    4. [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb"
      Australier last edited by
      Leider unverändert, ich kriege den Admin nicht dauerhaft auf den Stand 4.0.10
      root@20c8e6bb5f55:/opt/iobroker# pkill io
      root@20c8e6bb5f55:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2020-04-12
      ioBroker or some processes are still running:
       io.javascript.0
      Please stop them first and try again!
      library: loaded
       io.javascript.0
      root@20c8e6bb5f55:/opt/iobroker# iobroker stop
      iobroker controller daemon is not running
      library: loaded
          Welcome to the ioBroker installation fixer!
          Script version: 2020-04-12
          Installing prerequisites (1/3)
      Holen:1 http://deb.debian.org/debian buster InRelease [121 kB]
      Holen:2 http://security.debian.org/debian-security buster/updates InRelease [65,4 kB]
      Holen:3 https://deb.nodesource.com/node_10.x buster InRelease [4.584 B]
      Holen:4 http://deb.debian.org/debian buster-updates InRelease [49,3 kB]
      Holen:5 http://security.debian.org/debian-security buster/updates/main amd64 Packages [199 kB]
      Holen:6 http://deb.debian.org/debian buster/main amd64 Packages [7.905 kB]
      Holen:7 https://deb.nodesource.com/node_10.x buster/main amd64 Packages [767 B]
      90% [6 Packages 7.238 kB/7.905 kB 92%]        1.22497% [Wird verarbeitet]        1.22497% [6 Packages store 0 B] [Warten auf Kopfzeilen]        1.224Holen:8 http://deb.debian.org/debian buster-updates/main amd64 Packages [7.380 B]
      97% [6 Packages store 0 B] [8 Packages 0 B/7.380 B 0%]        1.22497% [6 Packages store 0 B]        1.22497% [6 Packages store 0 B]        1.22497% [6 Packages store 0 B]        1.22497% [6 Packages store 0 B]        1.22497% [6 Packages store 0 B]        1.22498% [Wird verarbeitet]        1.22498% [8 Packages store 0 B]        1.224100% [Wird verarbeitet]        1.224Es wurden 8.353 kB in 9 s geholt (922 kB/s).
      Installed gcc-c++
      Failed to set capabilities on file `/usr/bin/node' (Operation not supported)
      The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
      Docker detected!
      If you have any adapters that need the CAP_NET_ADMIN capability,
      you need to start the docker container with the option --cap-add=NET_ADMIN
      and manually add that capability to node
          Checking ioBroker user and directory permissions (2/3)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
      This system does not support setting default permissions.
      Do not use npm to manually install adapters unless you know what you are doing!
          Checking autostart (3/3)
      Unsupported init system, cannot enable autostart!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      root@20c8e6bb5f55:/opt/iobroker# iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 2379
      root@20c8e6bb5f55:/opt/iobroker# iobroker list adapters
      system.adapter.admin                   : admin          - v3.7.8
      system.adapter.alexa2                  : alexa2         - v3.0.5
      system.adapter.amazon-dash             : amazon-dash    - v0.2.7
      system.adapter.backitup                : backitup       - v1.4.5
      system.adapter.cloud                   : cloud          - v3.0.3
      system.adapter.daswetter               : daswetter      - v2.8.1
      system.adapter.discovery               : discovery      - v2.3.5
      system.adapter.dwd                     : dwd            - v2.4.6
      system.adapter.email                   : email          - v1.0.5
      system.adapter.feiertage               : feiertage      - v1.0.17
      system.adapter.find-my-iphone          : find-my-iphone - v0.2.15
      system.adapter.flot                    : flot           - v1.9.2
      system.adapter.fritzbox                : fritzbox       - v0.2.1
      system.adapter.fullybrowser            : fullybrowser   - v1.0.0
      system.adapter.geofency                : geofency       - v0.3.2
      system.adapter.harmony                 : harmony        - v1.2.2
      system.adapter.history                 : history        - v1.9.6
      system.adapter.hm-rega                 : hm-rega        - v2.5.5
      system.adapter.hm-rpc                  : hm-rpc         - v1.14.2
      system.adapter.homekit2                : homekit2       - v0.1.6
      system.adapter.hue                     : hue            - v3.2.3
      system.adapter.ical                    : ical           - v1.7.0
      system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.0
      system.adapter.icons-fatcow-hosting    : icons-fatcow-hosting - v0.1.0
      system.adapter.icons-icons8            : icons-icons8   - v0.0.1
      system.adapter.icons-material-png      : icons-material-png - v0.1.0
      system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
      system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
      system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
