    4. Nach Update läuft nichts mehr!
      Thomas Braun Most Active @SaschaS last edited by
      @SaschaS Richtig, das war der Plan...
        SaschaS @Thomas Braun last edited by
        @Thomas-Braun Weniger erfolgreich..
        pi@raspberrypi:/opt/iobroker $ iobroker upgrade
        Update admin from @3.7.8 to @4.0.10
        NPM version: 6.14.2
        npm install iobroker.admin@4.0.10 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code EACCES
        npm ERR! syscall access
        npm ERR! path /opt/iobroker/node_modules/iobroker.admin
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.admin'
        npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.admin'
        npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.admin\'',
        npm ERR!   errno: -13,
        npm ERR!   code: 'EACCES',
        npm ERR!   syscall: 'access',
        npm ERR!   path: '/opt/iobroker/node_modules/iobroker.admin' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/pi/.npm/_logs/2020-05-21T08_58_31_749Z-debug.log
        host.raspberrypi Cannot install iobroker.admin@4.0.10: 243
        J Thomas Braun 2 Replies Last reply Reply Quote 0
          Jan1 @SaschaS last edited by Jan1
          @SaschaS
          das riecht nach "den Fixer noch mal laufen lassen"
          Wobei ich die Updates lieber direkt aus IOBroker Admin raus starten würde.
            @SaschaS Jag den Fixer nochmal drüber:
            curl -sL https://iobroker.net/fix.sh | bash -
              SaschaS @Jan1 last edited by SaschaS
              @Jan1 @Thomas-Braun
              pi@raspberrypi:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
              library: loaded
              Library version=2020-04-12
              ioBroker or some processes are still running:
               io.discovery.0
               io.history.0
               io.javascript.0
               io.web.0
               io.cloud.0
               io.info.0
               io.deconz.0
               io.tankerkoenig.0
               io.ble.0
              Please stop them first and try again!
              Wieso laufen denn da noch Dienste?
              pi@raspberrypi:/opt/iobroker $ iobroker stop
              iobroker controller daemon is not running
              Wie kille ich die jetzt am saubersten?
                Thomas Braun Most Active @SaschaS last edited by Thomas Braun
                @SaschaS
                sudo pkill io
                  @Thomas-Braun
                  nach
                  sudo pkill io
                  laufen immer noch Dienste
                  pi@raspberrypi:/opt/iobroker $ ps auxww | grep io
                  root        12  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/0]
                  root        15  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/1]
                  root        20  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/2]
                  root        25  0.0  0.0      0     0 ?        S    10:39   0:00 [migration/3]
                  root        41  0.0  0.0      0     0 ?        I<   10:39   0:00 [rpciod]
                  root        43  0.0  0.0      0     0 ?        I<   10:39   0:00 [xprtiod]
                  root        47  0.0  0.0      0     0 ?        I<   10:39   0:00 [nfsiod]
                  root        62  0.0  0.0      0     0 ?        I<   10:39   0:00 [DWC Notificatio]
                  message+   350  0.0  0.3   6512  3472 ?        Ss   10:39   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
                  iobroker 16869 30.8 11.5 186284 109716 ?       Dsl  11:04   0:08 iobroker.js-controller
                  iobroker 16920  9.9  4.5 120552 42908 ?        Sl   11:04   0:02 io.discovery.0
                  iobroker 16990 21.0  6.5 140452 62140 ?        Sl   11:04   0:03 io.history.0
                  iobroker 17030 45.6 10.8 181700 103192 ?       Sl   11:04   0:05 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/main.js 0 info
                  pi       17155  0.0  0.0   4772   576 pts/0    S+   11:04   0:00 grep --color=auto io
                    Und das werden immer mehr...wieso starten die denn jetzt alle durch?
