    4. Nach Update läuft nichts mehr!
      SaschaS @Thomas Braun last edited by
      @Thomas-Braun said in Nach Update läuft nichts mehr!:
      @SaschaS
      Könnte recht viel output werden, aber da scheint es tiefer zu klemmen:
      dmesg
      Hört sich nach nichts gutem an, wenn du das so sagst.
      pi@raspberrypi:~ $ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 4.19.66-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1253 SMP Thu Aug 15 11:49:46 BST 2019
      [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
      [    0.000000] On node 0 totalpages: 242688
      [    0.000000]   Normal zone: 2133 pages used for memmap
      [    0.000000]   Normal zone: 0 pages reserved
      [    0.000000]   Normal zone: 242688 pages, LIFO batch:63
      [    0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
      [    0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
      [    0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=b73bd0c1-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
      [    0.000000] Memory: 939088K/970752K available (8192K kernel code, 629K rwdata, 2176K rodata, 1024K init, 821K bss, 23472K reserved, 8192K cma-reserved)
      [    0.000000] Virtual kernel memory layout:
                         vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                         fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                         vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                         lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                         modules : 0x7f000000 - 0x80000000   (  16 MB)
                           .text : 0x(ptrval) - 0x(ptrval)   (9184 kB)
                           .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
                           .data : 0x(ptrval) - 0x(ptrval)   ( 630 kB)
                            .bss : 0x(ptrval) - 0x(ptrval)   ( 822 kB)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 26394 entries in 78 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
      [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
      [    0.000023] Switching to timer-based delay loop, resolution 52ns
      [    0.000291] Console: colour dummy device 80x30
      [    0.000915] console [tty1] enabled
      [    0.000972] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
      [    0.001017] pid_max: default: 32768 minimum: 301
      [    0.001372] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.001408] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
      [    0.002340] CPU: Testing write buffer coherency: ok
      [    0.002831] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.003499] Setting up static identity map for 0x100000 - 0x10003c
      [    0.003666] rcu: Hierarchical SRCU implementation.
      [    0.004481] smp: Bringing up secondary CPUs ...
      [    0.005346] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.006274] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.007140] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.007261] smp: Brought up 1 node, 4 CPUs
      [    0.007343] SMP: Total of 4 processors activated (153.60 BogoMIPS).
      [    0.007367] CPU: All CPU(s) started in HYP mode.
      [    0.007388] CPU: Virtualization extensions available.
      [    0.008379] devtmpfs: initialized
      [    0.021397] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
      [    0.021671] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.021719] futex hash table entries: 1024 (order: 4, 65536 bytes)
      [    0.022325] pinctrl core: initialized pinctrl subsystem
      [    0.023198] NET: Registered protocol family 16
      [    0.026153] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.031850] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
      [    0.031887] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.032107] Serial: AMBA PL011 UART driver
      [    0.034415] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
      [    0.069303] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
      [    0.071236] SCSI subsystem initialized
      [    0.071483] usbcore: registered new interface driver usbfs
      [    0.071564] usbcore: registered new interface driver hub
      [    0.071677] usbcore: registered new device driver usb
      [    0.090304] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-08-15 12:06, variant start
      [    0.100132] raspberrypi-firmware soc:firmware: Firmware hash is 0e6daa5106dd4164474616408e0dc24f997ffcf3
      [    0.111763] clocksource: Switched to clocksource arch_sys_counter
      [    0.200931] VFS: Disk quotas dquot_6.6.0
      [    0.201042] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.201219] FS-Cache: Loaded
      [    0.201446] CacheFiles: Loaded
      [    0.211475] NET: Registered protocol family 2
      [    0.212296] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
      [    0.212360] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
      [    0.212491] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
      [    0.212695] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.212855] UDP hash table entries: 512 (order: 2, 16384 bytes)
      [    0.212921] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
      [    0.213251] NET: Registered protocol family 1
      [    0.213821] RPC: Registered named UNIX socket transport module.
      [    0.213848] RPC: Registered udp transport module.
      [    0.213870] RPC: Registered tcp transport module.
