    4. js-controller 3.0/3.1 jetzt im Latest!
      e-i-k-e @apollon77 last edited by
      @apollon77
      Leider nicht möglich, zumindest nicht über die Web Oberfläche.
      host.ioBroker-Rock	2020-05-19 22:02:23.028	info	iobroker exit 0
      host.ioBroker-Rock	2020-05-19 22:02:22.020	info	iobroker Adapter "sql" updated
      host.ioBroker-Rock	2020-05-19 22:02:21.615	info	iobroker upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html custom.html text/html
      host.ioBroker-Rock	2020-05-19 22:02:20.831	info	iobroker upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html custom_m.html text/html
      host.ioBroker-Rock	2020-05-19 22:02:20.809	info	iobroker Update "system.adapter.sql.0"
      host.ioBroker-Rock	2020-05-19 22:02:20.771	info	iobroker upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
      host.ioBroker-Rock	2020-05-19 22:02:20.713	info	iobroker upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html index_m.html text/html
      host.ioBroker-Rock	2020-05-19 22:02:20.646	info	iobroker upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
      host.ioBroker-Rock	2020-05-19 22:02:20.508	info	iobroker upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
      host.ioBroker-Rock	2020-05-19 22:02:20.409	info	iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-19T22_02_20_364Z-debug.log
      host.ioBroker-Rock	2020-05-19 22:02:20.407	info	iobroker
      host.ioBroker-Rock	2020-05-19 22:02:20.361	info	iobroker a package version that doesn't exist.
      host.ioBroker-Rock	2020-05-19 22:02:20.360	info	iobroker notarget
      host.ioBroker-Rock	2020-05-19 22:02:20.359	info	iobroker npm ERR! notarget No matching version found for iobroker.sql@1.12.6.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR!
      host.ioBroker-Rock	2020-05-19 22:02:20.356	info	iobroker ERR! code ETARGET
      host.ioBroker-Rock	2020-05-19 22:02:20.355	info	iobroker npm
      host.ioBroker-Rock	2020-05-19 22:02:02.422	info	iobroker npm install iobroker.sql@1.12.6 --loglevel error --prefix "/opt/iobroker" (System call)
      host.ioBroker-Rock	2020-05-19 22:02:02.420	info	iobroker NPM version: 6.14.4
      host.ioBroker-Rock	2020-05-19 22:02:02.020	info	iobroker Update sql from @1.13.0 to @1.12.6
      host.ioBroker-Rock	2020-05-19 22:01:59.554	info	iobroker upgrade sql@1.12.6
      host.ioBroker-Rock	2020-05-19 22:01:46.249	info	Do not restart adapter system.adapter.sql.0 because disabled or deleted
      host.ioBroker-Rock	2020-05-19 22:01:46.245	error	instance system.adapter.sql.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      host.ioBroker-Rock	2020-05-20 00:03:34.386	info	Restart adapter system.adapter.sql.0 because enabled
      host.ioBroker-Rock	2020-05-20 00:03:34.386	info	instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
      host.ioBroker-Rock	2020-05-20 00:03:34.385	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      host.ioBroker-Rock	2020-05-20 00:03:34.385	error	Caught by controller[1]: at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115328)
      host.ioBroker-Rock	2020-05-20 00:03:34.385	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1482:21
      host.ioBroker-Rock	2020-05-20 00:03:34.384	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:26
      host.ioBroker-Rock	2020-05-20 00:03:34.384	error	Caught by controller[1]: at Array.map (<anonymous>)
      host.ioBroker-Rock	2020-05-20 00:03:34.384	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39
      host.ioBroker-Rock	2020-05-20 00:03:34.384	error	Caught by controller[1]: TypeError: Cannot read property 'startsWith' of undefined
      host.ioBroker-Rock	2020-05-20 00:03:34.383	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
      sql.0	2020-05-20 00:03:32.155	info	(22223) Terminated (NO_ERROR): Without reason
      sql.0	2020-05-20 00:03:32.153	info	(22223) terminating
      sql.0	2020-05-20 00:03:31.648	error	(22223) TypeError: Cannot read property 'startsWith' of undefined at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39 at Array.map (<anonymous>) at /opt/iobroker/no
      sql.0	2020-05-20 00:03:31.637	error	(22223) unhandled promise rejection: Cannot read property 'startsWith' of undefined
      sql.0	2020-05-20 00:03:31.636	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      sql.0	2020-05-20 00:03:31.293	info	(22223) enabled logging of discovergy.0.61234183.energy, Alias=false, 49 points now activated
      sql.0	2020-05-20 00:03:31.292	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Speicher_Laden, Alias=false, 48 points now activated
      sql.0	2020-05-20 00:03:31.292	info	(22223) enabled logging of hm-rega.0.OEQ0608543.0.DUTY_CYCLE, Alias=false, 47 points now activated
      sql.0	2020-05-20 00:03:31.292	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage.ENERGY_Power, Alias=false, 46 points now activated
      sql.0	2020-05-20 00:03:31.292	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage_Garage.ENERGY_Power, Alias=false, 45 points now activated
      sql.0	2020-05-20 00:03:31.291	info	(22223) enabled logging of rpi2.2.temperature.soc_temp, Alias=false, 44 points now activated
      sql.0	2020-05-20 00:03:31.291	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage.ENERGY_Voltage, Alias=false, 43 points now activated
      sql.0	2020-05-20 00:03:31.291	info	(22223) enabled logging of discovergy.0.4dd9ddc3cebe4ca5aa6c8e1693583fae.Power_Consumption, Alias=false, 42 points now activated
      sql.0	2020-05-20 00:03:31.291	info	(22223) enabled logging of hm-rpc.0.LEQ0422550.4.ACTUAL_TEMPERATURE, Alias=false, 41 points now activated
      sql.0	2020-05-20 00:03:31.290	info	(22223) enabled logging of hm-rpc.0.LEQ0594565.1.TEMPERATURE, Alias=false, 40 points now activated
      sql.0	2020-05-20 00:03:31.290	info	(22223) enabled logging of hm-rpc.0.LEQ0423259.4.ACTUAL_TEMPERATURE, Alias=false, 39 points now activated
      sql.0	2020-05-20 00:03:31.290	info	(22223) enabled logging of discovergy.0.61234183.energyOut, Alias=false, 38 points now activated
      sql.0	2020-05-20 00:03:31.289	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.zwischenZaehler, Alias=false, 37 points now activated
      sql.0	2020-05-20 00:03:31.289	info	(22223) enabled logging of sonoff.0.Schaltbaresteckdose_Kinderzimmer.ENERGY_Total, Alias=false, 36 points now activated
      sql.0	2020-05-20 00:03:31.289	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Leistung_Garage, Alias=false, 35 points now activated
      sql.0	2020-05-20 00:03:31.289	info	(22223) enabled logging of sonoff.0.Schaltbaresteckdose_Kinderzimmer.ENERGY_Power, Alias=false, 34 points now activated
      sql.0	2020-05-20 00:03:31.288	info	(22223) enabled logging of hm-rpc.0.UNITEMP001.1.TEMPERATURE, Alias=false, 33 points now activated
      sql.0	2020-05-20 00:03:31.288	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage.ENERGY_Total, Alias=false, 32 points now activated
      sql.0	2020-05-20 00:03:31.288	info	(22223) enabled logging of hm-rpc.0.UNITEMP001.2.TEMPERATURE, Alias=false, 31 points now activated
      sql.0	2020-05-20 00:03:31.286	info	(22223) enabled logging of mihome.0.devices.weather_v1_158d00023a7ec9.temperature, Alias=false, 30 points now activated
      sql.0	2020-05-20 00:03:31.286	info	(22223) enabled logging of discovergy.0.61234183.Power_Consumption, Alias=false, 29 points now activated
      sql.0	2020-05-20 00:03:31.286	info	(22223) enabled logging of rpi2.4.temperature.soc_temp, Alias=false, 28 points now activated
      sql.0	2020-05-20 00:03:31.285	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Gesamtleistung, Alias=false, 27 points now activated
      sql.0	2020-05-20 00:03:31.285	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Gesamtertrag_Tag, Alias=false, 26 points now activated
      sql.0	2020-05-20 00:03:31.285	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage_Garage.ENERGY_Today, Alias=false, 25 points now activated
      sql.0	2020-05-20 00:03:31.284	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage.ENERGY_Today, Alias=false, 24 points now activated
      sql.0	2020-05-20 00:03:31.284	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage.ENERGY_Yesterday, Alias=false, 23 points now activated
      sql.0	2020-05-20 00:03:31.283	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Gesamtertrag1, Alias=false, 22 points now activated
      sql.0	2020-05-20 00:03:31.283	info	(22223) enabled logging of discovergy.0.61234183.Power_Delivery, Alias=false, 21 points now activated
      sql.0	2020-05-20 00:03:31.283	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage_Garage.ENERGY_Yesterday, Alias=false, 20 points now activated
      sql.0	2020-05-20 00:03:31.283	info	(22223) enabled logging of mihome.0.devices.weather_v1_158d000277247f.temperature, Alias=false, 19 points now activated
      sql.0	2020-05-20 00:03:31.282	info	(22223) enabled logging of mihome.0.devices.weather_v1_158d00023a7f01.temperature, Alias=false, 18 points now activated
      sql.0	2020-05-20 00:03:31.282	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Leistung_Speicher, Alias=false, 17 points now activated
      sql.0	2020-05-20 00:03:31.282	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Gesamtverbrauch, Alias=false, 16 points now activated
      sql.0	2020-05-20 00:03:31.281	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage_Garage.ENERGY_Total, Alias=false, 15 points now activated
      sql.0	2020-05-20 00:03:31.281	info	(22223) enabled logging of sonoff.0.Leistungsmesser_PVAnlage_Garage.ENERGY_Voltage, Alias=false, 14 points now activated
      sql.0	2020-05-20 00:03:31.281	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Speicher_Speisen_direkt_von_PV, Alias=false, 13 points now activated
      sql.0	2020-05-20 00:03:31.281	info	(22223) enabled logging of hm-rpc.0.JPSENACT01.1.STATE, Alias=false, 12 points now activated
      sql.0	2020-05-20 00:03:31.280	info	(22223) enabled logging of sonoff.0.Schaltbaresteckdose_Kinderzimmer.POWER1, Alias=false, 11 points now activated
