    4. js-controller 3.0/3.1 jetzt im Latest!
      Thomas Braun Most Active @freak1051 last edited by
      @freak1051
      iobroker version
      iobroker list instances
        freak1051 @Thomas Braun last edited by
        @Thomas-Braun
        iobroker@iobroker:~$ iobroker version
        2.2.10
        iobroker@iobroker:~$ iobroker list instances
        + system.adapter.admin.0                 : admin                 -  enabled, por                                                 t: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                : alexa2                -  enabled
        + system.adapter.backitup.0              : backitup              -  enabled
          system.adapter.ble.0                   : ble                   -  enabled
        + system.adapter.denon.0                 : denon                 -  enabled
        + system.adapter.discovery.0             : discovery             -  enabled
        + system.adapter.fritzdect.0             : fritzdect             -  enabled
        + system.adapter.history.0               : history               -  enabled
        + system.adapter.hue-extended.0          : hue-extended          -  enabled
        + system.adapter.hue.0                   : hue                   -  enabled, por                                                 t: 80
        + system.adapter.info.0                  : info                  -  enabled
        + system.adapter.iot.0                   : iot                   -  enabled
        + system.adapter.javascript.0            : javascript            -  enabled
        + system.adapter.node-red.0              : node-red              -  enabled, por                                                 t: 1880, bind: 192.168.16.178
        + system.adapter.octoprint.0             : octoprint             -  enabled
        + system.adapter.ping.0                  : ping                  -  enabled
        + system.adapter.proxmox.0               : proxmox               -  enabled, por                                                 t: 8006
        + system.adapter.sonoff.0                : sonoff                -  enabled, por                                                 t: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0              : telegram              -  enabled, por                                                 t: 8443, bind: 0.0.0.0
        + system.adapter.terminal.0              : terminal              -  enabled, por                                                 t: 8088, bind: 192.168.16.178, run as: admin
        + system.adapter.text2command.0          : text2command          -  enabled
        + system.adapter.tuya.0                  : tuya                  -  enabled
          system.adapter.vis-bars.0              : vis-bars              -  enabled
          system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
          system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
          system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
          system.adapter.vis-google-fonts.0      : vis-google-fonts      -  enabled
          system.adapter.vis-history.0           : vis-history           -  enabled
          system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
          system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
          system.adapter.vis-justgage.0          : vis-justgage          -  enabled
          system.adapter.vis-keyboard.0          : vis-keyboard          -  enabled
          system.adapter.vis-map.0               : vis-map               -  enabled
          system.adapter.vis-players.0           : vis-players           -  enabled
          system.adapter.vis-rgraph.0            : vis-rgraph            -  enabled
          system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
          system.adapter.vis-weather.0           : vis-weather           -  enabled
          system.adapter.vis.0                   : vis                   -  enabled
        + system.adapter.web.0                   : web                   -  enabled, por                                                 t: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.worx.0                  : worx                  -  enabled
          system.adapter.zigbee.0                : zigbee                - disabled, por                                                 t: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194A202                                                 C-if00
        + instance is alive
        Und da Es hieß, dass evtl noch Zombies laufen kann, hab ich ihn mal gestoppt, es is dann auch alles aus:
        iobroker@iobroker:~$ iobroker stop
          system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.hue.0                   : hue                   -  enabled, port: 80
          system.adapter.node-red.0              : node-red              -  enabled, port: 1880, bind: 192.168.16.178
          system.adapter.proxmox.0               : proxmox               -  enabled, port: 8006
          system.adapter.sonoff.0                : sonoff                -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 192.168.16.178, run as: admin
          system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.zigbee.0                : zigbee                - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00194A202C-if00
        + instance is alive
          @freak1051
          iobroker update
          iobroker upgrade
            freak1051 last edited by freak1051
            @Thomas-Braun
            iobriobroker@iobroker:~$ iobroker update
            Used repository: latest
            hash changed or no sources cached => force download of new sources
            Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error: Error: ESOCKETTIMEDOUT
            update done
            iobroker@iobroker:~$ iobroker upgrade
            /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155
                    if (adapter.indexOf('@') !== -1) {
            TypeError: Cannot read property 'indexOf' of undefined
                at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155:21)
                at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:41:14)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:647:37
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2205:45
                at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:1487:62)
                at processImmediate (internal/timers.js:456:21)
            auch mit sudo, gleiches prob
              Thomas Braun Most Active @freak1051 last edited by Thomas Braun
              @freak1051 Was hast du eigentlich da für ein node laufen?
              nodejs -v && node -v && npm -v
              which nodejs && which node && which npm
              Du sollst auch gar nicht mit 'sudo' da rum machen!
                freak1051 @Thomas Braun last edited by freak1051
                @Thomas-Braun
                iobroker@iobroker:~$ nodejs -v && node -v && npm -v
                v12.16.3
                v12.16.3
                6.13.2
                iobroker@iobroker:~$ which nodejs && which node && which npm
                /usr/bin/nodejs
                /usr/bin/node
                /usr/local/bin/npm
                  @freak1051
                  Die Zeile mit which bitte auch.
                    @Thomas-Braun siehe oben
                      @freak1051 Da stimmt was nicht...
                      sudo rm /usr/local/bin/npm
                      sudo apt update
                      sudo apt upgrade
                      sudo apt install nodejs --reinstall
                        @Thomas-Braun said in js-controller 3.0/3.1 jetzt im Latest!:
                        sudo apt upgrade
                        iobroker@iobroker:~$ sudo rm /usr/local/bin/npm
                        iobroker@iobroker:~$ sudo apt update
                        OK:1 http://security.debian.org/debian-security buster/updates InRelease
                        OK:2 http://ftp.de.debian.org/debian buster InRelease
                        OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                        Holen:4 http://ftp.de.debian.org/debian buster-updates InRelease [49,3 kB]
                        Es wurden 49,3 kB in 0 s geholt (107 kB/s).