      [    0.213892] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.215579] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
      [    0.218611] Initialise system trusted keyrings
      [    0.218819] workingset: timestamp_bits=14 max_order=18 bucket_order=4
      [    0.228823] FS-Cache: Netfs 'nfs' registered for caching
      [    0.229423] NFS: Registering the id_resolver key type
      [    0.229476] Key type id_resolver registered
      [    0.229498] Key type id_legacy registered
      [    0.229530] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.231870] Key type asymmetric registered
      [    0.231900] Asymmetric key parser 'x509' registered
      [    0.231968] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
      [    0.232148] io scheduler noop registered
      [    0.232172] io scheduler deadline registered (default)
      [    0.232365] io scheduler cfq registered
      [    0.232389] io scheduler mq-deadline registered (default)
      [    0.232413] io scheduler kyber registered
      [    0.234614] bcm2708_fb soc:fb: FB found 1 display(s)
      [    0.244038] Console: switching to colour frame buffer device 82x26
      [    0.250847] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
      [    0.257552] bcm2835-rng 3f104000.rng: hwrng registered
      [    0.260218] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
      [    0.265532] vc-sm: Videocore shared memory driver
      [    0.268278] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
      [    0.284167] brd: module loaded
      [    0.296827] loop: module loaded
      [    0.299870] Loading iSCSI transport class v2.0-870.
      [    0.303047] libphy: Fixed MDIO Bus: probed
      [    0.305557] usbcore: registered new interface driver lan78xx
      [    0.308016] usbcore: registered new interface driver smsc95xx
      [    0.310369] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    0.340672] dwc_otg 3f980000.usb: base=(ptrval)
      [    0.543326] Core Release: 2.80a
      [    0.545705] Setting default values for core params
      [    0.548146] Finished setting default values for core params
      [    0.750882] Using Buffer DMA mode
      [    0.753288] Periodic Transfer Interrupt Enhancement - disabled
      [    0.755713] Multiprocessor Interrupt Enhancement - disabled
      [    0.758082] OTG VER PARAM: 0, OTG VER FLAG: 0
      [    0.760426] Dedicated Tx FIFOs mode
      [    0.763148] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = bad14000 dma = 0xfad14000 len=9024
      [    0.767725] FIQ FSM acceleration enabled for :
                     Non-periodic Split Transactions
                     Periodic Split Transactions
                     High-Speed Isochronous Endpoints
                     Interrupt/Control Split Transaction hack enabled
      [    0.778632] dwc_otg: Microframe scheduler enabled
      [    0.778693] WARN::hcd_init_fiq:457: FIQ on core 1
      [    0.780921] WARN::hcd_init_fiq:458: FIQ ASM at 80654f4c length 36
      [    0.783137] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
      [    0.785398] dwc_otg 3f980000.usb: DWC OTG Controller
      [    0.787660] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
      [    0.789984] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
      [    0.792310] Init: Port Power? op_state=1
      [    0.794554] Init: Power Port (0)
      [    0.796971] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
      [    0.801482] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.803926] usb usb1: Product: DWC OTG Controller
      [    0.806298] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
      [    0.808721] usb usb1: SerialNumber: 3f980000.usb
      [    0.811671] hub 1-0:1.0: USB hub found
      [    0.813966] hub 1-0:1.0: 1 port detected
      [    0.816728] dwc_otg: FIQ enabled
      [    0.816734] dwc_otg: NAK holdoff enabled
      [    0.816739] dwc_otg: FIQ split-transaction FSM enabled
      [    0.816751] Module dwc_common_port init
      [    0.817047] usbcore: registered new interface driver usb-storage
      [    0.819503] mousedev: PS/2 mouse device common for all mice
      [    0.822679] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    0.825308] bcm2835-cpufreq: min=600000 max=1400000
      [    0.828125] sdhci: Secure Digital Host Controller Interface driver
      [    0.830536] sdhci: Copyright(c) Pierre Ossman
      [    0.833334] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
      [    0.836240] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
      [    0.838913] sdhci-pltfm: SDHCI platform and OF driver helper
      [    0.843040] ledtrig-cpu: registered to indicate activity on CPUs
      [    0.845771] hidraw: raw HID events driver (C) Jiri Kosina
      [    0.848539] usbcore: registered new interface driver usbhid
      [    0.851170] usbhid: USB HID core driver
      [    0.854510] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
      [    0.858634] [vc_sm_connected_init]: start
      [    0.867387] [vc_sm_connected_init]: end - returning 0
      [    0.870923] Initializing XFRM netlink socket
      [    0.873385] NET: Registered protocol family 17
      [    0.875887] Key type dns_resolver registered
      [    0.878730] Registering SWP/SWPB emulation handler
      [    0.881867] registered taskstats version 1
      [    0.884278] Loading compiled-in X.509 certificates
      [    0.893906] uart-pl011 3f201000.serial: cts_event_workaround enabled
      [    0.896435] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
      [    0.903323] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    0.905861] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
      [    0.934469] sdhost: log_buf @ (ptrval) (fad13000)
      [    0.973197] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    0.977165] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    0.981022] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    0.983263] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
      [    0.986727] of_cfs_init
      [    0.988920] of_cfs_init: OK
      [    0.991536] Waiting for root device PARTUUID=b73bd0c1-02...
