    4. [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb"
      Thomas Braun Most Active @Australier last edited by
      @Australier Du scheinst da einen kruden Mix aus 'latest' (Beta) und 'default' (Stable) zu fahren.
      nodejs -v && node -v && npm -v
      iobroker version
        Australier @Thomas Braun last edited by
        @Thomas-Braun
        root@20c8e6bb5f55:/opt/iobroker# iobroker version
        2.2.9
        root@20c8e6bb5f55:/opt/iobroker# nodejs -v && node -v && npm -v
        v10.20.1
        v10.20.1
        6.14.4
          @Australier
          iobroker fix
            @Thomas-Braun said in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
            iobroker fix
            root@20c8e6bb5f55:/opt/iobroker# iobroker fix
            Commands:
            iobroker setup [--objects <host>] [--states <host>] [custom]
            iobroker start
            iobroker stop
            iobroker start <adapter>
            iobroker stop <adapter>
            iobroker start all
            iobroker restart
            iobroker restart <adapter>
            iobroker info
            iobroker logs [adapter] [--watch] [--lines=1000]
            iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
            iobroker install <adapter>
            iobroker url <url> [<name>]
            iobroker del <adapter>
            iobroker del <adapter>.<instance>
            iobroker update [repository url] [--updatable/--u] [--installed/--i]
            iobroker upgrade [repository url]
            iobroker upgrade self [repository url]
            iobroker upgrade <adapter> [repository url]
            iobroker upload <pathToLocalFile> <pathIniobroker>
            iobroker upload all
            iobroker upload <adapter>
            iobroker object get <id>
            iobroker object set <id> <json-value>
            iobroker object set <id> propertyname=value
            iobroker object del <id|pattern> [--yes]
            iobroker object chmod <object-mode> [state-mode] <id>
            iobroker object chown <user> <group> <id>
            iobroker object list <id>
            iobroker state get <id>
            iobroker state getplain <id> [--pretty]
            iobroker state getvalue <id>
            iobroker state set <id> <value> [ack]
            iobroker state del <id>
            iobroker message <adapter>[.instanceid] <command> [<message>]
            iobroker list <type> [filter]
            iobroker chmod <mode> <file>
            iobroker chown <user> <group> <file>
            iobroker touch <file>
            iobroker rm <file>
            iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
            iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
            iobroker file rm <iobroker-path-to-delete>
            iobroker file sync
            iobroker user add <user> [--ingroup group] [--password pass]
            iobroker user del <user>
            iobroker user passwd <user> [--password pass]
            iobroker user enable <user>
            iobroker user disable <user>
            iobroker user get <user>
            iobroker user check <user> [--password pass]
            iobroker group add <group>
            iobroker group del <group>
            iobroker group list <group>
            iobroker group enable <group>
            iobroker group disable <group>
            iobroker group get <group>
            iobroker group adduser <group> <user>
            iobroker group deluser <group> <user>
            iobroker host this
            iobroker host <hostname>
            iobroker host set <hostname>
            iobroker host remove <hostname>
            iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
            iobroker license <license.file or license.text>
            iobroker cert create
            iobroker cert view [<certificate name>]
            iobroker clean
            iobroker backup
            iobroker restore <backup name or path>
            iobroker validate <backup name or path>
            iobroker <command> --timeout 5000
            iobroker status [all]
            iobroker repo [name]
            iobroker repo add <name> <path or url>
            iobroker repo set <name>
            iobroker repo del <name>
            iobroker uuid
            iobroker unsetup
            iobroker fix
            iobroker multihost <enable|disable> [--secure true|false]
            iobroker multihost browse
            iobroker multihost connect
            iobroker compact status
            iobroker compact <enable|on|disable|off>
            iobroker compact <adapter>.<instance> status
            iobroker compact <adapter>.<instance> group <group-id>
            iobroker compact <adapter>.<instance> <disable|off>
            iobroker compact <adapter>.<instance> <enable|on> [group-id]
            iobroker version [adapter]
            iobroker [adapter] -v
            Optionen:
              --help     Hilfe anzeigen  [boolean]
              --version  Version anzeigen  [boolean]
            harrym 1 Reply Last reply Reply Quote 0
            • harrym
              harrym @Australier last edited by
              @Australier zuerst ..... iobroker stop 😉
                Australier @harrym last edited by
                @harrym
                root@20c8e6bb5f55:/opt/iobroker# iobroker stop
                iobroker controller daemon is not running
                Commands:
                iobroker start
                iobroker stop
                iobroker start all
                iobroker restart
                iobroker info
                iobroker upload all
                iobroker rm <file>
                iobroker file sync
                iobroker host this
                iobroker clean
                iobroker backup
                iobroker uuid
                iobroker unsetup
                iobroker fix
                Optionen:
                root@20c8e6bb5f55:/opt/iobroker# iobroker start
                Starting iobroker controller daemon...
