    4. js-controller 3.0/3.1 jetzt im Latest!
      freak1051 @Thomas Braun last edited by freak1051
      @Thomas-Braun
      iobroker@iobroker:~$ iobroker update
      Used repository: latest
      hash changed or no sources cached => force download of new sources
      Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error                                    : Error: ESOCKETTIMEDOUT
      update done
      iobroker@iobroker:~$ iobroker upgrade
      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155
              if (adapter.indexOf('@') !== -1) {
      TypeError: Cannot read property 'indexOf' of undefined
          at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:155:21)
          at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:41:14)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:647:37
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2205:45
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemFileDB.js:1487:62)
          at processImmediate (internal/timers.js:456:21)
      schaut ziemlich gleich aus wie davor...:(
      • Diginix
        Diginix @Thomas Braun last edited by
        @Thomas-Braun Bei mir läuft Ubuntu.
          Thomas Braun Most Active @Diginix last edited by
          @Diginix sagte in js-controller 3.0/3.1 jetzt im Latest!:
          Nicht das ich wüsste, aber ok. Geht bei den o.s. Befehlen irgendwas verloren?
          Deine Katze explodiert...
          Backup ist nie verkehrt. Aber eigentlich ist dpkg / apt recht robust.
            Thomas Braun Most Active @freak1051 last edited by
            @freak1051
            cd /opt/iobroker
            npm i iobroker.js-controller
              @Thomas-Braun said in js-controller 3.0/3.1 jetzt im Latest!:
              cd /opt/iobroker
              iobroker@iobroker:~$ cd /opt/iobroker/
              iobroker@iobroker:/opt/iobroker$ npm i iobroker.js-controller
              > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              > node lib/preinstallCheck.js
              NPM version: 6.14.4
              > node-aead-crypto@2.1.4 install /opt/iobroker/node_modules/node-aead-crypto
              > node lib/install.js
              node-aead-crypto is no longer needed on NodeJS 10+
              > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              The following notifications happened during sync:
              - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
              - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 (node_modules/node-aead-crypto):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 install: `node lib/install.js`
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              + iobroker.js-controller@2.2.10
              removed 10 packages and updated 1 package in 18.73s
              27 packages are looking for funding
                run `npm fund` for details
              Was mich etwas wundert, hab die tr-064-dinger eig gelöscht (Brauch den adapter nichmehr)
                @freak1051
                Der tr-064 Kram spielt auch keine Rolle.
                iobroker version
                iobroker start
                  iobroker version
                  iobroker@iobroker:/opt/iobroker$ iobroker version
                  2.2.10
                  Auch die Katze, oder hier der Hund?
                    @freak1051 Der ioBroker startet aber ansonsten sauber durch?
                      @Thomas-Braun
                      Er startet und bringt auch keine Errors im log
                        @freak1051
                        iobroker stop
                        iobroker update
                        iobroker upgrade self
                          @Thomas-Braun
                          iobroker@iobroker:/opt/iobroker$ iobroker stop
                          iobroker@iobroker:/opt/iobroker$ iobroker update
                          Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error: Error: ESOCKETTIMEDOUT
                          update done
                          iobroker iobroker@iobroker:/opt/iobroker$ iobroker upgrade self
                          Cannot find this controller "js-controller" in repository.
                            Thomas Braun Most Active @freak1051 last edited by Thomas Braun
                            @freak1051 Stell mal im Admin eine weitere Downloadquelle rein:
                            http://iobroker.live/repo/sources-dist-latest.json
                              jetzt Zeigt er mir auch ettliche Aktuallisierungen von adaptern an auch inkl. dem Admin.
                              erst die adapter, oder erst js?
                                @freak1051
                                iobroker update
                                iobroker upgrade
                                iobroker stop
                                  Mach nix. Kann jedem mal passieren.
                                  • Diginix
                                    @Thomas-Braun Sehr unterhaltsam, aber wenig hilfreich...
                                      @Diginix Was willst du denn jetzt hören?
                                      Ubuntu basiert auf Debian und es gibt von nodesource ein eigenes Repo für Ubuntu.
                                      ICH würde node sauber installieren. Befehle sind bei ubuntu und debian die gleichen in deinem Fall.
                                        @Thomas-Braun Hat geklappt. iobroker version 3.1.4
                                        danke dir
                                          @freak1051 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                          danke dir
                                          Fein, freut mich. Und nebenher haben wir dein System und auch node noch sauber gemacht. Tipp am Rande: Mal öfter das System mit
                                          sudo apt update && sudo apt upgrade
                                          auf Stand halten. Schadet nie. (Bzw. nur äußerst selten...)
                                            @Thomas-Braun bin da immer wieder nen schisser... never change a running system 🙂
                                            js-controller
                                            127
                                            1340
                                            434992
