    4. Test Adapter milight-smart-light v0.3.0 GitHub/Latest
      Schimi @carsten04 last edited by
      @carsten04
      hi, ich hoffe es kann dir was helfen....
      Habe die Gruppe über einen schalter eingeschaltet (OnOff ID).
      ist sofort rot angegangen, habe dann mehrmals aus und an gemacht dann auf FFFFFF manell geändert und wieder aus gemacht... beim erneuten einschalten war es wieder Rot... (mit "dem anderen" milight Adapter, funzt das Script einwandfrei)
      undefined2020-05-16 20:32:15.911 - info: host.SmartHome(SmartHome) stopInstance system.adapter.milight-smart-light.0 (force=false, process=true)
      2020-05-16 20:32:15.911 - info: milight-smart-light.0 (2628) on:message:stopInstance->All command have been executed - closing MiLight!
      2020-05-16 20:32:16.927 - info: host.SmartHome(SmartHome) stopInstance timeout 1000 system.adapter.milight-smart-light.0 killing pid 2628
      2020-05-16 20:32:16.958 - warn: host.SmartHome(SmartHome) instance system.adapter.milight-smart-light.0 terminated due to SIGTERM
      2020-05-16 20:32:16.958 - info: host.SmartHome(SmartHome) instance system.adapter.milight-smart-light.0 terminated with code null ()
      2020-05-16 20:32:19.459 - info: host.SmartHome(SmartHome) instance system.adapter.milight-smart-light.0 started with pid 5628
      2020-05-16 20:32:20.116 - debug: milight-smart-light.0 (5628) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-05-16 20:32:20.381 - debug: milight-smart-light.0 (5628) Objects client ready ... initialize now
      2020-05-16 20:32:20.381 - debug: milight-smart-light.0 (5628) Objects create System PubSub Client
      2020-05-16 20:32:20.381 - debug: milight-smart-light.0 (5628) Objects create User PubSub Client
      2020-05-16 20:32:20.381 - debug: milight-smart-light.0 (5628) Objects client initialize lua scripts
      2020-05-16 20:32:20.397 - debug: milight-smart-light.0 (5628) Objects connected to redis: 127.0.0.1:9001
      2020-05-16 20:32:20.397 - debug: milight-smart-light.0 (5628) objectDB connected
      2020-05-16 20:32:20.397 - debug: milight-smart-light.0 (5628) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-05-16 20:32:20.412 - debug: milight-smart-light.0 (5628) States create User PubSub Client
      2020-05-16 20:32:20.412 - debug: milight-smart-light.0 (5628) States create System PubSub Client
      2020-05-16 20:32:20.412 - debug: milight-smart-light.0 (5628) States connected to redis: 127.0.0.1:9000
      2020-05-16 20:32:20.412 - debug: milight-smart-light.0 (5628) statesDB connected
      2020-05-16 20:32:20.506 - info: milight-smart-light.0 (5628) starting. Version 0.4.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.milight-smart-light, node: v10.17.0
      2020-05-16 20:32:20.569 - info: milight-smart-light.0 (5628) main->::all MiLight zones and states were created!
      2020-05-16 20:32:20.569 - info: milight-smart-light.0 (5628) main->::all states were subscribed!
      2020-05-16 20:32:20.569 - info: milight-smart-light.0 (5628) main->::milight-smart-light adapter was started successfully!