      system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
      system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
      system.adapter.influxdb                : influxdb       - v1.7.0
      system.adapter.info                    : info           - v1.5.6
      system.adapter.javascript              : javascript     - v4.3.4
      system.adapter.mihome-vacuum           : mihome-vacuum  - v1.1.5
      system.adapter.mobile                  : mobile         - v0.5.0
      system.adapter.musiccast               : musiccast      - v0.1.3
      system.adapter.node-red                : node-red       - v1.13.0
      system.adapter.nut                     : nut            - v1.1.3
      system.adapter.parser                  : parser         - v1.0.7
      system.adapter.ping                    : ping           - v1.4.7
      system.adapter.pollenflug              : pollenflug     - v1.0.4
      system.adapter.pushover                : pushover       - v1.2.3
      system.adapter.radar                   : radar          - v1.1.3
      system.adapter.rickshaw                : rickshaw       - v1.0.0
      system.adapter.samsung                 : samsung        - v0.2.9
      system.adapter.sayit                   : sayit          - v1.9.4
      system.adapter.scenes                  : scenes         - v1.1.0
      system.adapter.shelly                  : shelly         - v3.1.6
      system.adapter.simple-api              : simple-api     - v2.4.5
      system.adapter.socketio                : socketio       - v3.0.7
      system.adapter.solarwetter             : solarwetter    - v1.0.0
      system.adapter.sql                     : sql            - v1.12.5
      system.adapter.tankerkoenig            : tankerkoenig   - v1.0.4
      system.adapter.telegram                : telegram       - v1.5.9
      system.adapter.text2command            : text2command   - v1.3.0
      system.adapter.tr-064-community        : tr-064-community - v1.0.0
      system.adapter.tvspielfilm             : tvspielfilm    - v1.0.4
      system.adapter.unifi                   : unifi          - v0.4.3
      system.adapter.upnp                    : upnp           - v1.0.16
      system.adapter.vis                     : vis            - v1.2.4
      system.adapter.vis-bars                : vis-bars       - v0.1.4
      system.adapter.vis-beta                : vis-beta       - v0.14.1
      system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
      system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
      system.adapter.vis-history             : vis-history    - v1.0.0
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
      system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
      system.adapter.vis-justgage            : vis-justgage   - v1.0.2
      system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
      system.adapter.vis-lcars               : vis-lcars      - v1.0.4
      system.adapter.vis-map                 : vis-map        - v1.0.4
      system.adapter.vis-metro               : vis-metro      - v1.1.2
      system.adapter.vis-players             : vis-players    - v0.1.5
      system.adapter.vis-plumb               : vis-plumb      - v1.0.1
      system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
      system.adapter.vis-weather             : vis-weather    - v2.5.2
      system.adapter.weatherunderground      : weatherunderground - v3.1.6
      system.adapter.web                     : web            - v3.0.8
      system.adapter.yahka                   : yahka          - v0.7.1
      system.adapter.yamaha                  : yamaha         - v0.3.19
      system.adapter.yr                      : yr             - v2.0.3
      root@20c8e6bb5f55:/opt/iobroker# iobroker version
      2.2.9
      root@20c8e6bb5f55:/opt/iobroker# iobroker update
      Used repository: default
      hash changed or no sources cached => force download of new sources
      update done
      Adapter    "admin"         : 4.0.10   , installed 4.0.10
      Adapter    "alarm"         : 0.3.0
      Adapter    "alexa2"        : 3.0.5    , installed 3.0.5
      Adapter    "alpha2"        : 1.0.0
      Adapter    "amazon-dash"   : 1.1.0
      Adapter    "artnet"        : 1.2.2
      Adapter    "asterisk"      : 1.0.6
      Adapter    "asuswrt"       : 1.0.1
      Adapter    "b-control-em"  : 0.2.1
      Adapter    "backitup"      : 1.4.5    , installed 1.4.5
      Adapter    "beckhoff"      : 1.2.0
      Adapter    "benq"          : 0.2.0
      Adapter    "binance"       : 1.1.2
      Adapter    "ble"           : 0.11.0
      Adapter    "bmw"           : 1.3.3
      Adapter    "bosesoundtouch": 0.2.4
      Adapter    "botvac"        : 1.0.0
      Adapter    "bring"         : 1.7.2
      Adapter    "broadlink2"    : 2.0.2
      Adapter    "bsblan"        : 0.1.0
      Adapter    "bshb"          : 0.1.10
      Adapter    "chromecast"    : 2.3.1
      Adapter    "cloud"         : 3.0.3    , installed 3.0.3
