    4. host.iobroker Fehlermeldung
    UNSOLVED host.iobroker Fehlermeldung
      Thomas Braun Most Active @karstent last edited by
      @karstent node 12 installieren...
      Wo hängst du denn da nun mit node genau?
      nodejs -v && node -v && npm -v
      which nodejs && which node && which npm
      apt policy nodejs
        karstent @Thomas Braun last edited by
        @Thomas-Braun ```
        nodejs:
        Installiert: 10.20.1-1nodesource1
        Installationskandidat: 10.20.1-1nodesource1
        Versionstabelle:
        *** 10.20.1-1nodesource1 500
        500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
        100 /var/lib/dpkg/status
        4.8.2~dfsg-1 500
        500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
          @karstent
          Die anderen Ausgaben waren geheim?
            mehr kommt da nicht
            iobroker:~$ which nodejs && which node && which npm
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            ktrepte@iobroker:~$ apt policy nodejs
            nodejs:
              Versionstabelle:
                 4.8.2~dfsg-1 500
              @karstent
              iobroker update
              iobroker upgrade
                das ist alles:
                ktrepte@iobroker:~$ iobroker update
                internal/modules/cjs/loader.js:638
                    throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                    at startup (internal/bootstrap/node.js:283:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                ktrepte@iobroker:~$ iobroker upgrade
                    throw err;
                  @karstent
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                    wieder so eine Ellenlange Ausgabe:
                    ktrepte@iobroker:~$ cd /opt/iobroker
                    ktrepte@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                    > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                    > node lib/preinstallCheck.js
                    NPM version: 6.14.4
                    > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                    > node iobroker.js setup first
                    110 file(s) successfully synchronized with ioBroker storage.
                    Please DO NOT copy files manually into ioBroker storage directories!
                    The following notifications happened during sync:
                    - Added 94 Files in Directory "iqontrol.meta"
                    - Added 16 Files in Directory "javascript.admin"
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                    + iobroker.js-controller@2.2.10
                    added 59 packages from 83 contributors and audited 1498 packages in 48.098s
                    7 packages are looking for funding
                      run `npm fund` for details
                    found 76 vulnerabilities (56 low, 20 high)
                      run `npm audit fix` to fix them, or `npm audit` for details
                    ktrepte@iobroker:/opt/iobroker$ npm audit fix
                    npm ERR! code ELOCKVERIFY
                    npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
                    npm ERR!     Invalid: lock file's iobroker.admin@3.6.0 does not satisfy iobroker.admin@^4.1.1
                    npm ERR!     Missing: iobroker.alexa2@^3.1.2
                    npm ERR!     Missing: iobroker.backitup@^1.5.7
                    npm ERR!     Missing: iobroker.cloud@^2.6.2
                    npm ERR!     Missing: iobroker.devices@^0.3.6
                    npm ERR!     Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@^2.3.3
                    npm ERR!     Missing: iobroker.flot@^1.9.2
                    npm ERR!     Missing: iobroker.fritzdect@^0.3.2
                    npm ERR!     Missing: iobroker.history@^1.9.6
                    npm ERR!     Missing: iobroker.hm-rega@^2.6.7
                    npm ERR!     Missing: iobroker.hm-rpc@^1.14.2
                    npm ERR!     Missing: iobroker.ical@^1.7.0
                    npm ERR!     Missing: iobroker.influxdb@^1.8.6
                    npm ERR!     Invalid: lock file's iobroker.info@1.3.7 does not satisfy iobroker.info@^1.7.2
                    npm ERR!     Missing: iobroker.iot@^1.2.0
                    npm ERR!     Missing: iobroker.iqontrol@https://github.com/sbormann/ioBroker.iqontrol/tarball/master
                    npm ERR!     Missing: iobroker.javascript@^4.6.4
                    npm ERR!     Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@^2.2.10
                    npm ERR!     Missing: iobroker.meross@^1.3.13
                    npm ERR!     Missing: iobroker.mihome@^1.3.0
                    npm ERR!     Missing: iobroker.mobile@^0.5.0
                    npm ERR!     Missing: iobroker.mqtt@^2.1.3
                    npm ERR!     Missing: iobroker.mqtt-client@^1.3.1
                    npm ERR!     Missing: iobroker.node-red@^1.16.5
