Sql.0 daten futsch …...
Update sql.0 auf Version 1.0.3 auf RPi2
LOG
! RPi2-1 28 10:52:38.995 info iobroker exit 0
! RPi2-1 28 10:52:38.935 info iobroker Adapter "sql" updated
! RPi2-1 28 10:52:38.825 info iobroker upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html index.html text/html
! RPi2-1 28 10:52:38.727 info host.RPi2-1 object change system.adapter.sql.0
! RPi2-1 28 10:52:38.693 info iobroker upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
! RPi2-1 28 10:52:38.686 info iobroker Update "system.adapter.sql.0"
! RPi2-1 28 10:52:38.524 info iobroker upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/storage.html storage.html text/html
! RPi2-1 28 10:52:38.477 info iobroker got /opt/iobroker/node_modules/iobroker.sql/admin
! RPi2-1 28 10:52:25.144 info iobroker npm install –production --prefix "/opt/iobroker/node_modules/iobroker.sql" (System call)
! RPi2-1 28 10:51:29.456 info iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’
! RPi2-1 28 10:51:29.378 info iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’
! RPi2-1 28 10:51:29.321 info iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [
! RPi2-1 28 10:51:29.285 info iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [
! RPi2-1 28 10:51:29.259 info iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:../src/macros.h:125:9: warning: unused variable ‘status’ [
! RPi2-1 28 10:51:29.241 info iobroker In file included from ../src/statement.cc:6:0:../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’: ../src/mac
! RPi2-1 28 10:51:29.195 info iobroker ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:../src/statement.cc:118:9: warning: unused variable ‘st
! RPi2-1 28 10:50:57.059 info iobroker ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:../src/database.cc:605:9: warning: unused variable
! RPi2-1 28 10:50:57.014 info iobroker ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:../src/database.cc:505:9: warning: unused variable ‘status’
! RPi2-1 28 10:50:56.726 info iobroker ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:../src/database.cc:227:9: warning: unused variable ‘status’
! RPi2-1 28 10:50:56.718 info iobroker ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:../src/database.cc:143:9: warning: unused variable ‘status’
! iobroker 28 10:43:03.967 info ERR! Tried to download: https://mapbox-node-binary.s3.amazonaws ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.4 and node@4.4.3 (node-v46
! iobroker 28 10:43:03.955 info node-pre-gyp
! iobroker 28 10:41:18.494 info npm install iobroker.sql --production --prefix "/opt/iobroker" (System call)
! iobroker 28 10:41:14.901 info upgrade sql -
Was für ein SQL DB wird verwendet? `
MySQL
Was für ein Aggregation im flot? `
Eh die Einstellung seh ich nirgends (bestimmt blind ?)
Update: gefunden, ob 300 | 3000 oder 30000 macht keinen Unterschied.
Gestern hatte ich Daten bis 26-5, heute ist der älteste Wert von 27-5 10 Uhr
sendTo('sql.0', 'query', 'select ts from ts_number where id=1', function (result) {
console.log(JSON.stringify(result.result));
No error's 602 rows affected
Also allgemein sind die Daten in der DB da, sieht so aus als würde flott Max letzte 24 Stunden Anzeigen….
MySQL
Also allgemein sind die Daten in der DB da, sieht so aus als würde flott Max letzte 24 Stunden Anzeigen…. `
Mit dem letzten Befehl wollte ich erfahren was für Werte stehen da bei dir in ts.
Kannst du es auslesen?
Aggregation wird im flot eingestellt:min, max, average, minmax,…
Kannst du es auslesen? `
AH deutlich, hier die daten:
mit id=1 1 1464333602000 18.1 1 1 0 1 1464333733000 18 1 1 0 1 1464333913000 18 1 1 0 1 1464334079000 18.1 1 1 0 1 1464334231000 18 1 1 0 1 1464334368000 18 1 1 0 1 1464334490000 18 1 1 0 1 1464334663000 18 1 1 0 1 1464334820000 18 1 1 0 1 1464334964000 18 1 1 0 1 1464335093000 18 1 1 0 1 1464335271000 18 1 1 0 1 1464335436000 18 1 1 0 id=2 2 1464333669000 18.8 1 1 0 2 1464333799000 18.8 1 1 0 2 1464333977000 18.8 1 1 0 2 1464334142000 18.8 1 1 0 2 1464334292000 18.8 1 1 0 2 1464334427000 18.8 1 1 0 2 1464334548000 18.8 1 1 0 2 1464334719000 18.8 1 1 0 2 1464334875000 18.8 1 1 0 2 1464335017000 18.8 1 1 0 2 1464335144000 18.8 1 1 0 2 1464335321000 18.8 1 1 0 2 1464335484000 18.8 1 1 0
Aggregation = OK, hebe Temperatur werte min-max sichergestellt mit 0-30 was im Bereich der dater der DB is.
Im flot keine Daten sichtbar alter als 10uhr gestern morgen, gestern Abend waren nog daten sichtbar vom tag zuvor 18.00
Was auffällt: Sieht für mich so aus als wen Zeitpunkt erstes öffnen flot max 24 stunden zurück geht und er dan irgendwie cached.
Also gestern (27-05) erstes mal aufgerufen 18.00 Uhr, daten gingen bis 26-05 18.00
Heuten erstes aufrufen 10.00, dan zichtbar bis von gestern 10.uur und bleibt auch so.
Alles davor nicht sichtbar
hier mal spoiler aller werte vond ID=1:
! 1 1464333602000 18.1 1 1 0
! 1 1464333733000 18 1 1 0
! 1 1464333913000 18 1 1 0
! 1 1464334079000 18.1 1 1 0
! 1 1464334231000 18 1 1 0
! 1 1464334368000 18 1 1 0
! 1 1464334490000 18 1 1 0
! 1 1464334663000 18 1 1 0
! 1 1464334820000 18 1 1 0
! 1 1464334964000 18 1 1 0
! 1 1464335093000 18 1 1 0
! 1 1464335271000 18 1 1 0
! 1 1464335436000 18 1 1 0
! 1 1464335585000 18 1 1 0
! 1 1464335721000 18 1 1 0
! 1 1464335841000 18 1 1 0
! 1 1464336012000 18 1 1 0
! 1 1464336168000 18 1 1 0
! 1 1464336309000 18 1 1 0
! 1 1464336437000 17.9 1 1 0
! 1 1464336613000 18 1 1 0
! 1 1464336776000 17.9 1 1 0
! 1 1464336924000 17.9 1 1 0
! 1 1464337057000 17.9 1 1 0
! 1 1464337221000 17.9 1 1 0
! 1 1464337370000 17.9 1 1 0
! 1 1464337504000 17.9 1 1 0
! 1 1464337624000 17.9 1 1 0
! 1 1464337794000 17.9 1 1 0
! 1 1464337949000 17.9 1 1 0
! 1 1464338090000 17.9 1 1 0
! 1 1464338217000 17.9 1 1 0
! 1 1464338393000 17.9 1 1 0
! 1 1464338555000 17.9 1 1 0
! 1 1464338702000 17.9 1 1 0
! 1 1464338835000 17.9 1 1 0
! 1 1464339017000 17.9 1 1 0
! 1 1464339185000 17.9 1 1 0
! 1 1464339338000 17.9 1 1 0
! 1 1464339477000 18 1 1 0
! 1 1464339602000 17.9 1 1 0
! 1 1464339776000 18 1 1 0
! 1 1464339936000 18 1 1 0
! 1 1464340082000 18 1 1 0
! 1 1464340213000 18 1 1 0
! 1 1464340393000 18 1 1 0
! 1 1464340559000 18 1 1 0
! 1 1464340711000 18.1 1 1 0
! 1 1464340848000 18.1 1 1 0
! 1 1464340971000 18.1 1 1 0
! 1 1464341144000 18.1 1 1 0
! 1 1464341302000 18.1 1 1 0
! 1 1464341445000 18.1 1 1 0
! 1 1464341574000 18.1 1 1 0