      [    1.007861] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.041890] Indeed it is in host mode hprt0 = 00021501
      [    1.109919] random: fast init done
      [    1.128667] mmc0: host does not support reading read-only switch, assuming write-enable
      [    1.137015] mmc0: new high speed SDHC card at address aaaa
      [    1.140537] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
      [    1.146816]  mmcblk0: p1 p2
      [    1.152470] mmc1: new high speed SDIO card at address 0001
      [    1.176868] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [    1.179170] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [    1.251809] usb 1-1: new high-speed USB device number 2 using dwc_otg
      [    1.254250] Indeed it is in host mode hprt0 = 00001101
      [    1.492116] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
      [    1.496873] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    1.500217] hub 1-1:1.0: USB hub found
      [    1.502964] hub 1-1:1.0: 4 ports detected
      [    1.511454] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [    1.573266] EXT4-fs (mmcblk0p2): 12 orphan inodes deleted
      [    1.575984] EXT4-fs (mmcblk0p2): recovery complete
      [    1.751259] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [    1.756582] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.771023] devtmpfs: mounted
      [    1.778926] Freeing unused kernel memory: 1024K
      [    1.781958] Run /sbin/init as init process
      [    1.821798] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
      [    1.952110] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
      [    1.957408] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    1.960843] hub 1-1.1:1.0: USB hub found
      [    1.963679] hub 1-1.1:1.0: 3 ports detected
      [    2.266960] systemd[1]: System time before build time, advancing clock.
      [    2.281814] usb 1-1.1.3: new full-speed USB device number 4 using dwc_otg
      [    2.400446] NET: Registered protocol family 10
      [    2.404350] Segment Routing with IPv6
      [    2.416197] usb 1-1.1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
      [    2.421451] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    2.427039] usb 1-1.1.3: Product: ConBee II
      [    2.429883] usb 1-1.1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
      [    2.432812] usb 1-1.1.3: SerialNumber: DE2131494
      [    2.446092] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.451537] random: systemd: uninitialized urandom read (16 bytes read)
      [    2.460433] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
      [    2.469655] systemd[1]: Detected architecture arm.
      [    2.501955] systemd[1]: Set hostname to <raspberrypi>.
      [    2.560620] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
      [    2.731866] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
      [    2.872315] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
      [    2.877839] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    3.062607] systemd[1]: Configuration file /lib/systemd/system/iobroker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
      [    3.087494] systemd[1]: [/lib/systemd/system/deconz.service:9] Unknown lvalue 'StartLimitIntervalSec' in section 'Service'
      [    3.118271] systemd[1]: Listening on udev Control Socket.
      [    3.126399] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
      [    3.136493] systemd[1]: Reached target Swap.
      [    3.143581] systemd[1]: Listening on fsck to fsckd communication Socket.
      [    3.148029] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
      [    3.149042] libphy: lan78xx-mdiobus: probed
      [    3.173246] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
      [    3.174491] systemd[1]: Created slice User and Session Slice.