                iobroker controller daemon started. PID: 2304
                A harrym 2 Replies Last reply Reply Quote 0
                  crunchip Forum Testing Most Active @Australier last edited by crunchip
                  @Australier sagte in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
                  Bei mir läuft iobroker im Docker-Container von buanet
                  @Thomas-Braun siehe FAQ https://forum.iobroker.net/post/231178
                    Australier @Australier last edited by
                    @Australier nach Neustart ist der Admin-Adapter immer noch auf der alten Version:
                    root@20c8e6bb5f55:/opt/iobroker# iobroker list adapters
                    system.adapter.admin                   : admin          - v3.7.8
                    system.adapter.hm-rpc                  : hm-rpc         - v1.14.2
                    system.adapter.hm-rega                 : hm-rega        - v2.5.5
                    system.adapte
                    ich versuche jetzt noch einmal die version, update und upgrade-Kommandos, mal schauen ob er sie jetzt nimmt.
                    • harrym
                      @Australier du musst de "alte" variante vom fixer benutzen !
                      curl -sL https://iobroker.net/fix.sh | bash -
                        @harrym said in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
                        system.adapter.web                     : web            - v3.0.8
                        system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
                        system.adapter.dwd                     : dwd            - v2.4.6
                        system.adapter.icons-fatcow-hosting    : icons-fatcow-hosting - v0.1.0
                        system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
                        system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
                        system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
                        system.adapter.icons-icons8            : icons-icons8   - v0.0.1
                        system.adapter.tankerkoenig            : tankerkoenig   - v1.0.4
                        system.adapter.hue                     : hue            - v3.2.3
                        system.adapter.fritzbox                : fritzbox       - v0.2.1
                        system.adapter.yamaha                  : yamaha         - v0.3.19
                        system.adapter.samsung                 : samsung        - v0.2.9
                        system.adapter.telegram                : telegram       - v1.5.9
                        system.adapter.flot                    : flot           - v1.9.2
                        system.adapter.scenes                  : scenes         - v1.1.0
                        system.adapter.yr                      : yr             - v2.0.3
                        system.adapter.find-my-iphone          : find-my-iphone - v0.2.15
                        system.adapter.rickshaw                : rickshaw       - v1.0.0
                        system.adapter.icons-material-png      : icons-material-png - v0.1.0
                        system.adapter.weatherunderground      : weatherunderground - v3.1.6
                        system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
                        system.adapter.sayit                   : sayit          - v1.9.4
                        system.adapter.email                   : email          - v1.0.5
                        system.adapter.socketio                : socketio       - v3.0.7
                        system.adapter.simple-api              : simple-api     - v2.4.5
                        system.adapter.javascript              : javascript     - v4.3.4
                        system.adapter.text2command            : text2command   - v1.3.0
                        system.adapter.ping                    : ping           - v1.4.7
                        system.adapter.node-red                : node-red       - v1.13.0
                        system.adapter.sql                     : sql            - v1.12.5
                        system.adapter.history                 : history        - v1.9.6
                        system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
                        system.adapter.feiertage               : feiertage      - v1.0.17
                        system.adapter.parser                  : parser         - v1.0.7
                        system.adapter.tvspielfilm             : tvspielfilm    - v1.0.4
                        system.adapter.upnp                    : upnp           - v1.0.16
                        system.adapter.mobile                  : mobile         - v0.5.0
                        system.adapter.discovery               : discovery      - v2.3.5
                        system.adapter.geofency                : geofency       - v0.3.2
                        system.adapter.vis-beta                : vis-beta       - v0.14.1
                        system.adapter.vis                     : vis            - v1.2.4
                        system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
                        system.adapter.amazon-dash             : amazon-dash    - v0.2.7
                        system.adapter.radar                   : radar          - v1.1.3
                        system.adapter.vis-bars                : vis-bars       - v0.1.4
                        system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
                        system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
                        system.adapter.vis-history             : vis-history    - v1.0.0
                        system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
                        system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                        system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                        system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
                        system.adapter.vis-lcars               : vis-lcars      - v1.0.4
                        system.adapter.vis-map                 : vis-map        - v1.0.4
                        system.adapter.vis-metro               : vis-metro      - v1.1.2
                        system.adapter.vis-players             : vis-players    - v0.1.5
                        system.adapter.vis-plumb               : vis-plumb      - v1.0.1
                        system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
                        system.adapter.solarwetter             : solarwetter    - v1.0.0
                        system.adapter.homekit2                : homekit2       - v0.1.6
                        system.adapter.yahka                   : yahka          - v0.7.1
                        system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
                        system.adapter.ical                    : ical           - v1.7.0
                        system.adapter.unifi                   : unifi          - v0.4.3
                        system.adapter.nut                     : nut            - v1.1.3
                        system.adapter.vis-weather             : vis-weather    - v2.5.2
                        system.adapter.pushover                : pushover       - v1.2.3
                        system.adapter.backitup                : backitup       - v1.4.5
                        system.adapter.daswetter               : daswetter      - v2.8.1
                        system.adapter.cloud                   : cloud          - v3.0.3
                        system.adapter.musiccast               : musiccast      - v0.1.3
                        system.adapter.info                    : info           - v1.5.6
                        system.adapter.influxdb                : influxdb       - v1.7.0
                        system.adapter.pollenflug              : pollenflug     - v1.0.4
                        system.adapter.alexa2                  : alexa2         - v3.0.5
                        system.adapter.fullybrowser            : fullybrowser   - v1.0.0
                        system.adapter.tr-064-community        : tr-064-community - v1.0.0
                        system.adapter.shelly                  : shelly         - v3.1.6
                        system.adapter.harmony                 : harmony        - v1.2.2
                        Stopping iobroker controller daemon...