! 1 1464341753000 18.1 1 1 0
! 1 1464341917000 18.2 1 1 0
! 1 1464342067000 18.2 1 1 0
! 1 1464342203000 18.2 1 1 0
! 1 1464342324000 18.2 1 1 0
! 1 1464342494000 18.2 1 1 0
! 1 1464342651000 18.2 1 1 0
! 1 1464342792000 18.3 1 1 0
! 1 1464342920000 18.3 1 1 0
! 1 1464343097000 18.3 1 1 0
! 1 1464343259000 18.3 1 1 0
! 1 1464343407000 18.3 1 1 0
! 1 1464343541000 18.4 1 1 0
! 1 1464343724000 18.4 1 1 0
! 1 1464343893000 18.4 1 1 0
! 1 1464344047000 18.4 1 1 0
! 1 1464344187000 18.4 1 1 0
! 1 1464344313000 18.4 1 1 0
! 1 1464344488000 18.4 1 1 0
! 1 1464344649000 18.5 1 1 0
! 1 1464344795000 18.5 1 1 0
! 1 1464344927000 18.5 1 1 0
! 1 1464345108000 18.5 1 1 0
! 1 1464345275000 18.5 1 1 0
! 1 1464345428000 18.5 1 1 0
! 1 1464345566000 18.5 1 1 0
! 1 1464345690000 18.5 1 1 0
! 1 1464345863000 18.5 1 1 0
! 1 1464346022000 18.6 1 1 0
! 1 1464346127000 18.6 1 1 0
! 1 1464346257000 18.6 1 1 0
! 1 1464346437000 18.6 1 1 0
! 1 1464346602000 18.6 1 1 0
! 1 1464346753000 18.6 1 1 0
! 1 1464346889000 18.6 1 1 0
! 1 1464347011000 18.6 1 1 0
! 1 1464347182000 18.7 1 1 0
! 1 1464347482000 18.7 1 1 0
! 1 1464347610000 18.7 1 1 0
! 1 1464347788000 18.7 1 1 0
! 1 1464347952000 18.7 1 1 0
! 1 1464348101000 18.7 1 1 0
! 1 1464348235000 18.7 1 1 0
! 1 1464348355000 18.7 1 1 0
! 1 1464348525000 18.7 1 1 0
! 1 1464348680000 18.7 1 1 0
! 1 1464348821000 18.7 1 1 0
! 1 1464348947000 18.7 1 1 0
! 1 1464349123000 18.8 1 1 0
! 1 1464349285000 18.8 1 1 0
! 1 1464349432000 18.8 1 1 0
! 1 1464349565000 18.8 1 1 0
! 1 1464349747000 18.8 1 1 0
! 1 1464349915000 18.8 1 1 0
! 1 1464350068000 18.8 1 1 0
! 1 1464350207000 18.8 1 1 0
! 1 1464350332000 18.8 1 1 0
! 1 1464350506000 18.8 1 1 0
! 1 1464350666000 18.8 1 1 0
! 1 1464350811000 18.8 1 1 0
! 1 1464350942000 18.9 1 1 0
! 1 1464351123000 18.8 1 1 0
! 1 1464351289000 18.9 1 1 0
! 1 1464351440000 18.9 1 1 0
! 1 1464351578000 18.9 1 1 0
! 1 1464351700000 18.9 1 1 0
! 1 1464351873000 18.9 1 1 0
! 1 1464352031000 18.9 1 1 0
! 1 1464352174000 18.9 1 1 0
! 1 1464352303000 18.9 1 1 0
! 1 1464352482000 18.9 1 1 0
! 1 1464352646000 18.9 1 1 0
! 1 1464352796000 18.9 1 1 0
! 1 1464352931000 18.9 1 1 0
! 1 1464353052000 18.9 1 1 0
! 1 1464353223000 19 1 1 0
! 1 1464353379000 19 1 1 0
! 1 1464353521000 19 1 1 0
! 1 1464353648000 19 1 1 0
! 1 1464353825000 19 1 1 0
! 1 1464353987000 19 1 1 0
! 1 1464354135000 19 1 1 0
! 1 1464354269000 19 1 1 0
! 1 1464354452000 19 1 1 0
! 1 1464354621000 19 1 1 0
! 1 1464354775000 19.1 1 1 0
! 1 1464354915000 19.1 1 1 0
! 1 1464355041000 19.1 1 1 0
! 1 1464355216000 19.1 1 1 0
! 1 1464355376000 19.1 1 1 0
! 1 1464355523000 19.1 1 1 0
! 1 1464355654000 19.1 1 1 0
! 1 1464355836000 19.1 1 1 0
! 1 1464356003000 19.1 1 1 0
! 1 1464356155000 19.1 1 1 0
! 1 1464356293000 19.2 1 1 0
! 1 1464356417000 19.2 1 1 0
! 1 1464356590000 19.2 1 1 0
! 1 1464356749000 19.2 1 1 0
! 1 1464356893000 19.2 1 1 0
! 1 1464357023000 19.2 1 1 0
! 1 1464357203000 19.2 1 1 0
! 1 1464357368000 19.2 1 1 0
! 1 1464357519000 19.2 1 1 0
! 1 1464357655000 19.2 1 1 0
! 1 1464357777000 19.2 1 1 0
! 1 1464357948000 19.2 1 1 0
! 1 1464358105000 19.3 1 1 0
! 1 1464358248000 19.3 1 1 0
! 1 1464358376000 19.3 1 1 0
! 1 1464358554000 19.3 1 1 0
! 1 1464358717000 19.3 1 1 0
! 1 1464358866000 19.3 1 1 0
! 1 1464359001000 19.3 1 1 0
! 1 1464359121000 19.3 1 1 0
! 1 1464359290000 19.3 1 1 0
! 1 1464359445000 19.3 1 1 0
! 1 1464359586000 19.3 1 1 0
! 1 1464359712000 19.4 1 1 0
! 1 1464359888000 19.4 1 1 0
! 1 1464360050000 19.4 1 1 0
! 1 1464360197000 19.4 1 1 0
! 1 1464360330000 19.4 1 1 0
! 1 1464360512000 19.4 1 1 0
! 1 1464360680000 19.4 1 1 0
! 1 1464360833000 19.4 1 1 0
! 1 1464360972000 19.4 1 1 0
! 1 1464361097000 19.4 1 1 0
! 1 1464361271000 19.5 1 1 0
! 1 1464361430000 19.5 1 1 0
! 1 1464361576000 19.5 1 1 0
! 1 1464361706000 19.5 1 1 0
! 1 1464361887000 19.5 1 1 0
! 1 1464362204000 19.5 1 1 0
! 1 1464362342000 19.5 1 1 0
! 1 1464362464000 19.5 1 1 0
! 1 1464362637000 19.6 1 1 0
! 1 1464362795000 19.6 1 1 0
! 1 1464362938000 19.6 1 1 0
! 1 1464363067000 19.6 1 1 0
! 1 1464363246000 19.6 1 1 0
! 1 1464363410000 19.6 1 1 0
! 1 1464363560000 19.6 1 1 0
! 1 1464363695000 19.6 1 1 0
! 1 1464363816000 19.6 1 1 0
! 1 1464363986000 19.6 1 1 0
! 1 1464364142000 19.6 1 1 0
! 1 1464364284000 19.7 1 1 0
! 1 1464364411000 19.7 1 1 0
! 1 1464364588000 19.7 1 1 0
! 1 1464364751000 19.7 1 1 0
! 1 1464364899000 19.7 1 1 0
! 1 1464365032000 19.7 1 1 0
! 1 1464365215000 19.7 1 1 0
! 1 1464365384000 19.7 1 1 0
! 1 1464365538000 19.8 1 1 0
! 1 1464365678000 19.8 1 1 0
! 1 1464365803000 19.8 1 1 0
! 1 1464365978000 19.8 1 1 0
! 1 1464366285000 19.8 1 1 0
! 1 1464366417000 19.8 1 1 0
! 1 1464366598000 19.8 1 1 0
! 1 1464366765000 19.9 1 1 0
! 1 1464366918000 19.9 1 1 0
! 1 1464367056000 19.9 1 1 0
! 1 1464367179000 19.9 1 1 0
! 1 1464367352000 19.9 1 1 0
! 1 1464367511000 19.9 1 1 0
! 1 1464367655000 19.9 1 1 0
! 1 1464367785000 19.9 1 1 0
! 1 1464367965000 20 1 1 0
! 1 1464368130000 20 1 1 0
! 1 1464368281000 20 1 1 0
! 1 1464368417000 20 1 1 0
! 1 1464368539000 20 1 1 0
! 1 1464368710000 20 1 1 0
! 1 1464368867000 20 1 1 0
! 1 1464369009000 20 1 1 0
! 1 1464369137000 20.2 1 1 0
! 1 1464369315000 20.2 1 1 0
! 1 1464369478000 20.2 1 1 0
! 1 1464369627000 20.2 1 1 0
! 1 1464369762000 20.2 1 1 0
! 1 1464369882000 20.3 1 1 0
! 1 1464370051000 20.3 1 1 0
! 1 1464370206000 20.3 1 1 0
! 1 1464370347000 20.3 1 1 0
! 1 1464370473000 20.3 1 1 0
! 1 1464370649000 20.3 1 1 0
! 1 1464370811000 20.2 1 1 0
! 1 1464371550232 20.2 1 2 0
! 1 1464371687162 20.2 1 1 0
! 1 1464371811670 20.2 1 1 0
! 1 1464371985665 20.2 1 1 0
! 1 1464372145394 20.2 1 1 0
! 1 1464372350791 20.2 1 1 0
! 1 1464372481533 20.2 1 1 0
! 1 1464372661812 20.2 1 1 0
! 1 1464372827790 20.2 1 1 0
! 1 1464372979288 20.2 1 1 0
! 1 1464373116294 20.2 1 1 0
! 1 1464373239044 20.2 1 1 0
! 1 1464373411278 20.2 1 1 0
! 1 1464373569042 20.2 1 1 0
! 1 1464373712554 20.2 1 1 0
! 1 1464373841543 20.2 1 1 0
! 1 1464374020044 20.2 1 1 0
! 1 1464374184295 20.2 1 1 0
! 1 1464374334059 20.2 1 1 0
! 1 1464374469293 20.2 1 1 0
! 1 1464374590056 20.2 1 1 0
! 1 1464374760539 20.2 1 1 0
! 1 1464374916552 20.2 1 1 0
! 1 1464375058038 20.2 1 1 0
! 1 1464375185280 20.2 1 1 0
! 1 1464375362040 20.2 1 1 0
! 1 1464375524302 20.2 1 1 0
! 1 1464375672324 20.2 1 1 0
! 1 1464375805801 20.2 1 1 0