      2020-05-16 20:32:24.350 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1589653944350,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653944350}
      2020-05-16 20:32:24.366 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:32:24.366 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 16ms
      2020-05-16 20:32:24.366 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:32:24.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:32:24.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:24.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:32:24.678 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::328ms
      2020-05-16 20:32:27.366 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653947366,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653944381}
      2020-05-16 20:32:27.366 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:27.366 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:27.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:27.381 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 15ms
      2020-05-16 20:32:27.553 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::187ms
      2020-05-16 20:32:27.725 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::359ms
      2020-05-16 20:32:30.366 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589653950366,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653950366}
      2020-05-16 20:32:30.366 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:32:30.366 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:30.366 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:32:30.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:32:30.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:32:30.381 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:32:30.553 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::187ms
      2020-05-16 20:32:34.460 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1589653954460,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653954460}
      2020-05-16 20:32:34.475 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:32:34.475 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 15ms
      2020-05-16 20:32:34.475 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:32:34.475 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:32:34.475 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:34.475 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:32:34.803 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::343ms
      2020-05-16 20:32:37.210 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589653957210,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653957210}
      2020-05-16 20:32:37.225 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:32:37.225 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 15ms
      2020-05-16 20:32:37.225 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:32:37.241 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:32:37.241 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:32:37.241 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:32:37.319 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::109ms
      2020-05-16 20:32:37.475 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653957475,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653957475}
      2020-05-16 20:32:37.475 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:37.491 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 16ms
      2020-05-16 20:32:37.491 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:32:37.491 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:32:37.491 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:32:37.491 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:32:37.678 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::203ms
      2020-05-16 20:32:37.866 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::391ms
      2020-05-16 20:32:40.511 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653960511,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653957475}
      2020-05-16 20:32:40.511 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:40.511 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:40.795 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::284ms
      2020-05-16 20:32:43.735 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589653963720,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653963720}
      2020-05-16 20:32:43.735 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:32:43.735 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:43.735 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:32:43.735 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:32:43.735 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:32:43.751 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:32:43.876 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::141ms
      2020-05-16 20:32:47.007 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1589653967007,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653967007}
      2020-05-16 20:32:47.007 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:32:47.007 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:47.022 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:32:47.022 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:32:47.022 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:47.022 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:32:47.312 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::305ms
      2020-05-16 20:32:48.850 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589653968850,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653968850}
      2020-05-16 20:32:48.865 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:32:48.865 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 15ms
      2020-05-16 20:32:48.865 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:32:48.865 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:32:48.865 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:32:48.865 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:32:48.944 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::94ms
      2020-05-16 20:32:50.015 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653970016,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653970016}
      2020-05-16 20:32:50.015 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:50.015 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:32:50.015 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:50.015 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:32:50.015 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:32:50.031 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:32:50.203 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::188ms
      2020-05-16 20:32:50.390 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::375ms
      2020-05-16 20:32:53.031 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653973031,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653970016}
      2020-05-16 20:32:53.031 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:32:53.031 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:53.289 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::258ms
      2020-05-16 20:32:54.471 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589653974471,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653974471}
      2020-05-16 20:32:54.471 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:32:54.471 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:32:54.482 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:32:54.482 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:32:54.482 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:32:54.498 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:32:54.561 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::90ms
      2020-05-16 20:32:56.969 - debug: milight-smart-light.0 (5628) system.adapter.admin.0: logging false
      2020-05-16 20:33:09.732 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1589653989732,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653989732}
      2020-05-16 20:33:09.732 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:33:09.732 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:09.732 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:33:09.747 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:33:09.747 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:33:09.747 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:33:10.064 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::332ms