      [    3.795384] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    3.900472] systemd-journald[112]: Received request to flush runtime journal from PID 1
      [    4.257689] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.264654] media: Linux media interface: v0.10
      [    4.264800] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    4.264811] [vc_sm_connected_init]: start
      [    4.268883] [vc_sm_connected_init]: installed successfully
      [    4.308084] videodev: Linux video capture interface: v2.00
      [    4.346399] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.347686] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.380986] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.394378] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.403277] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    4.403289] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    4.417596] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    4.417608] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    4.426729] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    4.426745] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    4.496195] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
      [    4.518558] bcm2835_audio soc:audio: card created with 8 channels
      [    4.643126] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    4.710106] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    4.815538] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    4.831604] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    4.832482] usbcore: registered new interface driver brcmfmac
      [    4.871038] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [    5.075061] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
      [    5.114288] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
      [    5.128613] cdc_acm 1-1.1.3:1.0: ttyACM0: USB ACM device
      [    5.132672] usbcore: registered new interface driver cdc_acm
      [    5.132684] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
      [    5.160661] random: crng init done
      [    5.160674] random: 7 urandom warning(s) missed due to ratelimiting
      [    5.402367] usb 1-1.1.3: USB disconnect, device number 4
      [    5.701893] usb 1-1.1.3: new full-speed USB device number 6 using dwc_otg
      [    5.837346] usb 1-1.1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
      [    5.837363] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    5.837373] usb 1-1.1.3: Product: ConBee II
      [    5.837383] usb 1-1.1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
      [    5.837395] usb 1-1.1.3: SerialNumber: DE2131494
      [    5.840840] cdc_acm 1-1.1.3:1.0: ttyACM0: USB ACM device
      [    5.909395] uart-pl011 3f201000.serial: no DMA platform data
      [    6.398755] Bluetooth: Core ver 2.22
      [    6.398842] NET: Registered protocol family 31
      [    6.398849] Bluetooth: HCI device and connection manager initialized
      [    6.398871] Bluetooth: HCI socket layer initialized
      [    6.398885] Bluetooth: L2CAP socket layer initialized
      [    6.398925] Bluetooth: SCO socket layer initialized
      [    6.570960] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      [    6.570973] brcmfmac: power management disabled
      [    6.757773] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
      [    6.867378] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
      [    6.871389] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   12.792074] Bluetooth: HCI UART driver ver 2.3
      [   12.792090] Bluetooth: HCI UART protocol H4 registered
      [   12.792176] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   12.792388] Bluetooth: HCI UART protocol Broadcom registered
      [   12.967508] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   12.967519] Bluetooth: BNEP filters: protocol multicast
      [   12.967537] Bluetooth: BNEP socket layer initialized
      [   13.056205] Bluetooth: RFCOMM TTY layer initialized
      [   13.056224] Bluetooth: RFCOMM socket layer initialized
      [   13.056249] Bluetooth: RFCOMM ver 1.11
      [  155.399747] Bluetooth: hci0: advertising data len corrected
      [  157.591922] Bluetooth: hci0: advertising data len corrected
      [  161.938815] Bluetooth: hci0: advertising data len corrected
      [  164.127317] Bluetooth: hci0: advertising data len corrected
      [  165.240048] Bluetooth: hci0: advertising data len corrected
      [  167.463176] Bluetooth: hci0: advertising data len corrected
      [  168.589343] Bluetooth: hci0: advertising data len corrected
      [  170.792242] Bluetooth: hci0: advertising data len corrected
      [  173.048533] Bluetooth: hci0: advertising data len corrected
      [  174.152368] Bluetooth: hci0: advertising data len corrected
      [  176.313530] Bluetooth: hci0: advertising data len corrected
      [  177.424222] Bluetooth: hci0: advertising data len corrected
      [  187.324091] Bluetooth: hci0: advertising data len corrected
      [  188.439199] Bluetooth: hci0: advertising data len corrected