! 1 1464375969304 20.2 1 1 0
! 1 1464376118288 20.2 1 1 0
! 1 1464376252802 20.2 1 1 0
! 1 1464376373037 20.2 1 1 0
! 1 1464376542790 20.2 1 1 0
! 1 1464376698056 20.2 1 1 0
! 1 1464376839056 20.2 1 1 0
! 1 1464376965534 20.2 1 1 0
! 1 1464377141554 20.3 1 1 0
! 1 1464377303287 20.2 1 1 0
! 1 1464377450548 20.3 1 1 0
! 1 1464377583294 20.3 1 1 0
! 1 1464377765546 20.3 1 1 0
! 1 1464377933568 20.2 1 1 0
! 1 1464378087051 20.3 1 1 0
! 1 1464378226039 20.3 1 1 0
! 1 1464378350807 20.3 1 1 0
! 1 1464378525039 20.3 1 1 0
! 1 1464378684810 20.3 1 1 0
! 1 1464378830287 20.3 1 1 0
! 1 1464378961289 20.3 1 1 0
! 1 1464379141791 20.3 1 1 0
! 1 1464379308050 20.3 1 1 0
! 1 1464379459796 20.3 1 1 0
! 1 1464379597062 20.3 1 1 0
! 1 1464379719800 20.3 1 1 0
! 1 1464379892290 20.3 1 1 0
! 1 1464380050298 20.3 1 1 0
! 1 1464380193791 20.3 1 1 0
! 1 1464380323085 20.3 1 1 0
! 1 1464380501808 20.3 1 1 0
! 1 1464380666065 20.3 1 1 0
! 1 1464380816046 20.3 1 1 0
! 1 1464380951571 20.3 1 1 0
! 1 1464381072546 20.3 1 1 0
! 1 1464381243045 20.3 1 1 0
! 1 1464381399303 20.3 1 1 0
! 1 1464381541065 20.3 1 1 0
! 1 1464381668317 20.3 1 1 0
! 1 1464381845300 20.3 1 1 0
! 1 1464382007834 20.3 1 1 0
! 1 1464382155824 20.3 1 1 0
! 1 1464382289554 20.3 1 1 0
! 1 1464382472802 20.3 1 1 0
! 1 1464382641548 20.3 1 1 0
! 1 1464382796050 20.3 1 1 0
! 1 1464382936064 20.3 1 1 0
! 1 1464383061557 20.3 1 1 0
! 1 1464383236556 20.3 1 1 0
! 1 1464383397307 20.3 1 1 0
! 1 1464383543561 20.3 1 1 0
! 1 1464383675308 20.3 1 1 0
! 1 1464383856813 20.3 1 1 0
! 1 1464384023800 20.3 1 1 0
! 1 1464384176305 20.3 1 1 0
! 1 1464384314554 20.3 1 1 0
! 1 1464384438323 20.3 1 1 0
! 1 1464384611561 20.3 1 1 0
! 1 1464384770554 20.3 1 1 0
! 1 1464384915065 20.3 1 1 0
! 1 1464385045055 20.3 1 1 0
! 1 1464385224566 20.3 1 1 0
! 1 1464385389811 20.3 1 1 0
! 1 1464385540573 20.3 1 1 0
! 1 1464385676815 20.3 1 1 0
! 1 1464385798821 20.3 1 1 0
! 1 1464385970312 20.3 1 1 0
! 1 1464386127308 20.3 1 1 0
! 1 1464386270072 20.3 1 1 0
! 1 1464386398306 20.3 1 1 0
! 1 1464386576085 20.3 1 1 0
! 1 1464386739569 20.3 1 1 0
! 1 1464386888554 20.3 1 1 0
! 1 1464387023071 20.3 1 1 0
! 1 1464387143072 20.3 1 1 0
! 1 1464387312818 20.3 1 1 0
! 1 1464387468063 20.3 1 1 0
! 1 1464387608824 20.3 1 1 0
! 1 1464387735325 20.3 1 1 0
! 1 1464387911314 20.3 1 1 0
! 1 1464388072809 20.3 1 1 0
! 1 1464388220054 20.3 1 1 0
! 1 1464388352818 20.3 1 1 0
! 1 1464388535057 20.3 1 1 0
! 1 1464388702810 20.2 1 1 0
! 1 1464388856311 20.2 1 1 0
! 1 1464388995322 20.2 1 1 0
! 1 1464389119823 20.3 1 1 0
! 1 1464389294073 20.2 1 1 0
! 1 1464389453815 20.2 1 1 0
! 1 1464389599064 20.2 1 1 0
! 1 1464389730071 20.2 1 1 0
! 1 1464389910566 20.2 1 1 0
! 1 1464390076558 20.2 1 1 0
! 1 1464390228316 20.2 1 1 0
! 1 1464390365584 20.2 1 1 0
! 1 1464390488309 20.2 1 1 0
! 1 1464390660586 20.2 1 1 0
! 1 1464390818568 20.2 1 1 0
! 1 1464390962082 20.2 1 1 0
! 1 1464391091092 20.2 1 1 0
! 1 1464391269826 20.2 1 1 0
! 1 1464391434071 20.2 1 1 0
! 1 1464391583826 20 1 1 0
! 1 1464391719325 20 1 1 0
! 1 1464391840337 20 1 1 0
! 1 1464392010825 20 1 1 0
! 1 1464392167074 20 1 1 0
! 1 1464392308816 20 1 1 0
! 1 1464392436064 20 1 1 0
! 1 1464392612836 20 1 1 0
! 1 1464392775331 20 1 1 0
! 1 1464392923326 20 1 1 0
! 1 1464393056822 20 1 1 0
! 1 1464393240078 20 1 1 0
! 1 1464393408830 20 1 1 0
! 1 1464393563071 20 1 1 0
! 1 1464393703069 20 1 1 0
! 1 1464393828592 20 1 1 0
! 1 1464394003586 20 1 1 0
! 1 1464394164325 19.9 1 1 0
! 1 1464394310574 19.9 1 1 0
! 1 1464394442333 19.9 1 1 0
! 1 1464394623596 19.9 1 1 0
! 1 1464394790582 19.9 1 1 0
! 1 1464394943089 19.9 1 1 0
! 1 1464395081079 19.9 1 1 0
! 1 1464395204829 19.9 1 1 0
! 1 1464395378089 19.9 1 1 0
! 1 1464395536815 19.9 1 1 0
! 1 1464395681318 19.9 1 1 0
! 1 1464395811334 19.9 1 1 0
! 1 1464395990827 19.9 1 1 0
! 1 1464396156071 19.9 1 1 0
! 1 1464396306827 19.9 1 1 0
! 1 1464396443085 19.9 1 1 0
! 1 1464396564836 19.9 1 1 0
! 1 1464396736331 19.9 1 1 0
! 1 1464396893322 19.9 1 1 0
! 1 1464397035836 19.9 1 1 0
! 1 1464397164085 19.8 1 1 0
! 1 1464397341821 19.8 1 1 0
! 1 1464397505072 19.8 1 1 0
! 1 1464397654088 19.8 1 1 0
! 1 1464397788584 19.8 1 1 0
! 1 1464397908572 19.8 1 1 0
! 1 1464398078072 19.8 1 1 0
! 1 1464398233333 19.8 1 1 0
! 1 1464398374072 19.8 1 1 0
! 1 1464398500335 19.8 1 1 0
! 1 1464398676334 19.8 1 1 0
! 1 1464398837835 19.8 1 1 0
! 1 1464398984839 19.8 1 1 0
! 1 1464399117589 19.7 1 1 0
! 1 1464399299838 19.8 1 1 0
! 1 1464399467589 19.8 1 1 0
! 1 1464399621090 19.7 1 1 0
! 1 1464399760076 19.7 1 1 0
! 1 1464399884598 19.7 1 1 0
! 1 1464400058586 19.7 1 1 0
! 1 1464400218335 19.7 1 1 0
! 1 1464400363582 19.7 1 1 0
! 1 1464400494340 19.7 1 1 0
! 1 1464400674842 19.7 1 1 0
! 1 1464400840859 19.7 1 1 0
! 1 1464400992342 19.7 1 1 0
! 1 1464401129584 19.7 1 1 0
! 1 1464401252340 19.7 1 1 0
! 1 1464401424583 19.7 1 1 0
! 1 1464401582605 19.7 1 1 0
! 1 1464401726097 19.7 1 1 0
! 1 1464401855096 19.7 1 1 0
! 1 1464402033579 19.6 1 1 0
! 1 1464402197839 19.6 1 1 0
! 1 1464402347583 19.6 1 1 0
! 1 1464402482833 19.6 1 1 0
! 1 1464402603851 19.6 1 1 0
! 1 1464402774339 19.6 1 1 0
! 1 1464402930348 19.6 1 1 0
! 1 1464403072089 19.6 1 1 0
! 1 1464403199337 19.6 1 1 0
! 1 1464403376108 19.6 1 1 0
! 1 1464403538599 19.6 1 1 0
! 1 1464403820091 19.6 1 1 0
! 1 1464404003084 19.6 1 1 0
! 1 1464404171850 19.6 1 1 0
! 1 1464404326098 19.5 1 1 0
! 1 1464404465847 19.6 1 1 0
! 1 1464404591341 19.5 1 1 0
! 1 1464404766340 19.5 1 1 0
! 1 1464404926846 19.5 1 1 0
! 1 1464405073082 19.5 1 1 0
! 1 1464405204838 19.5 1 1 0
! 1 1464405386098 19.5 1 1 0
! 1 1464405553096 19.5 1 1 0
! 1 1464405705596 19.5 1 1 0
! 1 1464405843598 19.5 1 1 0
! 1 1464405967095 19.5 1 1 0
! 1 1464406140355 19.5 1 1 0
! 1 1464406299088 19.4 1 1 0
! 1 1464406443332 19.5 1 1 0
! 1 1464406573361 19.4 1 1 0
! 1 1464406752837 19.4 1 1 0
! 1 1464406917850 19.4 1 1 0
! 1 1464407068594 19.4 1 1 0
! 1 1464407204854 19.4 1 1 0
! 1 1464407326598 19.4 1 1 0
! 1 1464407497859 19.4 1 1 0
! 1 1464407654848 19.4 1 1 0
! 1 1464407797355 19.4 1 1 0
! 1 1464407925352 19.4 1 1 0
! 1 1464408103104 19.4 1 1 0
! 1 1464408266343 19.4 1 1 0
! 1 1464408415106 19.4 1 1 0
! 1 1464408549602 19.4 1 1 0
! 1 1464408669593 19.4 1 1 0
! 1 1464408839091 19.3 1 1 0
! 1 1464408994354 19.3 1 1 0
! 1 1464409135105 19.3 1 1 0
! 1 1464409261357 19.3 1 1 0
