    4. mercedesme problem nach update von node.js 10.xx auf 12.16.3
    UNSOLVED mercedesme problem nach update von node.js 10.xx auf 12.16.3
      Thomas Braun Most Active @crazyskater last edited by Thomas Braun
      @crazyskater
      iobroker rebuild canvas
        crazyskater @Thomas Braun last edited by
        @Thomas-Braun said in mercedesme problem nach update von node.js 10.xx auf 12.16.3:
        Hallo Thomas,
        das rebuild hat mein iobroker gar nicht.
        Commands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start
        iobroker stop
        iobroker start <adapter>
        iobroker stop <adapter>
        iobroker start all
        iobroker restart
        iobroker restart <adapter>
        iobroker info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter>
        iobroker url <url> [<name>]
        iobroker del <adapter>
        iobroker del <adapter>.<instance>
        iobroker update [repository url] [--updatable/--u] [--installed/--i]
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url]
        iobroker upgrade <adapter> [repository url]
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all
        iobroker upload <adapter>
        iobroker object get <id>
        iobroker object set <id> <json-value>
        iobroker object set <id> propertyname=value
        iobroker object del <id|pattern> [--yes]
        iobroker object chmod <object-mode> [state-mode] <id>
        iobroker object chown <user> <group> <id>
        iobroker object list <id>
        iobroker state get <id>
        iobroker state getplain <id> [--pretty]
        iobroker state getvalue <id>
        iobroker state set <id> <value> [ack]
        iobroker state del <id>
        iobroker message <adapter>[.instanceid] <command> [<message>]
        iobroker list <type> [filter]
        iobroker chmod <mode> <file>
        iobroker chown <user> <group> <file>
        iobroker touch <file>
        iobroker rm <file>
        iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
        iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
        iobroker file rm <iobroker-path-to-delete>
        iobroker file sync
        iobroker user add <user> [--ingroup group] [--password pass]
        iobroker user del <user>
        iobroker user passwd <user> [--password pass]
        iobroker user enable <user>
        iobroker user disable <user>
        iobroker user get <user>
        iobroker user check <user> [--password pass]
        iobroker group add <group>
        iobroker group del <group>
        iobroker group list <group>
        iobroker group enable <group>
        iobroker group disable <group>
        iobroker group get <group>
        iobroker group adduser <group> <user>
        iobroker group deluser <group> <user>
        iobroker host this
        iobroker host <hostname>
        iobroker host set <hostname>
        iobroker host remove <hostname>
        iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
        iobroker license <license.file or license.text>
        iobroker cert create
        iobroker cert view [<certificate name>]
        iobroker clean
        iobroker backup
        iobroker restore <backup name or path>
        iobroker validate <backup name or path>
        iobroker <command> --timeout 5000
        iobroker status [all]
        iobroker repo [name]
        iobroker repo add <name> <path or url>
        iobroker repo set <name>
        iobroker repo del <name>
        iobroker uuid
        iobroker unsetup
        iobroker fix
        iobroker multihost <enable|disable> [--secure true|false]
        iobroker multihost browse
        iobroker multihost connect
        iobroker compact status
        iobroker compact <enable|on|disable|off>
        iobroker compact <adapter>.<instance> status
        iobroker compact <adapter>.<instance> group <group-id>
        iobroker compact <adapter>.<instance> <disable|off>
        iobroker compact <adapter>.<instance> <enable|on> [group-id]
        iobroker version [adapter]
        iobroker [adapter] -v
        Options:
          --help     Show help  [boolean]
          --version  Show version number  [boolean]
          crazyskater @crazyskater last edited by
          @crazyskater
          iobroker --version
          2.2.9
            @crazyskater Dann in /opt/iobroker
            npm rebuild canvas
              @Thomas-Braun
              npm rebuild canvas
              Hat auch nicht geholfen.
              > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
              > node-pre-gyp install --fallback-to-build
              node-pre-gyp WARN Using request for node-pre-gyp https download
              [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" already installed
              Pass --update-binary to reinstall or --build-from-source to recompile
                @crazyskater
                npm rebuild canvas --build-from-source
                  Da hagelt es nur Fehler.
                  Package pixman-1 was not found in the pkg-config search path.
                  Perhaps you should add the directory containing `pixman-1.pc'
                  to the PKG_CONFIG_PATH environment variable
                  No package 'pixman-1' found
                  gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                  gyp ERR! configure error
                  gyp ERR! stack Error: `gyp` failed with exit code: 1
                  gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                  gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                  gyp ERR! System Linux 4.19.0-8-amd64
                  gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                  gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  gyp ERR! node -v v12.16.3
                  gyp ERR! node-gyp -v v5.0.5
                  gyp ERR! not ok
                  node-pre-gyp ERR! build error
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                  node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                  node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                  node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                  node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                  node-pre-gyp ERR! System Linux 4.19.0-8-amd64
                  node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                  node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  node-pre-gyp ERR! node -v v12.16.3
                  node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                  node-pre-gyp ERR! not ok
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the canvas@2.6.1 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /root/.npm/_logs/2020-05-22T19_42_44_243Z-debug.log
                    @crazyskater
                    sudo apt install libpixman-1-dev
                    Dann noch mal
                    versuchen.
                      @crazyskater said in mercedesme problem nach update von node.js 10.xx auf 12.16.3:
                      ging auch nicht, es hat im noch folgendes gefehlt.
                      • libcairo2-dev
                      • libpango-1.0-0
                      Nun scheint es ganz kaputt...
                      /usr/bin/env: ‘node’: No such file or directory
                        iobroker
                        sudo: node: command not found
                          ok, hab nochmal
                           curl -sL https://iobroker.net/fix.sh | bash -
                          gemacht, nun tut iobroker wieder
                            @Thomas-Braun
                            danke nun tut es, hab noch folgendes gemacht.
                            apt install   libpango1.0-dev
                            apt install   libjpeg62-turbo-dev
                            Mein Held Thomas.
                            Danke dir
                            cjsloader.js1183 mercedesme node.js12.16.3
                            736