      sql.0	2020-05-20 00:03:31.280	info	(22223) enabled logging of hm-rpc.0.LEQ0420912.4.ACTUAL_TEMPERATURE, Alias=false, 10 points now activated
      sql.0	2020-05-20 00:03:31.279	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Gesamtertrag_PV-Anlagen, Alias=false, 9 points now activated
      sql.0	2020-05-20 00:03:31.279	info	(22223) enabled logging of javascript.0.variablen.Photovoltaik.Speicher_Speisen_vom_Akku, Alias=false, 8 points now activated
      sql.0	2020-05-20 00:03:31.279	info	(22223) enabled logging of hm-rpc.0.LEQ0596527.1.TEMPERATURE, Alias=false, 7 points now activated
      sql.0	2020-05-20 00:03:31.278	info	(22223) enabled logging of sonoff.0.Schaltbaresteckdose_Kinderzimmer.ENERGY_Today, Alias=false, 6 points now activated
      sql.0	2020-05-20 00:03:31.278	info	(22223) enabled logging of mihome.0.devices.weather_v1_158d0002478275.temperature, Alias=false, 5 points now activated
      sql.0	2020-05-20 00:03:31.277	info	(22223) enabled logging of rpi2.1.temperature.soc_temp, Alias=false, 4 points now activated
      sql.0	2020-05-20 00:03:31.277	info	(22223) enabled logging of hm-rpc.0.LEQ0594586.1.TEMPERATURE, Alias=false, 3 points now activated
      sql.0	2020-05-20 00:03:31.276	info	(22223) enabled logging of discovergy.0.4dd9ddc3cebe4ca5aa6c8e1693583fae.Power_Delivery, Alias=false, 2 points now activated
      sql.0	2020-05-20 00:03:31.275	info	(22223) enabled logging of mihome.0.devices.weather_v1_158d0002325c93.temperature, Alias=false, 1 points now activated
      sql.0	2020-05-20 00:03:30.593	info	(22223) Connected to sqlite
      sql.0	2020-05-20 00:03:30.518	info	(22223) starting. Version 1.13.0 in /opt/iobroker/node_modules/iobroker.sql, node: v12.16.3, js-controller: 3.1.4
      host.ioBroker-Rock	2020-05-19 22:03:29.370	info	instance system.adapter.sql.0 started with pid 22223
        apollon77 @e-i-k-e last edited by
        @e-i-k-e Die 1.12.6 gab es nie auf nom ... 1.12. 5 is your friend
          freak1051 last edited by
          Hallo Zusammen,
          habe versucht das Upgrade zu machen. Habe zu erst den Node auf 12.16.3 erfolgreich upgedatet. Leider kommt mit die unten angezeigte Meldung immer wieder.
          Habe auch die "fixes" veruscht, und leider klappt das nicht. An was kann dies Liegen?
            Thomas Braun Most Active @freak1051 last edited by
            @freak1051
            iobroker version
            iobroker list instances
              freak1051 @Thomas Braun last edited by
              @Thomas-Braun
              iobroker@iobroker:~$ iobroker version
              2.2.10
              iobroker@iobroker:~$ iobroker list instances
              + system.adapter.admin.0                 : admin                 -  enabled, por                                                 t: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                : alexa2                -  enabled
              + system.adapter.backitup.0              : backitup              -  enabled
                system.adapter.ble.0                   : ble                   -  enabled
              + system.adapter.denon.0                 : denon                 -  enabled
              + system.adapter.discovery.0             : discovery             -  enabled
              + system.adapter.fritzdect.0             : fritzdect             -  enabled
              + system.adapter.history.0               : history               -  enabled
              + system.adapter.hue-extended.0          : hue-extended          -  enabled
              + system.adapter.hue.0                   : hue                   -  enabled, por                                                 t: 80
              + system.adapter.info.0                  : info                  -  enabled
              + system.adapter.iot.0                   : iot                   -  enabled
              + system.adapter.javascript.0            : javascript            -  enabled
              + system.adapter.node-red.0              : node-red              -  enabled, por                                                 t: 1880, bind: 192.168.16.178
              + system.adapter.octoprint.0             : octoprint             -  enabled
              + system.adapter.ping.0                  : ping                  -  enabled
              + system.adapter.proxmox.0               : proxmox               -  enabled, por                                                 t: 8006
              + system.adapter.sonoff.0                : sonoff                -  enabled, por                                                 t: 1883, bind: 0.0.0.0
              + system.adapter.telegram.0              : telegram              -  enabled, por                                                 t: 8443, bind: 0.0.0.0
              + system.adapter.terminal.0              : terminal              -  enabled, por                                                 t: 8088, bind: 192.168.16.178, run as: admin
              + system.adapter.text2command.0          : text2command          -  enabled
              + system.adapter.tuya.0                  : tuya                  -  enabled
                system.adapter.vis-bars.0              : vis-bars              -  enabled
                system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
                system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
                system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
                system.adapter.vis-google-fonts.0      : vis-google-fonts      -  enabled
                system.adapter.vis-history.0           : vis-history           -  enabled
                system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
                system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
                system.adapter.vis-justgage.0          : vis-justgage          -  enabled
                system.adapter.vis-keyboard.0          : vis-keyboard          -  enabled
                system.adapter.vis-map.0               : vis-map               -  enabled
                system.adapter.vis-players.0           : vis-players           -  enabled
                system.adapter.vis-rgraph.0            : vis-rgraph            -  enabled
                system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
                system.adapter.vis-weather.0           : vis-weather           -  enabled
                system.adapter.vis.0                   : vis                   -  enabled
              + system.adapter.web.0                   : web                   -  enabled, por                                                 t: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.worx.0                  : worx                  -  enabled
                system.adapter.zigbee.0                : zigbee                - disabled, por                                                 t: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194A202                                                 C-if00
              + instance is alive
              Und da Es hieß, dass evtl noch Zombies laufen kann, hab ich ihn mal gestoppt, es is dann auch alles aus:
              iobroker@iobroker:~$ iobroker stop
                system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.hue.0                   : hue                   -  enabled, port: 80
                system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 192.168.16.178
                system.adapter.proxmox.0               : proxmox               -  enabled, port: 8006
                system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 192.168.16.178, run as: admin
                system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.zigbee.0                : zigbee                - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194A202C-if00
              + instance is alive
                @freak1051
                iobroker update
                iobroker upgrade
                  freak1051 last edited by freak1051
                  @Thomas-Braun
                  iobriobroker@iobroker:~$ iobroker update
                  Used repository: latest
                  hash changed or no sources cached => force download of new sources
                  Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error: Error: ESOCKETTIMEDOUT
                  update done
                  iobroker@iobroker:~$ iobroker upgrade
                  /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155
                          if (adapter.indexOf('@') !== -1) {
                  TypeError: Cannot read property 'indexOf' of undefined
                      at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155:21)
                      at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:41:14)
                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:647:37
                      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2205:45
                      at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:1487:62)
                      at processImmediate (internal/timers.js:456:21)
                  auch mit sudo, gleiches prob
                    Thomas Braun Most Active @freak1051 last edited by Thomas Braun
                    @freak1051 Was hast du eigentlich da für ein node laufen?
                    nodejs -v && node -v && npm -v
                    which nodejs && which node && which npm
                    Du sollst auch gar nicht mit 'sudo' da rum machen!
                      freak1051 @Thomas Braun last edited by freak1051
                      @Thomas-Braun
                      iobroker@iobroker:~$ nodejs -v && node -v && npm -v
                      v12.16.3
                      v12.16.3
                      6.13.2
                      iobroker@iobroker:~$ which nodejs && which node && which npm
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/local/bin/npm
                        @freak1051
                        Die Zeile mit which bitte auch.