! 1 1464409437108 19.3 1 1 0
! 1 1464409598604 19.3 1 1 0
! 1 1464409745595 19.3 1 1 0
! 1 1464409878118 19.3 1 1 0
! 1 1464410060355 19.3 1 1 0
! 1 1464410228111 19.3 1 1 0
! 1 1464410381355 19.3 1 1 0
! 1 1464410520366 19.3 1 1 0
! 1 1464410644848 19.3 1 1 0
! 1 1464410818848 19.3 1 1 0
! 1 1464410978597 19.3 1 1 0
! 1 1464411123862 19.3 1 1 0
! 1 1464411254591 19.3 1 1 0
! 1 1464411434861 19.3 1 1 0
! 1 1464411600863 19.2 1 1 0
! 1 1464411752352 19.2 1 1 0
! 1 1464411889356 19.2 1 1 0
! 1 1464412012107 19.2 1 1 0
! 1 1464412184366 19.2 1 1 0
! 1 1464412342110 19.2 1 1 0
! 1 1464412485604 19.2 1 1 0
! 1 1464412614602 19.2 1 1 0
! 1 1464412793100 19.2 1 1 0
! 1 1464412957361 19.2 1 1 0
! 1 1464413107111 19.2 1 1 0
! 1 1464413242351 19.2 1 1 0
! 1 1464413533625 19.2 1 1 0
! 1 1464413689622 19.2 1 1 0
! 1 1464413831121 19.2 1 1 0
! 1 1464413958367 19.1 1 1 0
! 1 1464414135121 19.1 1 1 0
! 1 1464414297364 19.1 1 1 0
! 1 1464414445360 19.1 1 1 0
! 1 1464414578858 19.1 1 1 0
! 1 1464414742368 19.1 1 1 0
! 1 1464414891367 19.1 1 1 0
! 1 1464415025863 19.1 1 1 0
! 1 1464415146117 19.1 1 1 0
! 1 1464415315849 19.1 1 1 0
! 1 1464415471123 19.1 1 1 0
! 1 1464415612122 19.1 1 1 0
! 1 1464415738612 19.1 1 1 0
! 1 1464415914616 19.1 1 1 0
! 1 1464416076372 19.1 1 1 0
! 1 1464416223617 19.1 1 1 0
! 1 1464416356372 19.1 1 1 0
! 1 1464416538622 19.1 1 1 0
! 1 1464416706611 19.1 1 1 0
! 1 1464416860108 19.1 1 1 0
! 1 1464416999112 19.1 1 1 0
! 1 1464417123868 19 1 1 0
! 1 1464417298113 19 1 1 0
! 1 1464417457872 19 1 1 0
! 1 1464417603369 19 1 1 0
! 1 1464417734373 19 1 1 0
! 1 1464417914867 19 1 1 0
! 1 1464418081124 19 1 1 0
! 1 1464418232890 19 1 1 0
! 1 1464418384976 19 1 2 0
! 1 1464418492896 19 1 1 0
! 1 1464418665378 19 1 1 0
! 1 1464418810422 19 1 2 0
! 1 1464418821501 19 1 1 0
! 1 1464418964994 19 1 1 0
! 1 1464419094258 19 1 1 0
! 1 1464419272997 19 1 1 0
! 1 1464419328877 19 1 2 0
! 1 1464419437291 19 1 1 0
! 1 1464419587260 19 1 1 0
! 1 1464419722740 18.9 1 1 0
! 1 1464420048325 18.9 1 2 0
! 1 1464420170036 18.9 1 1 0
! 1 1464420311770 18.9 1 1 0
! 1 1464420439020 18.9 1 1 0
! 1 1464420616021 18.9 1 1 0
! 1 1464420778534 18.9 1 1 0
! 1 1464420926516 18.9 1 1 0
! 1 1464421060286 18.9 1 1 0
! 1 1464421243524 18.9 1 1 0
! 1 1464421412266 18.9 1 1 0
! 1 1464421566770 18.9 1 1 0
! 1 1464421706765 18.9 1 1 0
! 1 1464421832265 18.9 1 1 0
! 1 1464422007278 18.9 1 1 0
! 1 1464422168038 18.9 1 1 0
! 1 1464422314278 18.9 1 1 0
! 1 1464422446037 18.9 1 1 0
! 1 1464422627528 18.9 1 1 0
! 1 1464422794523 18.9 1 1 0
! 1 1464422947026 18.9 1 1 0
! 1 1464423085277 18.8 1 1 0
! 1 1464423209036 18.8 1 1 0
! 1 1464423382275 18.9 1 1 0
! 1 1464423541299 18.9 1 1 0
! 1 1464423685793 18.8 1 1 0
! 1 1464423815782 18.8 1 1 0
! 1 1464423995284 18.8 1 1 0
! 1 1464424160522 18.8 1 1 0
! 1 1464424311275 18.8 1 1 0
! 1 1464424447544 18.9 1 1 0
! 1 1464424569539 18.8 1 1 0
! 1 1464424741035 18.8 1 1 0
! 1 1464424898034 18.8 1 1 0
! 1 1464425040786 18.8 1 1 0
! 1 1464425169030 18.8 1 1 0
! 1 1464425346777 18.8 1 1 0
! 1 1464425510277 18.8 1 1 0
! 1 1464425659288 18.8 1 1 0
! 1 1464425793794 18.9 1 1 0
! 1 1464425913790 18.8 1 1 0
! 1 1464426083535 18.9 1 1 0
! 1 1464426238801 18.9 1 1 0
! 1 1464426379545 18.9 1 1 0
! 1 1464426506030 18.9 1 1 0
! 1 1464426682032 18.9 1 1 0
! 1 1464426843534 18.9 1 1 0
! 1 1464426990791 18.9 1 1 0
! 1 1464427123535 18.9 1 1 0
! 1 1464427305784 18.9 1 1 0
! 1 1464427473536 18.9 1 1 0
! 1 1464427627041 18.9 1 1 0
! 1 1464427766033 18.9 1 1 0
! 1 1464427890540 18.9 1 1 0
! 1 1464428059787 18.9 1 1 0
! 1 1464428219547 19 1 1 0
! 1 1464428364778 19 1 1 0
! 1 1464428495796 19 1 1 0
! 1 1464428676304 19.1 1 1 0
! 1 1464428842290 19.1 1 1 0
! 1 1464428994040 19.1 1 1 0
! 1 1464429131289 19.1 1 1 0
! 1 1464429254057 19.1 1 1 0
! 1 1464429426280 19.2 1 1 0
! 1 1464429584294 19.2 1 1 0
! 1 1464429727788 19.2 1 1 0
! 1 1464429856792 19.2 1 1 0
! 1 1464430035536 19.3 1 1 0
! 1 1464430199800 19.3 1 1 0
! 1 1464430349558 19.4 1 1 0
! 1 1464430485050 19.3 1 1 0
! 1 1464430606053 19.4 1 1 0
! 1 1464430776551 19.4 1 1 0
! 1 1464430932797 19.4 1 1 0
! 1 1464431074546 19.4 1 1 0
! 1 1464431201797 19.4 1 1 0
! 1 1464431378549 19.4 1 1 0
! 1 1464431541041 19.4 1 1 0
! 1 1464431689042 19.4 1 1 0
! 1 1464431822555 19.4 1 1 0
! 1 1464432005801 19.4 1 1 0
! 1 1464432328811 19.4 1 1 0
! 1 1464432468809 19.4 1 1 0
! 1 1464432594300 19.4 1 1 0
! 1 1464432769311 19.4 1 1 0
! 1 1464432930044 19.4 1 1 0
! 1 1464433076306 19.4 1 1 0
! 1 1464433208048 19.4 1 1 0
! 1 1464433389310 19.4 1 1 0
! 1 1464433556319 19.4 1 1 0
! 1 1464433708804 19.4 1 1 0
! 1 1464433846803 19.4 1 1 0
! 1 1464433970567 19.4 1 1 0
! 1 1464434143804 19.4 1 1 0
! 1 1464434302552 19.4 1 1 0
! 1 1464434447072 19.4 1 1 0
! 1 1464434577064 19.4 1 1 0
! 1 1464434756569 19.4 1 1 0
! 1 1464434921830 19.5 1 1 0
! 1 1464435072572 19.5 1 1 0
! 1 1464435208820 19.5 1 1 0
! 1 1464435330560 19.5 1 1 0
! 1 1464435502059 19.5 1 1 0
! 1 1464435659051 19.5 1 1 0
! 1 1464435801567 19.5 1 1 0
! 1 1464435929804 19.5 1 1 0
! 1 1464436107563 19.5 1 1 0
! 1 1464436270811 19.5 1 1 0
! 1 1464436419807 19.5 1 1 0und zum vergleich ID=14 (außen Temperatur messer):
! 14 1464333715000 10.7 1 1 0
! 14 1464333868000 10.9 1 1 0
! 14 1464334008000 11.4 1 1 0
! 14 1464334133000 10.7 1 1 0
! 14 1464334307000 10.9 1 1 0
! 14 1464334468000 10.8 1 1 0
! 14 1464334613000 10.9 1 1 0
! 14 1464334745000 11.4 1 1 0
! 14 1464334925000 11.7 1 1 0
! 14 1464335092000 11.7 1 1 0
! 14 1464335244000 11.4 1 1 0
! 14 1464335381000 11.5 1 1 0
! 14 1464335505000 11.8 1 1 0
! 14 1464335677000 11.5 1 1 0
! 14 1464335836000 12.3 1 1 0
! 14 1464335980000 12.1 1 1 0
! 14 1464336109000 12.1 1 1 0
! 14 1464336288000 12 1 1 0
! 14 1464336453000 12 1 1 0
! 14 1464336603000 11.8 1 1 0
! 14 1464336739000 12.4 1 1 0
! 14 1464336860000 12.9 1 1 0
! 14 1464337031000 12.3 1 1 0
! 14 1464337188000 11.8 1 1 0
! 14 1464337330000 12.7 1 1 0
! 14 1464337457000 12.4 1 1 0
! 14 1464337635000 12.7 1 1 0
! 14 1464337797000 12.6 1 1 0
! 14 1464337946000 12.9 1 1 0
! 14 1464338080000 14.1 1 1 0
! 14 1464338263000 13.6 1 1 0
! 14 1464338433000 13.6 1 1 0
! 14 1464338587000 14.5 1 1 0
! 14 1464338728000 14.2 1 1 0
! 14 1464338853000 14.4 1 1 0
! 14 1464339029000 14.4 1 1 0
! 14 1464339190000 14.2 1 1 0
! 14 1464339336000 14.7 1 1 0
! 14 1464339469000 15.3 1 1 0
