    4. ble adapter keine Verbindung mehr
    UNSOLVED ble adapter keine Verbindung mehr
      Marty56 @Marty56 last edited by
      nochmal mit debug option:
      ble.0	2020-05-17 14:33:33.112	debug	(15616) system.adapter.admin.0: logging true
      ble.0	2020-05-17 14:33:29.676	info	(15616) monitored services: fe95
      ble.0	2020-05-17 14:33:29.673	info	(15616) enabled plugins: mi-flora, _default
      ble.0	2020-05-17 14:33:29.671	info	(15616) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      ble.0	2020-05-17 14:33:29.586	info	(15616) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.16.3, js-controller: 3.1.4
      ble.0	2020-05-17 14:33:28.624	debug	(15616) statesDB connected
      ble.0	2020-05-17 14:33:28.623	debug	(15616) States connected to redis: 127.0.0.1:6379
      ble.0	2020-05-17 14:33:28.614	debug	(15616) States create System PubSub Client
      ble.0	2020-05-17 14:33:28.612	debug	(15616) States create User PubSub Client
      ble.0	2020-05-17 14:33:28.605	debug	(15616) Redis States: Use Redis connection: 127.0.0.1:6379
      ble.0	2020-05-17 14:33:28.602	debug	(15616) objectDB connected
      ble.0	2020-05-17 14:33:28.594	debug	(15616) Objects connected to redis: 127.0.0.1:9001
      ble.0	2020-05-17 14:33:28.580	debug	(15616) Objects client initialize lua scripts
      ble.0	2020-05-17 14:33:28.579	debug	(15616) Objects create User PubSub Client
      ble.0	2020-05-17 14:33:28.578	debug	(15616) Objects create System PubSub Client
      ble.0	2020-05-17 14:33:28.574	debug	(15616) Objects client ready ... initialize now
      ble.0	2020-05-17 14:33:28.539	debug	(15616) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.nuc	2020-05-17 14:33:27.773	info	instance system.adapter.ble.0 started with pid 15616
      host.nuc	2020-05-17 14:33:25.240	info	instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      ble.0	2020-05-17 14:33:24.711	info	(15594) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      ble.0	2020-05-17 14:33:24.710	info	(15594) terminating
      host.nuc	2020-05-17 14:33:24.708	info	stopInstance system.adapter.ble.0 send kill signal
      ble.0	2020-05-17 14:33:24.707	info	(15594) Got terminate signal TERMINATE_YOURSELF
      host.nuc	2020-05-17 14:33:24.698	info	stopInstance system.adapter.ble.0 (force=false, process=true)
      ble.0	2020-05-17 14:31:42.142	info	(15594) monitored services: fe95
      ble.0	2020-05-17 14:31:42.140	info	(15594) enabled plugins: mi-flora, _default
      ble.0	2020-05-17 14:31:42.138	info	(15594) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
      ble.0	2020-05-17 14:31:42.051	info	(15594) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.16.3, js-controller: 3.1.4
      host.nuc	2020-05-17 14:31:40.006	info	instance system.adapter.ble.0 started with pid 15594
      host.nuc	2020-05-17 14:31:39.949	info	"system.adapter.ble.0" enabled
      haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Marty56 last edited by
        @Marty56
        Was steht im Datenpunkt driverState?
          Thomas Braun Most Active @Marty56 last edited by Thomas Braun
          @Marty56
          Seltsamerweise hatte ich das eben auch.
          Ein Neustart hat es gerichtet.
          [Edit:] Doch nicht, ist doch wieder Gelb geworden.
          [Editedit:] Jetzt wieder Grün... 🙂
            Marty56 @haselchen last edited by Marty56
            @haselchen Not connected
            Neustart habe ich auch gemacht.
            Außerdem den Adapter neuinstalliert
              crunchip Forum Testing Most Active @Marty56 last edited by crunchip
              @Marty56 läuft zufällig auch der radar2 Adapter auf deinem System? Wenn ja, geht das nämlich nicht beides zusammen. Je nach dem würde da mal der radar oder mal der ble funktionieren.
              Andernfalls bräuchtest du dann nen externen Bluetooth Stick wenn du beides nutzen möchtest.
              Bei einem Adapter kannst du dann hci0 und beim anderen hci1 auswählen.
              Was steht bei ble.0.info.driverState?
                Marty56 @crunchip last edited by
                @crunchip der Radar Adapter läuft nicht.
                connection: false
                driverState:poweredOFF
                Es werde natürlich auch keine BLE Geräte erkannt.
                crunchip AlCalzone 2 Replies Last reply Reply Quote 0
                  @Marty56 mal testweise mit der version zurück gehen, v0.11.0
                  mit anschliessendem
                  sudo setcap cap_net_raw+eip $(eval readlink -f which node)
                  mal so nebenbei,
                  bei meinem Server gibt es manchmal so ne Art "Spannungsproblem" mit dem internen Bluetooth.
                  In dem Fall steht dann ebenfalls der ble.0.info.driverState auf poweredOFF
                  Abhilfe schafft dann bei mir nur, den Server auszuschalten und kurz vom Strom zu nehmen.
                  Danach läuft er wieder wie gewünscht.
                  • AlCalzone
                    AlCalzone Developer @Marty56 last edited by
                    @Marty56 sagte in ble adapter keine Verbindung mehr:
                    Natürlich habe ich "sudo setcap cap_net_raw+eip $(eval readlink -f which node)" gemacht.
                    Das macht der Fixer auch.
                    poweredOFF
                    Probier mal hciconfig hci0 up
                      Marty56 @AlCalzone last edited by Marty56
                      @AlCalzone sagte in ble adapter keine Verbindung mehr:
                      hciconfig hci0 up
                      liefert
                      hciconfig hci0 up
                      Can't init device hci0: Connection timed out (110)
                       hciconfig -a
                      hci0:	Type: Primary  Bus: USB
                      	BD Address: 00:00:00:00:00:00  ACL MTU: 0:0  SCO MTU: 0:0
                      	DOWN
                      	RX bytes:0 acl:0 sco:0 events:0 errors:0
                      	TX bytes:9 acl:0 sco:0 commands:3 errors:0
                      	Features: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
                      	Packet type: DM1 DH1 HV1
                      	Link policy:
                      	Link mode: SLAVE ACCEPT
                      • AlCalzone
                        Google das mal. Gibt ein paar Ansätze, aber das per stille Post durchzuspielen macht keinen Sinn.
                          @AlCalzone Das habe ich auch schon versucht, aber ich komme nicht weiter.
                            War wohl ein Hardwaredefekt. Ein USB Kabel war defekt und hat wohl den USB Hub außer Funktion gesetzt.
                            ble adapter
                            762