                        Aktualisierung für 65 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                        iobroker@iobroker:~$ sudo apt upgrade
                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                        Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                          gyp javascript-common libc-ares2 libjs-inherits libjs-is-typedarray libssl-dev libuv1 libuv1-dev node-abbrev node-ajv
                          node-ansi node-ansi-align node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy node-are-we-there-yet
                          node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
                          node-boxen node-brace-expansion node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless
                          node-chalk node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert node-color-name node-combined-stream
                          node-concat-map node-concat-stream node-config-chain node-console-control-strings node-copy-concurrently node-core-util-is
                          node-cross-spawn node-cyclist node-dashdash node-decamelize node-decompress-response node-deep-extend node-defaults
                          node-delayed-stream node-delegates node-detect-indent node-detect-newline node-duplexer3 node-duplexify node-ecc-jsbn
                          node-editor node-encoding node-end-of-stream node-errno node-escape-string-regexp node-execa node-extend node-extsprintf
                          node-find-up node-flush-write-stream node-forever-agent node-form-data node-from2 node-fs-vacuum node-fs-write-stream-atomic
                          node-fs.realpath node-gauge node-get-caller-file node-get-stream node-getpass node-glob node-got node-graceful-fs
                          node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode
                          node-hosted-git-info node-http-signature node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight
                          node-inherits node-ini node-invert-kv node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
                          node-is-retry-allowed node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn
                          node-json-parse-better-errors node-json-schema node-json-stable-stringify node-json-stringify-safe node-jsonify
                          node-jsonparse node-jsonstream node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path
                          node-lockfile node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn node-mimic-response node-minimatch
                          node-minimist node-mississippi node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
                          node-normalize-package-data node-npm-package-arg node-npm-run-path node-npmlog node-oauth-sign node-object-assign node-once
                          node-opener node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit node-p-locate node-p-timeout
                          node-package-json node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now
                          node-prepend-http node-process-nextick-args node-promise-inflight node-promzard node-proto-list node-prr node-pump
                          node-pumpify node-punycode node-qs node-qw node-rc node-read node-read-package-json node-readable-stream
                          node-registry-auth-token node-registry-url node-request node-require-directory node-require-main-filename node-resolve-from
                          node-retry node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff node-set-blocking node-sha
                          node-shebang-command node-shebang-regex node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
                          node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri node-stream-each node-stream-iterate node-stream-shift
                          node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments node-supports-color node-tar
                          node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent node-tweetnacl
                          node-typedarray node-uid-number node-unique-filename node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
                          node-uuid node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which
                          node-which-module node-wide-align node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic node-xdg-basedir
                          node-xtend node-y18n node-yallist node-yargs node-yargs-parser nodejs-doc python-pkg-resources
                        Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                        Die folgenden NEUEN Pakete werden installiert:
                          linux-image-4.19.0-9-amd64
                        Die folgenden Pakete werden aktualisiert (Upgrade):
                          apt apt-utils base-files bind9-host curl distro-info-data e2fsprogs git git-man iputils-ping libapt-inst2.0 libapt-pkg5.0
                          libbind9-161 libcom-err2 libcups2 libcurl3-gnutls libcurl4 libdns-export1104 libdns1104 libext2fs2 libfuse2 libgnutls30
                          libicu63 libidn2-0 libisc-export1100 libisc1100 libisccc161 libisccfg163 libldap-2.4-2 libldap-common liblwres161
                          libnss-systemd libpam-systemd libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpython3.7-minimal libpython3.7-stdlib
                          libsasl2-2 libsasl2-modules libsasl2-modules-db libss2 libssl-dev libssl1.1 libsystemd0 libtiff5 libudev-dev libudev1
                          linux-image-amd64 linux-libc-dev node-yargs-parser nodejs-doc openssh-client openssh-server openssh-sftp-server openssl
                          python-apt-common python3-apt python3.7 python3.7-minimal sudo systemd systemd-sysv tzdata udev
                        65 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen 95,6 MB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 270 MB Plattenplatz zusätzlich benutzt.
                        Möchten Sie fortfahren? [J/n] j
                        Holen:1 http://ftp.de.debian.org/debian buster/main amd64 base-files amd64 10.3+deb10u4 [69,8 kB]
                        Holen:2 http://security.debian.org/debian-security buster/updates/main amd64 libapt-pkg5.0 amd64 1.8.2.1 [966 kB]
                        Holen:3 http://ftp.de.debian.org/debian buster/main amd64 libnss-systemd amd64 241-7~deb10u4 [205 kB]
                        Holen:4 http://ftp.de.debian.org/debian buster/main amd64 libudev-dev amd64 241-7~deb10u4 [110 kB]
                        Holen:5 http://ftp.de.debian.org/debian buster/main amd64 libsystemd0 amd64 241-7~deb10u4 [331 kB]
                        Holen:6 http://ftp.de.debian.org/debian buster/main amd64 libpam-systemd amd64 241-7~deb10u4 [209 kB]
                        Holen:7 http://ftp.de.debian.org/debian buster/main amd64 systemd amd64 241-7~deb10u4 [3.499 kB]
                        Holen:8 http://ftp.de.debian.org/debian buster/main amd64 udev amd64 241-7~deb10u4 [1.277 kB]
                        Holen:9 http://ftp.de.debian.org/debian buster/main amd64 libudev1 amd64 241-7~deb10u4 [150 kB]
                        Holen:10 http://ftp.de.debian.org/debian buster/main amd64 systemd-sysv amd64 241-7~deb10u4 [99,9 kB]
                        Holen:11 http://ftp.de.debian.org/debian buster/main amd64 libidn2-0 amd64 2.0.5-1+deb10u1 [76,7 kB]
                        Holen:12 http://ftp.de.debian.org/debian buster/main amd64 libgnutls30 amd64 3.6.7-4+deb10u3 [1.124 kB]
                        Holen:13 http://ftp.de.debian.org/debian buster/main amd64 libext2fs2 amd64 1.44.5-1+deb10u3 [221 kB]
                        Holen:14 http://ftp.de.debian.org/debian buster/main amd64 e2fsprogs amd64 1.44.5-1+deb10u3 [576 kB]
                        Holen:15 http://ftp.de.debian.org/debian buster/main amd64 libssl-dev amd64 1.1.1d-0+deb10u3 [1.793 kB]
                        Holen:16 http://ftp.de.debian.org/debian buster/main amd64 libssl1.1 amd64 1.1.1d-0+deb10u3 [1.538 kB]
                        Holen:17 http://ftp.de.debian.org/debian buster/main amd64 python3.7 amd64 3.7.3-2+deb10u1 [330 kB]
                        Holen:18 http://ftp.de.debian.org/debian buster/main amd64 libpython3.7-stdlib amd64 3.7.3-2+deb10u1 [1.734 kB]
                        Holen:19 http://ftp.de.debian.org/debian buster/main amd64 python3.7-minimal amd64 3.7.3-2+deb10u1 [1.736 kB]
                        Holen:20 http://ftp.de.debian.org/debian buster/main amd64 libpython3.7-minimal amd64 3.7.3-2+deb10u1 [589 kB]
                        Holen:21 http://ftp.de.debian.org/debian buster/main amd64 tzdata all 2020a-0+deb10u1 [263 kB]
                        Holen:22 http://ftp.de.debian.org/debian buster/main amd64 iputils-ping amd64 3:20180629-2+deb10u1 [43,3 kB]
