    5. Spülmaschine fertig
    Spülmaschine fertig
      paul53 @grizzlyco last edited by paul53
      @grizzlyco
      Warum postest Du nicht das Blockly als Bild ?
      Die while-Schleife ist tödlich !
      Ein Intervall muss auch gestoppt werden.
          @grizzlyco
          Versuche es mal so:
          Wert findet man unter "Trigger".
           <variables>
             <variable id="WZDTdR2wt;{2fV(#SX#{">aktiv</variable>
             <variable type="interval" id="Intervall">Intervall</variable>
             <variable id="6VT=qP{xCaUHGfhs^U!=">Dauerzaehler</variable>
           </variables>
           <block type="on" id="Int%5TTx;UDERKcfPyX7" x="88" y="-112">
               <block type="controls_if" id="Tz=dssi/)[k11-}r3_1U">
                   <block type="logic_compare" id="5m5c/i7Nz%[k{FRd),5G">
                     <field name="OP">GTE</field>
                       <block type="on_source" id="rs.x~Q6+mEjG:094ayRM">
                       <block type="math_number" id="BTfJM96%X=[I/XG5~CPR">
                         <field name="NUM">50</field>
                   <block type="timeouts_clearinterval" id="T(gb.b0W.v]6`G4Nt@=m">
                     <field name="NAME">Intervall</field>
                       <block type="variables_set" id="3y-W6%Jis1R3=:BbT`e}">
                         <field name="VAR" id="WZDTdR2wt;{2fV(#SX#{">aktiv</field>
                           <block type="logic_boolean" id="uFmM`tGobz~IWHA:#awn">
                           <block type="variables_set" id="B2]oLnNdAcmt,%I%Kx~F">
                             <field name="VAR" id="6VT=qP{xCaUHGfhs^U!=">Dauerzaehler</field>
                               <block type="math_number" id="KagezaS@Vdhz4%~e[MxG">
                                 <field name="NUM">0</field>
                 <value name="IF1">
                   <block type="variables_get" id="p{_XM5r#+mh-{!y-Y4PP">
                 <statement name="DO1">
                   <block type="variables_set" id="xBsh47XP9)71g`1aWxk{">
                       <block type="logic_boolean" id="W4X]Ln|d?p!X`u}*l5Yr">
                       <block type="timeouts_setinterval" id="xHzL2wSV0@+3^RX7eC*Z">
                         <field name="INTERVAL">5</field>
                           <block type="math_change" id="5hNQHOvUQDvj.#CxMM04">
                             <value name="DELTA">
                               <shadow type="math_number" id="s*tEo(XLxreWv6I,Dp:@">
                                 <field name="NUM">5</field>
                               <block type="controls_if" id="5`_$HEFPU2wX/PnVp8[:">
                                   <block type="logic_compare" id="%e{ZI[QDu-I4P04vvZk1">
                                       <block type="variables_get" id="8E?vwzt8RUCH*/)+T.bE">
                                       <block type="math_number" id="wqC1GqpxsN]k_5GJZF^1">
                                         <field name="NUM">20</field>
                                   <block type="timeouts_clearinterval" id="(X{|X12*MP$fC|,Z+mGE">
                                       <block type="pushover" id="5vH!94frQy5%i6h?l^js">
                                         <field name="SOUND"></field>
                                         <field name="PRIORITY">0</field>
                                         <field name="LOG"></field>
                                         <value name="MESSAGE">
                                           <shadow type="text" id="R:ffmpetI?obCo,3zM;R">
                                             <field name="TEXT">Spülmaschine ist fertig</field>
            So ich habe jetzt auch nochmal was rumgebastelt. Danke @paul53
            Ich hoffe so klappt es wenn die Maschine das nächste mal startet.
            • buggybeast
              buggybeast last edited by
              @grizzlyco
              Nur mal so gefragt, möchtest du nur wissen, wann die Maschine fertig ist? Oder willst du später noch mehr Funktionen in das Skript bauen?
                grizzlyco @buggybeast last edited by
                @buggybeast
                erstmal möchte ich nur wissen, ob die Spülmaschine fertig ist. Keine Ahnung ob ich später noch mehr damit mache.
                Wieso fragst du?
                • buggybeast
                  @grizzlyco
                  Mir erscheint Dein Skript arg komliziert. Für meine Waschmaschine habe ich folgendes Skript nur für die Fertig-Meldung.
                  Wenn ich davon ausgehen kann, dass Dein Trigger, "Spülmaschine" wurde geändert, ein Energiewert ist, sollte das eigentlich auch funktionieren.
                  Die Schwellwerte musst Du natürlich an Deine Spülmaschine anpassen.
                    @buggybeast
                    wo bekommst du "voriger wert" her?
                    Das Problem ist, dass die Spülmaschine zwischendurch Pausen hat, wo quasi keine Leistung angefordert wird.
                    Deswegen musste ich die Zeit da mit rein bringen.
                    • buggybeast
                      Voriger Wert findest Du da, wo auch Wert herkommt:
                      Die Pausen habe ich natürlich auch und die werden abgefangen mit dem Timeout. Erst wenn meine Maschine 10 Minuten lang unter 5 Watt bleibt, ist sie fertig und ich bekomme eine Mail.
                      • buggybeast
                        Wenn innerhalb von 10 Minuten die Leistung nochmal auf über 5 Watt steigt, wird einfach nur der Timeout gestoppt.
                        734
