      Sorry ist Erledigt
        Thomas Braun Most Active @gifftstaub last edited by
        @gifftstaub Und dann bitte die komplette Konsole inkl. login prompt.
          Thomas Braun Most Active @gifftstaub last edited by Thomas Braun
          @gifftstaub
          nodejs -v && node -v && npm -v
          which nodejs
          which node
          which npm
          Ist im Ordner /opt/iobroker eine Datei package-lock.json?
          Ist im Ordner /opt/iobroker/node_modules ein Ordner iobroker ohne führendes @?
          Zeige bitte den Inhalt der Datei /opt/iobroker/package.json.
            @Thomas-Braun
            which nodejs
            /usr/bin/nodejs
            which node
            /usr/bin/node
            which npm
            /usr/bin/npm
            v12.16.3
            v12.16.3
            6.14.4
              @gifftstaub Und die drei anderen Punkte?
                @Thomas-Braun said in Fehlermeldung im Log:
                welche drei?
                  @gifftstaub
                    pi@raspberrypi4:~ $ cat /opt/iobroker/package.json
                      "name": "iobroker.inst",
                      "version": "2.0.3",
                      "private": true,
                      "description": "Automation platform in node.js",
                      "scripts": {
                        "install": "node lib/checkVersions.js",
                        "postinstall": "node lib/install.js",
                        "test": "node node_modules/mocha/bin/mocha --exit"
                      "dependencies": {
                        "colors": "^1.3.3",
                        "fs-extra": "^7.0.1",
                        "iobroker": "^2.0.3",
                        "iobroker.admin": "^4.1.1",
                        "iobroker.alexa2": "^3.1.2",
                        "iobroker.backitup": "^1.5.7",
                        "iobroker.coronavirus-statistics": "^0.5.9",
                        "iobroker.discovery": "^2.3.5",
                        "iobroker.email": "^1.0.6",
                        "iobroker.ical": "^1.7.0",
                        "iobroker.info": "^1.7.2",
                        "iobroker.iot": "^1.4.18",
                        "iobroker.javascript": "^4.6.4",
                        "iobroker.js-controller": "^3.1.4",
                        "iobroker.material": "^0.13.8",
                        "iobroker.nuki-extended": "^2.2.5",
                        "iobroker.rpi2": "^1.2.0",
                        "iobroker.samsung": "^0.2.9",
                        "iobroker.scenes": "^1.1.0",
                        "iobroker.simple-api": "^2.4.5",
                        "iobroker.socketio": "^3.0.7",
                        "iobroker.sonoff": "^2.3.3",
                        "iobroker.sonos": "^2.0.1",
                        "iobroker.telegram": "^1.5.9",
                        "iobroker.text2command": "^1.3.0",
                        "iobroker.trashschedule": "0.0.8",
                        "iobroker.web": "^3.0.8",
                        "iobroker.zigbee": "^1.1.1",
                        "semver": "^5.6.0",
                        "yargs": "^7.0.2"
                    ist alles vorhanden
                      @gifftstaub sagte in Fehlermeldung im Log:
                      Lösch mal die Zeile 15 raus:
                      dann abspeichern.
                      Dann
                      iobroker stop
                      iobroker rebuild self
                      iobroker start
                      Final würde ich vielleicht auch mal
                      iobroker update
                      iobroker upgrade
                      machen.
                        @Thomas-Braun
                        hab alles so gemacht.
                        pi@raspberrypi4:~ $ npm install
                        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.jso        n'
                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm WARN pi No description
                        npm WARN pi No repository field.
                        npm WARN pi No README data
                        npm WARN pi No license field.
                        up to date in 0.535s
                        found 0 vulnerabilities
                        pi@raspberrypi4:~ $
                          @gifftstaub Aber im falschen Ordner.
                          Für ein npm install musst du in /opt/iobroker stehen.
                          Davon hatte ich aber auch nichts geschrieben.
                            @Thomas-Braun
                            ich Danke dir für deine Hilfe.
                            Leider hat das auch nicht geholfen.
                            Ich habe jetzt eine Neuinstallation mit Restore gemacht nun lüppt alles wieder.
                            LG
                            47
                            3645
