    4. Nach Update läuft nichts mehr!
      SaschaS @Wal last edited by
      @Wal Ohne sudo geht meistens nichts..
      Unabhängig davon bring
      pi@raspberrypi:/opt/iobroker $ iobroker stop
      iobroker controller daemon is not running
      pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
      obwohl
      pi@raspberrypi:/opt/iobroker $ ps auxww | grep io
      root        12  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/0]
      root        15  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/1]
      root        20  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/2]
      root        25  0.0  0.0      0     0 ?        S    08:40   0:00 [migration/3]
      root        41  0.0  0.0      0     0 ?        I<   08:40   0:00 [rpciod]
      root        43  0.0  0.0      0     0 ?        I<   08:40   0:00 [xprtiod]
      root        47  0.0  0.0      0     0 ?        I<   08:40   0:00 [nfsiod]
      root        62  0.0  0.0      0     0 ?        I<   08:40   0:00 [DWC Notificatio]
      message+   355  0.0  0.3   6516  3360 ?        Ss   08:40   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
      iobroker   602 24.5 10.0 185492 95612 ?        Ssl  08:40   1:50 iobroker.js-controller
      iobroker   954  6.9  5.9 156136 56464 ?        Sl   08:40   0:30 io.admin.0
      iobroker  1566  0.7  3.9 130252 37384 ?        Sl   08:40   0:03 io.discovery.0
      iobroker  1609  3.8  5.3 132976 51140 ?        Sl   08:40   0:16 io.history.0
      iobroker  1751  8.2 13.0 201260 123956 ?       Sl   08:41   0:33 io.javascript.0
      iobroker  1761  5.2  5.5 140632 52724 ?        Sl   08:41   0:21 io.stiebel-isg.0
      iobroker  1780  1.2  4.2 133312 40212 ?        Sl   08:41   0:04 io.web.0
      iobroker  1787  2.2  5.0 144104 47728 ?        Sl   08:41   0:09 io.cloud.0
      iobroker  1797  1.3  3.9 132292 37772 ?        Sl   08:41   0:05 io.info.0
      iobroker  1804  1.5  4.3 134372 41328 ?        Sl   08:41   0:06 io.deconz.0
      iobroker  1860  1.5  4.1 134328 39300 ?        Sl   08:41   0:06 io.tankerkoenig.0
      iobroker  2015  6.2  6.4 138548 60808 ?        Sl   08:41   0:24 io.ble.0
      pi        6421  0.0  0.0   4772   532 pts/0    S+   08:48   0:00 grep --color=auto io
      sehr wohl rennt.
      Und daher kommt dann auch immer der Befehl @Jan1
      sudo systemctl stop iobroker
      ins Spiel.
      Und bim Fixer stehe ich vor
      pi@raspberrypi:/opt/iobroker $ curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/fix_installation.sh | bash -
      bash: Zeile 1: 404:: Kommando nicht gefunden.
      Wal J 2 Replies Last reply Reply Quote 0
        SaschaS @Jan1 last edited by
        @Jan1 said in Nach Update läuft nichts mehr!:
        @SaschaS
        Jou und genau da wird Node 10 benötigt, was auch dabei steht. Wenn Du dann mit Node 8 das Update startest, ist danach erst mal Ruhe im Karton, deshalb nun mal schön auf Node 10, oder besser gleich auf 12 da empfohlen.
        Dazu machst auf dem Pi am besten das was dazu in der Doku zum Thema Node steht. Das hat bei mir aufm Pi immer am besten funktioniert.
        Das ganze gleich mit den angegeben System Updates und wenn es dann immer noch nicht läuft, gehts hier weiter 😉
        Die Doku schaue ich mir nach dem Frühstück an.
        • Wal
          Wal Developer @SaschaS last edited by
          @SaschaS sagte in Nach Update läuft nichts mehr!:
          Stimmt, die Adresse des Fixers ist falsch, ich suche mal.
          • Wal
            Wal Developer last edited by Wal
            curl -sL https://iobroker.net/fix.sh | bash -
              Einstein67 @Wal last edited by Einstein67
              @Wal said in Nach Update läuft nichts mehr!:
              Man braucht diese Adresse nicht mehr
              "iobroker fix"
              reicht aus!
