    4. Test Adapter Alarm 3.6.x
      MartyBr @Kueppert last edited by
      @Kueppert
      Ich habe drei Buttons. In jedem Button schreibe in eine Ziffer in den Datenpunkt:
      Hier das Widget. Es zeigt aber nicht auf diesen Adapter, sonder auf eine Script-Lösung:
      [{"tpl":"tplJquiButtonState","data":{"oid":"javascript.0.Alarmanlage.Input.SwitchNumber","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"EXTERN","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"value":"3"},"style":{"left":"76px","top":"240px","background-color":"","z-index":"50"},"widgetSet":"jqui"}]
      • blauholsten
        blauholsten Developer @MartyBr last edited by
        @MartyBr sagte in Test Adapter Alarm 0.3.0:
        @blauholsten Wie groß sind denn die Spinnen bei Euch? 🕷
        groß....spaß
        War nur ein bsp.
        • blauholsten
          blauholsten Developer last edited by
          es gibt auf github eine neue Version, inkl. einen neuen DP, status.state_list.
          Bitte testen....
          Homer.J. M 2 Replies Last reply Reply Quote 0
          • Homer.J.
            Homer.J. @blauholsten last edited by
            Morgen @blauholsten gerade installiert ersten Tests sind Klasse, du hast jetzt noch burglar(4) mit eingearbeitet das ist Spitzte jetzt wird sogar wenn Alarm ausglöst wird es in der App Angezeige.
            Dann kann ich jetzt meine Anlage langsam umstellen. ☺
            Kannst du vieleicht im Log noch aufnehmen das der Warnkreis bei Aktivierung auch angezeigt wird.
            blauholsten 1 Reply Last reply Reply Quote 0
              MartyBr @blauholsten last edited by MartyBr
              @blauholsten
              Es geht ja schnell weiter! Eine Frage noch zur Umschaltung:
              Kann ich die Warnkreise direkt umschalten oder muss ich dazwischen immer ein "disable" setzen?
              Könntest du bitte den DP use.list mit seinen Werten beschreiben? Habe gerade bei Homer.J gelesen, dass du den Wert "4" eingefügt hast.
              Ich habe durch ausprobieren folgende Werte gefunden:
              0 disable
              1 enable
              2 sharp inside
              3 nightrest
              Kann ich die Anlage von 1=enable direkt auf 2=sharpinside umstellen?
                @blauholsten
                Deine Katze hätte ja auch Spinne heißen können.......
                (Spaß)
                • blauholsten
                  blauholsten Developer @Homer.J. last edited by
                  @Homer-J
                  sollte jetzt gehen, hatte aber noch keine Zeit zum testen.
                  • blauholsten
                    @blauholsten
                    sollte ohne disable gehen!
                    der Wert 4 ist bei dem DP status.state_list
                    0 disable
                    1 enable
                    2 sharp inside
                    3 nightrest
                    du kannst im Objektbaum in den Datenpunkt schauen.
                    Ich habe gerade mitbekommen das es noch ein Fehler gab, in der 0.5.5 sollte es behoben sein! Bitte mal testen.
                    Aber von aktiviert auf inter scharf ist nicht möglich.
                    M Homer.J. 3 Replies Last reply Reply Quote 0
                      @blauholsten
                      Okay, lade ich runter. Wenn ich den Status umschalte, also von intern scharf auf extern scharf (= Status 1) muss ich immer ein unscharf (status =0) einlegen?
                      • Homer.J.
                        Homer.J. @blauholsten last edited by Homer.J.
                        @blauholsten Log geht jetzt auch.👍
                        Frage. Wenn jetzt zum Beispiel der Warnkreis auf true geht bei Veränderung schaltet dieser erst nach der eingestellten Zeit auf false zurück,
                        kann man es noch einbauen das dieser auch bei deaktivierung auf false geht.
                        Grund wenn ich den Datenpunkt jetzt für eine Innensirene nutze läuft diese dann die ganze Zeit die eingestellt ist.