! 14 1464339650000 15.5 1 1 0
! 14 1464339818000 15.5 1 1 0
! 14 1464339971000 16.7 1 1 0
! 14 1464340109000 16.3 1 1 0
! 14 1464340233000 18.2 1 1 0
! 14 1464340407000 18.8 1 1 0
! 14 1464340566000 16.9 1 1 0
! 14 1464340711000 17 1 1 0
! 14 1464340841000 16.4 1 1 0
! 14 1464341021000 17.6 1 1 0
! 14 1464341186000 16.3 1 1 0
! 14 1464341337000 16.7 1 1 0
! 14 1464341474000 18.4 1 1 0
! 14 1464341596000 17 1 1 0
! 14 1464341768000 16.9 1 1 0
! 14 1464341926000 17.5 1 1 0
! 14 1464342069000 16.9 1 1 0
! 14 1464342197000 17.8 1 1 0
! 14 1464342375000 17.8 1 1 0
! 14 1464342539000 17.6 1 1 0
! 14 1464342688000 18.2 1 1 0
! 14 1464342823000 17.3 1 1 0
! 14 1464342943000 18.1 1 1 0
! 14 1464343113000 17.3 1 1 0
! 14 1464343269000 17.6 1 1 0
! 14 1464343410000 17.8 1 1 0
! 14 1464343537000 18.1 1 1 0
! 14 1464343713000 18.1 1 1 0
! 14 1464343875000 18.5 1 1 0
! 14 1464344023000 18.4 1 1 0
! 14 1464344156000 18.4 1 1 0
! 14 1464344338000 19 1 1 0
! 14 1464344506000 20.5 1 1 0
! 14 1464344660000 18.5 1 1 0
! 14 1464344799000 18.7 1 1 0
! 14 1464344924000 19.4 1 1 0
! 14 1464345099000 18.7 1 1 0
! 14 1464345259000 20.1 1 1 0
! 14 1464345405000 19.1 1 1 0
! 14 1464345536000 19.2 1 1 0
! 14 1464345717000 19 1 1 0
! 14 1464345883000 19.1 1 1 0
! 14 1464346035000 20.3 1 1 0
! 14 1464346173000 20.4 1 1 0
! 14 1464346296000 20.7 1 1 0
! 14 1464346468000 20.8 1 1 0
! 14 1464346627000 20.3 1 1 0
! 14 1464346770000 19 1 1 0
! 14 1464346900000 18.4 1 1 0
! 14 1464347079000 20.3 1 1 0
! 14 1464347243000 19.1 1 1 0
! 14 1464347394000 20 1 1 0
! 14 1464347529000 20.7 1 1 0
! 14 1464347651000 19.7 1 1 0
! 14 1464347822000 19.1 1 1 0
! 14 1464347978000 18.8 1 1 0
! 14 1464348120000 20.5 1 1 0
! 14 1464348248000 20 1 1 0
! 14 1464348425000 21.3 1 1 0
! 14 1464348588000 19.5 1 1 0
! 14 1464348736000 19.7 1 1 0
! 14 1464348870000 21.4 1 1 0
! 14 1464349053000 21.7 1 1 0
! 14 1464349222000 21 1 1 0
! 14 1464349377000 20.4 1 1 0
! 14 1464349517000 20.5 1 1 0
! 14 1464349643000 21.4 1 1 0
! 14 1464349818000 22.2 1 1 0
! 14 1464349979000 23.5 1 1 0
! 14 1464350126000 22.5 1 1 0
! 14 1464350258000 23.6 1 1 0
! 14 1464350440000 23.2 1 1 0
! 14 1464350607000 22.1 1 1 0
! 14 1464350760000 21.5 1 1 0
! 14 1464350898000 22.1 1 1 0
! 14 1464351022000 22.2 1 1 0
! 14 1464351196000 21.1 1 1 0
! 14 1464351355000 21.8 1 1 0
! 14 1464351500000 21 1 1 0
! 14 1464351630000 20.5 1 1 0
! 14 1464351810000 20.8 1 1 0
! 14 1464351975000 21.1 1 1 0
! 14 1464352126000 21.8 1 1 0
! 14 1464352263000 21.3 1 1 0
! 14 1464352385000 20.1 1 1 0
! 14 1464352557000 20.3 1 1 0
! 14 1464352714000 21.3 1 1 0
! 14 1464352857000 21.7 1 1 0
! 14 1464352985000 21.8 1 1 0
! 14 1464353163000 20.7 1 1 0
! 14 1464353327000 20.4 1 1 0
! 14 1464353476000 20.7 1 1 0
! 14 1464353611000 21.3 1 1 0
! 14 1464353731000 20.5 1 1 0
! 14 1464353901000 21.4 1 1 0
! 14 1464354057000 21.4 1 1 0
! 14 1464354198000 21.4 1 1 0
! 14 1464354325000 20.1 1 1 0
! 14 1464354501000 20.8 1 1 0
! 14 1464354663000 20.3 1 1 0
! 14 1464354810000 20.4 1 1 0
! 14 1464354943000 20.8 1 1 0
! 14 1464355126000 20.5 1 1 0
! 14 1464355294000 20 1 1 0
! 14 1464355447000 19.8 1 1 0
! 14 1464355587000 19.8 1 1 0
! 14 1464355712000 20.4 1 1 0
! 14 1464355886000 20.5 1 1 0
! 14 1464356046000 20.8 1 1 0
! 14 1464356192000 21.3 1 1 0
! 14 1464356323000 20.4 1 1 0
! 14 1464356504000 21 1 1 0
! 14 1464356670000 21.1 1 1 0
! 14 1464356822000 22.2 1 1 0
! 14 1464356959000 21.5 1 1 0
! 14 1464357082000 21.7 1 1 0
! 14 1464357255000 22.9 1 1 0
! 14 1464357413000 22.6 1 1 0
! 14 1464357557000 20.4 1 1 0
! 14 1464357686000 20.8 1 1 0
! 14 1464357865000 22.9 1 1 0
! 14 1464358030000 21.3 1 1 0
! 14 1464358180000 20.4 1 1 0
! 14 1464358315000 21.7 1 1 0
! 14 1464358437000 22.2 1 1 0
! 14 1464358607000 22 1 1 0
! 14 1464358764000 21.1 1 1 0
! 14 1464358906000 22.5 1 1 0
! 14 1464359033000 23 1 1 0
! 14 1464359211000 23.3 1 1 0
! 14 1464359373000 22.8 1 1 0
! 14 1464359521000 22 1 1 0
! 14 1464359655000 22.5 1 1 0
! 14 1464359839000 22.1 1 1 0
! 14 1464360008000 22.1 1 1 0
! 14 1464360162000 23.7 1 1 0
! 14 1464360302000 23.3 1 1 0
! 14 1464360428000 22 1 1 0
! 14 1464360604000 21.5 1 1 0
! 14 1464360764000 22.1 1 1 0
! 14 1464360911000 20.7 1 1 0
! 14 1464361043000 22.5 1 1 0
! 14 1464361224000 21.8 1 1 0
! 14 1464361392000 22.8 1 1 0
! 14 1464361544000 23.7 1 1 0
! 14 1464361683000 22.9 1 1 0
! 14 1464361807000 21.7 1 1 0
! 14 1464361980000 22.5 1 1 0
! 14 1464362139000 21.1 1 1 0
! 14 1464362284000 22 1 1 0
! 14 1464362414000 21.3 1 1 0
! 14 1464362574000 22 1 1 0
! 14 1464362720000 21.3 1 1 0
! 14 1464362851000 22 1 1 0
! 14 1464363032000 21 1 1 0
! 14 1464363199000 20.7 1 1 0
! 14 1464363351000 20.3 1 1 0
! 14 1464363489000 20.1 1 1 0
! 14 1464363612000 20.8 1 1 0
! 14 1464363785000 20.8 1 1 0
! 14 1464363943000 22 1 1 0
! 14 1464364087000 21.4 1 1 0
! 14 1464364217000 21.8 1 1 0
! 14 1464364396000 21.1 1 1 0
! 14 1464364560000 21.5 1 1 0
! 14 1464364711000 21.8 1 1 0
! 14 1464364846000 21.4 1 1 0
! 14 1464364968000 21.5 1 1 0
! 14 1464365139000 22.4 1 1 0
! 14 1464365295000 20.5 1 1 0
! 14 1464365438000 21.3 1 1 0
! 14 1464365565000 21.8 1 1 0
! 14 1464365743000 21.5 1 1 0
! 14 1464365906000 21.7 1 1 0
! 14 1464366054000 22.6 1 1 0
! 14 1464366188000 21.7 1 1 0
! 14 1464366372000 21.8 1 1 0
! 14 1464366541000 21.1 1 1 0
! 14 1464366696000 21.3 1 1 0
! 14 1464366836000 21.5 1 1 0
! 14 1464366962000 21 1 1 0
! 14 1464367137000 20.1 1 1 0
! 14 1464367298000 20.7 1 1 0
! 14 1464367445000 21.3 1 1 0
! 14 1464367577000 20.5 1 1 0
! 14 1464367759000 20.4 1 1 0
! 14 1464367927000 20.5 1 1 0
! 14 1464368080000 20.4 1 1 0
! 14 1464368218000 19.7 1 1 0
! 14 1464368342000 20 1 1 0
! 14 1464368516000 19.2 1 1 0
! 14 1464368675000 19.4 1 1 0
! 14 1464368820000 19.7 1 1 0
! 14 1464368950000 19.1 1 1 0
! 14 1464369130000 19 1 1 0
! 14 1464369296000 18.8 1 1 0
! 14 1464369447000 18.7 1 1 0
! 14 1464369584000 19 1 1 0
! 14 1464369706000 18.8 1 1 0
! 14 1464369878000 19 1 1 0
! 14 1464370036000 19.2 1 1 0
! 14 1464370179000 18.8 1 1 0
! 14 1464370307000 18.5 1 1 0
! 14 1464370485000 18.5 1 1 0
! 14 1464370649000 18.8 1 1 0
! 14 1464370798000 18.7 1 1 0
! 14 1464370933000 18.5 1 1 0
! 14 1464371550341 18.4 1 2 0
! 14 1464371602360 18.4 1 1 0
! 14 1464371778621 18.8 1 1 0
! 14 1464371940600 18.8 1 1 0
! 14 1464372088093 18.2 1 1 0
! 14 1464372281224 17.9 1 1 0
