    5. [Gelöst] Blockly startet alle 50 Minuten
      biker1602 @Jan1 last edited by biker1602
        <variables>
        </variables>
        <block type="on_ext" id="_GAXpeZECET+^MD+kDHC" x="-1021" y="-645">
          <value name="OID0">
            <shadow type="field_oid" id="xlgd^bXjY%1%OW96sm8~">
              <field name="oid">zigbee.0.00158d00045c9632.contact</field>
            <block type="timeouts_settimeout" id="EXO!NZp7=cz87vC0c;HS">
              <field name="DELAY">20</field>
                <block type="controls_if" id="mq*s5ki-0uH;+BVng#;w">
                    <block type="logic_compare" id="MnW4/UD`*^5@T[]Yv_c+">
                      <field name="OP">EQ</field>
                        <block type="get_value" id="*Y;;k1txUFXPx6L[?Uyh">
                          <field name="OID">zigbee.0.00158d00045c9632.contact</field>
                        <block type="logic_boolean" id="!bepK1hm;bZtvX)!sT,5">
                    <block type="control" id="%6P_@g_DpJ/cikTJI(U;">
                      <field name="OID">fritzdect.0.Comet_099950285545.mode</field>
                        <block type="math_number" id="gx2$(+W}8Wo9z|@o}:ER">
                          <field name="NUM">1</field>
                        <block type="control" id="5=2EA1LTs`,t7Xc8}Wj6">
                          <field name="OID">fritzdect.0.Comet_099950290397.mode</field>
                            <block type="math_number" id="CM6,IJyYAH1??64z(|]C">
                            <block type="control" id="AV2f[=n.g?[+S-9|@Qi9">
                              <field name="OID">fritzdect.0.Comet_119630410624.mode</field>
                                <block type="math_number" id="rqMuKRzIV)9@IRW{X?u%">
                                <block type="control" id="xDvh==g:|Oc05+,04D%p">
                                  <field name="OID">alexa2.0.Echo-Devices.G090LA09738502FL.Commands.speak</field>
                                    <block type="text" id="eL06WLH-XvHB^r@@vu+I">
                                      <field name="TEXT">Balkontür ist geöffnet</field>
                    <block type="controls_if" id=";6,4F:.Q*{/?J*dj$oh8">
                        <block type="logic_compare" id="WtHg}F=Fw}3I4.;BI+2t">
                            <block type="get_value" id=";XSV.HxXn]mXz2=)L9nv">
                            <block type="logic_boolean" id="]O1F:ulDH~#IksCoB=4q">
                        <block type="control" id="1J7))iXa=j{K$BuBez07">
                            <block type="math_number" id="|aG:n~Hk7nZy)zJ?nZ9@">
                              <field name="NUM">0</field>
                            <block type="control" id="RDwFqoEaESSrJI$43|E+">
                                <block type="math_number" id="7-TUZ:kc)6{,O1r$II*-">
                                <block type="control" id="0x7MQ%r/{!b:exTIf{!~">
                                    <block type="text" id="U}F,vgf,SWJlM4FYG:Yt">
                                      <field name="TEXT">Balkontür ist geschlossen</field>
                                    <block type="timeouts_cleartimeout" id="xk]d6Se:n2C~Q{IqN?0d">
        @Jan1 Das war so bestimmt verkehrt oder?
          Jan1 @biker1602 last edited by
          @biker1602
          in Code Tacks, das sind die Klammern oben, fünftes Symbol von links. Editiere das oben einfach noch mal.
            @biker1602
            <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="_GAXpeZECET+^MD+kDHC" x="-1021" y="-645">
             <value name="OID0">
                           <block type="logic_negate" id="++#j*R[f~CR5FOd)nR.@">
                             <value name="BOOL">
                               <block type="on_source" id="?eqA{eX|ra53bCorA!=U">
                         <value name="IF1">
                           <block type="on_source" id="NsrrNXHCLEGJ1SYpx)FK">
                         <statement name="DO1">
              crunchip Forum Testing Most Active @Jan1 last edited by
              @Jan1 genau so meinte ich es, wobei ich der Meinung bin, das
              sonst falls Wert
              weggelassen werden kann
                Jan1 @crunchip last edited by Jan1
                @crunchip
                ja kann weg, da "sonst falls" eh dem "falsch" entspricht und somit ein einfaches "sonst" auch reicht 😉
                Normal fängt man auch mit der Abfrage auf wahr an und ich habs so gelassen um das mit "nicht" "Wert" leichter zu zeigen.