      Adapter    "comfoair"      : 0.3.2
      Adapter    "contactid"     : 1.0.0
      Adapter    "coronavirus-statistics": 0.5.9
      Adapter    "countdown"     : 1.1.0
      Adapter    "cul"           : 1.2.1
      Adapter    "daikin"        : 1.0.5
      Adapter    "daswetter"     : 2.8.1    , installed 2.8.1
      Adapter    "deconz"        : 1.3.7
      Adapter    "denon"         : 1.7.4
      Adapter    "devices"       : 0.3.6
      Adapter    "digitalstrom"  : 0.5.5
      Adapter    "discovergy"    : 0.5.0
      Adapter    "discovery"     : 2.3.5    , installed 2.3.5
      Adapter    "ds18b20"       : 1.1.4
      Adapter    "dwd"           : 2.4.9    , installed 2.4.9
      Adapter    "ebus"          : 1.0.0
      Adapter    "egigeozone"    : 0.1.2
      Adapter    "ekey"          : 1.1.0
      Adapter    "email"         : 1.0.6    , installed 1.0.6
      Adapter    "emby"          : 1.0.2
      Adapter    "energymanager" : 1.2.2
      Adapter    "enet"          : 1.0.1
      Adapter    "epson_stylus_px830": 0.2.1
      Adapter    "exchangerates" : 0.0.12
      Adapter    "fakeroku"      : 0.2.1
      Adapter    "fb-checkpresence": 0.3.0
      Adapter    "feiertage"     : 1.0.17   , installed 1.0.17
      Adapter    "fhem"          : 1.3.0
      Adapter    "find-my-iphone": 0.2.15   , installed 0.2.17
      Adapter    "firetv"        : 0.0.27
      Adapter    "flot"          : 1.9.2    , installed 1.9.2
      Adapter    "foobar2000"    : 1.0.0
      Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
      Adapter    "fritzdect"     : 0.2.4
      Adapter    "fronius"       : 1.0.5
      Adapter    "fullcalendar"  : 1.1.0
      Adapter    "fullybrowser"  : 1.0.0    , installed 1.0.0
      Adapter    "g-homa"        : 0.5.1
      Adapter    "geofency"      : 0.3.2    , installed 0.3.2
      Adapter    "gruenbeck"     : 0.0.18
      Adapter    "habpanel"      : 0.4.1
      Adapter    "haier"         : 1.0.2
      Adapter    "ham"           : 1.1.2
      Adapter    "ham-wemo"      : 1.0.1
      Adapter    "harmony"       : 1.2.2    , installed 1.2.2
      Adapter    "heatingcontrol": 0.3.19
      Adapter    "heytech"       : 0.2.0
      Adapter    "hid"           : 0.1.17
      Adapter    "history"       : 1.9.6    , installed 1.9.6
      Adapter    "hm-rega"       : 2.5.5    , installed 2.5.5
      Adapter    "hm-rpc"        : 1.14.2   , installed 1.14.2
      Adapter    "hmip"          : 0.0.11
      Adapter    "homeconnect"   : 0.0.30
      Adapter    "homee"         : 0.3.1
      Adapter    "homepilot"     : 1.0.3
      Adapter    "hp-ilo"        : 1.0.5
      Adapter    "hs100"         : 1.0.10
      Adapter    "hue"           : 3.2.4    , installed 3.2.4
      Adapter    "hue-extended"  : 1.2.3
      Adapter    "ical"          : 1.7.0    , installed 1.7.0
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "influxdb"      : 1.8.6    , installed 1.8.6
      Adapter    "info"          : 1.7.2    , installed 1.7.2
      Adapter    "innogy-smarthome": 0.3.3
      Adapter    "iogo"          : 0.5.9
      Adapter    "iot"           : 1.4.18
      Adapter    "iqontrol"      : 0.2.16
      Adapter    "javascript"    : 4.5.1    , installed 4.5.1
      Adapter    "jeelink"       : 0.1.0
      Controller "js-controller" : 2.2.9    , installed 2.2.9
      Adapter    "kecontact"     : 0.1.0
      Adapter    "klf200"        : 0.9.5
      Adapter    "km200"         : 1.1.6
      Adapter    "knmi-weather"  : 0.2.0
      Adapter    "knx"           : 1.0.39
      Adapter    "kodi"          : 2.0.1
      Adapter    "kress"         : 2.5.5
      Adapter    "lametric"      : 0.0.9
      Adapter    "landroid"      : 1.0.3
      Adapter    "lcn"           : 0.3.2
      Adapter    "lgtv"          : 1.1.6
      Adapter    "lgtv-rs"       : 0.0.4
      Adapter    "lgtv11"        : 1.0.5
      Adapter    "lifx"          : 0.1.0
      Adapter    "lightify"      : 0.2.16
      Adapter    "link"          : 0.5.9
      Adapter    "linkeddevices" : 1.1.4
      Adapter    "lovelace"      : 1.0.16
      Adapter    "loxone"        : 1.0.0
      Adapter    "luftdaten"     : 0.0.15
      Adapter    "lupusec"       : 1.2.3
      Adapter    "luxtronik1"    : 0.2.2
      Adapter    "material"      : 0.13.8
      Adapter    "maxcube"       : 0.1.2
      Adapter    "maxcul"        : 1.3.0
      Adapter    "mbus"          : 2.1.4
      Adapter    "mclighting"    : 0.1.1
      Adapter    "megad"         : 1.2.1
      Adapter    "megadd"        : 0.2.0
      Adapter    "megaesp"       : 0.1.0
      Adapter    "mercedesme"    : 0.0.21
      Adapter    "mercury"       : 0.1.0
      Adapter    "meross"        : 1.3.11
      Adapter    "meteoalarm"    : 1.0.9
      Adapter    "miele"         : 0.1.5
      Adapter    "mielecloudservice": 1.2.1
      Adapter    "mihome"        : 1.3.0
      Adapter    "mihome-lamp"   : 1.1.0
      Adapter    "mihome-plug"   : 0.2.0
      Adapter    "mihome-vacuum" : 1.1.5    , installed 1.1.5
      Adapter    "mikrotik"      : 1.0.11