                          @Thomas-Braun siehe oben
                            @freak1051 Da stimmt was nicht...
                            sudo rm /usr/local/bin/npm
                            sudo apt update
                            sudo apt upgrade
                            sudo apt install nodejs --reinstall
                              @Thomas-Braun said in js-controller 3.0/3.1 jetzt im Latest!:
                              sudo apt upgrade
                              iobroker@iobroker:~$ sudo rm /usr/local/bin/npm
                              iobroker@iobroker:~$ sudo apt update
                              OK:1 http://security.debian.org/debian-security buster/updates InRelease
                              OK:2 http://ftp.de.debian.org/debian buster InRelease
                              OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                              Holen:4 http://ftp.de.debian.org/debian buster-updates InRelease [49,3 kB]
                              Es wurden 49,3 kB in 0 s geholt (107 kB/s).
                              Aktualisierung für 65 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                              iobroker@iobroker:~$ sudo apt upgrade
                              Paketaktualisierung (Upgrade) wird berechnet... Fertig
                              Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                                gyp javascript-common libc-ares2 libjs-inherits libjs-is-typedarray libssl-dev libuv1 libuv1-dev node-abbrev node-ajv
                                node-ansi node-ansi-align node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy node-are-we-there-yet
                                node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
                                node-boxen node-brace-expansion node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless
                                node-chalk node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert node-color-name node-combined-stream
                                node-concat-map node-concat-stream node-config-chain node-console-control-strings node-copy-concurrently node-core-util-is
                                node-cross-spawn node-cyclist node-dashdash node-decamelize node-decompress-response node-deep-extend node-defaults
                                node-delayed-stream node-delegates node-detect-indent node-detect-newline node-duplexer3 node-duplexify node-ecc-jsbn
                                node-editor node-encoding node-end-of-stream node-errno node-escape-string-regexp node-execa node-extend node-extsprintf
                                node-find-up node-flush-write-stream node-forever-agent node-form-data node-from2 node-fs-vacuum node-fs-write-stream-atomic
                                node-fs.realpath node-gauge node-get-caller-file node-get-stream node-getpass node-glob node-got node-graceful-fs
                                node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode
                                node-hosted-git-info node-http-signature node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight
                                node-inherits node-ini node-invert-kv node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
                                node-is-retry-allowed node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn
                                node-json-parse-better-errors node-json-schema node-json-stable-stringify node-json-stringify-safe node-jsonify
                                node-jsonparse node-jsonstream node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path
                                node-lockfile node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn node-mimic-response node-minimatch
                                node-minimist node-mississippi node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
                                node-normalize-package-data node-npm-package-arg node-npm-run-path node-npmlog node-oauth-sign node-object-assign node-once
                                node-opener node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit node-p-locate node-p-timeout
                                node-package-json node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now
                                node-prepend-http node-process-nextick-args node-promise-inflight node-promzard node-proto-list node-prr node-pump
                                node-pumpify node-punycode node-qs node-qw node-rc node-read node-read-package-json node-readable-stream
                                node-registry-auth-token node-registry-url node-request node-require-directory node-require-main-filename node-resolve-from
                                node-retry node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff node-set-blocking node-sha
                                node-shebang-command node-shebang-regex node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
                                node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-stream-each node-stream-iterate node-stream-shift
                                node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments node-supports-color node-tar
                                node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent node-tweetnacl
                                node-typedarray node-uid-number node-unique-filename node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
                                node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which
                                node-which-module node-wide-align node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic node-xdg-basedir
                                node-xtend node-y18n node-yallist node-yargs node-yargs-parser nodejs-doc python-pkg-resources
                              Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                              Die folgenden NEUEN Pakete werden installiert:
                                linux-image-4.19.0-9-amd64
                              Die folgenden Pakete werden aktualisiert (Upgrade):
                                apt apt-utils base-files bind9-host curl distro-info-data e2fsprogs git git-man iputils-ping libapt-inst2.0 libapt-pkg5.0
                                libbind9-161 libcom-err2 libcups2 libcurl3-gnutls libcurl4 libdns-export1104 libdns1104 libext2fs2 libfuse2 libgnutls30
                                libicu63 libidn2-0 libisc-export1100 libisc1100 libisccc161 libisccfg163 libldap-2.4-2 libldap-common liblwres161
                                libnss-systemd libpam-systemd libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpython3.7-minimal libpython3.7-stdlib
                                libsasl2-2 libsasl2-modules libsasl2-modules-db libss2 libssl-dev libssl1.1 libsystemd0 libtiff5 libudev-dev libudev1
                                linux-image-amd64 linux-libc-dev node-yargs-parser nodejs-doc openssh-client openssh-server openssh-sftp-server openssl
                                python-apt-common python3-apt python3.7 python3.7-minimal sudo systemd systemd-sysv tzdata udev
                              65 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen 95,6 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 270 MB Plattenplatz zusätzlich benutzt.
                              Möchten Sie fortfahren? [J/n] j
                              Holen:1 http://ftp.de.debian.org/debian buster/main amd64 base-files amd64 10.3+deb10u4 [69,8 kB]
                              Holen:2 http://security.debian.org/debian-security buster/updates/main amd64 libapt-pkg5.0 amd64 1.8.2.1 [966 kB]
                              Holen:3 http://ftp.de.debian.org/debian buster/main amd64 libnss-systemd amd64 241-7~deb10u4 [205 kB]
                              Holen:4 http://ftp.de.debian.org/debian buster/main amd64 libudev-dev amd64 241-7~deb10u4 [110 kB]
                              Holen:5 http://ftp.de.debian.org/debian buster/main amd64 libsystemd0 amd64 241-7~deb10u4 [331 kB]
                              Holen:6 http://ftp.de.debian.org/debian buster/main amd64 libpam-systemd amd64 241-7~deb10u4 [209 kB]
                              Holen:7 http://ftp.de.debian.org/debian buster/main amd64 systemd amd64 241-7~deb10u4 [3.499 kB]
                              Holen:8 http://ftp.de.debian.org/debian buster/main amd64 udev amd64 241-7~deb10u4 [1.277 kB]
                              Holen:9 http://ftp.de.debian.org/debian buster/main amd64 libudev1 amd64 241-7~deb10u4 [150 kB]
                              Holen:10 http://ftp.de.debian.org/debian buster/main amd64 systemd-sysv amd64 241-7~deb10u4 [99,9 kB]
                              Holen:11 http://ftp.de.debian.org/debian buster/main amd64 libidn2-0 amd64 2.0.5-1+deb10u1 [76,7 kB]
                              Holen:12 http://ftp.de.debian.org/debian buster/main amd64 libgnutls30 amd64 3.6.7-4+deb10u3 [1.124 kB]
                              Holen:13 http://ftp.de.debian.org/debian buster/main amd64 libext2fs2 amd64 1.44.5-1+deb10u3 [221 kB]
                              Holen:14 http://ftp.de.debian.org/debian buster/main amd64 e2fsprogs amd64 1.44.5-1+deb10u3 [576 kB]
                              Holen:15 http://ftp.de.debian.org/debian buster/main amd64 libssl-dev amd64 1.1.1d-0+deb10u3 [1.793 kB]
                              Holen:16 http://ftp.de.debian.org/debian buster/main amd64 libssl1.1 amd64 1.1.1d-0+deb10u3 [1.538 kB]
                              Holen:17 http://ftp.de.debian.org/debian buster/main amd64 python3.7 amd64 3.7.3-2+deb10u1 [330 kB]
                              Holen:18 http://ftp.de.debian.org/debian buster/main amd64 libpython3.7-stdlib amd64 3.7.3-2+deb10u1 [1.734 kB]
                              Holen:19 http://ftp.de.debian.org/debian buster/main amd64 python3.7-minimal amd64 3.7.3-2+deb10u1 [1.736 kB]
                              Holen:20 http://ftp.de.debian.org/debian buster/main amd64 libpython3.7-minimal amd64 3.7.3-2+deb10u1 [589 kB]
