    4. js-controller 3.0/3.1 jetzt im Latest!
      Thomas Braun Most Active @Diginix last edited by
      @Diginix sagte in js-controller 3.0/3.1 jetzt im Latest!:
      Nicht das ich wüsste, aber ok. Geht bei den o.s. Befehlen irgendwas verloren?
      Deine Katze explodiert...
      Backup ist nie verkehrt. Aber eigentlich ist dpkg / apt recht robust.
        Thomas Braun Most Active @freak1051 last edited by
        @freak1051
        cd /opt/iobroker
        npm i iobroker.js-controller
          freak1051 @Thomas Braun last edited by freak1051
          @Thomas-Braun said in js-controller 3.0/3.1 jetzt im Latest!:
          cd /opt/iobroker
          iobroker@iobroker:~$ cd /opt/iobroker/
          iobroker@iobroker:/opt/iobroker$ npm i iobroker.js-controller
          > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.4
          > node-aead-crypto@2.1.4 install /opt/iobroker/node_modules/node-aead-crypto
          > node lib/install.js
          node-aead-crypto is no longer needed on NodeJS 10+
          > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          The following notifications happened during sync:
          - Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
          - Ignoring Directory "tr-064.admin" because officially not created as meta object. Please remove directory!
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/zigbee-herdsman/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 (node_modules/node-aead-crypto):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 install: `node lib/install.js`
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          + iobroker.js-controller@2.2.10
          removed 10 packages and updated 1 package in 18.73s
          27 packages are looking for funding
            run `npm fund` for details
          Was mich etwas wundert, hab die tr-064-dinger eig gelöscht (Brauch den adapter nichmehr)
            @freak1051
            Der tr-064 Kram spielt auch keine Rolle.
            iobroker version
            iobroker start
              iobroker version
              iobroker@iobroker:/opt/iobroker$ iobroker version
              2.2.10
              Auch die Katze, oder hier der Hund?
                @freak1051 Der ioBroker startet aber ansonsten sauber durch?
                  @Thomas-Braun
                  Er startet und bringt auch keine Errors im log
                    @freak1051
                    iobroker stop
                    iobroker update
                    iobroker upgrade self
                      @Thomas-Braun
                      iobroker@iobroker:/opt/iobroker$ iobroker stop
                      iobroker@iobroker:/opt/iobroker$ iobroker update
                      Used repository: latest
                      hash changed or no sources cached => force download of new sources
                      Cannot download json from http://download.iobroker.net/sources-dist-latest.json. Error: Error: ESOCKETTIMEDOUT
                      update done
                      iobroker iobroker@iobroker:/opt/iobroker$ iobroker upgrade self
                      Cannot find this controller "js-controller" in repository.
                        Thomas Braun Most Active @freak1051 last edited by Thomas Braun
                        @freak1051 Stell mal im Admin eine weitere Downloadquelle rein:
                        http://iobroker.live/repo/sources-dist-latest.json
                          jetzt Zeigt er mir auch ettliche Aktuallisierungen von adaptern an auch inkl. dem Admin.
                          erst die adapter, oder erst js?
                            @freak1051
                            iobroker update
                            iobroker upgrade
                            iobroker stop
                              @Thomas-Braun Bei mir läuft Ubuntu.
                              Mach nix. Kann jedem mal passieren.
                              • Diginix
                                Diginix @Thomas Braun last edited by
                                @Thomas-Braun Sehr unterhaltsam, aber wenig hilfreich...
                                  @Diginix Was willst du denn jetzt hören?
                                  Ubuntu basiert auf Debian und es gibt von nodesource ein eigenes Repo für Ubuntu.
                                  ICH würde node sauber installieren. Befehle sind bei ubuntu und debian die gleichen in deinem Fall.
                                    @Thomas-Braun Hat geklappt. iobroker version 3.1.4
                                    danke dir
                                      @freak1051 sagte in js-controller 3.0/3.1 jetzt im Latest!:
                                      danke dir
                                      Fein, freut mich. Und nebenher haben wir dein System und auch node noch sauber gemacht. Tipp am Rande: Mal öfter das System mit
                                      sudo apt update && sudo apt upgrade
                                      auf Stand halten. Schadet nie. (Bzw. nur äußerst selten...)
                                        @Thomas-Braun bin da immer wieder nen schisser... never change a running system 🙂
                                          @freak1051
                                          ...never fix your security issues, never touch your low performance.
                                          Debian Stable ist da recht konservativ, was da noch upgedatet wird hat schon seine Berechtigung. In Stable werden nie neue Versionen eingespielt, lediglich patches für existierende Versionen.
                                            @freak1051 Ich sehe gerade da noch einen 'Fehler'.
                                            Zeig mal
                                            apt policy node-yargs-parser nodejs-doc
                                            Das sollte eigentlich nicht installiert sein.
                                            Falls doch:
                                            sudo apt remove node-yargs-parser nodejs-doc
                                            sudo apt install nodejs --reinstall
                                            js-controller
                                            127
                                            1340
                                            434992