      2020-05-16 20:33:12.728 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653992729,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653989747}
      2020-05-16 20:33:12.744 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589653992729,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653989747}
      2020-05-16 20:33:12.744 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:33:12.744 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 16ms
      2020-05-16 20:33:12.744 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:12.931 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::203ms
      2020-05-16 20:33:13.082 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Garten.rgbw-3.rgb::state->{"val":"#000000","ack":false,"ts":1589653993081,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589301872228}
      2020-05-16 20:33:13.097 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Garten.rgbw-3.rgb::#000000
      2020-05-16 20:33:13.097 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 15ms
      2020-05-16 20:33:13.113 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::369ms
      2020-05-16 20:33:13.175 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::93ms
      2020-05-16 20:33:15.731 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589653995731,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589653995731}
      2020-05-16 20:33:15.731 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:33:15.731 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:15.746 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:33:15.746 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:33:15.746 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:33:15.746 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:33:15.825 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::94ms
      2020-05-16 20:33:21.470 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1589654001454,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589654001454}
      2020-05-16 20:33:21.470 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:33:21.470 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:21.470 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:33:21.470 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:33:21.470 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:33:21.486 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ff0000
      2020-05-16 20:33:21.736 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::266ms
      2020-05-16 20:33:24.474 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589654004473,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589654001470}
      2020-05-16 20:33:24.474 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:33:24.474 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:24.490 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 16ms
      2020-05-16 20:33:24.709 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::235ms
      2020-05-16 20:33:24.884 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::410ms
      2020-05-16 20:33:27.772 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.rgb::state->{"val":"#ffFFFF","ack":false,"ts":1589654007770,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589654007770}
      2020-05-16 20:33:27.772 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ffffff
      2020-05-16 20:33:27.772 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.saturation::0
      2020-05-16 20:33:27.772 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:27.772 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.whiteMode::true
      2020-05-16 20:33:28.053 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::281ms
      2020-05-16 20:33:32.231 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1589654012230,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589654012230}
      2020-05-16 20:33:32.231 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::false
      2020-05-16 20:33:32.231 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:32.231 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::true
      2020-05-16 20:33:32.247 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::false
      2020-05-16 20:33:32.247 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#000000
      2020-05-16 20:33:32.247 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::0
      2020-05-16 20:33:32.247 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.whiteMode::false
      2020-05-16 20:33:32.402 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::171ms
      2020-05-16 20:33:36.344 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1589654016343,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589654016343}
      2020-05-16 20:33:36.344 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.onoff::true
      2020-05-16 20:33:36.344 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:36.344 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.on::true
      2020-05-16 20:33:36.360 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.off::false
      2020-05-16 20:33:36.360 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:33:36.360 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.rgb::#ffffff
      2020-05-16 20:33:36.360 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.whiteMode::true
      2020-05-16 20:33:36.729 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::385ms
      2020-05-16 20:33:39.349 - debug: milight-smart-light.0 (5628) on:stateChange:ack=false->milight-smart-light.0.Wonzimmer.rgbw-1.brightness::state->{"val":100,"ack":false,"ts":1589654019348,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1589654016360}
      2020-05-16 20:33:39.349 - debug: milight-smart-light.0 (5628) _setVal->setStateAsync->::milight-smart-light.0.Wonzimmer.rgbw-1.brightness::100
      2020-05-16 20:33:39.349 - debug: milight-smart-light.0 (5628) on:stateChange:mslStatestore.setState || 0ms
      2020-05-16 20:33:39.615 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::266ms
      2020-05-16 20:33:39.833 - debug: milight-smart-light.0 (5628) mslcommandsV6 executed::484ms
      2020-05-16 20:33:49.210 - info: host.SmartHome(SmartHome) stopInstance system.adapter.milight-smart-light.0 (force=false, process=true)
      2020-05-16 20:33:49.227 - info: milight-smart-light.0 (5628) on:message:stopInstance->All command have been executed - closing MiLight!
      2020-05-16 20:33:50.227 - info: host.SmartHome(SmartHome) stopInstance timeout 1000 system.adapter.milight-smart-light.0 killing pid 5628
      2020-05-16 20:33:50.242 - warn: host.SmartHome(SmartHome) instance system.adapter.milight-smart-light.0 terminated due to SIGTERM
      2020-05-16 20:33:50.242 - info: host.SmartHome(SmartHome) instance system.adapter.milight-smart-light.0 terminated with code null ()
      2020-05-16 20:33:52.744 - info: host.SmartHome(SmartHome) instance system.adapter.milight-smart-light.0 started with pid 4204
      2020-05-16 20:33:53.650 - info: milight-smart-light.0 (4204) starting. Version 0.4.1 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.milight-smart-light, node: v10.17.0
      2020-05-16 20:33:53.697 - info: milight-smart-light.0 (4204) main->::all MiLight zones and states were created!
      2020-05-16 20:33:53.697 - info: milight-smart-light.0 (4204) main->::all states were subscribed!
      2020-05-16 20:33:53.697 - info: milight-smart-light.0 (4204) main->::milight-smart-light adapter was started successfully!
      carsten04 1 Reply Last reply Reply Quote 0
      • carsten04
        carsten04 Developer @Schimi last edited by carsten04
        @Schimi sagte in Test Adapter milight-smart-light v0.3.0 GitHub/Latest:
        @carsten04
        Habe den Fehler gefunden. Es gibt Anfang der Woche auf GitHub eine neue Version, dann bitte noch einmal testen.
          claus1993 @carsten04 last edited by
          Um die Farbe grün zu erzeugen, hättest Du entweder rgb=#00ff00 (-> saturation=100, hue=120, brightness=100) , oder neben hue=120 noch zusätzlich brightness=100 setzen müssen.
          Das war mein Problem...hatte bei der saturation keinen Wert hinterlegt. Wenn ich dort die 100 eingetragen habe kann ich auch die Farben über den HUE Wert steuern.