                              Holen:21 http://ftp.de.debian.org/debian buster/main amd64 tzdata all 2020a-0+deb10u1 [263 kB]
                              Holen:22 http://ftp.de.debian.org/debian buster/main amd64 iputils-ping amd64 3:20180629-2+deb10u1 [43,3 kB]
                              Holen:23 http://ftp.de.debian.org/debian buster/main amd64 libcom-err2 amd64 1.44.5-1+deb10u3 [68,4 kB]
                              Holen:24 http://ftp.de.debian.org/debian buster/main amd64 openssh-sftp-server amd64 1:7.9p1-10+deb10u2 [44,6 kB]
                              Holen:25 http://ftp.de.debian.org/debian buster/main amd64 openssh-server amd64 1:7.9p1-10+deb10u2 [352 kB]
                              Holen:26 http://ftp.de.debian.org/debian buster/main amd64 git-man all 1:2.20.1-2+deb10u3 [1.620 kB]
                              Holen:27 http://ftp.de.debian.org/debian buster/main amd64 libsasl2-modules-db amd64 2.1.27+dfsg-1+deb10u1 [69,1 kB]
                              Holen:28 http://ftp.de.debian.org/debian buster/main amd64 libsasl2-2 amd64 2.1.27+dfsg-1+deb10u1 [106 kB]
                              Holen:29 http://ftp.de.debian.org/debian buster/main amd64 libldap-common all 2.4.47+dfsg-3+deb10u2 [89,7 kB]
                              Holen:30 http://ftp.de.debian.org/debian buster/main amd64 libldap-2.4-2 amd64 2.4.47+dfsg-3+deb10u2 [224 kB]
                              Holen:31 http://ftp.de.debian.org/debian buster/main amd64 libcurl3-gnutls amd64 7.64.0-4+deb10u1 [330 kB]
                              Holen:32 http://ftp.de.debian.org/debian buster/main amd64 git amd64 1:2.20.1-2+deb10u3 [5.633 kB]
                              Holen:33 http://security.debian.org/debian-security buster/updates/main amd64 libapt-inst2.0 amd64 1.8.2.1 [203 kB]
                              Holen:34 http://security.debian.org/debian-security buster/updates/main amd64 apt amd64 1.8.2.1 [1.418 kB]
                              Holen:35 http://security.debian.org/debian-security buster/updates/main amd64 apt-utils amd64 1.8.2.1 [421 kB]
                              Holen:36 http://security.debian.org/debian-security buster/updates/main amd64 bind9-host amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [271 kB]
                              Holen:37 http://security.debian.org/debian-security buster/updates/main amd64 libbind9-161 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [247 kB]
                              Holen:38 http://security.debian.org/debian-security buster/updates/main amd64 libisccfg163 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [266 kB]
                              Holen:39 http://security.debian.org/debian-security buster/updates/main amd64 libisccc161 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [236 kB]
                              Holen:40 http://security.debian.org/debian-security buster/updates/main amd64 libdns1104 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [1.222 kB]
                              Holen:41 http://security.debian.org/debian-security buster/updates/main amd64 libisc1100 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [457 kB]
                              Holen:42 http://security.debian.org/debian-security buster/updates/main amd64 liblwres161 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [251 kB]
                              Holen:43 http://security.debian.org/debian-security buster/updates/main amd64 libisc-export1100 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [380 kB]
                              Holen:44 http://security.debian.org/debian-security buster/updates/main amd64 libdns-export1104 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [972 kB]
                              Holen:45 http://ftp.de.debian.org/debian buster/main amd64 openssh-client amd64 1:7.9p1-10+deb10u2 [782 kB]
                              Holen:46 http://ftp.de.debian.org/debian buster/main amd64 curl amd64 7.64.0-4+deb10u1 [264 kB]
                              Holen:47 http://ftp.de.debian.org/debian buster/main amd64 libcurl4 amd64 7.64.0-4+deb10u1 [331 kB]
                              Holen:48 http://ftp.de.debian.org/debian buster/main amd64 distro-info-data all 0.41+deb10u2 [6.584 B]
                              Holen:49 http://ftp.de.debian.org/debian buster/main amd64 libcups2 amd64 2.2.10-6+deb10u3 [324 kB]
                              Holen:50 http://ftp.de.debian.org/debian buster/main amd64 libfuse2 amd64 2.9.9-1+deb10u1 [128 kB]
                              Holen:51 http://ftp.de.debian.org/debian buster/main amd64 libicu63 amd64 63.1-6+deb10u1 [8.300 kB]
                              Holen:52 http://ftp.de.debian.org/debian buster/main amd64 libpango-1.0-0 amd64 1.42.4-8~deb10u1 [186 kB]
                              Holen:53 http://ftp.de.debian.org/debian buster/main amd64 libpangoft2-1.0-0 amd64 1.42.4-8~deb10u1 [68,3 kB]
                              Holen:54 http://ftp.de.debian.org/debian buster/main amd64 libpangocairo-1.0-0 amd64 1.42.4-8~deb10u1 [55,7 kB]
                              Holen:55 http://ftp.de.debian.org/debian buster/main amd64 libsasl2-modules amd64 2.1.27+dfsg-1+deb10u1 [104 kB]
                              Holen:56 http://ftp.de.debian.org/debian buster/main amd64 libss2 amd64 1.44.5-1+deb10u3 [72,9 kB]
                              Holen:57 http://ftp.de.debian.org/debian buster/main amd64 libtiff5 amd64 4.1.0+git191117-2~deb10u1 [271 kB]
                              Holen:58 http://ftp.de.debian.org/debian buster/main amd64 linux-image-4.19.0-9-amd64 amd64 4.19.118-2 [48,2 MB]
                              Holen:59 http://ftp.de.debian.org/debian buster/main amd64 linux-image-amd64 amd64 4.19+105+deb10u4 [8.140 B]
                              Holen:60 http://ftp.de.debian.org/debian buster/main amd64 linux-libc-dev amd64 4.19.118-2 [1.353 kB]
                              Holen:61 http://ftp.de.debian.org/debian buster/main amd64 node-yargs-parser all 11.1.1-1+deb10u1 [16,7 kB]
                              Holen:62 http://ftp.de.debian.org/debian buster/main amd64 nodejs-doc all 10.19.0~dfsg1-1 [968 kB]
                              Holen:63 http://ftp.de.debian.org/debian buster/main amd64 openssl amd64 1.1.1d-0+deb10u3 [844 kB]
                              Holen:64 http://ftp.de.debian.org/debian buster/main amd64 python-apt-common all 1.8.4.1 [95,7 kB]
                              Holen:65 http://ftp.de.debian.org/debian buster/main amd64 python3-apt amd64 1.8.4.1 [184 kB]
                              Holen:66 http://ftp.de.debian.org/debian buster/main amd64 sudo amd64 1.8.27-1+deb10u2 [1.245 kB]
                              Es wurden 95,6 MB in 7 s geholt (13,3 MB/s).
                              Changelogs werden gelesen... Fertig
                              Extrahiere Vorlagen aus Paketen: 100%
                              Vorkonfiguration der Pakete ...
                              (Lese Datenbank ... 51010 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../base-files_10.3+deb10u4_amd64.deb ...
                              Entpacken von base-files (10.3+deb10u4) über (10.3+deb10u2) ...
                              base-files (10.3+deb10u4) wird eingerichtet ...
                              Neue Version der Konfigurationsdatei /etc/debian_version wird installiert ...
                              Vorbereitung zum Entpacken von .../libnss-systemd_241-7~deb10u4_amd64.deb ...
                              Entpacken von libnss-systemd:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                              Vorbereitung zum Entpacken von .../libudev-dev_241-7~deb10u4_amd64.deb ...
                              Entpacken von libudev-dev:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                              Vorbereitung zum Entpacken von .../libsystemd0_241-7~deb10u4_amd64.deb ...
                              Entpacken von libsystemd0:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                              libsystemd0:amd64 (241-7~deb10u4) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libpam-systemd_241-7~deb10u4_amd64.deb ...
                              Entpacken von libpam-systemd:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                              Vorbereitung zum Entpacken von .../systemd_241-7~deb10u4_amd64.deb ...
                              Entpacken von systemd (241-7~deb10u4) über (241-7~deb10u2) ...
                              Vorbereitung zum Entpacken von .../udev_241-7~deb10u4_amd64.deb ...
                              Entpacken von udev (241-7~deb10u4) über (241-7~deb10u2) ...
                              Vorbereitung zum Entpacken von .../libudev1_241-7~deb10u4_amd64.deb ...
                              Entpacken von libudev1:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                              libudev1:amd64 (241-7~deb10u4) wird eingerichtet ...
                              systemd (241-7~deb10u4) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../systemd-sysv_241-7~deb10u4_amd64.deb ...
                              Entpacken von systemd-sysv (241-7~deb10u4) über (241-7~deb10u2) ...
                              Vorbereitung zum Entpacken von .../libidn2-0_2.0.5-1+deb10u1_amd64.deb ...
                              Entpacken von libidn2-0:amd64 (2.0.5-1+deb10u1) über (2.0.5-1) ...
                              libidn2-0:amd64 (2.0.5-1+deb10u1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libgnutls30_3.6.7-4+deb10u3_amd64.deb ...
                              Entpacken von libgnutls30:amd64 (3.6.7-4+deb10u3) über (3.6.7-4) ...
                              libgnutls30:amd64 (3.6.7-4+deb10u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libapt-pkg5.0_1.8.2.1_amd64.deb ...
                              Entpacken von libapt-pkg5.0:amd64 (1.8.2.1) über (1.8.2) ...
                              libapt-pkg5.0:amd64 (1.8.2.1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../libapt-inst2.0_1.8.2.1_amd64.deb ...
                              Entpacken von libapt-inst2.0:amd64 (1.8.2.1) über (1.8.2) ...
                              Vorbereitung zum Entpacken von .../archives/apt_1.8.2.1_amd64.deb ...