      Adapter    "milight"       : 0.3.6
      Adapter    "milight-smart-light": 0.2.7
      Adapter    "mobile"        : 0.5.0    , installed 0.5.0
      Adapter    "modbus"        : 3.0.0
      Adapter    "moma"          : 1.2.6
      Adapter    "mpd"           : 1.0.4
      Adapter    "mqtt"          : 2.1.2
      Adapter    "mqtt-client"   : 1.3.1
      Adapter    "musiccast"     : 0.1.3    , installed 0.1.3
      Adapter    "mysensors"     : 2.0.0
      Adapter    "nanoleaf-lightpanels": 0.8.1
      Adapter    "nello"         : 2.0.6
      Adapter    "netatmo"       : 1.3.1
      Adapter    "nibeuplink"    : 0.3.0
      Adapter    "nina"          : 0.0.22
      Adapter    "node-red"      : 1.13.0   , installed 1.13.0
      Adapter    "nuki"          : 1.2.0
      Adapter    "nuki-extended" : 2.2.5
      Adapter    "nut"           : 1.1.3    , installed 1.1.3
      Adapter    "odl"           : 1.0.5
      Adapter    "oilfox"        : 0.0.5
      Adapter    "onkyo"         : 2.0.3
      Adapter    "onvif"         : 0.0.2
      Adapter    "openhab"       : 1.1.0
      Adapter    "openligadb"    : 1.0.0
      Adapter    "openweathermap": 0.1.0
      Adapter    "opi"           : 0.1.1
      Adapter    "oppoplayer"    : 0.2.1
      Adapter    "owfs"          : 0.6.4
      Adapter    "owntracks"     : 0.6.2
      Adapter    "panasonic-viera": 1.0.2
      Adapter    "parser"        : 1.0.7    , installed 1.0.7
      Adapter    "paw"           : 0.0.7
      Adapter    "phantomjs"     : 1.0.1
      Adapter    "pi-hole"       : 1.2.3
      Adapter    "piface"        : 1.0.0
      Adapter    "pimatic"       : 0.3.0
      Adapter    "ping"          : 1.4.7    , installed 1.4.7
      Adapter    "places"        : 0.7.0
      Adapter    "plex"          : 0.8.9
      Adapter    "plexconnect"   : 0.0.7
      Adapter    "pollenflug"    : 1.0.4    , installed 1.0.4
      Adapter    "proxmox"       : 1.0.1
      Adapter    "proxy"         : 1.1.1
      Adapter    "pushbullet"    : 0.0.11
      Adapter    "pushover"      : 2.0.2    , installed 2.0.2
      Adapter    "pushsafer"     : 0.1.8
      Adapter    "radar2"        : 1.0.9
      Adapter    "radiohead"     : 1.0.4
      Adapter    "rflink"        : 2.0.0
      Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
      Adapter    "ring"          : 1.1.3
      Adapter    "robonect"      : 0.1.3
      Adapter    "roomba"        : 1.1.1
      Adapter    "rpi2"          : 1.1.1
      Adapter    "s7"            : 1.1.7
      Adapter    "samsung"       : 0.2.9
      Adapter    "sayit"         : 1.9.4    , installed 1.9.4
      Adapter    "sbfspot"       : 2.4.0
      Adapter    "scenes"        : 1.1.0    , installed 1.1.0
      Adapter    "schoolfree"    : 0.5.0
      Adapter    "shelly"        : 3.1.6    , installed 3.1.6
      Adapter    "shuttercontrol": 0.4.3
      Adapter    "sia"           : 1.0.3
      Adapter    "siegenia"      : 1.0.0
      Adapter    "simple-api"    : 2.4.5    , installed 2.4.5
      Adapter    "smappee"       : 0.2.2
      Adapter    "smartmeter"    : 3.0.10
      Adapter    "snips"         : 1.5.0
      Adapter    "snmp"          : 0.5.0
      Adapter    "socketio"      : 3.0.7    , installed 3.0.7
      Adapter    "solarlog"      : 2.0.0
      Adapter    "solarwetter"   : 1.0.0    , installed 1.0.0
      Adapter    "sonnen"        : 1.4.0
      Adapter    "sonoff"        : 2.3.3
      Adapter    "sonos"         : 2.0.1
      Adapter    "sony-bravia"   : 1.0.1
      Adapter    "spotify-premium": 1.0.0
      Adapter    "sql"           : 1.12.5   , installed 1.12.5
      Adapter    "squeezebox"    : 1.0.0
      Adapter    "squeezeboxrpc" : 1.0.0
      Adapter    "starline"      : 1.0.0
      Adapter    "statistics"    : 0.2.2
      Adapter    "stiebel-isg"   : 1.4.11
      Adapter    "sunnyportal"   : 0.1.5
      Adapter    "swiss-weather-api": 0.2.0
      Adapter    "systeminfo"    : 0.3.1
      Adapter    "tahoma"        : 0.3.2
      Adapter    "tankerkoenig"  : 2.0.5    , installed 2.0.6
      Adapter    "telegram"      : 1.5.9    , installed 1.5.9
      Adapter    "terminal"      : 0.1.2
      Adapter    "tesla-motors"  : 0.2.3
      Adapter    "text2command"  : 1.3.0    , installed 1.3.0
      Adapter    "tr-064"        : 4.0.3
      Adapter    "tradfri"       : 2.6.1
      Adapter    "trashschedule" : 0.0.7
      Adapter    "tunnelbroker-endpoint-updater": 0.0.1
      Adapter    "tuya"          : 3.2.2
      Adapter    "tvspielfilm"   : 1.0.4    , installed 1.0.4
      Adapter    "unifi"         : 0.4.3    , installed 0.4.3
      Adapter    "upnp"          : 1.0.16   , installed 1.0.16
      Adapter    "vaillant"      : 0.0.10
      Adapter    "valloxmv"      : 1.0.3
      Adapter    "vcard"         : 0.0.9
      Adapter    "velux"         : 0.0.5
      Adapter    "viessmann"     : 1.2.4
      Adapter    "virtualpowermeter": 1.2.1
      Adapter    "vis"           : 1.2.4    , installed 1.2.4
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.1.1