      [  192.875021] Bluetooth: hci0: advertising data len corrected
      [  193.978813] Bluetooth: hci0: advertising data len corrected
      [  195.092925] Bluetooth: hci0: advertising data len corrected
      [  196.204439] Bluetooth: hci0: advertising data len corrected
      [  197.313987] Bluetooth: hci0: advertising data len corrected
      [  199.498756] Bluetooth: hci0: advertising data len corrected
      [  203.892146] Bluetooth: hci0: advertising data len corrected
      [  204.958260] Bluetooth: hci0: advertising data len corrected
      [  208.300408] Bluetooth: hci0: advertising data len corrected
      [  211.564607] Bluetooth: hci0: advertising data len corrected
      [  212.681586] Bluetooth: hci0: advertising data len corrected
      [  213.780242] Bluetooth: hci0: advertising data len corrected
      [  214.929276] Bluetooth: hci0: advertising data len corrected
      [  216.025278] Bluetooth: hci0: advertising data len corrected
      [  218.225119] Bluetooth: hci0: advertising data len corrected
      [  219.331616] Bluetooth: hci0: advertising data len corrected
      [  220.410490] Bluetooth: hci0: advertising data len corrected
      [  221.502850] Bluetooth: hci0: advertising data len corrected
      [  222.629042] Bluetooth: hci0: advertising data len corrected
      [  226.996777] Bluetooth: hci0: advertising data len corrected
      [  228.097156] Bluetooth: hci0: advertising data len corrected
      [  230.339541] Bluetooth: hci0: advertising data len corrected
      [  233.576331] Bluetooth: hci0: advertising data len corrected
      [  234.703214] Bluetooth: hci0: advertising data len corrected
      [  235.792352] Bluetooth: hci0: advertising data len corrected
      [  236.882599] Bluetooth: hci0: advertising data len corrected
      [  237.945210] Bluetooth: hci0: advertising data len corrected
      [  239.051179] Bluetooth: hci0: advertising data len corrected
      [  241.277080] Bluetooth: hci0: advertising data len corrected
      [  243.482821] Bluetooth: hci0: advertising data len corrected
      [  244.566940] Bluetooth: hci0: advertising data len corrected
      [  250.043728] Bluetooth: hci0: advertising data len corrected
      [  253.357930] Bluetooth: hci0: advertising data len corrected
      [  255.572364] Bluetooth: hci0: advertising data len corrected
      [  256.661481] Bluetooth: hci0: advertising data len corrected
      [  262.193539] Bluetooth: hci0: advertising data len corrected
      [  264.393498] Bluetooth: hci0: advertising data len corrected
      [  265.494968] Bluetooth: hci0: advertising data len corrected
      [  266.607307] Bluetooth: hci0: advertising data len corrected
      [  267.681629] Bluetooth: hci0: advertising data len corrected
      [  268.817469] Bluetooth: hci0: advertising data len corrected
      [  269.943339] Bluetooth: hci0: advertising data len corrected
      [  272.175482] Bluetooth: hci0: advertising data len corrected
      [  273.297524] Bluetooth: hci0: advertising data len corrected
      [  274.369227] Bluetooth: hci0: advertising data len corrected
      [  275.466374] Bluetooth: hci0: advertising data len corrected
        Thomas Braun Most Active @SaschaS last edited by
        @SaschaS
        Dein System speichert keine Daten. Die 29 Paket-Upgrade sind ja auch wieder weg.
        Vielleicht hat die SD-Karte auch einen Schuß...
        • Meister Mopper
          Meister Mopper @Thomas Braun last edited by
          @Thomas-Braun Dann ists ja noch schlimmer, ich bleib hier mal bei euch dran.
            Thomas Braun Most Active @SaschaS last edited by Thomas Braun
            @SaschaS Ab Zeile 201 kommen diverse Hilferufe vom System, dass die SD-Karte nicht sauber ist und dass das Dateisystem nur 'lesend' eingehängt wurde.
            Das erklärt auch, warum keinerlei Änderungen gespeichert wurden.
            Ich würde da jetzt nicht weiter rummachen sondern wenn möglich die Karte in einen anderen Rechner geben und wenigstens die Daten-Verzeichnisse vom ioBroker wegsichern. Oder zumindest es versuchen.
            [Edit:] Ich sehe gerade, da sind auch ein paar inodes 'geplatzt'. Das ist gar nicht gar nicht gar nicht gut.
              @Meister-Mopper @Thomas-Braun Bekommen wir es hin, dass wir Skripte, Einstellungen und VIS Projekte gesichert bekommen?
              Wenn ihr mir helft, können wir auch eine Neuinstallation machen. Wurde ja schon mehrfach erwähnt, dass das zu dieser Zeit der bessere Weg sei.
                @SaschaS
                Aus den Allgemeinen Hinweisen zu Versions-Updates:
                Wie bei jedem Update dieser Art: Bitte macht ein Backup! iobroker backup, bzw. kopieren des iobroker-data Verzeichnisses reichen an sich im Zweifel auch aus (ioBroker vorher stoppen natürlich). Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
                Mehr kann ich dazu auch nicht sagen, meine Backups laufen jede Nacht per Backitup-Adapter auf google drive hoch. Ich habe die aber (toitoitoi) auch noch nie benötigt...
                Um eine Neuinstallation (auf einer neuen Karte!) kommst du eh nicht drumherum, würde ich sagen. Die Karte ist höchstwahrscheinlich durchgenudelt.