                        Holen:23 http://ftp.de.debian.org/debian buster/main amd64 libcom-err2 amd64 1.44.5-1+deb10u3 [68,4 kB]
                        Holen:24 http://ftp.de.debian.org/debian buster/main amd64 openssh-sftp-server amd64 1:7.9p1-10+deb10u2 [44,6 kB]
                        Holen:25 http://ftp.de.debian.org/debian buster/main amd64 openssh-server amd64 1:7.9p1-10+deb10u2 [352 kB]
                        Holen:26 http://ftp.de.debian.org/debian buster/main amd64 git-man all 1:2.20.1-2+deb10u3 [1.620 kB]
                        Holen:27 http://ftp.de.debian.org/debian buster/main amd64 libsasl2-modules-db amd64 2.1.27+dfsg-1+deb10u1 [69,1 kB]
                        Holen:28 http://ftp.de.debian.org/debian buster/main amd64 libsasl2-2 amd64 2.1.27+dfsg-1+deb10u1 [106 kB]
                        Holen:29 http://ftp.de.debian.org/debian buster/main amd64 libldap-common all 2.4.47+dfsg-3+deb10u2 [89,7 kB]
                        Holen:30 http://ftp.de.debian.org/debian buster/main amd64 libldap-2.4-2 amd64 2.4.47+dfsg-3+deb10u2 [224 kB]
                        Holen:31 http://ftp.de.debian.org/debian buster/main amd64 libcurl3-gnutls amd64 7.64.0-4+deb10u1 [330 kB]
                        Holen:32 http://ftp.de.debian.org/debian buster/main amd64 git amd64 1:2.20.1-2+deb10u3 [5.633 kB]
                        Holen:33 http://security.debian.org/debian-security buster/updates/main amd64 libapt-inst2.0 amd64 1.8.2.1 [203 kB]
                        Holen:34 http://security.debian.org/debian-security buster/updates/main amd64 apt amd64 1.8.2.1 [1.418 kB]
                        Holen:35 http://security.debian.org/debian-security buster/updates/main amd64 apt-utils amd64 1.8.2.1 [421 kB]
                        Holen:36 http://security.debian.org/debian-security buster/updates/main amd64 bind9-host amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [271 kB]
                        Holen:37 http://security.debian.org/debian-security buster/updates/main amd64 libbind9-161 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [247 kB]
                        Holen:38 http://security.debian.org/debian-security buster/updates/main amd64 libisccfg163 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [266 kB]
                        Holen:39 http://security.debian.org/debian-security buster/updates/main amd64 libisccc161 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [236 kB]
                        Holen:40 http://security.debian.org/debian-security buster/updates/main amd64 libdns1104 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [1.222 kB]
                        Holen:41 http://security.debian.org/debian-security buster/updates/main amd64 libisc1100 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [457 kB]
                        Holen:42 http://security.debian.org/debian-security buster/updates/main amd64 liblwres161 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [251 kB]
                        Holen:43 http://security.debian.org/debian-security buster/updates/main amd64 libisc-export1100 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [380 kB]
                        Holen:44 http://security.debian.org/debian-security buster/updates/main amd64 libdns-export1104 amd64 1:9.11.5.P4+dfsg-5.1+deb10u1 [972 kB]
                        Holen:45 http://ftp.de.debian.org/debian buster/main amd64 openssh-client amd64 1:7.9p1-10+deb10u2 [782 kB]
                        Holen:46 http://ftp.de.debian.org/debian buster/main amd64 curl amd64 7.64.0-4+deb10u1 [264 kB]
                        Holen:47 http://ftp.de.debian.org/debian buster/main amd64 libcurl4 amd64 7.64.0-4+deb10u1 [331 kB]
                        Holen:48 http://ftp.de.debian.org/debian buster/main amd64 distro-info-data all 0.41+deb10u2 [6.584 B]
                        Holen:49 http://ftp.de.debian.org/debian buster/main amd64 libcups2 amd64 2.2.10-6+deb10u3 [324 kB]
                        Holen:50 http://ftp.de.debian.org/debian buster/main amd64 libfuse2 amd64 2.9.9-1+deb10u1 [128 kB]
                        Holen:51 http://ftp.de.debian.org/debian buster/main amd64 libicu63 amd64 63.1-6+deb10u1 [8.300 kB]
                        Holen:52 http://ftp.de.debian.org/debian buster/main amd64 libpango-1.0-0 amd64 1.42.4-8~deb10u1 [186 kB]
                        Holen:53 http://ftp.de.debian.org/debian buster/main amd64 libpangoft2-1.0-0 amd64 1.42.4-8~deb10u1 [68,3 kB]
                        Holen:54 http://ftp.de.debian.org/debian buster/main amd64 libpangocairo-1.0-0 amd64 1.42.4-8~deb10u1 [55,7 kB]
                        Holen:55 http://ftp.de.debian.org/debian buster/main amd64 libsasl2-modules amd64 2.1.27+dfsg-1+deb10u1 [104 kB]
                        Holen:56 http://ftp.de.debian.org/debian buster/main amd64 libss2 amd64 1.44.5-1+deb10u3 [72,9 kB]
                        Holen:57 http://ftp.de.debian.org/debian buster/main amd64 libtiff5 amd64 4.1.0+git191117-2~deb10u1 [271 kB]
                        Holen:58 http://ftp.de.debian.org/debian buster/main amd64 linux-image-4.19.0-9-amd64 amd64 4.19.118-2 [48,2 MB]
                        Holen:59 http://ftp.de.debian.org/debian buster/main amd64 linux-image-amd64 amd64 4.19+105+deb10u4 [8.140 B]
                        Holen:60 http://ftp.de.debian.org/debian buster/main amd64 linux-libc-dev amd64 4.19.118-2 [1.353 kB]
                        Holen:61 http://ftp.de.debian.org/debian buster/main amd64 node-yargs-parser all 11.1.1-1+deb10u1 [16,7 kB]
                        Holen:62 http://ftp.de.debian.org/debian buster/main amd64 nodejs-doc all 10.19.0~dfsg1-1 [968 kB]
                        Holen:63 http://ftp.de.debian.org/debian buster/main amd64 openssl amd64 1.1.1d-0+deb10u3 [844 kB]
                        Holen:64 http://ftp.de.debian.org/debian buster/main amd64 python-apt-common all 1.8.4.1 [95,7 kB]
                        Holen:65 http://ftp.de.debian.org/debian buster/main amd64 python3-apt amd64 1.8.4.1 [184 kB]
                        Holen:66 http://ftp.de.debian.org/debian buster/main amd64 sudo amd64 1.8.27-1+deb10u2 [1.245 kB]
                        Es wurden 95,6 MB in 7 s geholt (13,3 MB/s).
                        Changelogs werden gelesen... Fertig
                        Extrahiere Vorlagen aus Paketen: 100%
                        Vorkonfiguration der Pakete ...
                        (Lese Datenbank ... 51010 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../base-files_10.3+deb10u4_amd64.deb ...
                        Entpacken von base-files (10.3+deb10u4) über (10.3+deb10u2) ...
                        base-files (10.3+deb10u4) wird eingerichtet ...
                        Neue Version der Konfigurationsdatei /etc/debian_version wird installiert ...
                        Vorbereitung zum Entpacken von .../libnss-systemd_241-7~deb10u4_amd64.deb ...
                        Entpacken von libnss-systemd:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                        Vorbereitung zum Entpacken von .../libudev-dev_241-7~deb10u4_amd64.deb ...
                        Entpacken von libudev-dev:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                        Vorbereitung zum Entpacken von .../libsystemd0_241-7~deb10u4_amd64.deb ...
                        Entpacken von libsystemd0:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                        libsystemd0:amd64 (241-7~deb10u4) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../libpam-systemd_241-7~deb10u4_amd64.deb ...
                        Entpacken von libpam-systemd:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                        Vorbereitung zum Entpacken von .../systemd_241-7~deb10u4_amd64.deb ...
                        Entpacken von systemd (241-7~deb10u4) über (241-7~deb10u2) ...
                        Vorbereitung zum Entpacken von .../udev_241-7~deb10u4_amd64.deb ...
                        Entpacken von udev (241-7~deb10u4) über (241-7~deb10u2) ...
                        Vorbereitung zum Entpacken von .../libudev1_241-7~deb10u4_amd64.deb ...
                        Entpacken von libudev1:amd64 (241-7~deb10u4) über (241-7~deb10u2) ...
                        libudev1:amd64 (241-7~deb10u4) wird eingerichtet ...
                        systemd (241-7~deb10u4) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../systemd-sysv_241-7~deb10u4_amd64.deb ...
                        Entpacken von systemd-sysv (241-7~deb10u4) über (241-7~deb10u2) ...
                        Vorbereitung zum Entpacken von .../libidn2-0_2.0.5-1+deb10u1_amd64.deb ...
                        Entpacken von libidn2-0:amd64 (2.0.5-1+deb10u1) über (2.0.5-1) ...
                        libidn2-0:amd64 (2.0.5-1+deb10u1) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../libgnutls30_3.6.7-4+deb10u3_amd64.deb ...