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-google-fonts": 0.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.4    , installed 1.1.4
      Adapter    "vis-inventwo"  : 1.3.3
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-players"   : 0.1.5    , installed 0.1.5
      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "vis-weather"   : 2.5.2    , installed 2.5.2
      Adapter    "vr200"         : 1.0.0
      Adapter    "vw-connect"    : 0.0.15
      Adapter    "weatherunderground": 3.1.6   , installed 3.1.6
      Adapter    "web"           : 3.0.8    , installed 3.0.8
      Adapter    "weishaupt-wem" : 0.0.8
      Adapter    "wiffi-wz"      : 2.2.0
      Adapter    "wifilight"     : 1.1.0
      Adapter    "windows-control": 0.1.3
      Adapter    "wled"          : 0.5.0
      Adapter    "wm-bus"        : 0.1.12
      Adapter    "wolf"          : 0.9.2
      Adapter    "worx"          : 1.0.0
      Adapter    "xbox"          : 0.6.4
      Adapter    "xs1"           : 1.0.2
      Adapter    "yahka"         : 0.11.0
      Adapter    "yamaha"        : 0.3.19   , installed 0.3.19
      Adapter    "yeelight-2"    : 1.0.3
      Adapter    "youtube"       : 0.0.11
      Adapter    "yr"            : 2.0.3    , installed 2.0.3
      Adapter    "zigbee"        : 1.0.4
      Adapter    "zont"          : 0.5.3
      Adapter    "zwave"         : 2.0.1
      root@20c8e6bb5f55:/opt/iobroker# iobroker upgrade
      Adapter "admin"          is up to date.
      Adapter "alarm"          is not installed.
      Adapter "alexa2"         is up to date.
      Adapter "alpha2"         is not installed.
      Adapter "amazon-dash"    is not installed.
      Adapter "artnet"         is not installed.
      Adapter "asterisk"       is not installed.
      Adapter "asuswrt"        is not installed.
      Adapter "b-control-em"   is not installed.
      Adapter "backitup"       is up to date.
      Adapter "beckhoff"       is not installed.
      Adapter "benq"           is not installed.
      Adapter "binance"        is not installed.
      Adapter "ble"            is not installed.
      Adapter "bmw"            is not installed.
      Adapter "bosesoundtouch" is not installed.
      Adapter "botvac"         is not installed.
      Adapter "bring"          is not installed.
      Adapter "broadlink2"     is not installed.
      Adapter "bsblan"         is not installed.
      Adapter "bshb"           is not installed.
      Adapter "chromecast"     is not installed.
      Adapter "cloud"          is up to date.
      Adapter "comfoair"       is not installed.
      Adapter "contactid"      is not installed.
      Adapter "coronavirus-statistics" is not installed.
      Adapter "countdown"      is not installed.
      Adapter "cul"            is not installed.
      Adapter "daikin"         is not installed.
      Adapter "daswetter"      is up to date.
      Adapter "deconz"         is not installed.
      Adapter "denon"          is not installed.
      Adapter "devices"        is not installed.
      Adapter "digitalstrom"   is not installed.
      Adapter "discovergy"     is not installed.
      Adapter "discovery"      is up to date.
      Adapter "ds18b20"        is not installed.
      Adapter "dwd"            is up to date.
      Adapter "ebus"           is not installed.
      Adapter "egigeozone"     is not installed.
      Adapter "ekey"           is not installed.
      Adapter "email"          is up to date.
      Adapter "emby"           is not installed.
      Adapter "energymanager"  is not installed.
      Adapter "enet"           is not installed.
      Adapter "epson_stylus_px830" is not installed.
      Adapter "exchangerates"  is not installed.
      Adapter "fakeroku"       is not installed.
      Adapter "fb-checkpresence" is not installed.
      Adapter "feiertage"      is up to date.
      Adapter "fhem"           is not installed.
      Adapter "find-my-iphone" is up to date.
      Adapter "firetv"         is not installed.
      Adapter "flot"           is up to date.
      Adapter "foobar2000"     is not installed.
      Adapter "fritzbox"       is up to date.
      Adapter "fritzdect"      is not installed.
      Adapter "fronius"        is not installed.
      Adapter "fullcalendar"   is not installed.
      Adapter "fullybrowser"   is up to date.
      Adapter "g-homa"         is not installed.
      Adapter "geofency"       is up to date.
      Adapter "gruenbeck"      is not installed.
      Adapter "habpanel"       is not installed.
      Adapter "haier"          is not installed.
      Adapter "ham"            is not installed.
      Adapter "ham-wemo"       is not installed.
      Adapter "harmony"        is up to date.
      Adapter "heatingcontrol" is not installed.
      Adapter "heytech"        is not installed.
      Adapter "hid"            is not installed.
      Adapter "history"        is up to date.
      Adapter "hm-rega"        is up to date.
