    4. Adapter: DasWetter
    Adapter: DasWetter
      Coffeelover @Glasfaser last edited by
      @Glasfaser Das sieht dann so aus. Problem: Es sind weiterhin keine Datenpunkte vorhanden.
      daswetter.0	2020-05-02 15:18:10.034	debug	(6010) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0&h=1
      daswetter.0	2020-05-02 15:18:10.029	debug	(6010) 5 days forecast done, objects in list 1059
      daswetter.0	2020-05-02 15:18:09.286	debug	(6010) calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0
      daswetter.0	2020-05-02 15:18:09.277	debug	(6010) 7 days forecast done, objects in list 107
      daswetter.0	2020-05-02 15:18:08.885	debug	(6010) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621
      daswetter.0	2020-05-02 15:18:08.882	debug	(6010) using new data structure
      daswetter.0	2020-05-02 15:18:08.880	debug	(6010) set timeout to 60 sec
      daswetter.0	2020-05-02 15:18:08.822	info	(6010) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.16.3, js-controller: 3.0.20
      daswetter.0	2020-05-02 15:16:11.730	warn	(5753) Terminated (15): Without reason
      daswetter.0	2020-05-02 15:16:11.723	error	(5753) force terminate, objects still in list: 1059
      daswetter.0	2020-05-02 15:16:05.574	debug	(5753) system.adapter.admin.0: logging true
      daswetter.0	2020-05-02 15:15:14.647	debug	(5753) system.adapter.admin.0: logging false
      daswetter.0	2020-05-02 15:15:12.997	debug	(5753) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0&h=1
      daswetter.0	2020-05-02 15:15:12.993	debug	(5753) 5 days forecast done, objects in list 1059
      daswetter.0	2020-05-02 15:15:12.200	debug	(5753) calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0
      daswetter.0	2020-05-02 15:15:12.193	debug	(5753) 7 days forecast done, objects in list 107
      daswetter.0	2020-05-02 15:15:11.731	debug	(5753) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621
      daswetter.0	2020-05-02 15:15:11.723	debug	(5753) using new data structure
      daswetter.0	2020-05-02 15:15:11.719	debug	(5753) set timeout to 60 sec
      daswetter.0	2020-05-02 15:15:11.586	info	(5753) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.16.3, js-controller: 3.0.20
      • Rene_HM
        Rene_HM Developer @Coffeelover last edited by
        @Coffeelover setze mal den parse-timeout etwas höher. Du hast beim "force terminate" noch über 1000 Werte zu bearbeiten... Ich würde mal auf mindestens 120 Sekunden (anstatt 60) gehen...
          Coffeelover @Rene_HM last edited by Coffeelover
          @Rene_HM Großzügig auf 180 gesprungen. Ergebnis unverändert. Es existiert die ganze Baumstruktur der DPs nicht. Ich installiere mal ne weitere Instanz.
          Edit: Ergebnis unverändert. Keine Baumstruktur.
          Der Cron steht auf 5 Minuten. Force terminate auf 180.
          Rene_HM 2 Replies Last reply Reply Quote 0
          • Rene_HM
            @Coffeelover ich hoffe, du lässt den Adapter nicht alle Minuten laufen? Es darf kein "force terminate" im log auftauchen...
            • Rene_HM
              Rene_HM Developer @Coffeelover last edited by Rene_HM
              @Coffeelover sagte in Adapter: DasWetter:
              und trotzdem noch im log
              force terminate, objects still in list: 1000
              Dann rufe erst mal nur einen Pfad (anstatt 3) auf und schaue, ob das geht. Es ist auch seltsam, dass nach Abrufen des dritten Pfades (hourly) die gleiche Anzahl Einträge (1059) in der to-do-Liste stehen, wie zuvor...
              Das könnte daran liegen, dass der dritte Pfad keine Ergebnisse bekommt.
                @Rene_HM Ja trotzdem noch. Ich nehme mal Pfad 2 und 3 raus.