                    iobroker 16869 25.7 10.4 175232 99196 ?        Dsl  11:04   0:22 iobroker.js-controller
                    iobroker 16920  2.8  4.5 120552 42936 ?        Sl   11:04   0:02 io.discovery.0
                    iobroker 16990  7.1  3.7 128760 35148 ?        Sl   11:04   0:05 io.history.0
                    iobroker 17030 20.8 14.2 211672 134692 ?       Sl   11:04   0:15 io.javascript.0
                    iobroker 17237 12.1  4.5 135500 42748 ?        Rl   11:04   0:06 io.stiebel-isg.0
                    iobroker 17248  7.9  4.2 133872 40160 ?        Sl   11:04   0:04 io.web.0
                    iobroker 17254  7.3  3.9 131960 37660 ?        Sl   11:04   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.cloud/main.js 0 info
                    iobroker 17261  5.3  4.5 121004 43076 ?        Sl   11:04   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
                    iobroker 17339  7.5  5.1 131932 49248 ?        Sl   11:04   0:03 io.deconz.0
                    iobroker 17699 21.6  4.7 131708 45304 ?        Sl   11:05   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.tankerkoenig/main.js 0 info
                    iobroker 17706 22.6  5.1 132704 49024 ?        Sl   11:05   0:03 io.ical.0
                    iobroker 17716 21.6  4.0 131016 38792 ?        Sl   11:05   0:03 io.ble.0
                    pi       17888  0.0  0.0   4772   524 pts/0    S+   11:05   0:00 grep --color=auto io
                      @SaschaS
                      sudo kill 16869 16920 16990
                        @Thomas-Braun said in Nach Update läuft nichts mehr!:
                        Der scheint verdammt hartnäckig zu sein
                        pi@raspberrypi:/opt/iobroker $ sudo kill 16869
                        iobroker 16869 16.7 10.2 199612 97400 ?        Dsl  11:04   0:40 iobroker.js-controller
                        pi       19863  0.0  0.0   4772   552 pts/0    S+   11:08   0:00 grep --color=auto io
                          SaschaS @SaschaS last edited by SaschaS
                          Und jetzt hat er eine neue PID...ich raff's nicht..wieso startet der denn immer wieder?
                          iobroker 20224 20.6 14.5 229260 137796 ?       Rsl  11:08   0:15 iobroker.js-controller
                          iobroker 20266  3.2  4.5 120552 42844 ?        Sl   11:08   0:02 io.discovery.0
                          iobroker 20341  7.1  3.9 130108 37164 ?        Sl   11:09   0:04 io.history.0
                          iobroker 20380 14.9  9.5 184116 91028 ?        Sl   11:09   0:09 io.javascript.0
                          iobroker 20708 11.9  5.1 132532 49252 ?        Sl   11:09   0:04 /usr/bin/node /opt/iobroker/node_modules/iobroker.stiebel-isg/main.js 0 info
                          iobroker 20714  7.0  4.4 120504 42040 ?        Sl   11:09   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.vis/main.js 0 info
                          iobroker 20720  9.4  3.8 131212 36564 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.web/main.js 0 info
                          iobroker 20726  9.0  4.7 131444 45024 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.cloud/main.js 0 info
                          iobroker 20728  7.5  4.5 120544 43120 ?        Sl   11:09   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
                          iobroker 20745  9.2  4.8 131288 45548 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.deconz/main.js 0 info
                          iobroker 20792 11.3  3.9 131792 37300 ?        Sl   11:09   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.tankerkoenig/main.js 0 info
                          pi       21089  0.0  0.0   4772   548 pts/0    S+   11:10   0:00 grep --color=auto io
                            @Jan1 Jetzt übrigens nicht mehr über die Weboberfläche erreichbar..Aber ist auch kein Wunder, da io.admin sich nicht wie aus Geisterhand von alleine startet..
                              @SaschaS
                              iobroker stop
                              sudo killall iobroker
                              Wenn das nicht fruchtet:
                              sudo kill -9 PID
                              PID weißt du ja wie du die bekommst.
                                @Thomas-Braun
                                Das Problem ist doch gerade, dass nach jedem kill der iobroker.js-controller wieder auftaucht..
