    4. [gelöst]NPM Module bei Javascript-Adapter Update nicht mitgespeichert
    • Bluefox
      Bluefox last edited by
      Sollte mit 2.1.6 gefixt sein.
        ich habe eben mal nach deinem BTLE script gesehen.
        Da kam letztens eine Meldung, dass noble nicht da ist.
        So war es dann auch.
        noble wieder eingetragen,
        Skript neu gestartet - scan off
        javascript Instanz neu gestartet - scan off!
        Rainer
        • ruhr70
          ruhr70 last edited by
          @Bluefox:
          Sollte mit 2.1.6 gefixt sein. `
          Verhält sich jetzt anders:
          javascript.0 29 21:34:21.663 error javascript.0 Cannot install npm packet: w
          javascript.0 29 21:34:21.663 error javascript.0 Cannot install w: 1
          javascript.0 29 21:34:21.659 error javascript.0 /npm-debug.log
          javascript.0 29 21:34:21.659 error javascript.0 ERR!
          javascript.0 29 21:34:21.658 error javascript.0
          javascript.0 29 21:34:21.658 error javascript.0 npm
          javascript.0 29 21:34:21.658 error javascript.0 Please include the following file with any support request:
          javascript.0 29 21:34:21.658 error javascript.0 ERR!
          javascript.0 29 21:34:21.657 error javascript.0 npm
          javascript.0 29 21:34:21.638 error javascript.0 There is likely additional logging output above.
          javascript.0 29 21:34:21.636 error javascript.0 ERR!
          javascript.0 29 21:34:21.636 error javascript.0 npm ERR! npm owner ls w npm
          javascript.0 29 21:34:21.635 error javascript.0
          javascript.0 29 21:34:21.635 error javascript.0 ERR!
          javascript.0 29 21:34:21.635 error javascript.0 npm
          javascript.0 29 21:34:21.634 error javascript.0 Exit status 1 npm ERR! npm ERR! Failed at the w@0.0.1 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the w package, npm ERR! not with npm itself. npm ERR
          javascript.0 29 21:34:21.633 error javascript.0 ERR!
          javascript.0 29 21:34:21.632 error javascript.0 ERR! node v4.4.5 npm ERR! npm v2.15.5 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm
          javascript.0 29 21:34:21.631 error javascript.0 npm
          javascript.0 29 21:34:21.630 error javascript.0 npm ERR! Linux 4.4.0-22-generic npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
          javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! not ok
          javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! node-gyp -v v3.3.1
          javascript.0 29 21:34:21.624 error javascript.0 cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/w gyp ERR! node -v v4.4.5
          javascript.0 29 21:34:21.624 error javascript.0 ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR!
          javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic
          javascript.0 29 21:34:21.624 error javascript.0 ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js
          javascript.0 29 21:34:21.623 error javascript.0 ERR! stack Error: make failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          javascript.0 29 21:34:21.623 error javascript.0 gyp
          javascript.0 29 21:34:21.622 error javascript.0 build error
          javascript.0 29 21:34:21.622 error javascript.0 ERR!
          javascript.0 29 21:34:21.622 error javascript.0 gyp
          javascript.0 29 21:34:21.622 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1
          javascript.0 29 21:34:21.622 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird verlassen
          javascript.0 29 21:34:21.621 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte
          javascript.0 29 21:34:21.617 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
          javascript.0 29 21:34:21.600 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
          javascript.0 29 21:34:21.600 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
          javascript.0 29 21:34:21.226 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
          javascript.0 29 21:34:20.684 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
          javascript.0 29 21:34:20.684 error javascript.0 Cannot install w: 1
          javascript.0 29 21:34:20.676 error javascript.0 npm ERR! Please include the following file with any support request: npm ERR! /npm-debug.log
          javascript.0 29 21:34:20.673 error javascript.0
          javascript.0 29 21:34:20.654 error javascript.0 ERR! There is likely additional logging output above.