                        Entpacken von libgnutls30:amd64 (3.6.7-4+deb10u3) über (3.6.7-4) ...
                        libgnutls30:amd64 (3.6.7-4+deb10u3) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../libapt-pkg5.0_1.8.2.1_amd64.deb ...
                        Entpacken von libapt-pkg5.0:amd64 (1.8.2.1) über (1.8.2) ...
                        libapt-pkg5.0:amd64 (1.8.2.1) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../libapt-inst2.0_1.8.2.1_amd64.deb ...
                        Entpacken von libapt-inst2.0:amd64 (1.8.2.1) über (1.8.2) ...
                        Vorbereitung zum Entpacken von .../archives/apt_1.8.2.1_amd64.deb ...
                        Entpacken von apt (1.8.2.1) über (1.8.2) ...
                        apt (1.8.2.1) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../apt-utils_1.8.2.1_amd64.deb ...
                        Entpacken von apt-utils (1.8.2.1) über (1.8.2) ...
                        Vorbereitung zum Entpacken von .../libext2fs2_1.44.5-1+deb10u3_amd64.deb ...
                        Entpacken von libext2fs2:amd64 (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                        libext2fs2:amd64 (1.44.5-1+deb10u3) wird eingerichtet ...
                        Vorbereitung zum Entpacken von .../00-e2fsprogs_1.44.5-1+deb10u3_amd64.deb ...
                        Entpacken von e2fsprogs (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                        Vorbereitung zum Entpacken von .../01-libssl-dev_1.1.1d-0+deb10u3_amd64.deb ...
                        Entpacken von libssl-dev:amd64 (1.1.1d-0+deb10u3) über (1.1.1d-0+deb10u2) ...
                        Vorbereitung zum Entpacken von .../02-libssl1.1_1.1.1d-0+deb10u3_amd64.deb ...
                        Entpacken von libssl1.1:amd64 (1.1.1d-0+deb10u3) über (1.1.1d-0+deb10u2) ...
                        Vorbereitung zum Entpacken von .../03-python3.7_3.7.3-2+deb10u1_amd64.deb ...
                        Entpacken von python3.7 (3.7.3-2+deb10u1) über (3.7.3-2) ...
                        Vorbereitung zum Entpacken von .../04-libpython3.7-stdlib_3.7.3-2+deb10u1_amd64.deb ...
                        Entpacken von libpython3.7-stdlib:amd64 (3.7.3-2+deb10u1) über (3.7.3-2) ...
                        Vorbereitung zum Entpacken von .../05-python3.7-minimal_3.7.3-2+deb10u1_amd64.deb ...
                        Entpacken von python3.7-minimal (3.7.3-2+deb10u1) über (3.7.3-2) ...
                        Vorbereitung zum Entpacken von .../06-libpython3.7-minimal_3.7.3-2+deb10u1_amd64.deb ...
                        Entpacken von libpython3.7-minimal:amd64 (3.7.3-2+deb10u1) über (3.7.3-2) ...
                        Vorbereitung zum Entpacken von .../07-tzdata_2020a-0+deb10u1_all.deb ...
                        Entpacken von tzdata (2020a-0+deb10u1) über (2019c-0+deb10u1) ...
                        Vorbereitung zum Entpacken von .../08-iputils-ping_3%3a20180629-2+deb10u1_amd64.deb ...
                        Entpacken von iputils-ping (3:20180629-2+deb10u1) über (3:20180629-2) ...
                        Vorbereitung zum Entpacken von .../09-bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../10-libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../11-libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../12-libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../13-libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../14-libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../15-libcom-err2_1.44.5-1+deb10u3_amd64.deb ...
                        Entpacken von libcom-err2:amd64 (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                        Vorbereitung zum Entpacken von .../16-liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../17-openssh-sftp-server_1%3a7.9p1-10+deb10u2_amd64.deb ...
                        Entpacken von openssh-sftp-server (1:7.9p1-10+deb10u2) über (1:7.9p1-10+deb10u1) ...
                        Vorbereitung zum Entpacken von .../18-openssh-server_1%3a7.9p1-10+deb10u2_amd64.deb ...
                        Entpacken von openssh-server (1:7.9p1-10+deb10u2) über (1:7.9p1-10+deb10u1) ...
                        Vorbereitung zum Entpacken von .../19-git-man_1%3a2.20.1-2+deb10u3_all.deb ...
                        Entpacken von git-man (1:2.20.1-2+deb10u3) über (1:2.20.1-2) ...
                        Vorbereitung zum Entpacken von .../20-libsasl2-modules-db_2.1.27+dfsg-1+deb10u1_amd64.deb ...
                        Entpacken von libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u1) über (2.1.27+dfsg-1) ...
                        Vorbereitung zum Entpacken von .../21-libsasl2-2_2.1.27+dfsg-1+deb10u1_amd64.deb ...
                        Entpacken von libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u1) über (2.1.27+dfsg-1) ...
                        Vorbereitung zum Entpacken von .../22-libldap-common_2.4.47+dfsg-3+deb10u2_all.deb ...
                        Entpacken von libldap-common (2.4.47+dfsg-3+deb10u2) über (2.4.47+dfsg-3+deb10u1) ...
                        Vorbereitung zum Entpacken von .../23-libldap-2.4-2_2.4.47+dfsg-3+deb10u2_amd64.deb ...
                        Entpacken von libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u2) über (2.4.47+dfsg-3+deb10u1) ...
                        Vorbereitung zum Entpacken von .../24-libcurl3-gnutls_7.64.0-4+deb10u1_amd64.deb ...
                        Entpacken von libcurl3-gnutls:amd64 (7.64.0-4+deb10u1) über (7.64.0-4) ...
                        Vorbereitung zum Entpacken von .../25-git_1%3a2.20.1-2+deb10u3_amd64.deb ...
                        Entpacken von git (1:2.20.1-2+deb10u3) über (1:2.20.1-2) ...
                        Vorbereitung zum Entpacken von .../26-openssh-client_1%3a7.9p1-10+deb10u2_amd64.deb ...
                        Entpacken von openssh-client (1:7.9p1-10+deb10u2) über (1:7.9p1-10+deb10u1) ...
                        Vorbereitung zum Entpacken von .../27-curl_7.64.0-4+deb10u1_amd64.deb ...
                        Entpacken von curl (7.64.0-4+deb10u1) über (7.64.0-4) ...
                        Vorbereitung zum Entpacken von .../28-libcurl4_7.64.0-4+deb10u1_amd64.deb ...
                        Entpacken von libcurl4:amd64 (7.64.0-4+deb10u1) über (7.64.0-4) ...
                        Vorbereitung zum Entpacken von .../29-distro-info-data_0.41+deb10u2_all.deb ...
                        Entpacken von distro-info-data (0.41+deb10u2) über (0.41+deb10u1) ...
                        Vorbereitung zum Entpacken von .../30-libcups2_2.2.10-6+deb10u3_amd64.deb ...
                        Entpacken von libcups2:amd64 (2.2.10-6+deb10u3) über (2.2.10-6+deb10u1) ...
                        Vorbereitung zum Entpacken von .../31-libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../32-libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u1_amd64.deb ...
                        Entpacken von libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u1) über (1:9.11.5.P4+dfsg-5.1) ...
                        Vorbereitung zum Entpacken von .../33-libfuse2_2.9.9-1+deb10u1_amd64.deb ...
                        Entpacken von libfuse2:amd64 (2.9.9-1+deb10u1) über (2.9.9-1) ...
