    4. Material Design Widgets: Dialogs Widget
      Conquest @Scrounger last edited by Conquest
      @Scrounger sagte in Material Design Widgets: Dialog View Widget:
      Der Dialog öffnet immer in der Mitte des Screens, sofern du nicht die Fullscreen variante eingestellt hast. Zeig mal Bilder
      Bei mir öffnet er nicht in der Mitte.
      Hier noch die Einstellungen:
      screenshot-192.168.178.46_8082-2020.05.08-15_17_27.png screenshot-192.168.178.46_8082-2020.05.08-15_16_33.png
      [{"tpl":"tplVis-materialdesign-Vuetify-Dialog-View","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","showDialogMethod":"button","fullscreenResolutionLower":"672","vibrateOnMobilDevices":"50","buttonStyle":"text","iconPosition":"left","closingClickOutside":true,"showTitle":true,"buttonPosition":"center","buttonSize":"medium","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"backgroundColor":"#2e2e2e","dialogMaxWidth":"1200","viewHeight":"650","contains_view":"101_D_Bundesliga","buttonFont":"RobotoCondensed-BoldItalic","buttonFontColor":"#44739e","buttonText":"Schliessen","headerBackgroundColor":"#212722","titleFont":"RobotoCondensed-BoldItalic","titleColor":"white","title":"Bundesliga","titleFontSize":"17","showDivider":true,"dividerColor":"white","overlayColor":"silver","overlayOpacity":"0.8","buttonFullWidth":true,"footerHeight":"40","headerHeight":"40","footerBackgroundColor":"#2e2e2e","buttonFontSize":"19"},"style":{"left":"720px","top":"462px","width":"553px","height":"260px","z-index":"30"},"widgetSet":"materialdesign"}]
      Danke schon mal für deine Hilfe.
      • Iccube
        Iccube @Scrounger last edited by
        @Scrounger sorry das ich mich jetzt erst melde habe es aber nicht eher geschafft
        Anbei der auszug aus der Browser console
        • AxelF1977
          AxelF1977 @Scrounger last edited by AxelF1977
          Ich suche jetzt 2 Tagen die Vorlage für das View für die Zustände der Adapter aus dem Beispiel. Ich finde es nicht mehr.
          Hat einer den Link dazu?
          • Scrounger
            Scrounger Developer @AxelF1977 last edited by
            @AxelF1977
            https://github.com/Scrounger/ioBroker.vis-materialdesign#practical-examples
            Auf der github seite von MDW findest fast alle infos zu Widgets, Forum Links, praltische beispiele, etc.
            AxelF1977 1 Reply Last reply Reply Quote 1
            • AxelF1977
              @AxelF1977
              Danke!
                Conquest last edited by
                @Scrounger
                Hallo, konntest du was herausfinden warum das Dialog-Widget bei mir nicht in der Mitte öffnet?
                Scrounger C 2 Replies Last reply Reply Quote 0
                • Scrounger
                  Scrounger Developer @Conquest last edited by
                  @Conquest
                  Sorry bin ich noch nicht dazu gekommen.
                  Mach bitte ne issue bei GitHub, sonst vergesse ich das. Und ich brauche noch nen Export von deinem Projekt, weil ich nur mit dem wiget keinen Fehler finde.
                    @Conquest
                    Ok issue auf GitHub ist angelegt: https://github.com/Scrounger/ioBroker.vis-materialdesign/issues/82
                    Benötigst du mein komplettes Project als Export oder? Kann man nämlich leider nicht anonym Downloaden.
                    Starcon79 created this issue in Scrounger/ioBroker.vis-materialdesign
                    closed Dialog-Widget öffnet nicht in der Mitte des Bildschirms #82
                    • Scrounger
                      @Conquest
                      Reicht auch ein Beispiel Projekt, wo der Fehler auftritt.
                        @Conquest
                        Ok hoffe das reicht ansonsten schicke ich mein komplettes.