          Danke!!!
            @carsten04 gibst du kurz bescheid? 🙂
            • carsten04
              carsten04 Developer last edited by carsten04
              Es gibt eine neue Version 0.5.0 auf GitHub, die die hier beschriebenen Fehler beheben sollte. Bitte über Octocat-Symbol installieren und hier dann eine Rückmeldung posten. Danke euch.
              Hinweis: für die Installation müssen vorher keine States unter Objekte gelöscht werden, also einfach über die 0.4.1 drüberinstallieren!
                Schimi last edited by Schimi
                also die ersten tests* sehen gut aus...
                Genaueres wird sich heute und spätestens morgen abend Zeigen, wenn die Scripte ohne mein fummeln von selbst "vom anfang bis ende" durchlaufen.
                Bisher scheint es zu klappen...
                Ich werde mich morgen Abend oder Samstag morgen/mittag melden (bei Fehlern vorher 😉 )
                Danke für deine Arbeit!!!! 👍
                *1. Einschalten ohne Farbänderung
                *2. Ist mir auch aufgefallen.... Wenn ein z.B. Farbwechsel Modus an war auf langsamste geschwindigkeit.... Wurde beim wieder einschalten auch alles auf Rot gesetzt und beim Modus wechsel stimmte wieder die Speed nicht (vermutlich das gleiche "Problem" wie bei 1, deshalb habe ich das vorher nicht geschrieben)
                  Sooo Update 🙂
                  Licht schaltete jetzt immer "richtig" ohne Farbänderung ein.
                  Mir ist aber tatsächlich noch was aufgefallen....
                  Der "Fehler" "2"...
                  Wenn ich über die milight Remote oder "den Anderen Adapter" was eingestellt habe (z.B. Farbwechsel, Geschwindigkeit auf langsam und 60% Dimmen) und danach ausgeschaltet (egal ob über Remote oder Adapter).
                  War beim wieder einschalten (egal ob remote oder Adapter 😉 ), alles auf diesen Einstellungen verblieben.
                  Dein Adapter schaltet es immer in"weiß" ein... was für den einen fall gut aber für "Nr 2" wieder nicht...
                  J carsten04 2 Replies Last reply Reply Quote 0
                    Jan1 @Schimi last edited by
                    @Schimi
                    Das mit den Farben hatte mich eh gewundert, ich habe 4 Zonen und bei 3 Zonen sind es die glichen Lampen, allerdings hat nur eine immer weiß oder eben die zuletzt geschaltete Farbe angeschaltet, alle anderen immer rot.
                    Jetzt sind alle weiß 😉
                    • carsten04
                      @Schimi Erstmal Danke fürs feedback. Kannst Du bei "Fehler 2" noch mal etwas präziser werden? Was machst Du wann mit welcher Fernbedienung oder App, was steht dann in den Adapter-States und was würdest Du erwarten? Am Besten hier noch einmal im Debug-Modus das Log posten. So ganz ist mir noch nicht klar, wo das Problem liegt.
                      Ergänzung: ich glaube ich habe verstanden was Du meinst 🙂. Das habe ich so programmiert, damit immer beim Einschalten via Adapter die Farbe des Leuchtmittels auch tatsächlich mit den Adapter-States übereinstimmt. Wenn Du zwischendurch mit der Original-App oder einer dier vielen Milight-Fernbedienungen schaltest bekommt das der Adapter ja nicht mit (System hat keinen Rückkanal). Deswegen habe ich ja auch eine eigene App geschrieben, damit man möglichst unabhängig von den original Milight-App's und Fernbedienungen ist und alles schön über den ioBroker geht.
                        Ich versuch es mal ausführicher.... 🙂
                        Ich habe im Garten 3 Leuchtmittel....
                        Die sind immer auf Farbwechsel, mit 60% und die Geschwindigkeit auf minimum (einfach solange auf "effectSpeedDown" klicken bis es nicht mehr langsamer wird).
                        Wenn ich sie nun über "onoff" ausschalte (egal ob Modus, etc vorher über Remote, App oder Adapter eingestellt) und wieder auf true setze....
                        Starten Sie "weiß".
