    4. sql startet nach update nicht mehr
    UNSOLVED sql startet nach update nicht mehr
      rascal last edited by
      das Gleiche hier:
      host.Mastermind	2020-05-18 19:47:51.590	info	instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
      host.Mastermind	2020-05-18 19:47:51.590	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      host.Mastermind	2020-05-18 19:47:51.590	error	Caught by controller[1]: at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115328)
      host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1482:21
      host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:26
      host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at Array.map (<anonymous>)
      host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39
      host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: TypeError: Cannot read property 'startsWith' of undefined
      host.Mastermind	2020-05-18 19:47:51.588	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
      sql.0	2020-05-18 19:47:51.469	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.468	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.467	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.466	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.465	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.464	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.463	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.462	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.461	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.460	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.454	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.453	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.452	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.451	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.450	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.449	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.448	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.447	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.446	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.445	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.444	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.443	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.442	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.441	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.440	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.369	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.368	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.364	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.363	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.357	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.356	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.353	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.352	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.349	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.348	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.345	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.339	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.337	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.336	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.333	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.331	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.330	warn	(453392) No Connection to database
      sql.0	2020-05-18 19:47:51.043	info	(453392) Terminated (NO_ERROR): Without reason
      sql.0	2020-05-18 19:47:51.041	info	(453392) terminating
      sql.0	2020-05-18 19:47:50.436	error	(453392) TypeError: Cannot read property 'startsWith' of undefined at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39 at Array.map (<anonymous>) at /opt/iobroker/n
      sql.0	2020-05-18 19:47:50.426	error	(453392) unhandled promise rejection: Cannot read property 'startsWith' of undefined
      sql.0	2020-05-18 19:47:50.425	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        C-3po @madison last edited by
        @madison said in sql startet nach update nicht mehr:
        nach downgrade auf 1.12.5 läuft der adapter wieder.
        sieht nach einem bug in der version 1.13.0 aus!
        Jo,
        Hier das selbe Ergebnis. Nur seltsam das es in der History noch eine 1.12.6 gibt. Selbige aber nicht Installierbar ist.
        Mit 1.12.5 wieder io.
          mit 1.12.6 hatte ich den Fehler auch
          • Feuersturm
            Feuersturm last edited by
            Es gibt hierzu auch ein Github Issue: https://github.com/ioBroker/ioBroker.sql/issues/120
            peer69 created this issue in ioBroker/ioBroker.sql
            closed Adapter crashes after update to 1.13.0 #120
              Lstt last edited by
                bommel_030 last edited by bommel_030
                Habe auch auf die 1.13.0 aktualisiert (Vermute von der 1.12.5). Instanz ist permanent neu gestartet.
                Habe dann den Downgrade auf 1.12.5 und bekomme seitdem folgende Fehlermeldung.
                sql.0	2020-05-19 07:34:49.602	info	(4756) No Data
                sql.0	2020-05-19 07:34:24.964	error	(4756) Error: Packets out of order. Got: 1 Expected: 0
                Egal welche Version ich auch installiere, die Meldung kommt jetzt immer. Hat jemand ne Idee was das sein könnte?
                Edit:
                Downgrade auf 1.9.4 und danach upgrade auf 1.12.5 hat geholfen, warum auch immer...
                • opossum
                  opossum last edited by
                  bei mir gleiches Problem, aber Downgrade auf 1.12.5 hat fehlerfrei geklappt. Downgrade von 1.13.0 auf 1.12.6 hat bei mir gar nicht funktioniert.
                  • Dr. Bakterius
                    Dr. Bakterius Most Active last edited by
                    Kann ich auch bestätigen! Das mit der nicht existenten 1.12.6 ist auch fies. Wird ohne Fehler installiert, doch danach ist immer noch 1.13.0 installiert. Wollte schon über die Console installieren als ich diesen Hinweis hier bekam.
                      Berchemer last edited by Berchemer
                      Schließe mich an.
                      Habe jetzt die 1.12.6 gar nicht erst versucht sondern direkt auf 1.12.5 downgegraded und alles ist wieder gut.
                      Danke für die Warnung mit der 1.12.6 🙂
                      oberfragger 1 Reply Last reply Reply Quote 0
                      • oberfragger
                        oberfragger @Berchemer last edited by oberfragger
                        Vielen Dank für das Posting. Dachte nur bei mir wäre was im Eimer. 1.12.5 funktiniert auf Anhieb!
                          bombastikde last edited by
                          Nach dem Downgrade auf 1.12.5 funktionert jetzt wieder alles - Das hat aber einigen Scheiss gekostet
                            hat die Version 1.13.1 schon jemand getestet?
                            C Feuersturm 2 Replies Last reply Reply Quote 0
                              @madison
                              Jupp
                              eben gerade
                              Rennt wieder.
                                madison @C-3po last edited by
                                @C-3po super, danke!
                                  @madison
                                  dafür schiest aber das neue Script Engine quer
                                    @C-3po welche version?
                                      C-3po @madison last edited by C-3po
                                      @madison
                                      4.6.13
                                      macht stress mit Blockly und Datumsabfragen.
                                      bin erst mal wieder auf 4.6.4
                                      M B 2 Replies Last reply Reply Quote 1
                                        @C-3po Datumsabfragen verwende ich nicht, sonst wäre mir noch nichts aufgefallen!
                                          @madison
                                          und der neue IOT mault wegen dem Password.
                                          Die geforderte Richtlinie stimmt aber
                                          aber das ist hier OT
                                          gibt bestimmt gleich n rüffel.
                                          • Feuersturm
                                            Feuersturm @madison last edited by
                                            @madison Update war erfolgreich und bisher keine Probleme.
                                            sql adapter crash error
                                            14
                                            32
                                            2684