                        Vorbereitung zum Entpacken von .../34-libicu63_63.1-6+deb10u1_amd64.deb ...
                        Entpacken von libicu63:amd64 (63.1-6+deb10u1) über (63.1-6) ...
                        Vorbereitung zum Entpacken von .../35-libpango-1.0-0_1.42.4-8~deb10u1_amd64.deb ...
                        Entpacken von libpango-1.0-0:amd64 (1.42.4-8~deb10u1) über (1.42.4-7~deb10u1) ...
                        Vorbereitung zum Entpacken von .../36-libpangoft2-1.0-0_1.42.4-8~deb10u1_amd64.deb ...
                        Entpacken von libpangoft2-1.0-0:amd64 (1.42.4-8~deb10u1) über (1.42.4-7~deb10u1) ...
                        Vorbereitung zum Entpacken von .../37-libpangocairo-1.0-0_1.42.4-8~deb10u1_amd64.deb ...
                        Entpacken von libpangocairo-1.0-0:amd64 (1.42.4-8~deb10u1) über (1.42.4-7~deb10u1) ...
                        Vorbereitung zum Entpacken von .../38-libsasl2-modules_2.1.27+dfsg-1+deb10u1_amd64.deb ...
                        Entpacken von libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u1) über (2.1.27+dfsg-1) ...
                        Vorbereitung zum Entpacken von .../39-libss2_1.44.5-1+deb10u3_amd64.deb ...
                        Entpacken von libss2:amd64 (1.44.5-1+deb10u3) über (1.44.5-1+deb10u2) ...
                        Vorbereitung zum Entpacken von .../40-libtiff5_4.1.0+git191117-2~deb10u1_amd64.deb ...
                        Entpacken von libtiff5:amd64 (4.1.0+git191117-2~deb10u1) über (4.0.10-4) ...
                        Vormals nicht ausgewähltes Paket linux-image-4.19.0-9-amd64 wird gewählt.
                        Vorbereitung zum Entpacken von .../41-linux-image-4.19.0-9-amd64_4.19.118-2_amd64.deb ...
                        Entpacken von linux-image-4.19.0-9-amd64 (4.19.118-2) ...
                        Vorbereitung zum Entpacken von .../42-linux-image-amd64_4.19+105+deb10u4_amd64.deb ...
                        Entpacken von linux-image-amd64 (4.19+105+deb10u4) über (4.19+105+deb10u1) ...
                        Vorbereitung zum Entpacken von .../43-linux-libc-dev_4.19.118-2_amd64.deb ...
                        Entpacken von linux-libc-dev:amd64 (4.19.118-2) über (4.19.67-2+deb10u2) ...
                        Vorbereitung zum Entpacken von .../44-node-yargs-parser_11.1.1-1+deb10u1_all.deb ...
                        Entpacken von node-yargs-parser (11.1.1-1+deb10u1) über (11.1.1-1) ...
                        Vorbereitung zum Entpacken von .../45-nodejs-doc_10.19.0~dfsg1-1_all.deb ...
                        Entpacken von nodejs-doc (10.19.0~dfsg1-1) über (10.15.2~dfsg-2) ...
                        Vorbereitung zum Entpacken von .../46-openssl_1.1.1d-0+deb10u3_amd64.deb ...
                        Entpacken von openssl (1.1.1d-0+deb10u3) über (1.1.1d-0+deb10u2) ...
                        Vorbereitung zum Entpacken von .../47-python-apt-common_1.8.4.1_all.deb ...
                        Entpacken von python-apt-common (1.8.4.1) über (1.8.4) ...
                        Vorbereitung zum Entpacken von .../48-python3-apt_1.8.4.1_amd64.deb ...
                        Entpacken von python3-apt (1.8.4.1) über (1.8.4) ...
                        Vorbereitung zum Entpacken von .../49-sudo_1.8.27-1+deb10u2_amd64.deb ...
                        Entpacken von sudo (1.8.27-1+deb10u2) über (1.8.27-1+deb10u1) ...
                        systemd-sysv (241-7~deb10u4) wird eingerichtet ...
                        linux-image-4.19.0-9-amd64 (4.19.118-2) wird eingerichtet ...
                        I: /vmlinuz is now a symlink to boot/vmlinuz-4.19.0-9-amd64
                        I: /initrd.img is now a symlink to boot/initrd.img-4.19.0-9-amd64
                        /etc/kernel/postinst.d/initramfs-tools:
                        update-initramfs: Generating /boot/initrd.img-4.19.0-9-amd64
                        W: initramfs-tools configuration sets RESUME=UUID=577ea0da-21e7-41d0-a864-a3bc681aeabc
                        W: but no matching swap device is available.
                        I: The initramfs will attempt to resume from /dev/sda2
                        I: (UUID=2eae4334-dd4b-4154-92b7-c614d021c3f1)
                        I: Set the RESUME variable to override this.
                        /etc/kernel/postinst.d/zz-update-grub:
                        GRUB-Konfigurationsdatei wird erstellt …
                        Linux-Abbild gefunden: /boot/vmlinuz-4.19.0-9-amd64
                        initrd-Abbild gefunden: /boot/initrd.img-4.19.0-9-amd64
                        Linux-Abbild gefunden: /boot/vmlinuz-4.19.0-6-amd64
                        initrd-Abbild gefunden: /boot/initrd.img-4.19.0-6-amd64
                        erledigt
                        distro-info-data (0.41+deb10u2) wird eingerichtet ...
                        libssl1.1:amd64 (1.1.1d-0+deb10u3) wird eingerichtet ...
                        libpango-1.0-0:amd64 (1.42.4-8~deb10u1) wird eingerichtet ...
                        libsasl2-modules:amd64 (2.1.27+dfsg-1+deb10u1) wird eingerichtet ...
                        linux-libc-dev:amd64 (4.19.118-2) wird eingerichtet ...
                        libnss-systemd:amd64 (241-7~deb10u4) wird eingerichtet ...
                        libcom-err2:amd64 (1.44.5-1+deb10u3) wird eingerichtet ...
                        libisc1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        linux-image-amd64 (4.19+105+deb10u4) wird eingerichtet ...
                        libfuse2:amd64 (2.9.9-1+deb10u1) wird eingerichtet ...
                        libapt-inst2.0:amd64 (1.8.2.1) wird eingerichtet ...
                        libldap-common (2.4.47+dfsg-3+deb10u2) wird eingerichtet ...
                        libpython3.7-minimal:amd64 (3.7.3-2+deb10u1) wird eingerichtet ...
                        node-yargs-parser (11.1.1-1+deb10u1) wird eingerichtet ...
                        libicu63:amd64 (63.1-6+deb10u1) wird eingerichtet ...
                        libsasl2-modules-db:amd64 (2.1.27+dfsg-1+deb10u1) wird eingerichtet ...
                        tzdata (2020a-0+deb10u1) wird eingerichtet ...
                        Current default time zone: 'Europe/Berlin'
                        Local time is now:      Wed May 20 21:36:53 CEST 2020.
                        Universal Time is now:  Wed May 20 19:36:53 UTC 2020.
                        Run 'dpkg-reconfigure tzdata' if you wish to change it.
                        liblwres161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        libssl-dev:amd64 (1.1.1d-0+deb10u3) wird eingerichtet ...
                        udev (241-7~deb10u4) wird eingerichtet ...
                        update-initramfs: deferring update (trigger activated)
                        libss2:amd64 (1.44.5-1+deb10u3) wird eingerichtet ...
                        sudo (1.8.27-1+deb10u2) wird eingerichtet ...
