    4. js-controller 3.0/3.1 jetzt im Latest!
      Thomas Braun Most Active @Diginix last edited by
      @Diginix 'Richtig' ist das aber nicht auf einem Debian mit nodesource-Paket.
        freak1051 @Thomas Braun last edited by freak1051
        @Thomas-Braun
        iobroker@iobroker:~$ iobroker update
        Used repository: latest
        hash changed or no sources cached => force download of new sources
        Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error                                    : Error: ESOCKETTIMEDOUT
        update done
        iobroker@iobroker:~$ iobroker upgrade
        /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155
                if (adapter.indexOf('@') !== -1) {
        TypeError: Cannot read property 'indexOf' of undefined
            at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155:21)
            at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:41:14)
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:647:37
            at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2205:45
            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:1487:62)
            at processImmediate (internal/timers.js:456:21)
        schaut ziemlich gleich aus wie davor...:(
        • Diginix
          Diginix @Thomas Braun last edited by
          @Thomas-Braun Bei mir läuft Ubuntu.
            @Diginix sagte in js-controller 3.0/3.1 jetzt im Latest!:
            Nicht das ich wüsste, aber ok. Geht bei den o.s. Befehlen irgendwas verloren?
            Deine Katze explodiert...
            Backup ist nie verkehrt. Aber eigentlich ist dpkg / apt recht robust.
              Thomas Braun Most Active @freak1051 last edited by
              @freak1051
              cd /opt/iobroker
              npm i iobroker.js-controller
                @Thomas-Braun said in js-controller 3.0/3.1 jetzt im Latest!:
                cd /opt/iobroker
                iobroker@iobroker:~$ cd /opt/iobroker/
                iobroker@iobroker:/opt/iobroker$ npm i iobroker.js-controller
                > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                > node lib/preinstallCheck.js
                NPM version: 6.14.4
                > node-aead-crypto@2.1.4 install /opt/iobroker/node_modules/node-aead-crypto
                > node lib/install.js
                node-aead-crypto is no longer needed on NodeJS 10+
                > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                > node iobroker.js setup first
                The following notifications happened during sync:
                - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
                - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 (node_modules/node-aead-crypto):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 install: `node lib/install.js`
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                + iobroker.js-controller@2.2.10
                removed 10 packages and updated 1 package in 18.73s
                27 packages are looking for funding
                  run `npm fund` for details
                Was mich etwas wundert, hab die tr-064-dinger eig gelöscht (Brauch den adapter nichmehr)
                  @freak1051
                  Der tr-064 Kram spielt auch keine Rolle.
                  iobroker version
                  iobroker start
                    iobroker version
                    iobroker@iobroker:/opt/iobroker$ iobroker version
                    2.2.10
                    Auch die Katze, oder hier der Hund?
                      @freak1051 Der ioBroker startet aber ansonsten sauber durch?
                        @Thomas-Braun
                        Er startet und bringt auch keine Errors im log
                          @freak1051
                          iobroker stop
                          iobroker update
                          iobroker upgrade self
                            @Thomas-Braun
                            iobroker@iobroker:/opt/iobroker$ iobroker stop
                            iobroker@iobroker:/opt/iobroker$ iobroker update
                            Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error: Error: ESOCKETTIMEDOUT
                            update done
                            iobroker iobroker@iobroker:/opt/iobroker$ iobroker upgrade self
                            Cannot find this controller "js-controller" in repository.
                              Thomas Braun Most Active @freak1051 last edited by Thomas Braun
                              @freak1051 Stell mal im Admin eine weitere Downloadquelle rein:
                              http://iobroker.live/repo/sources-dist-latest.json
                                jetzt Zeigt er mir auch ettliche Aktuallisierungen von adaptern an auch inkl. dem Admin.
                                erst die adapter, oder erst js?
                                  @freak1051
                                  iobroker update
                                  iobroker upgrade
                                  iobroker stop
                                    Mach nix. Kann jedem mal passieren.
                                    • Diginix
                                      @Thomas-Braun Sehr unterhaltsam, aber wenig hilfreich...
                                        @Diginix Was willst du denn jetzt hören?
                                        Ubuntu basiert auf Debian und es gibt von nodesource ein eigenes Repo für Ubuntu.
                                        ICH würde node sauber installieren. Befehle sind bei ubuntu und debian die gleichen in deinem Fall.
                                          @Thomas-Braun Hat geklappt. iobroker version 3.1.4
                                          danke dir
                                            @freak1051 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                            danke dir
                                            Fein, freut mich. Und nebenher haben wir dein System und auch node noch sauber gemacht. Tipp am Rande: Mal öfter das System mit
                                            sudo apt update && sudo apt upgrade
                                            auf Stand halten. Schadet nie. (Bzw. nur äußerst selten...)
                                            js-controller
                                            127
                                            1340
                                            434992