                  SaschaS @Thomas Braun last edited by SaschaS
                  @Thomas-Braun Ich sicher mir gerade die Sachen per FTP. Scheint zu funktionieren.
                  Unter Files/VIS.0 finde ich auch meine Projekte. Damit habe ich alles was mir am Herzen liegt.
                  Muss ich die SD Karte aus dem Raspberry entfernen oder machen wir die direkt dort drauf platt?
                  Ok. Das mit der neuen Karte lese ich gerade erst...Des jetzt blöd..ich hab glaub gar keine mehr da.
                  Kann man die nicht formatieren und schauen, ob sie dann wieder mag? 😄
                  crunchip Thomas Braun 3 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @SaschaS last edited by
                    @SaschaS vis brauchst du nicht extra....das iobroker-data verzeichnis sichern, darin ist alles erhalten
                      @SaschaS sagte in Nach Update läuft nichts mehr!:
                      Das kannst du machen... Aber nur, wenn du kein stabiles System benötigst. Die Lebenszeit von SD-Karten ist halt nicht so wirklich gut. Wenn ich aber die Meldungen zu den Inodes in 'dmesg' sehe, dann glaube ich das die Karte hin ist.
                        SaschaS @crunchip last edited by
                        @crunchip In Progress. Wird gerade gesichert. Ich seh dabei auch, dass es offenbar Backup gibt. Aber keine Ahnung, ob die fehlerfrei sind.
                          du kannst auch dein durchrostetes auto drüberlackieren, der Rost kommt wieder
                            @SaschaS Du lässt alle zwei Stunden ein Backup ziehen? Und ich dachte ich sei mit meinen 24 Stunden paranoid.
                            S crunchip 2 Replies Last reply Reply Quote 0
                              @Thomas-Braun Ich verschweige mal, dass mir das bis eben nicht bewusst war?!
                                @Thomas-Braun @crunchip Angenommen ich hätte eine (neue oder frische) SD Karte. Wie wäre das vorgehen?
                                Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
                                  crunchip Forum Testing Most Active @Thomas Braun last edited by
                                  @Thomas-Braun Das ist voreingestellt und kein backup, hier sind die states alle 2Std/24Std hinterlegt
                                    Darf ich in dem Fall auf die Dokumentation verweisen:
                                    https://www.iobroker.net/#de/documentation
                                      Thomas Braun Most Active @crunchip last edited by
                                      @crunchip sagte in Nach Update läuft nichts mehr!:
                                      Ah. Ist mir auch noch nie aufgefallen... 😄
                                        @SaschaS wie in der Doku beschrieben, oder siehe weiter oben wie @XxJooO schrieb
                                          @Thomas-Braun @crunchip alright. Dann werde ich morgen mal die Neuinstallation angehen.
                                          Vielleicht noch abschließend. Kann ich nach einer Formatierung der SD Karte schauen, ob sie jetzt schreibende Rechte hat? Bzw könnt ihr mir dabei noch kurz helfen?
                                            Ich glaub jetzt ist's ganz abgeraucht.
                                            pi@raspberrypi:~ $
                                            Message from syslogd@raspberrypi at May 21 20:43:37 ...