                        libudev-dev:amd64 (241-7~deb10u4) wird eingerichtet ...
                        python3.7-minimal (3.7.3-2+deb10u1) wird eingerichtet ...
                        libsasl2-2:amd64 (2.1.27+dfsg-1+deb10u1) wird eingerichtet ...
                        nodejs-doc (10.19.0~dfsg1-1) wird eingerichtet ...
                        libisc-export1100:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        libcups2:amd64 (2.2.10-6+deb10u3) wird eingerichtet ...
                        python-apt-common (1.8.4.1) wird eingerichtet ...
                        libpam-systemd:amd64 (241-7~deb10u4) wird eingerichtet ...
                        libisccc161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        git-man (1:2.20.1-2+deb10u3) wird eingerichtet ...
                        libtiff5:amd64 (4.1.0+git191117-2~deb10u1) wird eingerichtet ...
                        libpangoft2-1.0-0:amd64 (1.42.4-8~deb10u1) wird eingerichtet ...
                        openssl (1.1.1d-0+deb10u3) wird eingerichtet ...
                        libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        iputils-ping (3:20180629-2+deb10u1) wird eingerichtet ...
                        libpangocairo-1.0-0:amd64 (1.42.4-8~deb10u1) wird eingerichtet ...
                        libdns1104:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        libpython3.7-stdlib:amd64 (3.7.3-2+deb10u1) wird eingerichtet ...
                        apt-utils (1.8.2.1) wird eingerichtet ...
                        python3-apt (1.8.4.1) wird eingerichtet ...
                        openssh-client (1:7.9p1-10+deb10u2) wird eingerichtet ...
                        libldap-2.4-2:amd64 (2.4.47+dfsg-3+deb10u2) wird eingerichtet ...
                        e2fsprogs (1.44.5-1+deb10u3) wird eingerichtet ...
                        libcurl3-gnutls:amd64 (7.64.0-4+deb10u1) wird eingerichtet ...
                        git (1:2.20.1-2+deb10u3) wird eingerichtet ...
                        libcurl4:amd64 (7.64.0-4+deb10u1) wird eingerichtet ...
                        curl (7.64.0-4+deb10u1) wird eingerichtet ...
                        libisccfg163:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        python3.7 (3.7.3-2+deb10u1) wird eingerichtet ...
                        openssh-sftp-server (1:7.9p1-10+deb10u2) wird eingerichtet ...
                        openssh-server (1:7.9p1-10+deb10u2) wird eingerichtet ...
                        rescue-ssh.target is a disabled or a static unit, not starting it.
                        libbind9-161:amd64 (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u1) wird eingerichtet ...
                        Trigger für libc-bin (2.28-10) werden verarbeitet ...
                        Trigger für systemd (241-7~deb10u4) werden verarbeitet ...
                        Trigger für man-db (2.8.5-2) werden verarbeitet ...
                        Trigger für dbus (1.12.16-1) werden verarbeitet ...
                        Trigger für mime-support (3.62) werden verarbeitet ...
                        Trigger für initramfs-tools (0.133+deb10u1) werden verarbeitet ...
                        iobroker@iobroker:~$ sudo apt install nodejs --reinstall
                        0 aktualisiert, 0 neu installiert, 1 erneut installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        Es müssen noch 0 B von 18,0 MB an Archiven heruntergeladen werden.
                        Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
                        (Lese Datenbank ... 55431 Dateien und Verzeichnisse sind derzeit installiert.)
                        Vorbereitung zum Entpacken von .../nodejs_12.16.3-1nodesource1_amd64.deb ...
                        Detected old npm client, removing...
                        Entpacken von nodejs (12.16.3-1nodesource1) über (12.16.3-1nodesource1) ...
                        nodejs (12.16.3-1nodesource1) wird eingerichtet ...
                          @freak1051 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                          sudo apt autoremove
                          sudo reboot
                          Da hast du mal irgendwelchen node-Krams irgendwo anders her gezogen.
                            @Thomas-Braun
                            iobroker@iobroker:~$ sudo apt autoremove
                            Die folgenden Pakete werden ENTFERNT:
                            0 aktualisiert, 0 neu installiert, 248 zu entfernen und 0 nicht aktualisiert.
                            Nach dieser Operation werden 26,2 MB Plattenplatz freigegeben.
                            Entfernen von gyp (0.1+20180428git4d467626-3) ...
                            Entfernen von javascript-common (11) ...
                            Entfernen von libc-ares2:amd64 (1.14.0-1) ...
                            Entfernen von node-cacache (11.3.2-2) ...
                            Entfernen von node-mississippi (3.0.0-1) ...
                            Entfernen von node-through2 (2.0.5-2) ...
                            Entfernen von node-flush-write-stream (1.0.3-1) ...
                            Entfernen von node-pumpify (1.5.1-1) ...
                            Entfernen von node-request (2.88.1-2) ...
                            Entfernen von node-is-typedarray (1.0.0-2) ...
                            Entfernen von libjs-is-typedarray (1.0.0-2) ...
                            Entfernen von libssl-dev:amd64 (1.1.1d-0+deb10u3) ...
                            Entfernen von libuv1-dev:amd64 (1.24.1-1) ...
                            Entfernen von libuv1:amd64 (1.24.1-1) ...
                            Entfernen von node-nopt (3.0.6-3) ...
                            Entfernen von node-abbrev (1.1.1-1) ...
                            Entfernen von node-har-validator (5.1.0-1) ...
                            Entfernen von node-ajv (5.0.0-1) ...
                            Entfernen von node-ansi (0.3.0-3) ...
                            Entfernen von node-boxen (1.2.2-1) ...
                            Entfernen von node-ansi-align (2.0.0-1) ...
                            Entfernen von node-libnpx (10.2.0+repack-1) ...
                            Entfernen von node-yargs (10.0.3-2) ...
                            Entfernen von node-cliui (4.1.0-1) ...
                            Entfernen von node-wrap-ansi (4.0.0-1) ...
                            Entfernen von node-chalk (2.3.0-2) ...
                            Entfernen von node-ansi-styles (3.2.1-1) ...
                            Entfernen von node-ansistyles (0.1.3-1) ...
                            Entfernen von node-npmlog (4.1.2-1) ...
                            Entfernen von node-gauge (2.7.4-1) ...
                            Entfernen von node-move-concurrently (1.0.1-2) ...
                            Entfernen von node-archy (1.0.0-2) ...
                            Entfernen von node-are-we-there-yet (1.1.4-1) ...
                            Entfernen von node-http-signature (1.2.0-1) ...
                            Entfernen von node-sshpk (1.13.1+dfsg-2) ...
                            Entfernen von node-asn1 (0.2.3-1) ...
                            Entfernen von node-dashdash (1.14.1-2) ...
                            Entfernen von node-jsprim (1.4.0-1) ...
                            Entfernen von node-verror (1.10.0-1) ...
                            Entfernen von node-form-data (2.3.2-2) ...
                            Entfernen von node-asynckit (0.4.0-2) ...
                            Entfernen von node-aws-sign2 (0.7.1-1) ...
                            Entfernen von node-aws4 (1.8.0-1) ...
                            Entfernen von node-read-package-json (2.0.13-1) ...
                            Entfernen von node-copy-concurrently (1.0.5-4) ...
                            Entfernen von node-bcrypt-pbkdf (1.0.1-1) ...
                            Entfernen von node-bluebird (3.5.1+dfsg2-2) ...
