    4. iobroker: Could not connect database (invalid protocol)
    UNSOLVED iobroker: Could not connect database (invalid protocol)
    • _
      _Matze_ @Thomas Braun last edited by
      @Thomas-Braun said in iobroker: Could not connect database (invalid protocol):
      iobroker list instances
      Could not connect database at 0.0.0.0:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0.
        system.adapter.backitup.0              : backitup              - disabled
        system.adapter.bring.0                 : bring                 -  enabled
        system.adapter.cloud.0                 : cloud                 - disabled
        system.adapter.coronavirus-statistics.0: coronavirus-statistics -  enabled
        system.adapter.cul.0                   : cul                   -  enabled, port: 23
        system.adapter.daswetter.0             : daswetter             - disabled
        system.adapter.discovery.0             : discovery             -  enabled
        system.adapter.fb-checkpresence.0      : fb-checkpresence      -  enabled
        system.adapter.flot.0                  : flot                  -  enabled
        system.adapter.fritzbox.0              : fritzbox              -  enabled
        system.adapter.history.0               : history               -  enabled
        system.adapter.hm-rega.0               : hm-rega               -  enabled
        system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 18701
        system.adapter.hm-rpc.2                : hm-rpc                -  enabled, port: 12001
        system.adapter.hm-rpc.3                : hm-rpc                -  enabled, port: 12010
        system.adapter.info.0                  : info                  -  enabled
        system.adapter.iqontrol.0              : iqontrol              -  enabled
        system.adapter.javascript.0            : javascript            -  enabled
        system.adapter.material.0              : material              -  enabled
        system.adapter.mihome.0                : mihome                - disabled, port: 9898, bind: 0.0.0.0
        system.adapter.mqtt.1                  : mqtt                  -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.openweathermap.0        : openweathermap        - disabled
        system.adapter.ping.0                  : ping                  -  enabled
        system.adapter.rickshaw.0              : rickshaw              -  enabled
        system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 10.168.1.26
        system.adapter.shuttercontrol.0        : shuttercontrol        - disabled
        system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1              : telegram              - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.terminal.0              : terminal              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0          : text2command          -  enabled
        system.adapter.tr-064.0                : tr-064                -  enabled
        system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.wetty.0                 : wetty                 - disabled, port: 8089, bind: 0.0.0.0
        system.adapter.yahka.0                 : yahka                 - disabled
        system.adapter.yamaha.0                : yamaha                -  enabled
        system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
      + instance is alive
      _ 1 Reply Last reply Reply Quote 0
      • _
        _Matze_ @_Matze_ last edited by
        @_Matze_
        🙄 Sieht so aus, als hätte ich mir durch die Installation von webhooks den Port 9000 versperrt
          Thomas Braun Most Active @_Matze_ last edited by
          @_Matze_
          Genau, auf 9000 läuft ein webhook
          0 :::9000                 :::*                    LISTEN      0          24180      703/webhook
          Kannst die Ports vom iobroker mit einer custom installation aber auf andere Ports biegen.
          • _
            @Thomas-Braun
            Den Webhook habe ich wieder deinstalliert - trotzdem kann ich noch nicht per Browser darauf zugreifen. Ich vermute durch meine Reparaturversuche habe ich noch etwas anderes zerlegt.
            iobroker status
            At least one iobroker host is running.
            Objects type: file
            States  type: file
            Hast Du noch einen Tip?
              @_Matze_ Zeig nochmal die Instanzen:
              • _
                + system.adapter.bring.0                 : bring                 -  enabled
                + system.adapter.cul.0                   : cul                   -  enabled, port: 23
                + system.adapter.discovery.0             : discovery             -  enabled
                + system.adapter.fritzbox.0              : fritzbox              -  enabled
                + system.adapter.hm-rega.0               : hm-rega               -  enabled
                + system.adapter.hm-rpc.1                : hm-rpc                -  enabled, port: 18701
                + system.adapter.hm-rpc.2                : hm-rpc                -  enabled, port: 12001
                + system.adapter.hm-rpc.3                : hm-rpc                -  enabled, port: 12010
                + system.adapter.mqtt.1                  : mqtt                  -  enabled, port: 1885, bind: 0.0.0.0
                + system.adapter.ping.0                  : ping                  -  enabled
                + system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 10.168.1.26
                + system.adapter.simple-api.0            : simple-api            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.0          : text2command          -  enabled
                + system.adapter.tr-064.0                : tr-064                -  enabled
                + system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.yamaha.0                : yamaha                -  enabled
                + system.adapter.zigbee.0                : zigbee                -  enabled, port: /dev/ttyACM0
                + instance is alive
                  @_Matze_
                  iobroker add admin
                  • _
                    iobroker add admin
                    Das war es! Herzlichen Dank für Deine Hilfe!!! Es läuft wieder alles 👍 👏 👏
                      Thomas Braun Most Active @_Matze_ last edited by Thomas Braun
                      @_Matze_ Freut mich. Magst du noch verraten wo der webhook herkam?
                      • _
                        @Thomas-Braun Den hatte ich am Vorabend installiert. Da hatte ich versucht eine Telegram direkt an einen User abzusetzen, um an die fertige Spülmaschine zu erinnern. Automatische Kommunikation mit Teens 🙂
                        https://nordicapis.com/how-to-build-your-first-telegram-bot-using-php-in-under-30-minutes/
                        Tja, und dann blieb der Webhook einfach zurück, ohne dass ich ihn wieder sauber deinstalliert hätte. Beim nächsten Reboot hat sich das dann bemerkbar gemacht.
                        database js-controller
                        2110