      Adapter "hm-rpc"         is up to date.
      Adapter "hmip"           is not installed.
      Adapter "homeconnect"    is not installed.
      Adapter "homee"          is not installed.
      Adapter "homepilot"      is not installed.
      Adapter "hp-ilo"         is not installed.
      Adapter "hs100"          is not installed.
      Adapter "hue"            is up to date.
      Adapter "hue-extended"   is not installed.
      Adapter "ical"           is up to date.
      Adapter "icons-addictive-flavour-png" is up to date.
      Adapter "icons-fatcow-hosting" is up to date.
      Adapter "icons-icons8"   is up to date.
      Adapter "icons-material-png" is up to date.
      Adapter "icons-material-svg" is up to date.
      Adapter "icons-mfd-png"  is up to date.
      Adapter "icons-mfd-svg"  is up to date.
      Adapter "icons-open-icon-library-png" is up to date.
      Adapter "icons-ultimate-png" is up to date.
      Adapter "influxdb"       is up to date.
      Adapter "info"           is up to date.
      Adapter "innogy-smarthome" is not installed.
      Adapter "iogo"           is not installed.
      Adapter "iot"            is not installed.
      Adapter "iqontrol"       is not installed.
      Adapter "javascript"     is up to date.
      Adapter "jeelink"        is not installed.
      Adapter "kecontact"      is not installed.
      Adapter "klf200"         is not installed.
      Adapter "km200"          is not installed.
      Adapter "knmi-weather"   is not installed.
      Adapter "knx"            is not installed.
      Adapter "kodi"           is not installed.
      Adapter "kress"          is not installed.
      Adapter "lametric"       is not installed.
      Adapter "landroid"       is not installed.
      Adapter "lcn"            is not installed.
      Adapter "lgtv"           is not installed.
      Adapter "lgtv-rs"        is not installed.
      Adapter "lgtv11"         is not installed.
      Adapter "lifx"           is not installed.
      Adapter "lightify"       is not installed.
      Adapter "link"           is not installed.
      Adapter "linkeddevices"  is not installed.
      Adapter "lovelace"       is not installed.
      Adapter "loxone"         is not installed.
      Adapter "luftdaten"      is not installed.
      Adapter "lupusec"        is not installed.
      Adapter "luxtronik1"     is not installed.
      Adapter "material"       is not installed.
      Adapter "maxcube"        is not installed.
      Adapter "maxcul"         is not installed.
      Adapter "mbus"           is not installed.
      Adapter "mclighting"     is not installed.
      Adapter "megad"          is not installed.
      Adapter "megadd"         is not installed.
      Adapter "megaesp"        is not installed.
      Adapter "mercedesme"     is not installed.
      Adapter "mercury"        is not installed.
      Adapter "meross"         is not installed.
      Adapter "meteoalarm"     is not installed.
      Adapter "miele"          is not installed.
      Adapter "mielecloudservice" is not installed.
      Adapter "mihome"         is not installed.
      Adapter "mihome-lamp"    is not installed.
      Adapter "mihome-plug"    is not installed.
      Adapter "mihome-vacuum"  is up to date.
      Adapter "mikrotik"       is not installed.
      Adapter "milight"        is not installed.
      Adapter "milight-smart-light" is not installed.
      Adapter "mobile"         is up to date.
      Adapter "modbus"         is not installed.
      Adapter "moma"           is not installed.
      Adapter "mpd"            is not installed.
      Adapter "mqtt"           is not installed.
      Adapter "mqtt-client"    is not installed.
      Adapter "musiccast"      is up to date.
      Adapter "mysensors"      is not installed.
      Adapter "nanoleaf-lightpanels" is not installed.
      Adapter "nello"          is not installed.
      Adapter "netatmo"        is not installed.
      Adapter "nibeuplink"     is not installed.
      Adapter "nina"           is not installed.
      Adapter "node-red"       is up to date.
      Adapter "nuki"           is not installed.
      Adapter "nuki-extended"  is not installed.
      Adapter "nut"            is up to date.
      Adapter "odl"            is not installed.
      Adapter "oilfox"         is not installed.
      Adapter "onkyo"          is not installed.
      Adapter "onvif"          is not installed.
      Adapter "openhab"        is not installed.
      Adapter "openligadb"     is not installed.
      Adapter "openweathermap" is not installed.
      Adapter "opi"            is not installed.
      Adapter "oppoplayer"     is not installed.
      Adapter "owfs"           is not installed.
      Adapter "owntracks"      is not installed.
      Adapter "panasonic-viera" is not installed.
      Adapter "parser"         is up to date.
      Adapter "paw"            is not installed.
      Adapter "phantomjs"      is not installed.
      Adapter "pi-hole"        is not installed.
      Adapter "piface"         is not installed.
      Adapter "pimatic"        is not installed.
      Adapter "ping"           is up to date.
      Adapter "places"         is not installed.
      Adapter "plex"           is not installed.
      Adapter "plexconnect"    is not installed.
      Adapter "pollenflug"     is up to date.
      Adapter "proxmox"        is not installed.
      Adapter "proxy"          is not installed.
      Adapter "pushbullet"     is not installed.
      Adapter "pushover"       is up to date.
      Adapter "pushsafer"      is not installed.
      Adapter "radar2"         is not installed.