                              Entpacken von apt (1.8.2.1) über (1.8.2) ...
                              apt (1.8.2.1) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../apt-utils_1.8.2.1_amd64.deb ...
                              Entpacken von apt-utils (1.8.2.1) über (1.8.2) ...
                              Vorbereitung zum Entpacken von .../libext2fs2_1.44.5-1+deb10u3_amd64.deb ...
                              Entpacken von libext2fs2:amd64 (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                              libext2fs2:amd64 (1.44.5-1+deb10u3) wird eingerichtet ...
                              Vorbereitung zum Entpacken von .../00-e2fsprogs_1.44.5-1+deb10u3_amd64.deb ...
                              Entpacken von e2fsprogs (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                              Vorbereitung zum Entpacken von .../01-libssl-dev_1.1.1d-0+deb10u3_amd64.deb ...
                              Entpacken von libssl-dev:amd64 (1.1.1d-0+deb10u3) über (1.1.1d-0+deb10u2) ...
                              Vorbereitung zum Entpacken von .../02-libssl1.1_1.1.1d-0+deb10u3_amd64.deb ...
                              Entpacken von libssl1.1:amd64 (1.1.1d-0+deb10u3) über (1.1.1d-0+deb10u2) ...
                              Vorbereitung zum Entpacken von .../03-python3.7_3.7.3-2+deb10u1_amd64.deb ...
                              Entpacken von python3.7 (3.7.3-2+deb10u1) über (3.7.3-2) ...
                              Vorbereitung zum Entpacken von .../04-libpython3.7-stdlib_3.7.3-2+deb10u1_amd64.deb ...
                              Entpacken von libpython3.7-stdlib:amd64 (3.7.3-2+deb10u1) über (3.7.3-2) ...
                              Vorbereitung zum Entpacken von .../05-python3.7-minimal_3.7.3-2+deb10u1_amd64.deb ...
                              Entpacken von python3.7-minimal (3.7.3-2+deb10u1) über (3.7.3-2) ...
                              Vorbereitung zum Entpacken von .../06-libpython3.7-minimal_3.7.3-2+deb10u1_amd64.deb ...
                              Entpacken von libpython3.7-minimal:amd64 (3.7.3-2+deb10u1) über (3.7.3-2) ...
                              Vorbereitung zum Entpacken von .../07-tzdata_2020a-0+deb10u1_all.deb ...
                              Entpacken von tzdata (2020a-0+deb10u1) über (2019c-0+deb10u1) ...
                              Vorbereitung zum Entpacken von .../08-iputils-ping_3%3a20180629-2+deb10u1_amd64.deb ...
                              Entpacken von iputils-ping (3:20180629-2+deb10u1) über (3:20180629-2) ...
                              Vorbereitung zum Entpacken von .../09-bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../10-libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../11-libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../12-libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../13-libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../14-libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../15-libcom-err2_1.44.5-1+deb10u3_amd64.deb ...
                              Entpacken von libcom-err2:amd64 (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                              Vorbereitung zum Entpacken von .../16-liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../17-openssh-sftp-server_1%3a7.9p1-10+deb10u2_amd64.deb ...
                              Entpacken von openssh-sftp-server (1:7.9p1-10+deb10u2) über (1:7.9p1-10+deb10u1) ...
                              Vorbereitung zum Entpacken von .../18-openssh-server_1%3a7.9p1-10+deb10u2_amd64.deb ...
                              Entpacken von openssh-server (1:7.9p1-10+deb10u2) über (1:7.9p1-10+deb10u1) ...
                              Vorbereitung zum Entpacken von .../19-git-man_1%3a2.20.1-2+deb10u3_all.deb ...
                              Entpacken von git-man (1:2.20.1-2+deb10u3) über (1:2.20.1-2) ...
                              Vorbereitung zum Entpacken von .../20-libsasl2-modules-db_2.1.27+dfsg-1+deb10u1_amd64.deb ...
                              Entpacken von libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u1) über (2.1.27+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../21-libsasl2-2_2.1.27+dfsg-1+deb10u1_amd64.deb ...
                              Entpacken von libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u1) über (2.1.27+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../22-libldap-common_2.4.47+dfsg-3+deb10u2_all.deb ...
                              Entpacken von libldap-common (2.4.47+dfsg-3+deb10u2) über (2.4.47+dfsg-3+deb10u1) ...
                              Vorbereitung zum Entpacken von .../23-libldap-2.4-2_2.4.47+dfsg-3+deb10u2_amd64.deb ...
                              Entpacken von libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u2) über (2.4.47+dfsg-3+deb10u1) ...
                              Vorbereitung zum Entpacken von .../24-libcurl3-gnutls_7.64.0-4+deb10u1_amd64.deb ...
                              Entpacken von libcurl3-gnutls:amd64 (7.64.0-4+deb10u1) über (7.64.0-4) ...
                              Vorbereitung zum Entpacken von .../25-git_1%3a2.20.1-2+deb10u3_amd64.deb ...
                              Entpacken von git (1:2.20.1-2+deb10u3) über (1:2.20.1-2) ...
                              Vorbereitung zum Entpacken von .../26-openssh-client_1%3a7.9p1-10+deb10u2_amd64.deb ...
                              Entpacken von openssh-client (1:7.9p1-10+deb10u2) über (1:7.9p1-10+deb10u1) ...
                              Vorbereitung zum Entpacken von .../27-curl_7.64.0-4+deb10u1_amd64.deb ...
                              Entpacken von curl (7.64.0-4+deb10u1) über (7.64.0-4) ...
                              Vorbereitung zum Entpacken von .../28-libcurl4_7.64.0-4+deb10u1_amd64.deb ...
                              Entpacken von libcurl4:amd64 (7.64.0-4+deb10u1) über (7.64.0-4) ...
                              Vorbereitung zum Entpacken von .../29-distro-info-data_0.41+deb10u2_all.deb ...
                              Entpacken von distro-info-data (0.41+deb10u2) über (0.41+deb10u1) ...
                              Vorbereitung zum Entpacken von .../30-libcups2_2.2.10-6+deb10u3_amd64.deb ...
                              Entpacken von libcups2:amd64 (2.2.10-6+deb10u3) über (2.2.10-6+deb10u1) ...
                              Vorbereitung zum Entpacken von .../31-libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../32-libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                              Entpacken von libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                              Vorbereitung zum Entpacken von .../33-libfuse2_2.9.9-1+deb10u1_amd64.deb ...
                              Entpacken von libfuse2:amd64 (2.9.9-1+deb10u1) über (2.9.9-1) ...
                              Vorbereitung zum Entpacken von .../34-libicu63_63.1-6+deb10u1_amd64.deb ...
                              Entpacken von libicu63:amd64 (63.1-6+deb10u1) über (63.1-6) ...
                              Vorbereitung zum Entpacken von .../35-libpango-1.0-0_1.42.4-8~deb10u1_amd64.deb ...
                              Entpacken von libpango-1.0-0:amd64 (1.42.4-8~deb10u1) über (1.42.4-7~deb10u1) ...
                              Vorbereitung zum Entpacken von .../36-libpangoft2-1.0-0_1.42.4-8~deb10u1_amd64.deb ...
                              Entpacken von libpangoft2-1.0-0:amd64 (1.42.4-8~deb10u1) über (1.42.4-7~deb10u1) ...
                              Vorbereitung zum Entpacken von .../37-libpangocairo-1.0-0_1.42.4-8~deb10u1_amd64.deb ...
                              Entpacken von libpangocairo-1.0-0:amd64 (1.42.4-8~deb10u1) über (1.42.4-7~deb10u1) ...
                              Vorbereitung zum Entpacken von .../38-libsasl2-modules_2.1.27+dfsg-1+deb10u1_amd64.deb ...
                              Entpacken von libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u1) über (2.1.27+dfsg-1) ...
                              Vorbereitung zum Entpacken von .../39-libss2_1.44.5-1+deb10u3_amd64.deb ...
                              Entpacken von libss2:amd64 (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                              Vorbereitung zum Entpacken von .../40-libtiff5_4.1.0+git191117-2~deb10u1_amd64.deb ...
                              Entpacken von libtiff5:amd64 (4.1.0+git191117-2~deb10u1) über (4.0.10-4) ...
                              Vormals nicht ausgewähltes Paket linux-image-4.19.0-9-amd64 wird gewählt.
                              Vorbereitung zum Entpacken von .../41-linux-image-4.19.0-9-amd64_4.19.118-2_amd64.deb ...
                              Entpacken von linux-image-4.19.0-9-amd64 (4.19.118-2) ...
                              Vorbereitung zum Entpacken von .../42-linux-image-amd64_4.19+105+deb10u4_amd64.deb ...
                              Entpacken von linux-image-amd64 (4.19+105+deb10u4) über (4.19+105+deb10u1) ...
                              Vorbereitung zum Entpacken von .../43-linux-libc-dev_4.19.118-2_amd64.deb ...