                        wenn ich den debug richtig verstehe (habe da aber im Grunde keine Ahnung von 😉 )
                        Dann schickst du einen Farbwert beim einschalten immer mit (der wechselt aber nicht mit wenn ein Farbwechsel an war), was natürlich einen Farbverlauf "abschaltet".
                        Als workaround habe ich dann; eingeschaltet, Modus auf 1 geschickt aber bei der Geschwindigkeit bin ich raus, wie ich das (z.B. 10mal) geklicke auf Down umsetzen soll (Dieser workaround würde mir voll ausreichen).
                        Der "andere" milight adapter, hat anscheinend nur Ein bzw. Ausgeschaltet... somit lief es einfach "weiter".... Der wurde mir aber inzwischen zu instabil.... Deshalb bin ich super happy das du weiter entwickelst 🙂
                        2020-05-22 23:05:07.650 - debug: milight-smart-light.0 (6200) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2020-05-22 23:05:07.916 - debug: milight-smart-light.0 (6200) Objects client ready ... initialize now
                        2020-05-22 23:05:07.916 - debug: milight-smart-light.0 (6200) Objects create System PubSub Client
                        2020-05-22 23:05:07.916 - debug: milight-smart-light.0 (6200) Objects create User PubSub Client
                        2020-05-22 23:05:07.916 - debug: milight-smart-light.0 (6200) Objects client initialize lua scripts
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) Objects connected to redis: 127.0.0.1:9001
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) objectDB connected
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) Redis States: Use Redis connection: 127.0.0.1:9000
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) States create User PubSub Client
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) States create System PubSub Client
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) States connected to redis: 127.0.0.1:9000
                        2020-05-22 23:05:07.931 - debug: milight-smart-light.0 (6200) statesDB connected
                        2020-05-22 23:05:07.994 - info: milight-smart-light.0 (6200) starting. Version 0.5.0 in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.milight-smart-light, node: v10.17.0
                        2020-05-22 23:05:08.025 - info: milight-smart-light.0 (6200) main->::all MiLight zones and states were created!
                        2020-05-22 23:05:08.025 - info: milight-smart-light.0 (6200) main->::all states were subscribed!
                        2020-05-22 23:05:08.025 - info: milight-smart-light.0 (6200) main->::milight-smart-light adapter was started successfully!
                        2020-05-22 23:05:14.970 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectMode::state->{"val":5,"ack":false,"ts":1590181514970,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590181514970}
                        2020-05-22 23:05:14.970 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectMode::5
                        2020-05-22 23:05:14.970 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:15.111 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::141ms
                        2020-05-22 23:05:18.799 - debug: milight-smart-light.0 (6200) system.adapter.admin.0: logging false
                        2020-05-22 23:05:18.814 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectMode::state->{"val":2,"ack":false,"ts":1590181518814,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590181518814}
                        2020-05-22 23:05:18.830 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectMode::2
                        2020-05-22 23:05:18.830 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 16ms
                        2020-05-22 23:05:18.986 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::172ms
                        2020-05-22 23:05:21.189 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.brightnessOnly::state->{"val":100,"ack":false,"ts":1590181521189,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153085611}
                        2020-05-22 23:05:21.189 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.brightnessOnly::100
                        2020-05-22 23:05:21.189 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:21.252 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::63ms
                        2020-05-22 23:05:21.423 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.brightness::state->{"val":40,"ack":false,"ts":1590181521424,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1590181521424}
                        2020-05-22 23:05:21.423 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.brightness::40
                        2020-05-22 23:05:21.439 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.rgb::#666666
                        2020-05-22 23:05:21.439 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 16ms
                        2020-05-22 23:05:21.689 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::266ms
                        2020-05-22 23:05:22.283 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectMode::state->{"val":1,"ack":false,"ts":1590181522283,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590181522283}
                        2020-05-22 23:05:22.283 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectMode::1
                        2020-05-22 23:05:22.283 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:22.408 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::125ms
                        2020-05-22 23:05:25.677 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181525677,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:25.693 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:25.693 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 16ms
                        2020-05-22 23:05:25.787 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::110ms
                        2020-05-22 23:05:25.818 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181525818,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:25.818 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:25.818 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:25.880 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::62ms
                        2020-05-22 23:05:25.950 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181525949,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:25.950 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:25.950 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.012 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::62ms
                        2020-05-22 23:05:26.090 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181526090,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:26.090 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:26.090 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.169 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::79ms
                        2020-05-22 23:05:26.231 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181526231,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:26.231 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:26.231 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.308 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::77ms
                        2020-05-22 23:05:26.397 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181526397,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:26.397 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:26.397 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.460 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::63ms
                        2020-05-22 23:05:26.530 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181526530,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:26.530 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:26.530 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.593 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::63ms