          javascript.0 29 21:34:20.653 error javascript.0 npm ERR! npm ERR! npm owner ls w npm
          javascript.0 29 21:34:20.653 error javascript.0 npm ERR! npm ERR! Failed at the w@0.0.1 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the w package, npm ERR! not with npm itself. npm ERR! Tell the auth
          javascript.0 29 21:34:20.651 error javascript.0 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm ERR! Exit status 1
          javascript.0 29 21:34:20.651 error javascript.0 ERR! node v4.4.5 npm ERR! npm v2.15.5
          javascript.0 29 21:34:20.650 error javascript.0 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
          javascript.0 29 21:34:20.650 error javascript.0 ERR! Linux 4.4.0-22-generic
          javascript.0 29 21:34:20.643 error javascript.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/w gyp ERR! node -v v4.4.5 gyp ERR! node-gyp -v v3.3.1 gyp ERR! not ok
          javascript.0 29 21:34:20.642 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd
          javascript.0 29 21:34:20.641 error javascript.0 stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:1
          javascript.0 29 21:34:20.640 error javascript.0
          javascript.0 29 21:34:20.638 error javascript.0 ERR!
          javascript.0 29 21:34:20.638 error javascript.0 gyp
          javascript.0 29 21:34:20.637 error javascript.0 ERR! build error gyp ERR! stack Error: make failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          javascript.0 29 21:34:20.637 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1 gyp
          javascript.0 29 21:34:20.637 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird
          javascript.0 29 21:34:20.632 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
          javascript.0 29 21:34:20.613 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
          javascript.0 29 21:34:20.612 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
          javascript.0 29 21:34:20.233 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
          javascript.0 29 21:34:19.683 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
          javascript.0 29 21:34:19.681 error javascript.0 Cannot install w: 1
          javascript.0 29 21:34:19.673 error javascript.0 /npm-debug.log
          javascript.0 29 21:34:19.672 error javascript.0 ERR!
          javascript.0 29 21:34:19.670 error javascript.0
          javascript.0 29 21:34:19.669 error javascript.0 npm
          javascript.0 29 21:34:19.667 error javascript.0 Please include the following file with any support request:
          javascript.0 29 21:34:19.666 error javascript.0 ERR!
          javascript.0 29 21:34:19.664 error javascript.0
          javascript.0 29 21:34:19.662 error javascript.0 npm
          javascript.0 29 21:34:19.660 error javascript.0
          javascript.0 29 21:34:19.639 error javascript.0 npm ERR! node v4.4.5 npm ERR! npm v2.15.5 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the w@0.0.1 install s
          javascript.0 29 21:34:19.639 error javascript.0 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
          javascript.0 29 21:34:19.634 error javascript.0 ERR! Linux 4.4.0-22-generic
          javascript.0 29 21:34:19.634 error javascript.0 npm
          javascript.0 29 21:34:19.629 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modul
          javascript.0 29 21:34:19.628 error javascript.0 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at Child
          javascript.0 29 21:34:19.627 error javascript.0 ERR! build error gyp ERR! stack Error: make failed with exit code: 2
          javascript.0 29 21:34:19.626 error javascript.0 gyp
          javascript.0 29 21:34:19.624 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1
          javascript.0 29 21:34:19.624 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird
          javascript.0 29 21:34:19.622 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
          javascript.0 29 21:34:19.603 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
          javascript.0 29 21:34:19.602 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
          javascript.0 29 21:34:19.232 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
          javascript.0 29 21:34:18.510 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
          javascript.0 29 21:34:18.510 info javascript.0 starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.javascript
          Nach dem Update auf 2.1.6 gab es erst keinen Unterschied.
          dewpoint war noch eingetragen.
          gelöscht und wieder eingetragen und dann kamen die Fehler oben.
          • ruhr70
            @Homoran:
            javascript Instanz neu gestartet - scan off! `
            Was heisst "scan off"?
            Meinst Du den Datenpunkt:
            javascript.0.Bluetooth.Control_ScanOn
            Wenn ja, einfach auf true setzen, damit der Scan gestartet wird.