                              Entpacken von linux-libc-dev:amd64 (4.19.118-2) über (4.19.67-2+deb10u2) ...
                              Vorbereitung zum Entpacken von .../44-node-yargs-parser_11.1.1-1+deb10u1_all.deb ...
                              Entpacken von node-yargs-parser (11.1.1-1+deb10u1) über (11.1.1-1) ...
                              Vorbereitung zum Entpacken von .../45-nodejs-doc_10.19.0~dfsg1-1_all.deb ...
                              Entpacken von nodejs-doc (10.19.0~dfsg1-1) über (10.15.2~dfsg-2) ...
                              Vorbereitung zum Entpacken von .../46-openssl_1.1.1d-0+deb10u3_amd64.deb ...
                              Entpacken von openssl (1.1.1d-0+deb10u3) über (1.1.1d-0+deb10u2) ...
                              Vorbereitung zum Entpacken von .../47-python-apt-common_1.8.4.1_all.deb ...
                              Entpacken von python-apt-common (1.8.4.1) über (1.8.4) ...
                              Vorbereitung zum Entpacken von .../48-python3-apt_1.8.4.1_amd64.deb ...
                              Entpacken von python3-apt (1.8.4.1) über (1.8.4) ...
                              Vorbereitung zum Entpacken von .../49-sudo_1.8.27-1+deb10u2_amd64.deb ...
                              Entpacken von sudo (1.8.27-1+deb10u2) über (1.8.27-1+deb10u1) ...
                              systemd-sysv (241-7~deb10u4) wird eingerichtet ...
                              linux-image-4.19.0-9-amd64 (4.19.118-2) wird eingerichtet ...
                              I: /vmlinuz is now a symlink to boot/vmlinuz-4.19.0-9-amd64
                              I: /initrd.img is now a symlink to boot/initrd.img-4.19.0-9-amd64
                              /etc/kernel/postinst.d/initramfs-tools:
                              update-initramfs: Generating /boot/initrd.img-4.19.0-9-amd64
                              W: initramfs-tools configuration sets RESUME=UUID=577ea0da-21e7-41d0-a864-a3bc681aeabc
                              W: but no matching swap device is available.
                              I: The initramfs will attempt to resume from /dev/sda2
                              I: (UUID=2eae4334-dd4b-4154-92b7-c614d021c3f1)
                              I: Set the RESUME variable to override this.
                              /etc/kernel/postinst.d/zz-update-grub:
                              GRUB-Konfigurationsdatei wird erstellt …
                              Linux-Abbild gefunden: /boot/vmlinuz-4.19.0-9-amd64
                              initrd-Abbild gefunden: /boot/initrd.img-4.19.0-9-amd64
                              Linux-Abbild gefunden: /boot/vmlinuz-4.19.0-6-amd64
                              initrd-Abbild gefunden: /boot/initrd.img-4.19.0-6-amd64
                              erledigt
                              distro-info-data (0.41+deb10u2) wird eingerichtet ...
                              libssl1.1:amd64 (1.1.1d-0+deb10u3) wird eingerichtet ...
                              libpango-1.0-0:amd64 (1.42.4-8~deb10u1) wird eingerichtet ...
                              libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u1) wird eingerichtet ...
                              linux-libc-dev:amd64 (4.19.118-2) wird eingerichtet ...
                              libnss-systemd:amd64 (241-7~deb10u4) wird eingerichtet ...
                              libcom-err2:amd64 (1.44.5-1+deb10u3) wird eingerichtet ...
                              libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              linux-image-amd64 (4.19+105+deb10u4) wird eingerichtet ...
                              libfuse2:amd64 (2.9.9-1+deb10u1) wird eingerichtet ...
                              libapt-inst2.0:amd64 (1.8.2.1) wird eingerichtet ...
                              libldap-common (2.4.47+dfsg-3+deb10u2) wird eingerichtet ...
                              libpython3.7-minimal:amd64 (3.7.3-2+deb10u1) wird eingerichtet ...
                              node-yargs-parser (11.1.1-1+deb10u1) wird eingerichtet ...
                              libicu63:amd64 (63.1-6+deb10u1) wird eingerichtet ...
                              libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u1) wird eingerichtet ...
                              tzdata (2020a-0+deb10u1) wird eingerichtet ...
                              Current default time zone: 'Europe/Berlin'
                              Local time is now:      Wed May 20 21:36:53 CEST 2020.
                              Universal Time is now:  Wed May 20 19:36:53 UTC 2020.
                              Run 'dpkg-reconfigure tzdata' if you wish to change it.
                              liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              libssl-dev:amd64 (1.1.1d-0+deb10u3) wird eingerichtet ...
                              udev (241-7~deb10u4) wird eingerichtet ...
                              update-initramfs: deferring update (trigger activated)
                              libss2:amd64 (1.44.5-1+deb10u3) wird eingerichtet ...
                              sudo (1.8.27-1+deb10u2) wird eingerichtet ...
                              libudev-dev:amd64 (241-7~deb10u4) wird eingerichtet ...
                              python3.7-minimal (3.7.3-2+deb10u1) wird eingerichtet ...
                              libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u1) wird eingerichtet ...
                              nodejs-doc (10.19.0~dfsg1-1) wird eingerichtet ...
                              libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              libcups2:amd64 (2.2.10-6+deb10u3) wird eingerichtet ...
                              python-apt-common (1.8.4.1) wird eingerichtet ...
                              libpam-systemd:amd64 (241-7~deb10u4) wird eingerichtet ...
                              libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              git-man (1:2.20.1-2+deb10u3) wird eingerichtet ...
                              libtiff5:amd64 (4.1.0+git191117-2~deb10u1) wird eingerichtet ...
                              libpangoft2-1.0-0:amd64 (1.42.4-8~deb10u1) wird eingerichtet ...
                              openssl (1.1.1d-0+deb10u3) wird eingerichtet ...
                              libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              iputils-ping (3:20180629-2+deb10u1) wird eingerichtet ...
                              libpangocairo-1.0-0:amd64 (1.42.4-8~deb10u1) wird eingerichtet ...
                              libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              libpython3.7-stdlib:amd64 (3.7.3-2+deb10u1) wird eingerichtet ...
                              apt-utils (1.8.2.1) wird eingerichtet ...
                              python3-apt (1.8.4.1) wird eingerichtet ...
                              openssh-client (1:7.9p1-10+deb10u2) wird eingerichtet ...
                              libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u2) wird eingerichtet ...
                              e2fsprogs (1.44.5-1+deb10u3) wird eingerichtet ...
                              libcurl3-gnutls:amd64 (7.64.0-4+deb10u1) wird eingerichtet ...
                              git (1:2.20.1-2+deb10u3) wird eingerichtet ...
                              libcurl4:amd64 (7.64.0-4+deb10u1) wird eingerichtet ...
                              curl (7.64.0-4+deb10u1) wird eingerichtet ...
                              libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              python3.7 (3.7.3-2+deb10u1) wird eingerichtet ...
                              openssh-sftp-server (1:7.9p1-10+deb10u2) wird eingerichtet ...
                              openssh-server (1:7.9p1-10+deb10u2) wird eingerichtet ...
                              rescue-ssh.target is a disabled or a static unit, not starting it.
                              libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                              Trigger für libc-bin (2.28-10) werden verarbeitet ...
                              Trigger für systemd (241-7~deb10u4) werden verarbeitet ...
                              Trigger für man-db (2.8.5-2) werden verarbeitet ...
                              Trigger für dbus (1.12.16-1) werden verarbeitet ...
                              Trigger für mime-support (3.62) werden verarbeitet ...
                              Trigger für initramfs-tools (0.133+deb10u1) werden verarbeitet ...
                              iobroker@iobroker:~$ sudo apt install nodejs --reinstall
                              0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                              Es müssen noch 0 B von 18,0 MB an Archiven heruntergeladen werden.
                              Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                              (Lese Datenbank ... 55431 Dateien und Verzeichnisse sind derzeit installiert.)
                              Vorbereitung zum Entpacken von .../nodejs_12.16.3-1nodesource1_amd64.deb ...
                              Detected old npm client, removing...
                              Entpacken von nodejs (12.16.3-1nodesource1) über (12.16.3-1nodesource1) ...
                              nodejs (12.16.3-1nodesource1) wird eingerichtet ...
                                @freak1051 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                sudo apt autoremove
                                sudo reboot
                                Da hast du mal irgendwelchen node-Krams irgendwo anders her gezogen.
                                  @Thomas-Braun
                                  iobroker@iobroker:~$ sudo apt autoremove
                                  Die folgenden Pakete werden ENTFERNT:
                                  0 aktualisiert, 0 neu installiert, 248 zu entfernen und 0 nicht aktualisiert.
                                  Nach dieser Operation werden 26,2 MB Plattenplatz freigegeben.
                                  Entfernen von gyp (0.1+20180428git4d467626-3) ...
                                  Entfernen von javascript-common (11) ...
                                  Entfernen von libc-ares2:amd64 (1.14.0-1) ...