                        2020-05-18-Fehler.zip
                        • AxelF1977
                          @Scrounger Wie bereits eben angekündigt, hier nochmal meine Probleme, evtl. hilft Dir das weiter
                          Manchmal erscheinen Popup (Dialoge) doppelt beim Öffnen
                          Nach einigen Dialogen die geöffnet wurden, gibt es teils 2 verschiedene Szenarien. Einmal gehen sie nicht mehr auf und der Dialog verliert die eingestellte Optik
                          Dann kann es passieren, dass der überlagernde dunkle Hintergrund nicht mehr weg geht, und auf der Seite überlagernd bleibt
                          normal
                          überlagert
                          Und wenn alles geht, sieht es so aus
                            Conquest @Conquest last edited by
                            @Conquest sagte in Material Design Widgets: Dialog View Widget:
                            @Scrounger
                            @Scrounger
                            Hallo, ich habe die neue Version installiert das Problem besteht leider weiterhin.
                              micklafisch last edited by
                              Hallo Scrounger,
                              könntest du mir bitte zu diesem Thema: https://forum.iobroker.net/topic/23346/vorlage-variable-zeitsteuerung-mit-vis-editor/481 Hilfe leisten? Ich schaffe es nicht den Dialog View als Alternative zum "jqui container button" einzusetzen.
                              Danke schonmal.
                              • Scrounger
                                @Scrounger
                                @Scrounger
                                Deine Einstellung sind falsch. Du musst den Widgets in der View die du dem Dialog zugerodnet hast raltive breiten geben, also mit % arbeiten.
                                  heinzie @AxelF1977 last edited by
                                  @AxelF1977 finde ich sehr gut gemacht deine Oberfläche.
                                  Würdest Du diese ggf. zur Verfügung stellen?
                                  AxelF1977 1 Reply Last reply Reply Quote 0
                                  • AxelF1977
                                    AxelF1977 @heinzie last edited by
                                    @heinzie sagte in Material Design Widgets: Dialog View Widget:
                                    Danke für das Lob!
                                    Prinzipiell kann ich das mal komplett zur Verfügung stellen. Ich muss mal sehen ob ich das anonymisiert exportieren kann.
                                    Sobald ich fertig bin, ich baue es gerade stark um, mache ich nochmal ein Vorstellungsthema auf, um es zu teilen.
                                    Wenn Du noch ein bisschen warten kannst, denke ich kann das klappen.
                                    VG
                                      @AxelF1977 Vielen Dank im Voraus. Bin schon sehr gespannt
                                        @Scrounger
                                        @Scrounger
                                        Funktioniert jetzt. Das Problem war das view in Widget 8.
                                          bommel_030 @Oli last edited by
                                          @Oli
                                          Hattest du ein issue zum schließen erstellt?
                                          @Scrounger
                                          Was genau hab ich denn unter "fullscreenResolutionlower" zu verstehen?
                                          Lasse ich es beim Wetter Dialog auf den eingestellten 672 ist füllt das PopUp auf dem Handy die gesamte Breite aus.
                                          Allerdings werden Kopf- und Fußzeile nicht angezeigt. Setze ich den Wert auf 0 bzw. leer, dann sehe ich Kopf- und Fußzeile, aber trotz Breite von 100% werden auf dem Handy nur ca. 80% verwendet.
                                          • Scrounger
                                            Scrounger Developer @bommel_030 last edited by
                                            @bommel_030 sagte in Material Design Widgets: Dialog View Widget:
                                            Darüber steuert man, ob der Dialog im fullscreen (siehe erster Post 2. Scrennshot) geöffnet wird ober nicht. Wenn du hier z.B. 400 Eeinträgst, dann wir der Fullscreen Dialog angezeigt, wenn die Auflösungsbreite des screens kleiner 400px ist -> z.B. Handy Hochformat
                                            vis
                                            27
                                            83
                                            12904