! 14 1464372463969 17.8 1 1 0
! 14 1464372632217 17.6 1 1 0
! 14 1464372785982 17.6 1 1 0
! 14 1464372925463 17.6 1 1 0
! 14 1464373050474 17.3 1 1 0
! 14 1464373224978 17.3 1 1 0
! 14 1464373385226 17.3 1 1 0
! 14 1464373530984 17.2 1 1 0
! 14 1464373662217 17.3 1 1 0
! 14 1464373842962 17.2 1 1 0
! 14 1464374009476 16.9 1 1 0
! 14 1464374161486 17 1 1 0
! 14 1464374298970 16.9 1 1 0
! 14 1464374422203 17 1 1 0
! 14 1464374594972 16.9 1 1 0
! 14 1464374753207 16.7 1 1 0
! 14 1464374897220 16.7 1 1 0
! 14 1464375026715 16.6 1 1 0
! 14 1464375205711 16.6 1 1 0
! 14 1464375370458 16.6 1 1 0
! 14 1464375520714 16.6 1 1 0
! 14 1464375656465 16.4 1 1 0
! 14 1464375777715 16.4 1 1 0
! 14 1464375948706 16.4 1 1 0
! 14 1464376105209 16.3 1 1 0
! 14 1464376247215 16.3 1 1 0
! 14 1464376374957 16.3 1 1 0
! 14 1464376552225 16.1 1 1 0
! 14 1464376714942 16 1 1 0
! 14 1464376863458 16 1 1 0
! 14 1464376997462 16 1 1 0
! 14 1464377180961 15.8 1 1 0
! 14 1464377350201 15.8 1 1 0
! 14 1464377504956 15.8 1 1 0
! 14 1464377645208 15.8 1 1 0
! 14 1464377770973 15.8 1 1 0
! 14 1464377946445 15.8 1 1 0
! 14 1464378107446 15.8 1 1 0
! 14 1464378253953 15.6 1 1 0
! 14 1464378386212 15.6 1 1 0
! 14 1464378567961 15.6 1 1 0
! 14 1464378735200 15.5 1 1 0
! 14 1464378888196 15.5 1 1 0
! 14 1464379026694 15.6 1 1 0
! 14 1464379150696 15.5 1 1 0
! 14 1464379324196 15.5 1 1 0
! 14 1464379483444 15.5 1 1 0
! 14 1464379628197 15.3 1 1 0
! 14 1464379758433 15.5 1 1 0
! 14 1464379938446 15.2 1 1 0
! 14 1464380103954 15.3 1 1 0
! 14 1464380254942 15.2 1 1 0
! 14 1464380391706 15.2 1 1 0
! 14 1464380513933 15.2 1 1 0
! 14 1464380685691 15.2 1 1 0
! 14 1464380843187 15 1 1 0
! 14 1464380986191 15 1 1 0
! 14 1464381114696 15.2 1 1 0
! 14 1464381292696 15 1 1 0
! 14 1464381456448 15 1 1 0
! 14 1464381605687 15 1 1 0
! 14 1464381740438 15 1 1 0
! 14 1464381860954 14.9 1 1 0
! 14 1464382030937 14.9 1 1 0
! 14 1464382186469 14.7 1 1 0
! 14 1464382327694 14.7 1 1 0
! 14 1464382454431 14.7 1 1 0
! 14 1464382630705 14.7 1 1 0
! 14 1464382792690 14.5 1 1 0
! 14 1464382940195 14.4 1 1 0
! 14 1464383073198 14.4 1 1 0
! 14 1464383255679 14.4 1 1 0
! 14 1464383423949 14.4 1 1 0
! 14 1464383577703 14.2 1 1 0
! 14 1464383716941 14.2 1 1 0
! 14 1464383841927 14.2 1 1 0
! 14 1464384016431 14.2 1 1 0
! 14 1464384176437 14.2 1 1 0
! 14 1464384322187 14.1 1 1 0
! 14 1464384453438 14.1 1 1 0
! 14 1464384634176 13.9 1 1 0
! 14 1464384800684 14.1 1 1 0
! 14 1464384952677 14.1 1 1 0
! 14 1464385090179 13.9 1 1 0
! 14 1464385213194 13.9 1 1 0
! 14 1464385385934 13.9 1 1 0
! 14 1464385544180 13.9 1 1 0
! 14 1464385687941 13.9 1 1 0
! 14 1464385817435 13.9 1 1 0
! 14 1464385996432 13.9 1 1 0
! 14 1464386160925 13.8 1 1 0
! 14 1464386311179 13.9 1 1 0
! 14 1464386446938 13.9 1 1 0
! 14 1464386568184 13.9 1 1 0
! 14 1464386739168 13.9 1 1 0
! 14 1464386895693 13.9 1 1 0
! 14 1464387037686 13.9 1 1 0
! 14 1464387165179 13.9 1 1 0
! 14 1464387342447 13.8 1 1 0
! 14 1464387505193 13.8 1 1 0
! 14 1464387653431 13.8 1 1 0
! 14 1464387787419 13.8 1 1 0
! 14 1464387970935 13.6 1 1 0
! 14 1464388139926 13.6 1 1 0
! 14 1464388294671 13.6 1 1 0
! 14 1464388434924 13.5 1 1 0
! 14 1464388560664 13.5 1 1 0
! 14 1464388735923 13.5 1 1 0
! 14 1464388896936 13.5 1 1 0
! 14 1464389043430 13.3 1 1 0
! 14 1464389175424 13.3 1 1 0
! 14 1464389357171 13.3 1 1 0
! 14 1464389524427 13.2 1 1 0
! 14 1464389677177 13.2 1 1 0
! 14 1464389815679 13.2 1 1 0
! 14 1464389939673 13.2 1 1 0
! 14 1464390113167 13 1 1 0
! 14 1464390272425 13 1 1 0
! 14 1464390417187 13 1 1 0
! 14 1464390547429 13 1 1 0
! 14 1464390727176 13 1 1 0
! 14 1464390892665 13 1 1 0
! 14 1464391043678 13 1 1 0
! 14 1464391180162 13 1 1 0
! 14 1464391302428 13 1 1 0
! 14 1464391474182 13 1 1 0
! 14 1464391631422 13 1 1 0
! 14 1464391774425 13 1 1 0
! 14 1464391902929 12.9 1 1 0
! 14 1464392080905 12.9 1 1 0
! 14 1464392244665 12.9 1 1 0
! 14 1464392393929 12.9 1 1 0
! 14 1464392528676 12.9 1 1 0
! 14 1464392648934 12.9 1 1 0
! 14 1464392818912 12.9 1 1 0
! 14 1464392974425 12.7 1 1 0
! 14 1464393115415 12.7 1 1 0
! 14 1464393242167 12.7 1 1 0
! 14 1464393418415 12.7 1 1 0
! 14 1464393580153 12.7 1 1 0
! 14 1464393727668 12.9 1 1 0
! 14 1464393860663 12.7 1 1 0
! 14 1464394043155 12.9 1 1 0
! 14 1464394211420 12.7 1 1 0
! 14 1464394365158 12.7 1 1 0
! 14 1464394504419 12.7 1 1 0
! 14 1464394629157 12.9 1 1 0
! 14 1464394803663 12.9 1 1 0
! 14 1464394963670 12.9 1 1 0
! 14 1464395109163 12.9 1 1 0
! 14 1464395240409 12.9 1 1 0
! 14 1464395421164 12.7 1 1 0
! 14 1464395587417 12.9 1 1 0
! 14 1464395739416 12.7 1 1 0
! 14 1464395876918 12.7 1 1 0
! 14 1464395999907 12.7 1 1 0
! 14 1464396172646 12.7 1 1 0
! 14 1464396330912 12.7 1 1 0
! 14 1464396474662 12.7 1 1 0
! 14 1464396603907 12.7 1 1 0
! 14 1464396782910 12.7 1 1 0
! 14 1464396947402 12.6 1 1 0
! 14 1464397097409 12.6 1 1 0
! 14 1464397233169 12.6 1 1 0
! 14 1464397354410 12.6 1 1 0
! 14 1464397525171 12.6 1 1 0
! 14 1464397681661 12.6 1 1 0
! 14 1464397823675 12.4 1 1 0
! 14 1464397951159 12.4 1 1 0
! 14 1464398128153 12.6 1 1 0
! 14 1464398290907 12.4 1 1 0
! 14 1464398439176 12.4 1 1 0
! 14 1464398572906 12.4 1 1 0
! 14 1464398756406 12.4 1 1 0
! 14 1464398925415 12.3 1 1 0
! 14 1464399079907 12.4 1 1 0
! 14 1464399220146 12.4 1 1 0
! 14 1464399345904 12.4 1 1 0
! 14 1464399521148 12.4 1 1 0
! 14 1464399682152 12.6 1 1 0
! 14 1464399828676 12.6 1 1 0
! 14 1464399960662 12.6 1 1 0
! 14 1464400142178 12.7 1 1 0
! 14 1464400309413 12.7 1 1 0
! 14 1464400462157 12.9 1 1 0
! 14 1464400600410 12.9 1 1 0
! 14 1464400724404 13 1 1 0
! 14 1464400897896 13 1 1 0
! 14 1464401056894 13 1 1 0
! 14 1464401201657 13 1 1 0
! 14 1464401331910 13.2 1 1 0
! 14 1464401492159 13.2 1 1 0
! 14 1464401637896 13.2 1 1 0
! 14 1464401769150 13.2 1 1 0
! 14 1464401950148 13.3 1 1 0
! 14 1464402116657 13.3 1 1 0
! 14 1464402268645 13.2 1 1 0
! 14 1464402406400 13.2 1 1 0
! 14 1464402529645 13.2 1 1 0
! 14 1464402702401 13 1 1 0
! 14 1464402860886 13 1 1 0
! 14 1464403004915 13 1 1 0
! 14 1464403134408 13 1 1 0
! 14 1464403313404 13 1 1 0
! 14 1464403478155 13 1 1 0
! 14 1464403628401 13 1 1 0
! 14 1464403764154 13 1 1 0
! 14 1464403885630 13 1 1 0
! 14 1464404056646 13 1 1 0
! 14 1464404213181 13 1 1 0
! 14 1464404355402 13 1 1 0
! 14 1464404483145 13 1 1 0
! 14 1464404660394 13 1 1 0
! 14 1464404823401 12.9 1 1 0