                                             kernel:[ 3101.850217] Internal error: Oops - BUG: 0 [#1] SMP ARM
                                             kernel:[ 3101.881705] Process kworker/u8:1 (pid: 27177, stack limit = 0x354a0cd2)
                                             kernel:[ 3101.883126] Stack: (0x860918d0 to 0x86092000)
                                             kernel:[ 3101.884512] 18c0:                                     b8ef2030 b8ef202c 00397ec0 00000000
                                             kernel:[ 3101.887191] 18e0: 00397ebe 00000000 00000000 b8de40d8 b8ef2000 b8ffb848 b9de0c00 ffffffff
                                             kernel:[ 3101.889822] 1900: 00000000 80e3aae4 8609196c 86091918 803732b8 80372154 86091934 86091938
                                             kernel:[ 3101.892458] 1920: 00397ebe 00000000 00397ebe 00000000 8034b244 00000072 00007ebe 42a8e01b
                                             kernel:[ 3101.895172] 1940: 804d4600 86091a48 b9de0c00 b8ef2000 86091a38 b9de0800 b9bcd2d0 80e3aae4
                                             kernel:[ 3101.898028] 1960: 860919dc 86091970 80379c10 80372f8c 00000000 00000000 860919dc 86091988
                                             kernel:[ 3101.901019] 1980: 8034c330 80350d60 0000af57 00000000 00000000 00000000 804c5518 804d9da8
                                             kernel:[ 3101.904121] 19a0: 00000000 00000000 00000000 00000000 860919dc b8ffb6b8 86091c70 00000000
                                             kernel:[ 3101.907387] 19c0: 0000007e 00000002 00000002 00000000 86091ab4 860919e0 803511c8 8037981c
                                             kernel:[ 3101.910725] 19e0: 86091a34 860919f0 8051b504 8051b3bc b96bbc8c 0000004e 00000080 b971d000
                                             kernel:[ 3101.914122] 1a00: 86091a2c 86091a10 00397e80 00000000 00000004 b9bcd2d0 b9de0c00 00000000
                                             kernel:[ 3101.917609] 1a20: 00000000 00000000 80d04d48 00000425 8617e980 00000000 00000000 0000007e
                                             kernel:[ 3101.921132] 1a40: 86090002 86091a50 b8ffb6b8 00000002 0000007e 00000074 0000007e 42a8e01b
                                             kernel:[ 3101.924653] 1a60: 00397ebe 00000000 00397eb4 00000000 00000000 00000000 00002420 b8ffb688
                                             kernel:[ 3101.928171] 1a80: 86091a9c 42a8e01b 80831344 86091c70 b8ffb6b8 80d04d48 00000425 b9bcd2d0
                                             kernel:[ 3101.931692] 1aa0: b8ffb688 00000000 86091b34 86091ab8 80365c78 8035054c 00000000 b8ffb7b8
                                             kernel:[ 3101.935216] 1ac0: 804d2520 baa26994 00000002 86091b8c 86091b8c baa26994 00000002 86091b14
                                             kernel:[ 3101.938743] 1ae0: 86091b4c 86091af0 8024af2c 0000007e 00000002 80d04d48 ffffffff 27ffffff
                                             kernel:[ 3101.942269] 1b00: 80d04d48 42a8e01b 00000080 0000000c 00000000 00000000 b8ffb6b8 86091d58
                                             kernel:[ 3101.945791] 1b20: 86090000 86091c58 86091bf4 86091b38 80369f18 80365b60 b8ffb7b4 86091c58
                                             kernel:[ 3101.949314] 1b40: 86091b64 86091b50 8024c750 86091c3f 80d04d48 80d91000 b8ffb6b8 80d04d70
                                             kernel:[ 3101.952845] 1b60: 86090000 b9bcd2d0 86091c70 0000000c 80d04d48 00000000 ffffffff 00000000
                                             kernel:[ 3101.956409] 1b80: ffffffff 86090100 ba79fdd4 baa26994 86091bac 86091ba0 00600040 00000000
                                             kernel:[ 3101.959937] 1ba0: 86091bc4 b8ffb6b8 b9de0800 0000000c 8036ab94 00000b1c 86091bf4 86091bc8
                                             kernel:[ 3101.963458] 1bc0: 80349ffc 42a8e01b 00000002 b8ffb6b8 00000000 00000000 b9bcd2d0 86091d58
                                             kernel:[ 3101.966983] 1be0: 86090000 86091d58 86091cdc 86091bf8 8036ad30 80369e24 00000000 80d90508
                                             kernel:[ 3101.970511] 1c00: 00000000 80d04d70 86090018 00000001 80d04d48 80d91018 b9de0c00 b8ffb7b4
                                             kernel:[ 3101.974037] 1c20: 00000000 80d04d70 00000001 00000000 b9de0f58 00001800 baa38e38 00a41268
                                             kernel:[ 3101.977562] 1c40: babc8090 baa42e40 baa38f10 baa0c7c8 baa08298 ba645b98 b8ffb6b8 86091d58
