    4. ioBroker.web Problem
    UNSOLVED ioBroker.web Problem
    • Heimann
      Heimann last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspian
      Node-Version: 12.16.3
      Nodejs-Version: 12.16.3
      NPM-Version: 6.14.4
      Installationsart: Skript
      Image genutzt: Ja
      Info: Update von 3.0.7 auf 3.0.8 nicht möglich. Nach der Deinstallation keine Neuinstallation möglich.
      Ort/Name der Imagedatei: Screenshot_2020-05-19 adapters - ioBroker.png ![Link](image url)
        Thomas Braun Most Active @Heimann last edited by Thomas Braun
        @Heimann
        In /opt/iobroker
        iobroker rebuild iobroker.web --install
        versuchen.
        • Heimann
          Wenn ich das eingebe kommen folgende Zeilen, aber der Adapter ist nicht installiert. 😢
          pi@raspberrypi:/opt/iobroker $ iobroker rebuild iobroker.web --install
          Commands:
          iobroker setup [--objects <host>] [--states <host>] [custom]
          iobroker start
          iobroker stop
          iobroker start <adapter>
          iobroker stop <adapter>
          iobroker start all
          iobroker restart
          iobroker restart <adapter>
          iobroker info
          iobroker logs [adapter] [--watch] [--lines=1000]
          iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
          iobroker install <adapter>
          iobroker url <url> [<name>]
          iobroker del <adapter>
          iobroker del <adapter>.<instance>
          iobroker update [repository url] [--updatable/--u] [--installed/--i]
          iobroker upgrade [repository url]
          iobroker upgrade self [repository url]
          iobroker upgrade <adapter> [repository url]
          iobroker upload <pathToLocalFile> <pathIniobroker>
          iobroker upload all
          iobroker upload <adapter>
          iobroker object get <id>
          iobroker object set <id> <json-value>
          iobroker object set <id> propertyname=value
          iobroker object del <id|pattern> [--yes]
          iobroker object chmod <object-mode> [state-mode] <id>
          iobroker object chown <user> <group> <id>
          iobroker object list <id>
          iobroker state get <id>
          iobroker state getplain <id> [--pretty]
          iobroker state getvalue <id>
          iobroker state set <id> <value> [ack]
          iobroker state del <id>
          iobroker message <adapter>[.instanceid] <command> [<message>]
          iobroker list <type> [filter]
          iobroker chmod <mode> <file>
          iobroker chown <user> <group> <file>
          iobroker touch <file>
          iobroker rm <file>
          iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
          iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
          iobroker file rm <iobroker-path-to-delete>
          iobroker file sync
          iobroker user add <user> [--ingroup group] [--password pass]
          iobroker user del <user>
          iobroker user passwd <user> [--password pass]
          iobroker user enable <user>
          iobroker user disable <user>
          iobroker user get <user>
          iobroker user check <user> [--password pass]
          iobroker group add <group>
          iobroker group del <group>
          iobroker group list <group>
          iobroker group enable <group>
          iobroker group disable <group>
          iobroker group get <group>
          iobroker group adduser <group> <user>
          iobroker group deluser <group> <user>
          iobroker host this
          iobroker host <hostname>
          iobroker host set <hostname>
          iobroker host remove <hostname>
          iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
          iobroker license <license.file or license.text>
          iobroker cert create
          iobroker cert view [<certificate name>]
          iobroker clean
          iobroker backup
          iobroker restore <backup name or path>
          iobroker validate <backup name or path>
          iobroker <command> --timeout 5000
          iobroker status [all]
          iobroker repo [name]
          iobroker repo add <name> <path or url>
          iobroker repo set <name>
          iobroker repo del <name>
          iobroker uuid
          iobroker unsetup
          iobroker fix
          iobroker multihost <enable|disable> [--secure true|false]
          iobroker multihost browse
          iobroker multihost connect
          iobroker compact status
          iobroker compact <enable|on|disable|off>
          iobroker compact <adapter>.<instance> status
          iobroker compact <adapter>.<instance> group <group-id>
          iobroker compact <adapter>.<instance> <disable|off>
          iobroker compact <adapter>.<instance> <enable|on> [group-id]
          iobroker version [adapter]
          iobroker [adapter] -v
          Options:
          --help Hilfe anzeigen [boolean]
          --version Version anzeigen [boolean]
            @Heimann sagte in ioBroker.web Problem:
            iobroker install web
            • Heimann
              Dann kommt :
              pi@raspberrypi:/opt/iobroker $ iobroker install web
              NPM version: 6.14.4
              npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
              npm ERR! code EINTEGRITY
              npm ERR! errno EINTEGRITY
              npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/mime-types: Integrity verification failed for sha512-pqrfpctgKFrIQ1AXVx9p03WTeag2merZ1Drv2Izy2F7FqRA+AGrOIRYtPmTdRIFonEv1UFSXqogdKkMtmLIrnQ== (/home/iobroker/.npm/_cacache/content-v2/sha512/a6/aa/dfa5cb60285ac8435017571f69d3759379a83699ead9d43aefd88cf2d85ec5a9103e006ace21162d3e64dd4481689c4bf5505497aa881d2a432d98b22b9d)
              npm ERR! /home/iobroker/.npm/_logs/2020-05-19T21_03_05_642Z-debug.log
              host.raspberrypi Cannot install iobroker.web@3.0.8: 1
              • Heimann
                So, jetzt hat es geklappt. 👌
                Hab einfach als admin über ssh den Ordner ....../aa umbenannt.
                Dann noch mal neu installiert und siehe da, es ist wieder da. 👍
                xxx.xxx.xxx.xxx:8082 ist wieder aufrufbar.
                  @Heimann Hättest auch den npm cache leeren können.
                  • Heimann
                    Wie wäre das denn zu erledigen gewesen? 🤓
                      @Heimann
                      npm cache clean --force
                      • Heimann
                        Sollte man das jetzt trotzdem noch mal machen?
                          @Heimann Nö.
                          Aber das könntest du mal machen:
                          npm cache verify
                          • Heimann
                            Das hat er geantwortet:
                            pi@raspberrypi:/opt/iobroker $ npm cache verify
                            Cache verified and compressed (~/.npm/_cacache):
                            Content verified: 1134 (107628668 bytes)
                            Corrupted content removed: 15
                            Content garbage-collected: 53 (809903 bytes)
                            Missing content: 16
                            Index entries: 1749
                            Finished in 21.512s
                            Ist das so in Ordnung? 🙄
                              @Heimann Schaut doch gar nicht schlecht aus.
                              • Heimann
                                Vielen Dank. 😘
                                Du hast mir sehr geholfen. 👍
                                Somit kann das hier geschlossen werden. 👌
                                errorproblem fehler iobroker.web
                                535