                                pi@raspberrypi:/opt/iobroker $ sudo killall iobroker
                                iobroker: Kein Prozess gefunden
                                iobroker 24294 11.6  7.7 170944 73416 ?        Rsl  11:14   0:36 iobroker.js-controller
                                iobroker 24334  0.9  4.4 120548 42532 ?        Sl   11:14   0:02 io.discovery.0
                                iobroker 24405  3.0  3.7 129788 35732 ?        Sl   11:14   0:09 io.history.0
                                iobroker 24447  8.1 11.5 200760 109760 ?       Sl   11:14   0:24 io.javascript.0
                                iobroker 25571  6.2  6.4 145400 61484 ?        Sl   11:15   0:15 io.stiebel-isg.0
                                iobroker 25582  1.8  4.2 134016 40080 ?        Sl   11:15   0:04 io.web.0
                                iobroker 25588  3.1  7.8 155956 74028 ?        Sl   11:15   0:07 io.cloud.0
                                iobroker 25591  1.1  4.5 120868 42888 ?        Sl   11:15   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.info/main.js 0 info
                                iobroker 25602  2.4  4.3 134352 41060 ?        Sl   11:15   0:06 io.deconz.0
                                iobroker 25613  1.5  4.0 132196 37988 ?        Sl   11:15   0:03 /usr/bin/node /opt/iobroker/node_modules/iobroker.tankerkoenig/main.js 0 info
                                iobroker 25620  5.8  4.6 135784 44408 ?        Sl   11:15   0:14 io.ble.0
                                iobroker 28191  0.0  0.0      0     0 ?        Z    11:19   0:00 [sh] <defunct>
                                pi       28194  0.0  0.0   4772   560 pts/0    S+   11:19   0:00 grep --color=auto io
                                pi@raspberrypi:/opt/iobroker $ sudo kill -9 24294
                                iobroker 24405  3.8  5.3 131160 50456 ?        Sl   11:14   0:13 io.history.0
                                pi       28986  0.0  0.0   4772   536 pts/0    S+   11:20   0:00 grep --color=auto io
                                pi@raspberrypi:/opt/iobroker $ sudo kill -9 24405
                                kill: (24405): Kein passender Prozess gefunden
                                iobroker 29172  119  6.4 147356 61188 ?        Rsl  11:20   0:03 iobroker.js-controller
                                iobroker 29208  0.0  0.0      0     0 ?        Z    11:20   0:00 [sh] <defunct>
                                iobroker 29210  0.0  0.0      0     0 ?        Z    11:20   0:00 [sh] <defunct>
                                iobroker 29212  0.0  0.0      0     0 ?        Z    11:20   0:00 [sh] <defunct>
                                pi       29215  0.0  0.0   4772   524 pts/0    S+   11:20   0:00 grep --color=auto io
                                  @SaschaS
                                  sudo -u iobroker kill -15 -1
                                    @SaschaS
                                    pi@raspberrypi:/opt/iobroker $ sudo -u iobroker kill -15 -1
                                    Speicherzugriffsfehler
                                      Ich würde ja gerne wieder sudo systemctl stop iobroker verwenden. Aber das findet @Jan1 ja nicht so prickelnd bzw. veraltet 😄
                                      Thomas Braun J 2 Replies Last reply Reply Quote 0
                                        @SaschaS Das kannst du aber mal probieren.
                                          @SaschaS said in Nach Update läuft nichts mehr!:
                                          Das Stehaufmännchen ist besiegt! Warum das jetzt funktioniert, verstehe ich nicht. Vielleicht habt ihr Ideen.
                                          Ich würde jetzt den Fixer laufen lassen.
                                          pi@raspberrypi:/opt/iobroker $ sudo systemctl stop iobroker
                                          root        12  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/0]
                                          root        15  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/1]
                                          root        20  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/2]
                                          root        25  0.0  0.0      0     0 ?        S    11:23   0:00 [migration/3]
                                          root        41  0.0  0.0      0     0 ?        I<   11:23   0:00 [rpciod]
                                          root        43  0.0  0.0      0     0 ?        I<   11:23   0:00 [xprtiod]
                                          root        47  0.0  0.0      0     0 ?        I<   11:23   0:00 [nfsiod]
                                          root        62  0.0  0.0      0     0 ?        I<   11:23   0:00 [DWC Notificatio]
                                          message+   354  0.1  0.3   6516  3504 ?        Ss   11:23   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
                                          pi        4563  0.0  0.0   4772   544 pts/0    S+   11:27   0:00 grep --color=auto io
                                          pi        4650  0.0  0.0   4772   532 pts/0    S+   11:27   0:00 grep --color=auto io
                                            @SaschaS
                                            Das war eben mal zwischen durch nötig, wobei Deine alte Installation da vielleicht immer noch drauf besteht 😉
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56249
