    4. iobroker: Could not connect database (invalid protocol)
    UNSOLVED iobroker: Could not connect database (invalid protocol)
      Thomas Braun Most Active @_Matze_ last edited by Thomas Braun
      @_Matze_ Bitte in </> code tags. Danke.
      iobroker list instances
      _ 1 Reply Last reply Reply Quote 0
      • _
        _Matze_ @Thomas Braun last edited by
        @Thomas-Braun said in iobroker: Could not connect database (invalid protocol):
        Could not connect database at 0.0.0.0:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0.
          system.adapter.backitup.0              : backitup              - disabled
          system.adapter.bring.0                 : bring                 -  enabled
          system.adapter.cloud.0                 : cloud                 - disabled
          system.adapter.coronavirus-statistics.0: coronavirus-statistics -  enabled
          system.adapter.cul.0                   : cul                   -  enabled, port: 23
          system.adapter.daswetter.0             : daswetter             - disabled
          system.adapter.discovery.0             : discovery             -  enabled
          system.adapter.fb-checkpresence.0      : fb-checkpresence      -  enabled
          system.adapter.flot.0                  : flot                  -  enabled
          system.adapter.fritzbox.0              : fritzbox              -  enabled
          system.adapter.history.0               : history               -  enabled
          system.adapter.hm-rega.0               : hm-rega               -  enabled
          system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 18701
          system.adapter.hm-rpc.2                : hm-rpc                -  enabled, port: 12001
          system.adapter.hm-rpc.3                : hm-rpc                -  enabled, port: 12010
          system.adapter.info.0                  : info                  -  enabled
          system.adapter.iqontrol.0              : iqontrol              -  enabled
          system.adapter.javascript.0            : javascript            -  enabled
          system.adapter.material.0              : material              -  enabled
          system.adapter.mihome.0                : mihome                - disabled, port: 9898, bind: 0.0.0.0
          system.adapter.mqtt.1                  : mqtt                  -  enabled, port: 1885, bind: 0.0.0.0
          system.adapter.openweathermap.0        : openweathermap        - disabled
          system.adapter.ping.0                  : ping                  -  enabled
          system.adapter.rickshaw.0              : rickshaw              -  enabled
          system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 10.168.1.26
          system.adapter.shuttercontrol.0        : shuttercontrol        - disabled
          system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.telegram.1              : telegram              - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0              : terminal              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.text2command.0          : text2command          -  enabled
          system.adapter.tr-064.0                : tr-064                -  enabled
          system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wetty.0                 : wetty                 - disabled, port: 8089, bind: 0.0.0.0
          system.adapter.yahka.0                 : yahka                 - disabled
          system.adapter.yamaha.0                : yamaha                -  enabled
          system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
        + instance is alive
        • _
          _Matze_ @_Matze_ last edited by
          @_Matze_
          🙄 Sieht so aus, als hätte ich mir durch die Installation von webhooks den Port 9000 versperrt
            @_Matze_
            Genau, auf 9000 läuft ein webhook
            0 :::9000                 :::*                    LISTEN      0          24180      703/webhook
            Kannst die Ports vom iobroker mit einer custom installation aber auf andere Ports biegen.
            • _
              @Thomas-Braun
              Den Webhook habe ich wieder deinstalliert - trotzdem kann ich noch nicht per Browser darauf zugreifen. Ich vermute durch meine Reparaturversuche habe ich noch etwas anderes zerlegt.
              iobroker status
              At least one iobroker host is running.
              Objects type: file
              States  type: file
              Hast Du noch einen Tip?
                @_Matze_ Zeig nochmal die Instanzen:
                • _
                  + system.adapter.bring.0                 : bring                 -  enabled
                  + system.adapter.cul.0                   : cul                   -  enabled, port: 23
                  + system.adapter.discovery.0             : discovery             -  enabled
                  + system.adapter.fritzbox.0              : fritzbox              -  enabled
                  + system.adapter.hm-rega.0               : hm-rega               -  enabled
                  + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 18701
                  + system.adapter.hm-rpc.2                : hm-rpc                -  enabled, port: 12001
                  + system.adapter.hm-rpc.3                : hm-rpc                -  enabled, port: 12010
                  + system.adapter.mqtt.1                  : mqtt                  -  enabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.ping.0                  : ping                  -  enabled
                  + system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 10.168.1.26
                  + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0          : text2command          -  enabled
                  + system.adapter.tr-064.0                : tr-064                -  enabled
                  + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.yamaha.0                : yamaha                -  enabled
                  + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
                  + instance is alive
                    @_Matze_
                    iobroker add admin
                    • _
                      iobroker add admin
                      Das war es! Herzlichen Dank für Deine Hilfe!!! Es läuft wieder alles 👍 👏 👏
                        @_Matze_ Freut mich. Magst du noch verraten wo der webhook herkam?
                        • _
                          @Thomas-Braun Den hatte ich am Vorabend installiert. Da hatte ich versucht eine Telegram direkt an einen User abzusetzen, um an die fertige Spülmaschine zu erinnern. Automatische Kommunikation mit Teens 🙂
                          https://nordicapis.com/how-to-build-your-first-telegram-bot-using-php-in-under-30-minutes/
                          Tja, und dann blieb der Webhook einfach zurück, ohne dass ich ihn wieder sauber deinstalliert hätte. Beim nächsten Reboot hat sich das dann bemerkbar gemacht.
                          database js-controller
                          2110