                                             kernel:[ 3101.981081] 1c60: 0000007e 00000080 ffffffff 86091d58 00000000 00000000 0000007e 00000002
                                             kernel:[ 3101.984604] 1c80: 00000000 86091c90 86091d58 00000000 b8ef1390 00000000 002a80f4 00000000
                                             kernel:[ 3101.988130] 1ca0: 8014ce8d 801567d0 b6738f00 42a8e01b 86091cec 86091d58 b8ffb7b4 86091d58
                                             kernel:[ 3101.991656] 1cc0: 00001800 b9de0800 b8ffb7b4 80d04d48 86091cf4 86091ce0 80248cb0 8036a64c
                                             kernel:[ 3101.995175] 1ce0: b8ffb6b8 b8ffb760 86091d2c 86091cf8 802dd650 80248c8c b8d0fa0c 00000007
                                             kernel:[ 3101.998699] 1d00: 00000000 b96b2438 b8ffb760 b8ffb6b8 b96b244c b9de0800 86091ea8 80d04d48
                                             kernel:[ 3102.002226] 1d20: 86091dcc 86091d30 802ddfa0 802dd618 b8d0fa0c 00001800 b8ffb720 80d90298
                                             kernel:[ 3102.005750] 1d40: 80d04d70 80e15548 00044678 80d03d00 86090030 00000002 00001800 00000000
                                             kernel:[ 3102.009279] 1d60: 00000000 00000000 ffffffff 7fffffff 00000000 00000011 00000000 00000000
                                             kernel:[ 3102.012786] 1d80: 00000000 00000000 00000000 00000000 00000000 00000000 b96b244c 42a8e01b
                                             kernel:[ 3102.016297] 1da0: 86091dd4 b96b2438 b9de0800 00000015 86091ea8 b96b244c 80d03d00 b8d0fa38
                                             kernel:[ 3102.019811] 1dc0: 86091e04 86091dd0 802de2f8 802ddd7c b96b2520 00044682 86091e04 b96b2438
                                             kernel:[ 3102.023330] 1de0: 86091ea8 86090000 00044678 80d04d70 b96b2520 80d1ae1c 86091e6c 86091e08
                                             kernel:[ 3102.026847] 1e00: 802de590 802de274 80d04d48 000036e3 b96b2464 80d90298 80d03d00 00044678
                                             kernel:[ 3102.030351] 1e20: 00043ac0 86091e24 86091e24 b9769830 b9769c30 86091e34 86091e34 42a8e01b
                                             kernel:[ 3102.033871] 1e40: 00044480 00000000 b96b2438 b96b251c 00044480 b96b2510 b96b2520 000036e3
                                             kernel:[ 3102.037381] 1e60: 86091efc 86091e70 802deefc 802de344 80144020 80d04d48 80d03d00 80d1ae18
                                             kernel:[ 3102.040959] 1e80: b96b243c 80d90298 80d04d70 b96b2514 00000000 b91d9c00 000002d2 ba362e40
                                             kernel:[ 3102.044540] 1ea0: b5e0e900 80d04d48 000036ce 00000000 86091e20 00000000 00000006 00000003
                                             kernel:[ 3102.048103] 1ec0: 00000000 00000000 00000000 42a8e01b 86091efc 9fd5ce80 b96b251c b9c16400
                                             kernel:[ 3102.051682] 1ee0: b9c26a00 00000000 b96b2520 00000000 86091f34 86091f00 8013bf0c 802ded20
                                             kernel:[ 3102.055269] 1f00: 40000193 b9c16400 b9c16400 b9c16400 9fd5ce94 b9c16400 b9c16418 80d03d00
                                             kernel:[ 3102.058839] 1f20: 00000088 9fd5ce80 86091f7c 86091f38 8013c250 8013bda8 86091f5c 86091f48
                                             kernel:[ 3102.062379] 1f40: 808367e4 80d03d00 80d8ecfa 86090038 86091f7c b9719200 b7b82600 00000000
                                             kernel:[ 3102.065951] 1f60: 9fd5ce80 8013c1f4 b971921c 9fc1fe74 86091fac 86091f80 8014253c 8013c200
                                             kernel:[ 3102.069517] 1f80: 80104378 b7b82600 80142404 00000000 00000000 00000000 00000000 00000000
                                             kernel:[ 3102.073085] 1fa0: 00000000 86091fb0 801010ac 80142410 00000000 00000000 00000000 00000000
                                             kernel:[ 3102.076616] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                                             kernel:[ 3102.080129] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
                                             kernel:[ 3102.150014] Code: e24bd028 e89daff0 e7f001f2 e7f001f2 (e7f001f2)
                                            help wanted iobroker update js controller update json npm
                                            18
                                            416
                                            56265