      Adapter "radiohead"      is not installed.
      Adapter "rflink"         is not installed.
      Adapter "rickshaw"       is up to date.
      Adapter "ring"           is not installed.
      Adapter "robonect"       is not installed.
      Adapter "roomba"         is not installed.
      Adapter "rpi2"           is not installed.
      Adapter "s7"             is not installed.
      Adapter "samsung"        is not installed.
      Adapter "sayit"          is up to date.
      Adapter "sbfspot"        is not installed.
      Adapter "scenes"         is up to date.
      Adapter "schoolfree"     is not installed.
      Adapter "shelly"         is up to date.
      Adapter "shuttercontrol" is not installed.
      Adapter "sia"            is not installed.
      Adapter "siegenia"       is not installed.
      Adapter "simple-api"     is up to date.
      Adapter "smappee"        is not installed.
      Adapter "smartmeter"     is not installed.
      Adapter "snips"          is not installed.
      Adapter "snmp"           is not installed.
      Adapter "socketio"       is up to date.
      Adapter "solarlog"       is not installed.
      Adapter "solarwetter"    is up to date.
      Adapter "sonnen"         is not installed.
      Adapter "sonoff"         is not installed.
      Adapter "sonos"          is not installed.
      Adapter "sony-bravia"    is not installed.
      Adapter "spotify-premium" is not installed.
      Adapter "sql"            is up to date.
      Adapter "squeezebox"     is not installed.
      Adapter "squeezeboxrpc"  is not installed.
      Adapter "starline"       is not installed.
      Adapter "statistics"     is not installed.
      Adapter "stiebel-isg"    is not installed.
      Adapter "sunnyportal"    is not installed.
      Adapter "swiss-weather-api" is not installed.
      Adapter "systeminfo"     is not installed.
      Adapter "tahoma"         is not installed.
      Adapter "tankerkoenig"   is up to date.
      Adapter "telegram"       is up to date.
      Adapter "terminal"       is not installed.
      Adapter "tesla-motors"   is not installed.
      Adapter "text2command"   is up to date.
      Adapter "tr-064"         is not installed.
      Adapter "tradfri"        is not installed.
      Adapter "trashschedule"  is not installed.
      Adapter "tunnelbroker-endpoint-updater" is not installed.
      Adapter "tuya"           is not installed.
      Adapter "tvspielfilm"    is up to date.
      Adapter "unifi"          is up to date.
      Adapter "upnp"           is up to date.
      Adapter "vaillant"       is not installed.
      Adapter "valloxmv"       is not installed.
      Adapter "vcard"          is not installed.
      Adapter "velux"          is not installed.
      Adapter "viessmann"      is not installed.
      Adapter "virtualpowermeter" is not installed.
      Adapter "vis"            is up to date.
      Adapter "vis-bars"       is up to date.
      Adapter "vis-canvas-gauges" is up to date.
      Adapter "vis-colorpicker" is not installed.
      Adapter "vis-fancyswitch" is up to date.
      Adapter "vis-google-fonts" is not installed.
      Adapter "vis-history"    is up to date.
      Adapter "vis-hqwidgets"  is up to date.
      Adapter "vis-inventwo"   is not installed.
      Adapter "vis-jqui-mfd"   is up to date.
      Adapter "vis-justgage"   is up to date.
      Adapter "vis-keyboard"   is up to date.
      Adapter "vis-lcars"      is up to date.
      Adapter "vis-map"        is up to date.
      Adapter "vis-metro"      is up to date.
      Adapter "vis-players"    is up to date.
      Adapter "vis-plumb"      is up to date.
      Adapter "vis-rgraph"     is up to date.
      Adapter "vis-timeandweather" is up to date.
      Adapter "vis-weather"    is up to date.
      Adapter "vr200"          is not installed.
      Adapter "vw-connect"     is not installed.
      Adapter "weatherunderground" is up to date.
      Adapter "web"            is up to date.
      Adapter "weishaupt-wem"  is not installed.
      Adapter "wiffi-wz"       is not installed.
      Adapter "wifilight"      is not installed.
      Adapter "windows-control" is not installed.
      Adapter "wled"           is not installed.
      Adapter "wm-bus"         is not installed.
      Adapter "wolf"           is not installed.
      Adapter "worx"           is not installed.
      Adapter "xbox"           is not installed.
      Adapter "xs1"            is not installed.
      Adapter "yahka"          is not installed.
      Adapter "yamaha"         is up to date.
      Adapter "yeelight-2"     is not installed.
      Adapter "youtube"        is not installed.
      Adapter "yr"             is up to date.
      Adapter "zigbee"         is not installed.
      Adapter "zont"           is not installed.
      Adapter "zwave"          is not installed.
        Thomas Braun Most Active @Australier last edited by
        @Australier
        iobroker install admin
          Australier @Thomas Braun last edited by
          @Thomas-Braun said in [iot] iot-Adapter verbindet sich nicht bzw Verbindung ist "gelb":
          root@20c8e6bb5f55:/opt/iobroker# iobroker install admin
          adapter "admin" already installed. Use "upgrade" to upgrade to a newer version.
          root@20c8e6bb5f55:/opt/iobroker# iobroker upgrade admin
          Stopping iobroker controller daemon...
          iobroker controller daemon stopped.