                                  Entfernen von node-cacache (11.3.2-2) ...
                                  Entfernen von node-mississippi (3.0.0-1) ...
                                  Entfernen von node-through2 (2.0.5-2) ...
                                  Entfernen von node-flush-write-stream (1.0.3-1) ...
                                  Entfernen von node-pumpify (1.5.1-1) ...
                                  Entfernen von node-request (2.88.1-2) ...
                                  Entfernen von node-is-typedarray (1.0.0-2) ...
                                  Entfernen von libjs-is-typedarray (1.0.0-2) ...
                                  Entfernen von libssl-dev:amd64 (1.1.1d-0+deb10u3) ...
                                  Entfernen von libuv1-dev:amd64 (1.24.1-1) ...
                                  Entfernen von libuv1:amd64 (1.24.1-1) ...
                                  Entfernen von node-nopt (3.0.6-3) ...
                                  Entfernen von node-abbrev (1.1.1-1) ...
                                  Entfernen von node-har-validator (5.1.0-1) ...
                                  Entfernen von node-ajv (5.0.0-1) ...
                                  Entfernen von node-ansi (0.3.0-3) ...
                                  Entfernen von node-boxen (1.2.2-1) ...
                                  Entfernen von node-ansi-align (2.0.0-1) ...
                                  Entfernen von node-libnpx (10.2.0+repack-1) ...
                                  Entfernen von node-yargs (10.0.3-2) ...
                                  Entfernen von node-cliui (4.1.0-1) ...
                                  Entfernen von node-wrap-ansi (4.0.0-1) ...
                                  Entfernen von node-chalk (2.3.0-2) ...
                                  Entfernen von node-ansi-styles (3.2.1-1) ...
                                  Entfernen von node-ansistyles (0.1.3-1) ...
                                  Entfernen von node-npmlog (4.1.2-1) ...
                                  Entfernen von node-gauge (2.7.4-1) ...
                                  Entfernen von node-move-concurrently (1.0.1-2) ...
                                  Entfernen von node-archy (1.0.0-2) ...
                                  Entfernen von node-are-we-there-yet (1.1.4-1) ...
                                  Entfernen von node-http-signature (1.2.0-1) ...
                                  Entfernen von node-sshpk (1.13.1+dfsg-2) ...
                                  Entfernen von node-asn1 (0.2.3-1) ...
                                  Entfernen von node-dashdash (1.14.1-2) ...
                                  Entfernen von node-jsprim (1.4.0-1) ...
                                  Entfernen von node-verror (1.10.0-1) ...
                                  Entfernen von node-form-data (2.3.2-2) ...
                                  Entfernen von node-asynckit (0.4.0-2) ...
                                  Entfernen von node-aws-sign2 (0.7.1-1) ...
                                  Entfernen von node-aws4 (1.8.0-1) ...
                                  Entfernen von node-read-package-json (2.0.13-1) ...
                                  Entfernen von node-copy-concurrently (1.0.5-4) ...
                                  Entfernen von node-bcrypt-pbkdf (1.0.1-1) ...
                                  Entfernen von node-bluebird (3.5.1+dfsg2-2) ...
                                  Entfernen von node-normalize-package-data (2.4.0-1) ...
                                  Entfernen von node-is-builtin-module (2.0.0-1) ...
                                  Entfernen von node-builtin-modules (3.0.0-1) ...
                                  Entfernen von node-npm-package-arg (6.0.0-2) ...
                                  Entfernen von node-validate-npm-package-name (3.0.0-1) ...
                                  Entfernen von node-builtins (1.0.3-1) ...
                                  Entfernen von node-call-limit (1.1.0-1) ...
                                  Entfernen von node-yargs-parser (11.1.1-1+deb10u1) ...
                                  Entfernen von node-camelcase (5.0.0-1) ...
                                  Entfernen von node-caseless (0.12.0-1) ...
                                  Entfernen von node-tar (4.4.6+ds1-3) ...
                                  Entfernen von node-chownr (1.1.1-1) ...
                                  Entfernen von node-cli-boxes (1.0.0-1) ...
                                  Entfernen von node-widest-line (1.2.2-1) ...
                                  Entfernen von node-co (4.6.0-1) ...
                                  Entfernen von node-color-convert (1.9.0-3) ...
                                  Entfernen von node-color-name (1.1.3-1) ...
                                  Entfernen von node-combined-stream (1.0.7-1) ...
                                  Entfernen von node-concat-stream (1.6.2-1) ...
                                  Entfernen von node-config-chain (1.1.11-1) ...
                                  Entfernen von node-console-control-strings (1.1.0-1) ...
                                  Entfernen von node-term-size (1.2.0+dfsg-2) ...
                                  Entfernen von node-os-locale (2.0.0-1) ...
                                  Entfernen von node-execa (0.10.0+dfsg-1) ...
                                  Entfernen von node-cross-spawn (5.1.0-2) ...
                                  Entfernen von node-parallel-transform (1.1.0-2) ...
                                  Entfernen von node-cyclist (1.0.1-2) ...
                                  Entfernen von node-decamelize (1.2.0-1) ...
                                  Entfernen von node-latest-version (3.1.0-1) ...
                                  Entfernen von node-package-json (4.0.1-1) ...
                                  Entfernen von node-got (7.1.0-1) ...
                                  Entfernen von node-decompress-response (3.3.0-1) ...
                                  Entfernen von node-registry-url (3.1.0-1) ...
                                  Entfernen von node-registry-auth-token (3.3.1-1) ...
                                  Entfernen von node-rc (1.1.6-2) ...
                                  Entfernen von node-deep-extend (0.4.1-2) ...
                                  Entfernen von node-delayed-stream (0.0.5-1) ...
                                  Entfernen von node-delegates (1.0.0-1) ...
                                  Entfernen von node-detect-indent (5.0.0-1) ...
                                  Entfernen von node-detect-newline (2.1.0-1) ...
                                  Entfernen von node-duplexer3 (0.1.4-4) ...
                                  Entfernen von node-duplexify (3.6.1-1) ...
                                  Entfernen von node-ecc-jsbn (0.1.1-1) ...
                                  Entfernen von node-editor (1.0.0-1) ...
                                  Entfernen von node-encoding (0.1.12-2) ...
                                  Entfernen von node-stream-each (1.2.2-2) ...
                                  Entfernen von node-pump (3.0.0-1) ...
                                  Entfernen von node-end-of-stream (1.4.1-1) ...
                                  Entfernen von node-errno (0.1.4-1) ...
                                  Entfernen von node-escape-string-regexp (1.0.5-1) ...
                                  Entfernen von node-extend (3.0.2-1) ...
                                  Entfernen von node-extsprintf (1.3.0-1) ...
                                  Entfernen von node-find-up (2.1.0-1) ...
                                  Entfernen von node-forever-agent (0.6.1-1) ...
                                  Entfernen von node-from2 (2.3.0-1) ...
                                  Entfernen von node-fs-vacuum (1.2.10-2) ...
                                  Entfernen von node-fs-write-stream-atomic (1.0.10-4) ...
                                  Entfernen von node-get-caller-file (1.0.2-1) ...
                                  Entfernen von node-get-stream (3.0.0-1) ...
                                  Entfernen von node-getpass (0.1.7-1) ...
                                  Entfernen von node-write-file-atomic (2.3.0-1) ...
                                  Entfernen von node-sha (2.0.1-1) ...
                                  Entfernen von node-graceful-fs (4.1.11-1) ...
                                  Entfernen von node-har-schema (2.0.0-1) ...
                                  Entfernen von node-supports-color (4.4.0-2) ...
                                  Entfernen von node-has-flag (2.0.0-1) ...
                                  Entfernen von node-isurl (1.0.0-1) ...
                                  Entfernen von node-has-to-string-tag-x (1.4.1+dfsg-1) ...
                                  Entfernen von node-has-symbol-support-x (1.4.1+dfsg-1) ...
                                  Entfernen von node-has-unicode (2.0.1-2) ...
                                  Entfernen von node-hosted-git-info (2.7.1-1) ...
                                  Entfernen von node-iconv-lite (0.4.13-2) ...
                                  Entfernen von node-iferr (1.0.2-1) ...
                                  Entfernen von node-import-lazy (3.0.0.REALLY.2.1.0-1) ...
                                  Entfernen von node-unique-filename (1.1.0+ds-2) ...
                                  Entfernen von node-imurmurhash (0.1.4-1) ...
                                  Entfernen von node-ini (1.3.5-1) ...
                                  Entfernen von node-lcid (1.0.0-1) ...
                                  Entfernen von node-invert-kv (1.0.0-1) ...
                                  Entfernen von node-is-npm (1.0.0-1) ...
                                  Entfernen von node-is-object (1.0.1-1) ...
                                  Entfernen von node-is-plain-obj (1.1.0-1) ...
                                  Entfernen von node-is-retry-allowed (1.1.0-1) ...
                                  Entfernen von node-is-stream (1.1.0-1) ...
                                  Entfernen von node-which (1.3.0-2) ...