                        2020-05-22 23:05:26.682 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181526681,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:26.682 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:26.682 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.760 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:26.851 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181526850,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:26.851 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:26.851 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:26.913 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::62ms
                        2020-05-22 23:05:27.001 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527001,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.001 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.001 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:27.079 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:27.157 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527157,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.157 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.157 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:27.235 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:27.320 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527320,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.320 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.320 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:27.383 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::63ms
                        2020-05-22 23:05:27.480 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527479,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.480 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.480 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:27.542 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::62ms
                        2020-05-22 23:05:27.645 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527644,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.645 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.645 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:27.707 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::62ms
                        2020-05-22 23:05:27.801 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527801,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.801 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.801 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:27.864 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::63ms
                        2020-05-22 23:05:27.973 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181527973,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:27.973 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:27.973 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:28.051 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:28.133 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181528133,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:28.133 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:28.133 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:28.211 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:28.298 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181528298,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:28.298 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:28.298 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:28.361 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::63ms
                        2020-05-22 23:05:28.458 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181528457,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:28.458 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:28.458 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:28.520 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::62ms
                        2020-05-22 23:05:28.621 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181528621,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:28.621 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:28.621 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:28.715 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::94ms
                        2020-05-22 23:05:28.762 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181528762,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:28.777 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:28.777 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 15ms
                        2020-05-22 23:05:28.840 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:28.916 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::state->{"val":true,"ack":false,"ts":1590181528916,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590153094656}
                        2020-05-22 23:05:28.931 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.effectSpeedDown::true
                        2020-05-22 23:05:28.931 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 15ms
                        2020-05-22 23:05:28.994 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::78ms
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.onoff::state->{"val":false,"ack":false,"ts":1590181535427,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590181535427}
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.onoff::false
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.off::true
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.on::false
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.rgb::#000000
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.brightness::0
                        2020-05-22 23:05:35.427 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.whiteMode::false
                        2020-05-22 23:05:35.608 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::181ms
                        2020-05-22 23:05:39.862 - debug: milight-smart-light.0 (6200) on:stateChange:ack=false->milight-smart-light.0.Wohnzimmer.rgbw-1.onoff::state->{"val":true,"ack":false,"ts":1590181539861,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1590181539861}
                        2020-05-22 23:05:39.862 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.onoff::true
                        2020-05-22 23:05:39.862 - debug: milight-smart-light.0 (6200) on:stateChange:mslStatestore.setState || 0ms
                        2020-05-22 23:05:39.862 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.on::true
                        2020-05-22 23:05:39.862 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.off::false
                        2020-05-22 23:05:39.877 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.brightness::40
                        2020-05-22 23:05:39.877 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.rgb::#666666
                        2020-05-22 23:05:39.877 - debug: milight-smart-light.0 (6200) _setVal->setStateAsync->::milight-smart-light.0.Wohnzimmer.rgbw-1.whiteMode::true
                        2020-05-22 23:05:40.221 - debug: milight-smart-light.0 (6200) mslcommandsV6 executed::359ms
                        2020-05-22 23:05:48.479 - debug: milight-smart-light.0 (6200) system.adapter.admin.0: logging true
                        Ich hoffe es ist etwas verständlich was ich meine 🙂
                        • carsten04
                          @Schimi Es gibt eine neue Version 0.6.0 auf GitHub zum testen. Ich habe mir das Thema Effekte noch einmal angeschaut und das Ganze etwas erweitert.
                          Es gibt jetzt für iBox1 und iBox2 (bridge, rgbw, fullColor, fullColor8Zone) für das Thema Effekte drei neue und einen umbenannten State.
                          neu: effectOn, effectOff, effectOnOff
                          umbenannt: onlyBrightness nach effectBrightness
                          Was passiert:
                          1. effectOn=true: Schaltet den aktuellen Effekt mit der aktuellen effectBrightness ein, d.h.