                            Entfernen von node-normalize-package-data (2.4.0-1) ...
                            Entfernen von node-is-builtin-module (2.0.0-1) ...
                            Entfernen von node-builtin-modules (3.0.0-1) ...
                            Entfernen von node-npm-package-arg (6.0.0-2) ...
                            Entfernen von node-validate-npm-package-name (3.0.0-1) ...
                            Entfernen von node-builtins (1.0.3-1) ...
                            Entfernen von node-call-limit (1.1.0-1) ...
                            Entfernen von node-yargs-parser (11.1.1-1+deb10u1) ...
                            Entfernen von node-camelcase (5.0.0-1) ...
                            Entfernen von node-caseless (0.12.0-1) ...
                            Entfernen von node-tar (4.4.6+ds1-3) ...
                            Entfernen von node-chownr (1.1.1-1) ...
                            Entfernen von node-cli-boxes (1.0.0-1) ...
                            Entfernen von node-widest-line (1.2.2-1) ...
                            Entfernen von node-co (4.6.0-1) ...
                            Entfernen von node-color-convert (1.9.0-3) ...
                            Entfernen von node-color-name (1.1.3-1) ...
                            Entfernen von node-combined-stream (1.0.7-1) ...
                            Entfernen von node-concat-stream (1.6.2-1) ...
                            Entfernen von node-config-chain (1.1.11-1) ...
                            Entfernen von node-console-control-strings (1.1.0-1) ...
                            Entfernen von node-term-size (1.2.0+dfsg-2) ...
                            Entfernen von node-os-locale (2.0.0-1) ...
                            Entfernen von node-execa (0.10.0+dfsg-1) ...
                            Entfernen von node-cross-spawn (5.1.0-2) ...
                            Entfernen von node-parallel-transform (1.1.0-2) ...
                            Entfernen von node-cyclist (1.0.1-2) ...
                            Entfernen von node-decamelize (1.2.0-1) ...
                            Entfernen von node-latest-version (3.1.0-1) ...
                            Entfernen von node-package-json (4.0.1-1) ...
                            Entfernen von node-got (7.1.0-1) ...
                            Entfernen von node-decompress-response (3.3.0-1) ...
                            Entfernen von node-registry-url (3.1.0-1) ...
                            Entfernen von node-registry-auth-token (3.3.1-1) ...
                            Entfernen von node-rc (1.1.6-2) ...
                            Entfernen von node-deep-extend (0.4.1-2) ...
                            Entfernen von node-delayed-stream (0.0.5-1) ...
                            Entfernen von node-delegates (1.0.0-1) ...
                            Entfernen von node-detect-indent (5.0.0-1) ...
                            Entfernen von node-detect-newline (2.1.0-1) ...
                            Entfernen von node-duplexer3 (0.1.4-4) ...
                            Entfernen von node-duplexify (3.6.1-1) ...
                            Entfernen von node-ecc-jsbn (0.1.1-1) ...
                            Entfernen von node-editor (1.0.0-1) ...
                            Entfernen von node-encoding (0.1.12-2) ...
                            Entfernen von node-stream-each (1.2.2-2) ...
                            Entfernen von node-pump (3.0.0-1) ...
                            Entfernen von node-end-of-stream (1.4.1-1) ...
                            Entfernen von node-errno (0.1.4-1) ...
                            Entfernen von node-escape-string-regexp (1.0.5-1) ...
                            Entfernen von node-extend (3.0.2-1) ...
                            Entfernen von node-extsprintf (1.3.0-1) ...
                            Entfernen von node-find-up (2.1.0-1) ...
                            Entfernen von node-forever-agent (0.6.1-1) ...
                            Entfernen von node-from2 (2.3.0-1) ...
                            Entfernen von node-fs-vacuum (1.2.10-2) ...
                            Entfernen von node-fs-write-stream-atomic (1.0.10-4) ...
                            Entfernen von node-get-caller-file (1.0.2-1) ...
                            Entfernen von node-get-stream (3.0.0-1) ...
                            Entfernen von node-getpass (0.1.7-1) ...
                            Entfernen von node-write-file-atomic (2.3.0-1) ...
                            Entfernen von node-sha (2.0.1-1) ...
                            Entfernen von node-graceful-fs (4.1.11-1) ...
                            Entfernen von node-har-schema (2.0.0-1) ...
                            Entfernen von node-supports-color (4.4.0-2) ...
                            Entfernen von node-has-flag (2.0.0-1) ...
                            Entfernen von node-isurl (1.0.0-1) ...
                            Entfernen von node-has-to-string-tag-x (1.4.1+dfsg-1) ...
                            Entfernen von node-has-symbol-support-x (1.4.1+dfsg-1) ...
                            Entfernen von node-has-unicode (2.0.1-2) ...
                            Entfernen von node-hosted-git-info (2.7.1-1) ...
                            Entfernen von node-iconv-lite (0.4.13-2) ...
                            Entfernen von node-iferr (1.0.2-1) ...
                            Entfernen von node-import-lazy (3.0.0.REALLY.2.1.0-1) ...
                            Entfernen von node-unique-filename (1.1.0+ds-2) ...
                            Entfernen von node-imurmurhash (0.1.4-1) ...
                            Entfernen von node-ini (1.3.5-1) ...
                            Entfernen von node-lcid (1.0.0-1) ...
                            Entfernen von node-invert-kv (1.0.0-1) ...
                            Entfernen von node-is-npm (1.0.0-1) ...
                            Entfernen von node-is-object (1.0.1-1) ...
                            Entfernen von node-is-plain-obj (1.1.0-1) ...
                            Entfernen von node-is-retry-allowed (1.1.0-1) ...
                            Entfernen von node-is-stream (1.1.0-1) ...
                            Entfernen von node-which (1.3.0-2) ...
                            Entfernen von node-isexe (2.0.0-4) ...
                            Entfernen von node-isstream (0.1.2+dfsg-1) ...
                            Entfernen von node-jsbn (1.1.0-1) ...
                            Entfernen von node-json-parse-better-errors (1.0.2-2) ...
                            Entfernen von node-json-schema (0.2.3-1) ...
                            Entfernen von node-json-stable-stringify (1.0.1-1) ...
                            Entfernen von node-json-stringify-safe (5.0.1-1) ...
                            Entfernen von node-jsonify (0.0.0-1) ...
                            Entfernen von node-jsonstream (1.3.2-1) ...
                            Entfernen von node-jsonparse (1.3.1-6) ...
                            Entfernen von node-lazy-property (1.0.0-3) ...
                            Entfernen von node-locate-path (2.0.0-1) ...
                            Entfernen von node-lockfile (1.0.4-1) ...
                            Entfernen von node-lowercase-keys (1.0.0-2) ...
                            Entfernen von node-lru-cache (5.1.1-4) ...
                            Entfernen von node-mem (1.1.0-1) ...
                            Entfernen von node-mime-types (2.1.21-1) ...
                            Entfernen von node-mimic-fn (1.1.0-1) ...
                            Entfernen von node-mimic-response (1.0.0-1) ...
                            Entfernen von node-minimist (1.2.0-1) ...
                            Entfernen von node-mkdirp (0.5.1-1) ...
                            Entfernen von node-promzard (0.3.0-1) ...
                            Entfernen von node-read (1.0.7-1) ...
                            Entfernen von node-mute-stream (0.0.8-1) ...
                            Entfernen von node-node-uuid (3.3.2-2) ...
                            Entfernen von node-npm-run-path (2.0.2-2) ...
                            Entfernen von node-oauth-sign (0.9.0-1) ...