              Aber solange ein JS-Controler 3.1.x unter Node8 läuft, bringt das alles nichts ...
                Jan1 @SaschaS last edited by Jan1
                und wo genau hast diesen Befehl ausgegraben? Das ist alt und wenn Du mit so alten Zeug weiter machen willst, ist es allein Dein Problem.
                Genau so wie die uralte Adresse des Fixer, wo hast die denn her? Du verwendest irgend welche Anleitungen die sehr alt sind und das macht es nur schlimmer.
                Las den Fixer laufen:
                oder mit:
                iobroker fix
                Danach ein System Update:
                sudo apt-get update && sudo apt-get upgrade
                Dann die Node nach der Doku und es sollte wieder laufen.
                Wal 2 Replies Last reply Reply Quote 0
                • Wal
                  Wal Developer @Jan1 last edited by
                  @Jan1 sagte in Nach Update läuft nichts mehr!:
                  Wenn er vor deinen Befehlen ein
                  curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
                  macht, wird nodejs geupdatet.
                    Einstein67 last edited by
                    Ich fürchte dann hat er beide Versionen drauf!
                    Deshalb erst die Alte Version deinstallieren und dann mit dem Befehl die neue drauf ... wie es im Doku-Link von Jan1 steht.
                      Jan1 @Wal last edited by Jan1
                      @Wal
                      Ja wird es nur will ich das erst mal machen, wenn der Rest aktuell ist und nicht irgendwo im Nirwana steht.
                      Deshalb verweise ich auch auf die Doku, wo dieser Befehl (allerdings für 10) ebenfalls drin steht 😉
                      Einstein war schneller, denn das befürchte ich auch und genau aus dem Grund nach Doku, weil dann die alte Node weg ist.
                      • Wal
                        Da gehste mal auf die Doku von Iobroker installation linux, da steht das noch.
                          @Wal
                          Dann hast die alte Doku Du Held 😉
                          • Wal
                            @Wal
                            Ich weiss, er aber nicht.😊
                              @Wal
                              Es geistert immer noch der Link zur alten rum, deshalb bitte immer oben den Link verwenden.
                              • Wal
                                @Wal
                                Genau den Link, den du gepostet hast steht der Befehl drin. Ganz weit unten. 😉
                                  @Wal
                                  Für den Fixer ja, aber nicht für das Stoppen des IOBroker
                                  Wobei das Fixer Script immer noch läuft.
                                  • Wal
                                    @Jan1
                                    mich brauchst du nicht überzeugen, ich habe diese Probleme nicht.
                                    Wir sollten zurück zum Thema und dem TE helfen.
                                      @Wal
                                      Dann lass die Behauptungen bleiben 😉
                                      Edit:
                                      Du hattest recht, steht da auch noch, voll überlesen😁
                                      Ich kenne aber auch die alte Doku, da steht das auch drin, allerdings etwas größer.
                                      @apollon77
                                      könnte die Doku an der Stelle bitte aktualisiert werden? Das ist sehr verwirrend wenn man sich eh nicht auskennt.
                                      @SaschaS
                                      Also hier noch mal bevor das überlesen wird:
                                      oder mit:
                                      iobroker fix
                                        Thomas Braun Most Active @Jan1 last edited by
                                        @Jan1 @SaschaS
                                        Ich würde da jetzt mal ganz langsam 'von unten' herangehen.
                                        Alles als user:
                                        groups
                                        sudo whoami
                                        lsb_release -a
                                        apt policy nodejs
                                        nodejs -v && node -v && npm -v
                                        which nodejs && which node && which npm
                                          Jan1 @Thomas Braun last edited by
                                          @Thomas-Braun
                                          Ja geht natürlich auch. Wobei ich mir bei der Hälfte der Abfragen schon sicher bin was raus kommt 😉
                                          Bei Node 8 hat er auf alle Fälle kein Buster laufen. Die Node Version hat er schon gepostet.
                                          Sein Fehler liegt an Node 8, wenn er nach dem Admin Update nicht mehr drauf kommt.
                                            @Jan1 Da stimmt aber auch irgendwas nicht bei npm. Das ist eigentlich zu neu für eine reine node 8. Das dürfte von irgendwosonst herkommen.
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56152