                daswetter.0	2020-05-02 15:38:12.124	warn	(7245) Terminated (15): Without reason
                daswetter.0	2020-05-02 15:38:12.116	error	(7245) force terminate, objects still in list: 1059
                daswetter.0	2020-05-02 15:37:33.517	debug	(7245) system.adapter.admin.0: logging true
                daswetter.0	2020-05-02 15:37:32.799	debug	(7245) system.adapter.admin.0: logging false
                daswetter.0	2020-05-02 15:37:02.340	debug	(7245) system.adapter.admin.0: logging true
                daswetter.0	2020-05-02 15:35:13.413	debug	(7245) system.adapter.admin.0: logging false
                daswetter.0	2020-05-02 15:35:13.162	debug	(7245) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0&h=1
                daswetter.0	2020-05-02 15:35:13.140	debug	(7245) 5 days forecast done, objects in list 1059
                daswetter.0	2020-05-02 15:35:12.483	debug	(7245) calling forecast 5 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621&v=2.0
                daswetter.0	2020-05-02 15:35:12.475	debug	(7245) 7 days forecast done, objects in list 107
                daswetter.0	2020-05-02 15:35:12.118	debug	(7245) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=de&localidad=97795&affiliate_id=pkwnqrmo8621
                daswetter.0	2020-05-02 15:35:12.116	debug	(7245) using new data structure
                daswetter.0	2020-05-02 15:35:12.112	debug	(7245) set timeout to 180 sec
                Edit: Jackpot. Mit nur einem Pfad kommen jetzt Daten an und Datenpunkte werden erzeugt.
                • Rene_HM
                  @Coffeelover okay, dann nimm doch die aktuelle 3.0 aus github. Dort habe ich genau für solche Probleme das Handling umgebaut. Die Daten werden direkt geparsed und in DP's geschrieben. In Version 2.x schreibe ich sie erst in eine Liste und erst am Schluß arbeite ich die Liste ab...
                  Die 3.0 im github von heute morgen ist sowieso der release candidate...
                  Glasfaser 1 Reply Last reply Reply Quote 1
                  • Glasfaser
                    Glasfaser @Rene_HM last edited by Glasfaser
                    @Rene_HM
                    Ich vermute dann mal , die Zeit 60 sek. waren beim 3.0.0 auch zu kurz !
                    Deshalb ging es nicht bei Ihm !
                    Ist dann das gleiche wie bei mir ... mit 3.0.0 funktioniert es
                      Coffeelover last edited by Coffeelover
                      Gut - dann gehe ich jetzt wieder hoch. 🙂
                      Edit: vielen Dank euch beiden. Jetzt produziert die 3.0 gerade Unmengen an Insert-Einträgen im Log. Funktioniert also jetzt auch bei mir.
                        pk68 last edited by
                        Hi, ich bin neu beim ioBroker. Pfad 3 und 4 habe ja vermulich die gleichen Daten nur ein unterschiedliches Format (XML bzw. JSON). Ist das dann egal, welchen Pfad man nimmt? Und bestehen die bei Github beschriebenen Probleme zu Pfad 4 noch? Ich verwende Version 3.0.1.
                        • Rene_HM
                          Rene_HM Developer @pk68 last edited by
                          @pk68 ja, Pfad 3 und 4 liefern die gleiche Daten und ja, die Probleme sind zwar noch vorhanden, ich habe das aber im Adapter repariert, du merkst die Probleme also nicht. (außer im log, wo mal "trying to repair" geloggt wird... 🙂 , das ist aber kein wirkliches Problem)
                            pk68 last edited by
                            Danke Rene für die schnelle Antwort. Aber nochmal zu dem Format (XML bzw. JSON), welches ist zu bevorzugen?
                            • Rene_HM
                              @pk68 ich selbst nutze xml, aber nur deshalb weil ich Pfad 1 und 2 ebenfalls verwende...
                                pk68 last edited by
                                Ok, danke, ich dachte es gibt vielleicht Vorteile bezügl. Speicherbedarf oder Performance.
                                  A Former User last edited by
                                  Ist es möglich, überhaupt den Regen aufzuzeichnen?
                                  Auf welche Variable muss ich da zugreifen und was stellt sie da?
                                  Mir würde auch schon eine Wahrscheinlichkeit ausreichen. So ganz grob.
                                  Nur aktuell, nicht in die Zukunft gerichtet.
                                    sigi234 Forum Testing Most Active @Guest last edited by
                                    @Paul-OL sagte in Adapter: DasWetter:
                                    https://forum.iobroker.net/topic/32232/material-design-widgets-wetter-view
                                    • Basti97
                                      Basti97 Most Active last edited by
                                      Was habt ihr bei der Registierung des Api Code als Internetseite eingetragen? Leider habe ich keine da ich das nur für iob brauche.
                                      • Glasfaser
                                        Glasfaser @Basti97 last edited by
                                        @Basti97
                                        Ein Beispiel , steht im Beitrag 87 .
                                        Basti97 1 Reply Last reply Reply Quote 0
                                        • Basti97
                                          Basti97 Most Active @Glasfaser last edited by
                                          @Glasfaser Danke hat geholfen. Darauf muss man erst kommen.
                                          • Glasfaser
                                            @Basti97 sagte in Adapter: DasWetter:
                                            Ja ... den Thread einmal lesen 😁
                                            1208
                                            410900