          No "killall.sh" script found. Just stop.
            @Australier Keine Ahnung was du da verfummelt hast.
            A 2 Replies Last reply Reply Quote 0
              @Thomas-Braun Trotzdem vielen Dank für eure Unterstützung. Danke insbesondere auch HARRYM.
                @Thomas-Braun Ich habe gestern noch einen zweiten Admin-Adapter installiert, dieser war jedoch dann auch nur auf der Version 3.7.8. Danach habe ich ihn wieder über die Konsole deinstalliert. Danach dann noch 2-mal update und upgrade durchgeführt, nach list adapters war er dann immer noch auf 3.7.8 . Danach konnte ich dann aber den IoT im 2. Versuch ohne Fehlermeldungen installieren und jetzt läuft er wieder. Wenn ich jetzt list adapters aufrufe steht der Admin mit der Version 4.0.10 dort. Alles Ok. Nochmals Vielen Dank.
                  duffbeer2000 last edited by
                  @Australier @harrym
                  In einem Docker Container funktioniert der Befehlt "iobroker stop" nicht. Die einzige Möglichkeit hier den iobroker zu stoppen ist wie @Thomas-Braun geschrieben hat "pkill io"
                    Thomas Braun Most Active @duffbeer2000 last edited by
                    @duffbeer2000 Ich mag den Docker einfach nicht... 🙂
                      Jan1 last edited by Jan1
                      Hat schon einer den neuen IoT 1.5.0 laufen?
                      Der will bei mir nicht und fordert mich auf das Passwort mit 8 Zeichen, groß und Kleinbuchstaben anzulegen. Das hat es aber schon und er bleibt gelb!
                      iot.0
                      2020-05-20 17:26:18.774
                      error
                      (701258) The password must be at least 8 characters long and have numbers, upper and lower case letters. Please change the password in the profile https://iobroker.pro/accountProfile.
                      Thomas Braun Alfa Siera 2 Replies Last reply Reply Quote 0
                        Thomas Braun Most Active @Jan1 last edited by
                        @Jan1
                        Ist hier unauffällig:
                        2020-05-20 17:27:25.609  - info: iot.0 (14659) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.iot, node: v12.16.3, js-controller: 3.1.4
                        2020-05-20 17:27:25.646  - info: iot.0 (14659) Connecting with LALELU.eu-west-1.amazonaws.com
                        2020-05-20 17:27:26.325  - info: iot.0 (14659) Connection changed: connect
                        Alles schön grün.
                          Jan1 @Thomas Braun last edited by
                          @Thomas-Braun
                          Hab jetzt extra mal das Passwort geändert, aber 1.5.0 bleibt gelb und bringt immer noch die Meldung nach dem Passwort im Log.
                          Wie viel Zeichen hat Dein Passwort und viele davon sind Zahlen? Dann ändere ich das noch mal in der Kombination.
                            @Jan1 Zwischen 8 und 16 Zeichen, davon 3 Ziffern. 🙂
                              @Thomas-Braun
                              Hast da noch Sonderzeichen drin oder sind das nur Buchstaben und Zahlen?
                                Thomas Braun Most Active @Jan1 last edited by Thomas Braun
                                @Jan1 Nix besonderes. Nur Ziffern und Buchstaben.
                                50 3!|\| /\/\394 |-|4(|<3|2 |3!|\| !(|-| |\|!(|-|7. 🙂
                                • Palm_Maniac
                                  Palm_Maniac last edited by
                                  Ich hab genau das gleiche Problem seit der neuen Version V1.5.0. Hab mein PW geändert, insgesamt 11 Zeichen, davon 4 Zahlen und 2 Großbuchstaben. Im Log beharrt er weiter auf ein neues Kennwort.
                                    Jan1 @Palm_Maniac last edited by
                                    @Palm_Maniac
                                    Schön dass ich nicht alleine bin, beruhigt schon mal etwas. Ich geh dann mal zurück auf die alte Version und lege ein Issues an.
                                    Thomas Braun Palm_Maniac 2 Replies Last reply Reply Quote 0
                                      @Jan1 Aus dem Changelog:
                                      1.5.0 (2020-05-20)
                                      (bluefox) Changed requirements for password
                                      (bluefox) Do not try load the "sharp" if blood sugar not enabled
                                      Die Frage ist nur, was die neuen Bedingungen sind...
                                      • Palm_Maniac
                                        Palm_Maniac @Jan1 last edited by
                                        @Jan1 So mache ich es jetzt auch.
                                          Jan1 @Thomas Braun last edited by Jan1
                                          @Thomas-Braun
                                          Hab ich gelesen, wobei ich den Blutzucker Geraffel eh nicht habe, ich nicht mal weiß was das sein soll.
                                          Passwort hab ich ja geändert und im Log steht ja schon wie es definiert sein soll.
                                          Was mir aber aufgefallen ist, es ist egal ob das Passwort richtig oder falsch eingegeben wird, die Version 1.4.18 wird auch mit einem völlig falschen Passwort grün 🙄
                                            @Jan1
                                            Die Ziffern waren aber nicht zufällig am Anfang und/oder am Ende des PW? Das wird oft unterbunden, weil zu leicht zu brute forcen.
                                            cloud
                                            75
                                            414
                                            64667