                          • effectOn=true, effectOff=false, effectOnOff=true
                          • on=false, off=true, onoff=false, brightness=0, rgb=#000000
                          1. effectOff=true: Schaltet den aktuellen Effekt mit der aktuellen effectBrightness aus, d.h.
                          • effectOn=false, effectOff=true, effectOnOff=false
                          1. effectMode=1..9: Schaltet den gewählten effectMode mit der aktuellen effectBrightness ein, d.h.
                          Du kannst also den Effektmodus völlig unabhängig von der eigentlichen Farbwahl wählen, d.h. wenn ein Effektmodus aktiv ist kannst Du durch wahl von on direkt die alte Farbe wieder nutzen und umgekehrt (alle States die irgendwie gesetzt werden müssen, also effectOn, effectOff, effectOnOff, on, off, onoff, brightness, saturation, hue, rgb behalten immer ihre richtigen Abhängigkeiten). Am Besten Du schaust Dir das live im Objektbaum an, dann siehst Du sehr schnell wie es funktioniert.
                          Ich hoffe das hilft Dir bei Deinen Skripten.
                            Jan1 @carsten04 last edited by
                            @carsten04
                            bringt diesen Fehler und nix läuft mehr:
                            	error	(821679) main->::TypeError: Cannot read property 'val' of null
                            • carsten04
                              carsten04 Developer @Jan1 last edited by carsten04
                              @Jan1 Noch ein Hinweis zur Installation:
                              Nach der Installation im Adapter-Admin alle Zonen deaktivieren, speichern, Zonen wieder aktivieren, dann wieder speichern (s. Doku). Dadurch werden die neuen States im Objektbaum angelegt, ohne das Du alle Instanzen löschen und wieder neu anlegen musst und der Fehler sollte verschwinden.
                                @carsten04
                                OK, hatte nur die Instanz neu gestartet wären der Halbzeit Pause 😉
                                • carsten04
                                  @Jan1 Tja, Augen auf bei der Vereinswahl 😀
                                    @carsten04
                                    3:0 alles gut 🙂
                                      Jan1 @carsten04 last edited by Jan1
                                      @carsten04
                                      So, Zonen ausgeschaltet und abgespeichert, wieder an und gespeichert. Ergebnis sieht so aus:
                                      Wie bekomme ich die an, so das es an bleibt?
                                      Edit:
                                      habs geschafft. Im Firefox sie die grafische Darstellung der Schalter wohl nur Schall und Rauch. Wenn die aktiv, also blau sind, heißt das nichts. Ich hab jetzt mit der Maus geklickt und geschoben, dann noch mal auf die rechte Seite geklickt, so bleiben sie aktiv. Etwas nervig, kannst da nicht einfach ne Ckeckbox mit Haken verwenden?
                                      • carsten04
                                        @Jan1 Wenn das immer alles so einfach wäre 🙂 . Das ist noch ein Fehler in materializeCSS und tritt immer dann auf, wenn Checkboxes, oder Switches in Tabs verwendet werden. Du musst dann immer etwas links oder rechts neben den Switch klicken, dann gehts.
                                          @carsten04
                                          Wenn man es weiß ist es zwar immer noch nervig, man wundert sich aber deutlich weniger 😉
                                          Jetzt geht auch endlich das APP, denn das war nämlich auch immer nur pseudo-an und ich hab mich gewundert, dass es nicht geht.
                                            HI,
                                            die Funktion ist echt praktisch (habe zwar noch kein Einsatz Scenario aber mir fallen da in "Zukunft" bestimmt ein, zwei sachen ein 😉
                                            Jetzt muss nur noch mein Blockly mit dem SpeedDown funktionieren (geht ja anscheinend nicht über "Zahl" 🙂
                                            Hier mal das Garten Blockly um was es die ganze Zeit (beim Farbwechsel Thema) geht... (Das mit dem "wiederhole 15 mal teste ich heute nach Sonnenuntergang 😉 )
                                            Echt klasse arbeit von dir!!!! 👍
                                            edit
                                            ok, das "wiederhole 15 mal" klappt nicht so wie ich gehofft habe.... muss mir da also was überlegen...
                                            31.7k
                                            79.9k
                                            bulbs milight milight-smart-light
                                            11
                                            73
                                            4470