                        iobroker controller daemon stopped.
                        No "killall.sh" script found. Just stop.
                        root@20c8e6bb5f55:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
                        library: loaded
                        Library version=2020-04-12
                        ioBroker or some processes are still running:
                         io.admin.0
                         io.web.0
                         io.tankerkoenig.0
                         io.hue.0
                         io.yamaha.0
                         io.telegram.0
                         io.scenes.0
                         io.email.0
                         io.socketio.0
                         io.javascript.0
                         io.ping.0
                         io.history.0
                         io.hue.2
                         io.hue.4
                         io.hue.5
                         io.unifi.0
                         io.nut.0
                         io.backitup.0
                         io.influxdb.0
                         io.pollenflug.0
                         io.sql.0
                         io.pushover.0
                         io.fullybrowser.0
                         io.shelly.0
                         io.harmony.0
                         io.alexa2.0
                         io.dwd.0
                        Please stop them first and try again!
                        library: loaded
                         io.admin.0
                         io.web.0
                         io.tankerkoenig.0
                         io.hue.0
                         io.yamaha.0
                         io.telegram.0
                         io.scenes.0
                         io.email.0
                         io.socketio.0
                         io.javascript.0
                         io.ping.0
                         io.history.0
                         io.hue.2
                         io.hue.4
                         io.hue.5
                         io.unifi.0
                         io.nut.0
                         io.backitup.0
                         io.influxdb.0
                         io.pollenflug.0
                         io.sql.0
                         io.pushover.0
                         io.fullybrowser.0
                         io.shelly.0
                         io.harmony.0
                         io.alexa2.0
                         io.ical.0
                         io.ical.0
                        library: loaded
                         io.admin.0
                         io.web.0
                         io.tankerkoenig.0
                         io.hue.0
                         io.yamaha.0
                         io.telegram.0
                         io.scenes.0
                         io.email.0
                         io.socketio.0
                         io.javascript.0
                         io.ping.0
                         io.history.0
                         io.hue.2
                         io.hue.4
                         io.hue.5
                         io.unifi.0
                         io.nut.0
                         io.backitup.0
                         io.influxdb.0
                         io.pollenflug.0
                         io.sql.0
                         io.pushover.0
                         io.fullybrowser.0
                         io.shelly.0
                         io.harmony.0
                         io.alexa2.0
                         io.dwd.0
                        • harrym
                          harrym @Australier last edited by harrym
                          iobroker stop ..... ?
                          der broker sagt dir doch eh alles, was zu tun ist ..... muss man halt auch lesen 😉 (ist jetzt nicht böse gemeint!)
                            @harrym War das das falsche Kommando?
                            harrym A 2 Replies Last reply Reply Quote 0
                            • harrym
                              @Australier ne! zuerst den broker mit .... iobroker stop ... stoppen ..... DANN den fixer via curl laden und ausführen.
                                @Australier D. h. alle Prozesse Einzel stoppen z. B. iobroker stop admin
                                • harrym
                                  @Australier NEIN!
                                  einfach "iobroker stop" machen ..... dann den fixer laufen lassen .... danach wieder "iobroker start"
                                    @harrym Das hatte ich doch mehrfach gemacht, ok ich mach es noch einmal.
                                    • harrym
                                      @Australier du hast aber immer versucht "iobroker fix" zu machen ^_^ nimm die ganze zeile mit dem curl ....
                                        @Australier ```
                                        library: loaded
                                        io.admin.0
                                        io.web.0
                                        io.tankerkoenig.0
                                        io.hue.0
                                        io.yamaha.0
                                        io.telegram.0
                                        io.scenes.0
                                        io.email.0
                                        io.socketio.0
                                        io.javascript.0
                                        io.ping.0
                                        io.history.0
                                        io.hue.2
                                        io.hue.4
                                        io.hue.5
                                        io.unifi.0
                                        io.nut.0
                                        io.backitup.0
                                        io.influxdb.0
                                        io.pollenflug.0
                                        io.sql.0
                                        io.pushover.0
                                        io.fullybrowser.0
                                        io.shelly.0
                                        io.harmony.0
                                        io.alexa2.0
                                        • harrym
                                          @Australier warten! g dauert bis alles gestoppt wurde .... kommt auf die hardware an!
                                            Thomas Braun Most Active @harrym last edited by
                                            @harrym
                                            Oder mit
                                            pkill io
                                            ran.
                                            cloud
                                            75
                                            414
                                            64662