                    npm ERR!     Missing: iobroker.nut@^1.1.3
                    npm ERR!     Missing: iobroker.parser@^1.0.7
                    npm ERR!     Missing: iobroker.proxmox@^1.0.2
                    npm ERR!     Missing: iobroker.rickshaw@^1.0.0
                    npm ERR!     Missing: iobroker.scenes@^1.1.0
                    npm ERR!     Missing: iobroker.simple-api@^2.4.1
                    npm ERR!     Missing: iobroker.snmp@^0.5.0
                    npm ERR!     Missing: iobroker.socketio@^3.0.7
                    npm ERR!     Missing: iobroker.sonoff@^2.3.3
                    npm ERR!     Missing: iobroker.sql@^1.9.5
                    npm ERR!     Missing: iobroker.squeezebox@^1.0.0
                    npm ERR!     Missing: iobroker.statistics@^0.2.2
                    npm ERR!     Missing: iobroker.synology@^0.1.10
                    npm ERR!     Missing: iobroker.systeminfo@^0.3.1
                    npm ERR!     Missing: iobroker.terminal@^0.1.2
                    npm ERR!     Missing: iobroker.tr-064@^0.4.18
                    npm ERR!     Missing: iobroker.tr-064-community@https://github.com/iobroker-community-adapters/ioBroker.tr-064-community/tarball/master
                    npm ERR!     Missing: iobroker.upnp@^1.0.14
                    npm ERR!     Missing: iobroker.viessmannapi@^1.3.2
                    npm ERR!     Missing: iobroker.virtualpowermeter@^1.0.1
                    npm ERR!     Missing: iobroker.vis@^1.2.3
                    npm ERR!     Missing: iobroker.vis-hqwidgets@^1.1.2
                    npm ERR!     Missing: iobroker.vis-jqui-mfd@^1.0.12
                    npm ERR!     Missing: iobroker.web@^3.0.5
                    npm ERR!     /home/ktrepte/.npm/_logs/2020-05-18T20_42_42_679Z-debug.log
                      Nach dem ich die ioBroker Instanz wieder starten konnte ergibt sich folgendes im log:
                      host.iobroker	2020-05-18 22:49:03.812	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.iobroker	2020-05-18 22:49:03.812	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                      host.iobroker	2020-05-18 22:49:03.811	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                      host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                      host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                      host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                      host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                      host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                      host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                      host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                      host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                      host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                      host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                      host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: was compiled against a different Node.js version using
                      host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                      host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: ^
                      host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                      host.iobroker	2020-05-18 22:49:03.801	error	Caught by controller[0]: internal/modules/cjs/loader.js:807
                        @karstent
                        iobroker rebuild
                          Vielen Dank für deine Hilfe. Nach dem ich aus Verzweiflung noch einmal die befehle
                          cd /opt/iobroker
                          npm cache clean
                          sudo iobroker stop
                          sudo iobroker update
                          sudo iobroker upgrade self
                          sudo iobroker start
                          in die Console getippt habe hat sich, oh Wunder, die Instanz wieder selber zum leben erweckt. Im Moment habe ich keinerlei Fehlermeldungen mehr und der Controller ist jetzt dort wo er sein soll:
                          Typ: js-controller
                          Titel: JS controller
                          Verfügbar: 3.1.4
                          Installiert: 3.1.4
                          Also, vielen Dank noch mal 🙂
                            Stejin last edited by
                            sry fürs raus kramen, aber ich hatte das gleiche Problem, mir hat das update auf node12 geholfen!
                            sudo apt-get install curl software-properties-common
                            curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                            apt-get install nodejs
                            npm install iobroker.js-controller@3.1.4 --unsafe-perm --loglevel error --prefix "/opt/iobroker"
                            host.iobroker
                            2586