! 14 1464404971901 12.9 1 1 0
! 14 1464405105888 12.9 1 1 0
! 14 1464405289401 12.9 1 1 0
! 14 1464405458629 12.9 1 1 0
! 14 1464405613380 12.9 1 1 0
! 14 1464405753646 12.9 1 1 0
! 14 1464405879635 12.9 1 1 0
! 14 1464406055146 12.9 1 1 0
! 14 1464406216149 12.9 1 1 0
! 14 1464406362888 12.9 1 1 0
! 14 1464406495144 12.9 1 1 0
! 14 1464406676897 12.7 1 1 0
! 14 1464406844383 12.7 1 1 0
! 14 1464406997394 12.7 1 1 0
! 14 1464407135886 12.7 1 1 0
! 14 1464407259884 12.7 1 1 0
! 14 1464407433641 12.7 1 1 0
! 14 1464407592897 12.7 1 1 0
! 14 1464407737642 12.9 1 1 0
! 14 1464407868147 12.9 1 1 0
! 14 1464408048149 12.9 1 1 0
! 14 1464408213637 12.9 1 1 0
! 14 1464408364883 12.9 1 1 0
! 14 1464408501631 12.9 1 1 0
! 14 1464408623874 12.9 1 1 0
! 14 1464408795870 12.9 1 1 0
! 14 1464408953388 12.9 1 1 0
! 14 1464409096375 12.9 1 1 0
! 14 1464409224871 12.9 1 1 0
! 14 1464409403127 13 1 1 0
! 14 1464409566881 13 1 1 0
! 14 1464409716131 13 1 1 0
! 14 1464409851133 13 1 1 0
! 14 1464409971643 13 1 1 0
! 14 1464410141648 13 1 1 0
! 14 1464410297381 13 1 1 0
! 14 1464410438633 13 1 1 0
! 14 1464410565378 13 1 1 0
! 14 1464410741635 13 1 1 0
! 14 1464410903632 13 1 1 0
! 14 1464411051125 13.2 1 1 0
! 14 1464411184137 13.2 1 1 0
! 14 1464411366888 13.3 1 1 0
! 14 1464411535127 13.3 1 1 0
! 14 1464411688885 13.3 1 1 0
! 14 1464411828371 13.3 1 1 0
! 14 1464411953382 13.5 1 1 0
! 14 1464412127888 13.5 1 1 0
! 14 1464412288139 13.6 1 1 0
! 14 1464412433894 13.5 1 1 0
! 14 1464412565115 13.5 1 1 0
! 14 1464412745867 13.6 1 1 0
! 14 1464412912374 13.6 1 1 0
! 14 1464413064388 13.8 1 1 0
! 14 1464413201880 13.6 1 1 0
! 14 1464413325124 13.8 1 1 0
! 14 1464413497866 13.9 1 1 0
! 14 1464413656119 13.9 1 1 0
! 14 1464413800121 14.1 1 1 0
! 14 1464413929653 14.1 1 1 0
! 14 1464414108617 14.1 1 1 0
! 14 1464414273395 14.1 1 1 0
! 14 1464414423626 14.2 1 1 0
! 14 1464414559381 14.4 1 1 0
! 14 1464414680624 14.4 1 1 0
! 14 1464414851620 14.4 1 1 0
! 14 1464415008127 14.7 1 1 0
! 14 1464415150123 14.4 1 1 0
! 14 1464415277871 14.4 1 1 0
! 14 1464415455121 14.6 1 1 0
! 14 1464415617865 14.4 1 1 0
! 14 1464415766367 14.7 1 1 0
! 14 1464415900372 14.9 1 1 0
! 14 1464416083872 14.7 1 1 0
! 14 1464416253110 14.7 1 1 0
! 14 1464416407868 14.7 1 1 0
! 14 1464416548125 14.7 1 1 0
! 14 1464416673854 14.9 1 1 0
! 14 1464416849374 14.6 1 1 0
! 14 1464417010383 14.4 1 1 0
! 14 1464417156878 14.5 1 1 0
! 14 1464417289121 14.9 1 1 0
! 14 1464417470869 14.9 1 1 0
! 14 1464417638110 14.7 1 1 0
! 14 1464417791099 14.9 1 1 0
! 14 1464417929615 15 1 1 0
! 14 1464418053620 15.3 1 1 0
! 14 1464418227144 15.8 1 1 0
! 14 1464418386363 15 1 1 0
! 14 1464418661354 15.5 1 1 0
! 14 1464418810469 15.5 1 2 0
! 14 1464418839486 15.6 1 1 0
! 14 1464419004985 15.6 1 1 0
! 14 1464419155961 15.6 1 1 0
! 14 1464419292732 15.6 1 1 0
! 14 1464419329013 15.6 1 2 0
! 14 1464419414960 15.8 1 1 0
! 14 1464419586721 15.6 1 1 0
! 14 1464419744221 15.6 1 1 0
! 14 1464419887227 16 1 1 0
! 14 1464420048372 16 1 2 0
! 14 1464420193256 16.1 1 1 0
! 14 1464420356997 16.4 1 1 0
! 14 1464420506248 16.3 1 1 0
! 14 1464420640994 16.3 1 1 0
! 14 1464420761505 16.6 1 1 0
! 14 1464420931496 16.6 1 1 0
! 14 1464421087004 16.7 1 1 0
! 14 1464421228253 17 1 1 0
! 14 1464421354995 16.9 1 1 0
! 14 1464421531244 17.3 1 1 0
! 14 1464421693238 17.3 1 1 0
! 14 1464421840736 17 1 1 0
! 14 1464421973752 17.2 1 1 0
! 14 1464422156249 16.9 1 1 0
! 14 1464422324478 17 1 1 0
! 14 1464422478241 17.2 1 1 0
! 14 1464422617508 17.2 1 1 0
! 14 1464422742508 16.9 1 1 0
! 14 1464422917007 17 1 1 0
! 14 1464423076977 16.9 1 1 0
! 14 1464423222733 16.9 1 1 0
! 14 1464423353986 17.2 1 1 0
! 14 1464423534733 16.9 1 1 0
! 14 1464423701249 17 1 1 0
! 14 1464423853239 17.2 1 1 0
! 14 1464423990740 17.2 1 1 0
! 14 1464424113723 17.6 1 1 0
! 14 1464424286493 17.5 1 1 0
! 14 1464424444770 17.9 1 1 0
! 14 1464424588483 18.1 1 1 0
! 14 1464424717988 18.1 1 1 0
! 14 1464424897001 18.4 1 1 0
! 14 1464425061505 18.2 1 1 0
! 14 1464425211733 18.7 1 1 0
! 14 1464425347479 18.4 1 1 0
! 14 1464425468726 18.4 1 1 0
! 14 1464425639731 19.1 1 1 0
! 14 1464425796230 18.7 1 1 0
! 14 1464425938243 19.1 1 1 0
! 14 1464426065721 18.7 1 1 0
! 14 1464426242978 19.1 1 1 0
! 14 1464426405733 19.1 1 1 0
! 14 1464426553977 19.7 1 1 0
! 14 1464426687990 19.5 1 1 0
! 14 1464426871476 20.1 1 1 0
! 14 1464427040478 19.7 1 1 0
! 14 1464427195240 21.4 1 1 0
! 14 1464427335474 20.1 1 1 0
! 14 1464427461228 20 1 1 0
! 14 1464427636463 20 1 1 0
! 14 1464427797479 20.4 1 1 0
! 14 1464427943964 20.7 1 1 0
! 14 1464428075969 22.2 1 1 0
! 14 1464428257727 22 1 1 0
! 14 1464428424979 20.7 1 1 0
! 14 1464428577719 21.4 1 1 0
! 14 1464428716230 21.7 1 1 0
! 14 1464428840217 21 1 1 0
! 14 1464429013717 22.2 1 1 0
! 14 1464429172962 22.4 1 1 0
! 14 1464429317717 22.2 1 1 0
! 14 1464429447959 21.1 1 1 0
! 14 1464429627713 22.1 1 1 0
! 14 1464429793210 22.9 1 1 0
! 14 1464429944223 21.8 1 1 0
! 14 1464430080716 21.4 1 1 0
! 14 1464430202959 22.8 1 1 0
! 14 1464430374730 22.2 1 1 0
! 14 1464430531973 23 1 1 0
! 14 1464430674962 22.4 1 1 0
! 14 1464430803466 23.6 1 1 0
! 14 1464430981465 22.9 1 1 0
! 14 1464431145206 24 1 1 0
! 14 1464431294475 23.9 1 1 0
! 14 1464431429213 22.6 1 1 0
! 14 1464431549458 22.8 1 1 0
! 14 1464431719456 21.4 1 1 0
! 14 1464431874966 22.5 1 1 0
! 14 1464432015961 22.6 1 1 0
! 14 1464432142690 22.6 1 1 0
! 14 1464432318956 22.8 1 1 0
! 14 1464432480711 23 1 1 0
! 14 1464432628208 22.1 1 1 0
! 14 1464432761192 22.9 1 1 0
! 14 1464432943709 22.9 1 1 0
! 14 1464433111946 23.3 1 1 0
! 14 1464433265700 23.5 1 1 0
! 14 1464433404941 22.6 1 1 0
! 14 1464433529698 22.8 1 1 0
! 14 1464433704193 23.3 1 1 0
! 14 1464433864202 22.9 1 1 0
! 14 1464434009692 22.2 1 1 0
! 14 1464434321707 22.9 1 1 0
! 14 1464434487955 22.4 1 1 0
! 14 1464434639951 22.6 1 1 0
! 14 1464434777458 23.2 1 1 0
! 14 1464434900448 22.5 1 1 0
! 14 1464435073189 21.5 1 1 0
! 14 1464435231453 21.8 1 1 0
! 14 1464435375197 22.6 1 1 0
! 14 1464435504442 23.3 1 1 0
! 14 1464435683450 22.4 1 1 0
! 14 1464435847958 24 1 1 0
! 14 1464435997936 24.8 1 1 0
! 14 1464436133697 25 1 1 0
! 14 1464436254936 23.2 1 1 0
! 14 1464436425689 24.4 1 1 0
! 14 1464436582194 23.5 1 1 0 -
! 14 1464436582194 23.5 1 1 0 `Ich verstehe gar nichts. Wie sieht Chart aus? Wie sehen flot Einstellungen aus?