                            Entfernen von node-object-assign (4.1.1-2) ...
                            Entfernen von node-opener (1.4.3-1) ...
                            Entfernen von node-osenv (0.1.5-1) ...
                            Entfernen von node-p-cancelable (0.3.0-1) ...
                            Entfernen von node-p-timeout (1.2.0-1) ...
                            Entfernen von node-p-finally (1.0.0-2) ...
                            Entfernen von node-p-locate (2.0.0-1) ...
                            Entfernen von node-p-limit (1.1.0-1) ...
                            Entfernen von node-path-exists (3.0.0-1) ...
                            Entfernen von node-path-is-inside (1.0.2-1) ...
                            Entfernen von node-performance-now (2.1.0+debian-1) ...
                            Entfernen von node-url-parse-lax (1.0.0-1) ...
                            Entfernen von node-prepend-http (2.0.0-1) ...
                            Entfernen von node-promise-inflight (1.0.1-1) ...
                            Entfernen von node-proto-list (1.2.4-1) ...
                            Entfernen von node-prr (1.0.1-1) ...
                            Entfernen von node-tough-cookie (2.3.4+dfsg-1) ...
                            Entfernen von node-punycode (2.1.1-2) ...
                            Entfernen von node-qs (6.5.2-1) ...
                            Entfernen von node-qw (1.0.1-1) ...
                            Entfernen von node-require-directory (2.1.1-1) ...
                            Entfernen von node-require-main-filename (1.0.1-1) ...
                            Entfernen von node-resolve-from (4.0.0-1) ...
                            Entfernen von node-retry (0.10.1-1) ...
                            Entfernen von node-tunnel-agent (0.6.1-1) ...
                            Entfernen von node-semver-diff (2.1.0-2) ...
                            Entfernen von node-semver (5.5.1-1) ...
                            Entfernen von node-set-blocking (2.0.0-1) ...
                            Entfernen von node-shebang-command (1.2.0-1) ...
                            Entfernen von node-shebang-regex (2.0.0-1) ...
                            Entfernen von node-signal-exit (3.0.2-1) ...
                            Entfernen von node-slash (1.0.0-1) ...
                            Entfernen von node-slide (1.1.6-2) ...
                            Entfernen von node-sorted-object (2.0.1-1) ...
                            Entfernen von node-validate-npm-package-license (3.0.1-1) ...
                            Entfernen von node-spdx-correct (1.0.2-1) ...
                            Entfernen von node-spdx-expression-parse (1.0.4-1) ...
                            Entfernen von node-spdx-license-ids (1.2.2-1) ...
                            Entfernen von node-ssri (5.2.4-2) ...
                            Entfernen von node-stream-iterate (1.2.0-4) ...
                            Entfernen von node-stream-shift (1.0.0-1) ...
                            Entfernen von node-strip-eof (1.0.0-2) ...
                            Entfernen von node-strip-json-comments (2.0.1-2) ...
                            Entfernen von node-text-table (0.2.0-2) ...
                            Entfernen von node-through (2.3.8-1) ...
                            Entfernen von node-timed-out (4.0.1-4) ...
                            Entfernen von node-tweetnacl (0.14.5+dfsg-3) ...
                            Entfernen von node-typedarray (0.0.6-1) ...
                            Entfernen von node-uid-number (0.0.6-1) ...
                            Entfernen von node-unpipe (1.0.0-1) ...
                            Entfernen von node-url-to-options (1.0.1-1) ...
                            Entfernen von node-uuid (3.3.2-2) ...
                            Entfernen von node-which-module (2.0.0-1) ...
                            Entfernen von node-wide-align (1.1.0-1) ...
                            Entfernen von node-xdg-basedir (3.0.0-1) ...
                            Entfernen von node-xtend (4.0.1-2) ...
                            Entfernen von node-y18n (3.2.1-2) ...
                            Entfernen von node-yallist (3.0.3-1) ...
                            Entfernen von nodejs-doc (10.19.0~dfsg1-1) ...
                            Entfernen von python-pkg-resources (40.8.0-1) ...
                            Entfernen von node-readable-stream (2.3.6-1) ...
                            Entfernen von node-run-queue (1.0.3-1) ...
                            Entfernen von node-aproba (1.2.0-1) ...
                            Entfernen von node-assert-plus (1.0.0-1) ...
                            Entfernen von node-rimraf (2.6.2-1) ...
                            Entfernen von node-glob (7.1.3-2) ...
                            Entfernen von node-minimatch (3.0.4-3) ...
                            Entfernen von node-brace-expansion (1.1.8-1) ...
                            Entfernen von node-balanced-match (0.4.2-1) ...
                            Entfernen von node-string-width (2.1.1-1) ...
                            Entfernen von node-wcwidth.js (1.0.0-1) ...
                            Entfernen von node-defaults (1.0.3-1) ...
                            Entfernen von node-clone (2.1.2-1) ...
                            Entfernen von node-concat-map (0.0.1-1) ...
                            Entfernen von node-core-util-is (1.0.2-1) ...
                            Entfernen von node-fs.realpath (1.0.0-1) ...
                            Entfernen von node-inflight (1.0.6-1) ...
                            Entfernen von node-isarray (2.0.4-1) ...
                            Entfernen von node-once (1.4.0-3) ...
                            Entfernen von node-path-is-absolute (1.0.0-1) ...
                            Entfernen von node-process-nextick-args (2.0.0-1) ...
                            Entfernen von node-string-decoder (1.2.0-1) ...
                            Entfernen von node-safe-buffer (5.1.2-1) ...
                            Entfernen von node-util-deprecate (1.0.2-1) ...
                            Entfernen von node-wrappy (1.0.2-1) ...
                            Entfernen von node-inherits (2.0.3-1) ...
                            Entfernen von libjs-inherits (2.0.3-1) ...
                            Entfernen von node-strip-ansi (4.0.0-1) ...
                            Entfernen von node-ansi-regex (3.0.0-1) ...
                            ... und neu gestartet
                              @Thomas-Braun
                              kann sein... wüsste aber nicht wie und woher..
                              müsste nun das iobroker update und iobroker upgrade gehen?
                              • Diginix
                                Diginix last edited by
                                Und was ist nach der Aktion der Pfad von npm?
                                Bei mir ist es auch unter "/usr/local/bin/npm" und alles läuft seit über 12 Monaten perfekt.
                                F Thomas Braun 3 Replies Last reply Reply Quote 0
                                  freak1051 @Diginix last edited by freak1051
                                  @Diginix
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                    Thomas Braun Most Active @Diginix last edited by Thomas Braun
                                    @Diginix
                                    Dann hast du das auch mal irgendwann quer installiert.
                                    pi@raspberrypi:/opt/iobroker $ which npm
                                    /usr/bin/npm
                                      @Diginix bei mir läuft eig auch alles,... bius auf das Update ^^
                                        @freak1051
                                        iobroker update
                                        iobroker upgrade
                                        • Diginix
                                          Diginix last edited by Diginix
                                          Ok, auch das funktioniert bei mir immer egal ob Controller oder Adapter mit npm in /usr/local.
                                          @Thomas-Braun Nicht das ich wüsste, aber ok. Geht bei den o.s. Befehlen irgendwas verloren?
                                          Oder ist danach alles wie zuvor nur npm unter /usr/bin?
                                            @Diginix 'Richtig' ist das aber nicht auf einem Debian mit nodesource-Paket.
                                            js-controller
                                            127
                                            1340
                                            434991