                          @blauholsten
                          Ich bin nun auf der 0.5.5
                          Hier mein Script für die Umschaltung der Stati:
                          // Alarm-Trigger
                          // Alarm-Adapter
                          use.list Datenpunkte
                          0	disable
                          1	enable
                          2	sharp inside
                          3	nightrest
                          var idDPlist = 'alarm.0.use.list';
                          // Unscharf
                          var idDP0 = 'alias.0.Status.Alarm_Status.Alarm_unscharf_aktiv';
                          var idDP1 = 'alarm.0.use.disable';
                          // Intern
                          var idDP2 = 'alias.0.Status.Alarm_Status.Alarm_intern_aktiv';
                          var idDP3 = 'alarm.0.use.enable';
                          // Extern
                          var idDP4 = 'alias.0.Status.Alarm_Status.Alarm_extern_aktiv';
                          var idDP5 = 'alarm.0.use.enable';
                          // Enable mit Delay
                          var idDP10 = 'alarm.0.use.enable_with_delay';
                          // Nachtruhe
                          var idDP6 = 'alarm.0.use.activate_nightrest'; // Aktivieren
                          var idDP7 = 'alarm.0.use.deactivate_nightrest'; // Deaktivieren
                          // Warnkreis
                          var idDP8 = 'alarm.0.use.activate_warn_circuit';
                          var idDP9 = 'alarm.0.use.deactivate_warn_circuit';
                          // Enable mit Delay
                          // alarm.0.use.enable_with_delay
                          // ==================   Trigger   ====================
                          // Unscharf
                          on(idDP0, function (dp) {
                                  if(dp.state.val) {
                                      setState(idDPlist,0);
                                      sendTo('telegram.0',
                                                  text: 'Alarmstatus auf UNSCHARF geschaltet',
                                                  caption: 'Alarmstatus auf UNSCHARF geschaltet',
                                                  chatId: 'xxxxxxx'
                          // Intern
                          on(idDP2, function (dp) {
                                  if(dp.state.val) {
                                      setState(idDPlist,2);
                                                  text: 'Alarmstatus auf INTERN geschaltet',
                                                  caption: 'Alarmstatus auf INTERN geschaltet',
                                                  chatId: '2xxxxx'
                          // Extern
                          on(idDP4, function (dp) {
                                  if(dp.state.val) {
                                      setState(idDP10,true);
                                                  text: 'Alarmstatus auf EXTERN geschaltet',
                                                  caption: 'Alarmstatus auf EXTERN geschaltet',
                                                  chatId: 'xxxxxxxx'
                          Ich habe drei Datenpunkte, die ich für die Alarmanlage nutze. Diese werden durch ein externes Script erzeugt:
                          Damit schalte ich den Status der Alarmanlage.
                          Kann ich die Umschaltung der verschiedenen Modi so lassen oder siehst du hier Probleme? Die Telegram Meldungen habe ich zum testen eingebaut.
                          • blauholsten
                            @blauholsten
                            sollte in der 0.5.5 nicht so sein!
                            M Homer.J. 2 Replies Last reply Reply Quote 0
                              @blauholsten Also kann ich mein Script so belassen?
                              • blauholsten
                                @MartyBr
                                muss ich mir später anschauen, mein Junge lässt mich gerade nicht denken
                                M siggi85 2 Replies Last reply Reply Quote 0
                                  @blauholsten
                                  das ist auch wichtiger, dafür habe ich vollstes Verständnis.
                                  • siggi85
                                    siggi85 @blauholsten last edited by siggi85
                                    @blauholsten Vielleicht noch den "toggle" Datenpunkten die Rolle "switch" und den "enable/activate" und "disable/deactivate" Datenpunkten die Rollen "button" mitgeben. Dann kann man das in GUIs (ich nutze iQontrol) ohne manuelle Anpassungen direkt nutzen.
                                    EDIT: Und die Statusänderugen (egal über welchen Datenpunkt sie ausgelöst werden), sollten die Switchdatenpunkte und auch den List Datenpunkt am besten auch aktualisieren.
                                    1. Kann man dann sogar einige Datenpunkte unter Status sparen (die Switche zeigen dann ja immer den aktuellen Status an)
                                    2. Kann man alle Datenpunkte zur Konfiguration verwenden, ohne dass es Inkonsistenzen gibt. Aktuell muss man sich festlegen, List? Switch-DP? Button DPs? Falls man nämlich mischt, kann es sein, dass die Alarmanlage über den Switch Datenpunkt aktiviert wurde, der list-Datenpunkt zeigt aber disable(0) an. Das wirkt in oberflächen dann verwirrend.
                                    Zum Adapter selber: Ich werde langsam warm mit ihm und den Warnkreisen. Gefällt mir dadurch immer besser. 😄
                                    blauholsten 1 Reply Last reply Reply Quote 1
                                    • Homer.J.
                                      @blauholsten kleine Sache noch wenn man etwas mit dem Datenpunkt status_warn_circuit_activated verknüpft geht das nicht, ersetze ich diesen mit status_sleep geht es wunderbar.
                                      • blauholsten
                                        @Homer-J sagte in Test Adapter Alarm 0.3.0:
                                        sollte in 0.5.6 gehen
                                        Homer.J. 1 Reply Last reply Reply Quote 0
                                        • blauholsten
                                          blauholsten Developer @siggi85 last edited by
                                          @siggi85 sagte in Test Adapter Alarm 0.3.0:
                                          habe ich in der 0.5.6. eingefügt, da ich bei den Rollen nicht auf dem besten Wissenstand bin, habe ich bei anderen Adaptern geschaut und die Bezeichnung erweitert. Geht das so?
                                          Das ist absolut sinnig, aber etwas Aufwand. Ich werde das versuchen die Tage umzusetzen.
                                          Freut mich
                                          siggi85 1 Reply Last reply Reply Quote 2
                                          • siggi85
                                            @blauholsten Heute ist leider zu spät für mich und morgen fahren wir ein paar Tage weg. Hoffentlich schaffe ich es, mir das morgen noch Mal anzuschauen. Auf jeden Fall super wie schnell hier auf Vorschläge eingegangen wird. 👍 Keep up the good work!
                                            alarm alarmanlage alarmsystem
                                            111
                                            1368
                                            554166
