<variables>
<variable id="QH)a+q+/HjBMpJitoK=X">datum</variable>
</variables>
<block type="comment" id="-8Q#8O{5;,7Y..MP%hLW" x="-37" y="-262">
<field name="COMMENT">Format: DD.MM.YYYY</field>
<block type="variables_set" id=";Y0.4)M3k/vxOsmby4Xy">
<field name="VAR" id="QH)a+q+/HjBMpJitoK=X">datum</field>
<block type="lists_split" id="4/QFHo_G:.MJ$;X`{P4]">
<mutation mode="SPLIT"></mutation>
<field name="MODE">SPLIT</field>
<value name="INPUT">
<block type="text" id="w0u;nXdc[wmh/,M~36ba">
<field name="TEXT">24.05.2020</field>
<value name="DELIM">
<shadow type="text" id="coS;jKZv/}Em3,.g7SZ%">
<field name="TEXT">.</field>
<block type="variables_set" id="[Xk9h=jzG6]]`1J%a*Zi">
<block type="text_join" id="BGr[z#v-,wmRX#B{xJ*V">
<mutation items="5"></mutation>
<value name="ADD0">
<block type="lists_getIndex" id="Vo~,]~vZ7fpVss=(VU#D">
<block type="variables_get" id="u)1:1G_LwMi^%[8!`@h+">
<value name="AT">
<block type="math_number" id="z:EgV_3fzMliqDv*d7@t">
<field name="NUM">3</field>
<value name="ADD1">
<block type="text" id="v{.rg`EP3]-z+KK$!O={">
<field name="TEXT">-</field>
<value name="ADD2">
<block type="lists_getIndex" id=",Ed,A}`TT}uj~r@%~$1C">
<block type="variables_get" id="bls)qffc}OI}{r26Q0uf">
<value name="AT">
<block type="math_number" id="G+6]tXOQv{Og^aZUNv^N">
<field name="NUM">2</field>
<value name="ADD3">
<block type="text" id="RGkfv;U1)Y4orfJNVYNp">
<value name="ADD4">
<block type="lists_getIndex" id="DWU@g%Rq!{1upsYsOS{y">
<block type="variables_get" id="]p7OC{g_Yk4onB%1z88V">
<value name="AT">
<block type="math_number" id="Vygz5c#iO~S92Po(c%FZ">
<field name="NUM">1</field>
<block type="update" id="/d+qy!+$iX:eyI4$T)Ex" inline="false">
<block type="math_round" id="Pz!QIVb1LT.zhltW_5VZ">
<field name="OP">ROUNDUP</field>
<value name="NUM">
<shadow type="math_number" id="C.)jzzX:9UgS!rP9PEiV">
<field name="NUM">3.1</field>
<block type="math_arithmetic" id="%cE,S^(^k:R]vKsm0I1Q" inline="false">
<field name="OP">DIVIDE</field>
<shadow type="math_number" id="~wZr;xu/(qG,sIE6])U@">
<block type="math_arithmetic" id="=r_26i!LgMnIt17eE5jd" inline="false">
<shadow type="math_number" id="EEGOvL@^jbcJG[g@XU-j">
<block type="convert_from_date" id="*A^s]8q=h8~f5TXo0cE;">
<field name="OPTION">object</field>
<block type="variables_get" id="U1A!~okJ{ywBDd:POkS[">
<shadow type="math_number" id="pM/9zf_[9r^pv:mkU|7B">
<block type="time_get" id="p{4)88UXm0g}T[Ycx1#E">
<shadow type="math_number" id="F]F|#O)y~8]6zPT`P*]D">
<field name="NUM">86400000</field>