Wie stellst du fest, dass die Daten fehlen?
Heißt es, dass du die Daten nur für 24 Stunden siehst?
Heißt es, dass du die Daten nur für 24 Stunden siehst? `
Wird auch bisschen zufiel info durcheinander, also mal SMART:
Flot einstellen Min-Max = 0 -30
Zeitraum Flot = 3 tage
Anzeige in flot (grafiek) = bis gestern 10 Uhr, also 24 stunden vor erste öffnen heute.
im kern: Zeitraum welchen ich einstellen wird in grafiek gescopet, aber grafiek begint erst -24 stunden alles davor lehr.
In de DB sind aber 600 datenpunkte für das Messgerät, die zeigt flot aber nicht.
Was mir dan auffällt is das erster sichtbare datenpunkt in grafiek genau -24 stunden ist vond erstes mal öffnen flot heute.
Dasselbe hatte ich gestern. Also gestern start grafie 26-05 18.00, heute start grafiek 27-05 10.00
Kannst du mir so einen Bild posten?
48_flot.png -
Kannst du mir so einen Bild posten? `
sicher siehe da, input data & zeit. Dies is die Grafik von de daten mit ID=14
http://postimg.org/image/p6loezybv/ ~~http://postimg.org/image/jwgpnpe2z/ ~~so wie man sieht nur date von 14.00 obwohl vor 2 stunden nog bis 10.00 Uhr sichtbar war.
Zur Sicherheit auch mal die SQL log Einstellungen:
Hi Bluefox,
bei mir ist es auch so.
Ich logge den Tages-Stromverbrauch vom Haus seit mind. 3 Wochen auf einem mySQL-Server im Internet.
Auf dem Ufertreffen hatte ich auch noch eine Grafik für die letzten7 Tage (in VIS mit eingebunden) abrufen / anzeigen können.
Jetzt komme ich auch nur nich auf 24 Stunden:
Eine direkte Abfrage beim SQL-Server mit
SELECT `ts_number`.`id`, `ts_number`.`ts`, `ts_number`.`val`, `ts_number`.`ack`, `ts_number`.`_from`, `ts_number`.`q` FROM `iobroker`.`ts_number`where id = 3;
(ID = 3 ist meine Systemvariable auf der CCU, die mit hm-rega abgeholt wird) ergibt 2812 Datensätze.
Das Ergebnis hänge ich als Anhang (txt tab getrennt) mit an.
Gruß,
Eric
Hi Bluefox,
@eric2905:… ergibt 2812 Datensätze.... `
Heute sind 3622 Datensätze (mit ID = 3) vorhanden, der Flor-Chart zeigt aber wieder nur einen kleinen Teil an - siehe Screenshot.Gruß,
Eric
Hallo Kollegen,
bei mir auch das gleiche wie beim eric2905.
Hi Bluefox,
filename="flot-config.png" index="0">~~Eine direkte Abfrage beim SQL-Server mit
filename="ID3.txt" index="1">~~Gruß,
Eric `
Super dass, du Rohdaten gepostet hast. Da sehe ich nämlich, dass deine Daten erst ab "Fri May 27 2016 21:19:15 GMT+0200" Starten. Das heißt, dass es im DB einfach nicht mehr Daten gibt. -
Danke für eure Unterstützung. Ich konnte das Problem finden.
Und zwar ist das Problem nur da, wenn man "Never delete" option auswählt.
Falls diese Option gesetzt war, dann wurde die Historie auf ein Tag reduziert.
Es gibt neue Version. 8-)
Hi Bluefox,
Super danke dir.
Ich wert heut Abend die neue Version laden und Resultat Posten.
Für mich hat es nicht funktioniert. Ich komme wie früher nur bis zum ca. 08:50 am 28.05.16.
Falls diese Option gesetzt war, dann wurde die Historie auf ein Tag reduziert. `
Das ist ja fast never! :mrgreen:Für mich hat es nicht funktioniert. Ich komme wie früher nur bis zum ca. 08:50 am 28.05.16. `
Wie auch, du musst ja erst neue Daten sammeln!Gruß
Rainer
Es gibt diese Daten nicht mehr bei dir. Deswegen kommst du nicht drauf. -
Hmm, seit ihr euch sicher ?
Ich habe den SQL adapter jetzt auf neuesten stand gebracht, auch bei mir fehlen die Daten davor.
Habe die query's verglichen mit vor 2 tagen:
27-05 = 16000 eintrage in der Datenbank
heute = 21000 eintrage
Ich frag mich dan auch ab ob die daten wirklich nicht da sind.
(mein SQL query "count" sagt mir was anderes :))
Zum debug mal completter dump der SQL dauen aus meiner DB.
979_ts_number.csv -
Danke Bluefox und Homoran,
ihr habt leider Recht! Den ersten Timestamp in DB ist vom 28.5.16 7:05. Also die Daten sind weg
Btw. kann mir jemand erklären die unterschied bei der Aggregationstypen Total und minmax? Ich will einfach die "echten" Daten im Float anzeigen, nicht irgendwelche Summen u.s.w.? Wenn ich minmax nehme, sollte der Float die min/max werte für das ausgewählte Zeitintervall zeigen, richtig? Was sollte beim Aggregation >> Schritttyp: Sekunden, Bzw. Anzahl stehen?
In deine Tabelle die erste Datensatz ist vom 28.5.16 7:24 und die letzte vom 29.5.16 13:24 - also wie be mir - die Daten sind weg!
Mach dir eine Excel Tabelle mit dem Formel````
=(((Bxx/60)/60)/24)+25569 -
Das passt zwar nur indirekt hierhin, aber ich denke, dass unter dem Begriff Aggregation zwei verschiedene Dinge durcheinandergewürfelt werden.
Einmal die "Anzeigeart" Min/max/mittel/minmax… die wahrscheinlich (Vermutung durch ausprobieren) den Wert (bei Minmax beide) anzeigt, der in dem Zeitraum, der in dem Chart einen Punkt ausmacht (und in Wirklichkeit aus mehrene Messpunkten besteht, diese aber wegen der Auflösung nicht alle angezeigt werden) über diese Funktion ermittelt wird.
Dieser Theorie widerspricht aber, dass ich bei min höhere Werte angezeigt bekomme, als bei max.
Das zweite Mal taucht Aggregation unter dem Block "Zeit" auf.
Hier kann man zwischen sec und Anzahl wählen.
Ich hätte erwartet, dass hier die Anzahl der zusammenfassenden Punkte (in Zeit resp. Sekunden) angegeben wird.
Anscheinend ist dies aber genau anders herum.
Wenn ich Anzahl angebe, kann ich (anscheinend) die Anzahl Punkte, die in einem Chart angezeigt werden sollen festlegen.
der Wert 2 ergibt eine Gerade, bei dem Wert 4 enthält diese 2 Knicke.
Auf jeden Fall kann man hiermit die Datenrate, die zum View geschickt wird deutlich reduzieren.
Rainer