                  @Jan1 das hätte ich so ja nie hinbekommen vielen Dank.
                  Du bist ja richtig fit. Darf ich dich nochmal zu einem anderen Problem befragen?
                    @biker1602
                    Klar und das hättest auch ohne Hilfe geschafft, war ja nicht wirklich falsch und es gibt massig Beispiele hier wie man das lösen kann. Es gibt eben nicht nur einen Weg der Lösung, sondern immer mehrere.
                      @Jan1 Also ich habe es als neues Script angelegt und gestartet aber Alexa sagt jetzt nichts mehr?
                        Jan1 @biker1602 last edited by Jan1
                        @biker1602
                        baue debug Blöcke ein und schau was noch ausgeführt wird, dann weißt wo es klemmt
                        Das sollte so laufen, da sich an der Funktion nichts geändert hat.
                        Im übrigen kannst das Thermostat abschalten auch weg lassen, weil die Fritz das nur alle 10 Minuten synchronisiert und die Tür dann schon 10 Minuten offen sein muss, bevor das überhaupt greift 😉
                         <variables>
                         </variables>
                         <block type="on_ext" id="_GAXpeZECET+^MD+kDHC" x="-1012" y="-737">
                           <value name="OID0">
                             <block type="debug" id="=EnWBy*1qXGjE3:8DH-i">
                               <value name="TEXT">
                                 <shadow type="text" id="y-F3C]{[XnbWvh3dvWZ{">
                                   <field name="TEXT">trigger ok</field>
                                         <block type="debug" id="I5y!{aHK?AC|L=NPW!TT">
                                           <value name="TEXT">
                                             <shadow type="text" id="]N~%ExNo+Gw{,o]=Gyj%">
                                               <field name="TEXT">timeout ok</field>
                                                   <value name="BOOL">
                                                 <block type="debug" id="X*(/$a:trI{Hp:mk*ia}">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="jV!owF+puWVZ1tsQ)57v">
                                                       <field name="TEXT">Heizung an ok</field>
                                               <statement name="ELSE">
                                                 <block type="debug" id="*ayuytZBd.|BIY?ebl8v">
                                                   <value name="TEXT">
                                                     <shadow type="text" id=")-ZZ=wFtEF^_~F!a9U|}">
                                                       <field name="TEXT">Heizung aus ok</field>
                          @Jan1 Jetzt nochmal eine anderes Problem wo du mir vielleicht helfen kannst. An der Balkontür wo der Sensor ist, habe ich von innen ein Rollo was über Funk läuft mit einem Broadlink. Ich habe die Befehle Hoch runter und Stopp angelernt. Ich würde das auch gerne so wie ich es jetzt an dem feststehenden Fensterteil über eine Routine mit Alexa habe das bei Sonnenaufgang hoch Sonnenuntergang automatisch heruntermachen. Mein Problem ist mit der Balkontür das das Rollo bei geöffnetem Fenster z.B. im Sommer nicht heruntergehen darf, wenn die Tür auf ist. Dieses wollte ich mit einem Blockly versuchen was prüft ob das Fenster auf ist und das Herunterfahren blockiert. Ich weiß nicht wo ich den Punkt vom Rollo hernehmen soll denn ich denke man braucht einen Datenpunk den man selber erstellt oder?
                          Vielleicht hast du ja eine Idee.
                          • haselchen
                            haselchen Most Active @biker1602 last edited by
                            @biker1602
                            Bitte erstmal das eine Thema beenden und dann ein Neues (neuer Thread) anfangen.
                              biker1602 @haselchen last edited by
                              @haselchen wo kann ich es beenden oder als erledigt markieren?
                              • haselchen
                                @biker1602
                                Entweder rechts bei den 3 Punkten
                                Oder Du schreibst im 1.Beitrag [Gelöst] vor deinem Threadtitel
                                blockly
                                1079
