    4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
      noch ein issue eingestellt
        tombox @arteck last edited by
        @arteck habe eine neu version erstellt die js controller 3 kompatibel sein sollte.
          arteck Developer Most Active @tombox last edited by
          @tombox dann schau ich mal
          • oberfragger
            oberfragger @arteck last edited by
            @arteck Koimt leider immer noch vor. 😞
            https://github.com/dna909/ioBroker.homeconnect/issues/41
            • Merlin123
              Merlin123 last edited by
              Mein Adapter spinnt mittlerweile auch..... Bin auf dem latest Repositiry und hab entsprechend auch 3.1.4er js-controller.
              Bei mir passiert das:
              homeconnect.0	2020-05-15 18:41:11.580	info	(23456) BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 577 seconds.
              homeconnect.0	2020-05-15 18:41:08.625	info	(23456) BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
              homeconnect.0	2020-05-15 18:41:03.993	info	(23456) BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 584 seconds.
              homeconnect.0	2020-05-15 18:41:02.479	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:41:00.973	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:59.477	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:57.976	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:56.465	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:54.978	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:53.473	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:51.975	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:50.481	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:48.972	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
              homeconnect.0	2020-05-15 18:40:34.021	info	(23456) Accesstoken renewed...
              homeconnect.0	2020-05-15 18:40:33.797	warn	(23456) BOSCH-WAYH2842-68A40E2AA61D is not connected cannot fetch information.
              homeconnect.0	2020-05-15 18:40:33.369	info	(23456) starting. Version 0.0.28 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v10.15.2, js-controller: 3.1.4
              Hat jemand ne Idee?
              Hab auch mal den Adapter gestoppt und erst nach ner halben Stunde neu probiert, geht leider nicht.
              Historie:
              Beim Benachrichtigungen zum Programmende kamen nicht mehr.
              Hab bei den Objekten dann gesehen, dass Waschmaschine und trockner 2x drin waren. Hab den Adapter gestoppt, alle Objekte gelöscht und neu gestartet.
              Dann hatte er Probleme mit den Credentials, also nochmal API Key neu generiert usw.
              Dann ging das einloggen wieder. Die Objekte wurden nach und nach neu generiert.
              Jetzt wirft er aber den Fehler 😞
                tombox @Merlin123 last edited by
                @Merlin123 Das liegt daran das der Adapter zu oft gestartet wird. Einfach mal für 10min ausschalten und dann normal starten.
                  @tombox @dna909
                  ich hab gerade noch einen
                  darauf hin folgte
                    @arteck bitte die version 0.0.30 via github installieren
                    • Merlin123
                      Merlin123 @tombox last edited by Merlin123
                      @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                      Wie geschrieben: Hab den auch mal ne halbe Stunde ausgeschaltet. Nach dem Neustart sofort wieder das Gleiche 😞
                      Hab jetzt mal auf die 0.3.0 aktualisiert, die zeigt das jetzt erstmal nicht mehr. Mal beobachten
                        @tombox gemacht... dann schau ich mal
                          marsroth last edited by
                          Hallo, ich habe seit ein paar Tagen folgendes Problem: Der Adapter bringt keinen Error, aber er aktualisiert die Werte nicht mehr. Vor allem bekommt der Adapter nicht mit, wenn die WM oder Trockner online geht und startet. Wenn ich den Adapter von Hand neustarte funktioniert eine Zeit lang alles wieder. In der App passt alles. Version 0.0.30 und js-controller 3.1.4.
                          T B 2 Replies Last reply Reply Quote 0
                            tombox @marsroth last edited by
                            @marsroth homeconnect hatte server problem bitte die Woche schauen ob es besser läuft.
                            oberfragger 1 Reply Last reply Reply Quote 0
                            • oberfragger
                              oberfragger @tombox last edited by
                              @tombox Das läuft nun bei mir seit Tagen ganz gut. Also kein Api-Limut Fehler mehr. Schauen wir mal...
                                beckerpa @marsroth last edited by
                                @marsroth @tombox
                                Kann das Problem von @marsroth nachvollziehen.
                                Wenn Waschmaschine und / oder Trockner ausgeschaltet werden, werden diese Geräte vom WLAN getrennt.
                                Beim Einschalten dieser Geräte verbinden diese sich direkt mit WLAN - im Adapter kommt das allerdings nicht an.
                                Ich habe das nun eine Weile getestet, das einzige was hilft ist ein Neustart des Adapters.
                                Das hat allerdings in einer sehr frühen Version des Adapters (kann ich leider nicht mehr nachvollziehen) funktioniert.
                                Einziger log-Eintrag, der kommt nachdem (in diesem Beispiel) die Waschmaschine eingeschaltet wurde:
                                beckerpa
                                T D 2 Replies Last reply Reply Quote 0
                                  tombox @beckerpa last edited by
                                  @beckerpa ich habe in der aktuellen github version noch ein paar zusätzliche warnings eingebaut um das problem einzugrenzen. Ich kann es leider gerade nicht testen weil die api down ist.
                                  Bitte neuinstalliern via github und das log im auge behalten.
                                    beckerpa @tombox last edited by beckerpa
                                    @tombox
                                    Moin, sry, hat bisschen länger gedauert.
                                    Die Datenpunkte von Waschmaschine und Trockner werden, sobald sie wieder angeschaltet wurden, aktualisiert.
                                    Bis auf den Datenpunkt BSH_Common_Setting_PowerState (Energiezustand).
                                    Wenn der Datenpunkt auf Aus gesetzt wird, gehen die Maschinen auch aus (wird natürlich nicht mehr bestätigt mit true, da die Geräte keine Rückmeldung mehr geben beim Ausschalten). Beim Einschalten der Geräte verbleibt der Datenpunkt allerdings auf Aus.
                                    Fehlermeldungen im log gibt es keine mehr!
                                    Einzige log Einträge (vermutlich von der Kaffeemaschine Siemens beim Ausschalten):
                                    beckerpa
                                      ich hab da mal wieder was
                                      kannst du das abfangen ..
                                        @arteck ja alles über fehler 500 liegt an der homeconnect api die nich erreichbar ist
                                        arteck T 2 Replies Last reply Reply Quote 0
                                          @tombox ja ist schon klar aber das kan man abfangen und eine schicke Fehlermeldung rauswerfen.
                                            tombox @tombox last edited by
                                            @tombox ist doch abgefangen steht doch da das homeconnect api nicht available ist
                                            bsh bsh home connect home connect homeconnect adapter
                                            195
                                            1373
                                            518221