                                  Entfernen von node-isexe (2.0.0-4) ...
                                  Entfernen von node-isstream (0.1.2+dfsg-1) ...
                                  Entfernen von node-jsbn (1.1.0-1) ...
                                  Entfernen von node-json-parse-better-errors (1.0.2-2) ...
                                  Entfernen von node-json-schema (0.2.3-1) ...
                                  Entfernen von node-json-stable-stringify (1.0.1-1) ...
                                  Entfernen von node-json-stringify-safe (5.0.1-1) ...
                                  Entfernen von node-jsonify (0.0.0-1) ...
                                  Entfernen von node-jsonstream (1.3.2-1) ...
                                  Entfernen von node-jsonparse (1.3.1-6) ...
                                  Entfernen von node-lazy-property (1.0.0-3) ...
                                  Entfernen von node-locate-path (2.0.0-1) ...
                                  Entfernen von node-lockfile (1.0.4-1) ...
                                  Entfernen von node-lowercase-keys (1.0.0-2) ...
                                  Entfernen von node-lru-cache (5.1.1-4) ...
                                  Entfernen von node-mem (1.1.0-1) ...
                                  Entfernen von node-mime-types (2.1.21-1) ...
                                  Entfernen von node-mimic-fn (1.1.0-1) ...
                                  Entfernen von node-mimic-response (1.0.0-1) ...
                                  Entfernen von node-minimist (1.2.0-1) ...
                                  Entfernen von node-mkdirp (0.5.1-1) ...
                                  Entfernen von node-promzard (0.3.0-1) ...
                                  Entfernen von node-read (1.0.7-1) ...
                                  Entfernen von node-mute-stream (0.0.8-1) ...
                                  Entfernen von node-node-uuid (3.3.2-2) ...
                                  Entfernen von node-npm-run-path (2.0.2-2) ...
                                  Entfernen von node-oauth-sign (0.9.0-1) ...
                                  Entfernen von node-object-assign (4.1.1-2) ...
                                  Entfernen von node-opener (1.4.3-1) ...
                                  Entfernen von node-osenv (0.1.5-1) ...
                                  Entfernen von node-p-cancelable (0.3.0-1) ...
                                  Entfernen von node-p-timeout (1.2.0-1) ...
                                  Entfernen von node-p-finally (1.0.0-2) ...
                                  Entfernen von node-p-locate (2.0.0-1) ...
                                  Entfernen von node-p-limit (1.1.0-1) ...
                                  Entfernen von node-path-exists (3.0.0-1) ...
                                  Entfernen von node-path-is-inside (1.0.2-1) ...
                                  Entfernen von node-performance-now (2.1.0+debian-1) ...
                                  Entfernen von node-url-parse-lax (1.0.0-1) ...
                                  Entfernen von node-prepend-http (2.0.0-1) ...
                                  Entfernen von node-promise-inflight (1.0.1-1) ...
                                  Entfernen von node-proto-list (1.2.4-1) ...
                                  Entfernen von node-prr (1.0.1-1) ...
                                  Entfernen von node-tough-cookie (2.3.4+dfsg-1) ...
                                  Entfernen von node-punycode (2.1.1-2) ...
                                  Entfernen von node-qs (6.5.2-1) ...
                                  Entfernen von node-qw (1.0.1-1) ...
                                  Entfernen von node-require-directory (2.1.1-1) ...
                                  Entfernen von node-require-main-filename (1.0.1-1) ...
                                  Entfernen von node-resolve-from (4.0.0-1) ...
                                  Entfernen von node-retry (0.10.1-1) ...
                                  Entfernen von node-tunnel-agent (0.6.1-1) ...
                                  Entfernen von node-semver-diff (2.1.0-2) ...
                                  Entfernen von node-semver (5.5.1-1) ...
                                  Entfernen von node-set-blocking (2.0.0-1) ...
                                  Entfernen von node-shebang-command (1.2.0-1) ...
                                  Entfernen von node-shebang-regex (2.0.0-1) ...
                                  Entfernen von node-signal-exit (3.0.2-1) ...
                                  Entfernen von node-slash (1.0.0-1) ...
                                  Entfernen von node-slide (1.1.6-2) ...
                                  Entfernen von node-sorted-object (2.0.1-1) ...
                                  Entfernen von node-validate-npm-package-license (3.0.1-1) ...
                                  Entfernen von node-spdx-correct (1.0.2-1) ...
                                  Entfernen von node-spdx-expression-parse (1.0.4-1) ...
                                  Entfernen von node-spdx-license-ids (1.2.2-1) ...
                                  Entfernen von node-ssri (5.2.4-2) ...
                                  Entfernen von node-stream-iterate (1.2.0-4) ...
                                  Entfernen von node-stream-shift (1.0.0-1) ...
                                  Entfernen von node-strip-eof (1.0.0-2) ...
                                  Entfernen von node-strip-json-comments (2.0.1-2) ...
                                  Entfernen von node-text-table (0.2.0-2) ...
                                  Entfernen von node-through (2.3.8-1) ...
                                  Entfernen von node-timed-out (4.0.1-4) ...
                                  Entfernen von node-tweetnacl (0.14.5+dfsg-3) ...
                                  Entfernen von node-typedarray (0.0.6-1) ...
                                  Entfernen von node-uid-number (0.0.6-1) ...
                                  Entfernen von node-unpipe (1.0.0-1) ...
                                  Entfernen von node-url-to-options (1.0.1-1) ...
                                  Entfernen von node-uuid (3.3.2-2) ...
                                  Entfernen von node-which-module (2.0.0-1) ...
                                  Entfernen von node-wide-align (1.1.0-1) ...
                                  Entfernen von node-xdg-basedir (3.0.0-1) ...
                                  Entfernen von node-xtend (4.0.1-2) ...
                                  Entfernen von node-y18n (3.2.1-2) ...
                                  Entfernen von node-yallist (3.0.3-1) ...
                                  Entfernen von nodejs-doc (10.19.0~dfsg1-1) ...
                                  Entfernen von python-pkg-resources (40.8.0-1) ...
                                  Entfernen von node-readable-stream (2.3.6-1) ...
                                  Entfernen von node-run-queue (1.0.3-1) ...
                                  Entfernen von node-aproba (1.2.0-1) ...
                                  Entfernen von node-assert-plus (1.0.0-1) ...
                                  Entfernen von node-rimraf (2.6.2-1) ...
                                  Entfernen von node-glob (7.1.3-2) ...
                                  Entfernen von node-minimatch (3.0.4-3) ...
                                  Entfernen von node-brace-expansion (1.1.8-1) ...
                                  Entfernen von node-balanced-match (0.4.2-1) ...
                                  Entfernen von node-string-width (2.1.1-1) ...
                                  Entfernen von node-wcwidth.js (1.0.0-1) ...
                                  Entfernen von node-defaults (1.0.3-1) ...
                                  Entfernen von node-clone (2.1.2-1) ...
                                  Entfernen von node-concat-map (0.0.1-1) ...
                                  Entfernen von node-core-util-is (1.0.2-1) ...
                                  Entfernen von node-fs.realpath (1.0.0-1) ...
                                  Entfernen von node-inflight (1.0.6-1) ...
                                  Entfernen von node-isarray (2.0.4-1) ...
                                  Entfernen von node-once (1.4.0-3) ...
                                  Entfernen von node-path-is-absolute (1.0.0-1) ...
                                  Entfernen von node-process-nextick-args (2.0.0-1) ...
                                  Entfernen von node-string-decoder (1.2.0-1) ...
                                  Entfernen von node-safe-buffer (5.1.2-1) ...
                                  Entfernen von node-util-deprecate (1.0.2-1) ...
                                  Entfernen von node-wrappy (1.0.2-1) ...
                                  Entfernen von node-inherits (2.0.3-1) ...
                                  Entfernen von libjs-inherits (2.0.3-1) ...
                                  Entfernen von node-strip-ansi (4.0.0-1) ...
                                  Entfernen von node-ansi-regex (3.0.0-1) ...
                                  ... und neu gestartet
                                    @Thomas-Braun
                                    kann sein... wüsste aber nicht wie und woher..
                                    müsste nun das iobroker update und iobroker upgrade gehen?
                                    • Diginix
                                      Diginix last edited by
                                      Und was ist nach der Aktion der Pfad von npm?
                                      Bei mir ist es auch unter "/usr/local/bin/npm" und alles läuft seit über 12 Monaten perfekt.
                                      F Thomas Braun 3 Replies Last reply Reply Quote 0
                                        freak1051 @Diginix last edited by freak1051
                                        @Diginix
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                          Thomas Braun Most Active @Diginix last edited by Thomas Braun
                                          @Diginix
                                          Dann hast du das auch mal irgendwann quer installiert.
                                          pi@raspberrypi:/opt/iobroker $ which npm
                                          /usr/bin/npm
                                            @Diginix bei mir läuft eig auch alles,... bius auf das Update ^^
                                            js-controller
                                            127
                                            1340
                                            434982