            Ansonsten… was steht im Datenpunkt:
            javascript.0.Bluetooth.InfoSkript.Status_noble
            • ruhr70
              @ruhr70:
              @Bluefox:
              gelöscht und wieder eingetragen und dann kamen die Fehler oben. `
              Nachtrag:
              in /opt/iobroker/node_modules/iobroker.javascript/node_modules/ wurden mit der Version 2.1.16 und dem Eintrag "dewpoint" nun folgende Unterverzeichnisse installiert:
              /d
              /e
              /i
              /n
              /o
              /p
              /t
              Bis auf das w ergibt das ja "dewpoint". :lol:
              [EDIT] die Verzeichnisse sind nicht leer. Jedes Verzeichnis hat aber einen anderen Inhalt.
              Es wurden wirklich die npm Module:
              d, e, i, n, o, p und t installiert :lol: 😮 :shock:
                Nee läuft einfach nicht, weil:
                21:44:30.825	[info]	javascript.0 Stop script script.js.Anwesenheit.Bluetoothscanner
                21:44:30.920	[info]	javascript.0 Start javascript script.js.Anwesenheit.Bluetoothscanner
                21:44:30.922	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' at script.js.Anwesenheit.Bluetoothscanner:350:15
                21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: --== script.js.Anwesenheit.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
                21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
                21:44:30.923	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: node.js Module "noble" steht nicht zur Verfügung
                21:44:30.923	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Voraussetzung für noble: https://github.com/sandeepmistry/noble#prerequisites
                21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: warn: Das Skript wurde nicht gestartet. Siehe Fehlermeldungen.
                Skript ist aber als aktiv markiert!
                Ich will jetzt die Instanz nicht noch löschen und neu installieren.
                Rainer
                • ruhr70
                  Schau mal bitte unter:
                  Findest Du dort noble?
                  • ruhr70
                    @ruhr70:
                    @ruhr70:
                    @Bluefox:
                    Wie entsorgt man eigentlich am Besten Node Module, die man nicht benötigt?
                    Für das Modul d einfach das Verzeichnis:
                    /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                    löschen?
                      bei mir sind die Verzeichnisse n,o,b,l und e angelegt worden :mrgreen:
                      • Bluefox
                        @ruhr70:
                        @ruhr70:
                        @ruhr70:
                        löschen? `
                        Ja :lol:
                        Es gibt neue Version. :?
                        • ruhr70
                          @Bluefox:
                          @ruhr70:
                          löschen? `
                          Ja :lol:
                          Es gibt neue Version. :? `
                          Wir nähern uns der Version 3.0 :mrgreen:
                          Jetzt funktioniert es! Danke!
                          dewpoint wurde nach dem Update installiert, ohne das ich was tun musste und die einzelnen Module d,e,p,o,i,n,t sind auch alle automatisch verschwunden. Das lässt Rückschlüsse auf die Installation zu (zum Verständnis für mich). Danke!
                            Auch bei mir war noble dann von selbst drin.
                            Ich hatte nur vorher die anderen Verzeichnisse gelöscht.
                            Die Meldung des fehlenden noble ist jetzt weg, aber er fängt nicht mehr an zu scannen:
                            22:07:54.286	[info]	javascript.0 Start javascript script.js.Anwesenheit.Bluetoothscanner
                            22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: --== script.js.Anwesenheit.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
                            22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
                            22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                            22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                            22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: dpAnlegen() - Datenpunkte angelegt (createState) in javascript.0.Bluetooth.
                            22:07:54.288	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: registered 0 subscriptions and 0 schedules
                            22:07:55.314	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Kommando Bluetooth Scanner an: false
                            Seltsamerweise war noble auch poweredOn, als noble gar nicht da war
                            Rainer
                            • ruhr70
                              Du musst den Datenpunkt hier auf true setzen:
                                Danke!
                                Aber warum, musste ich doch noch nie?
                                Auch neustart von script oder Instanz hatte den Scan nicht gestartet.
                                Rainer
                                • ruhr70
                                  @Homoran:
                                  Danke!
                                  Rainer `
                                  Das Skript ist so geschrieben, dass Du es komplett benutzen kannst, ohne im Skript was anzupassen. Ausser Du möchtest die Blacklists oder eigenen Geräte pflegen (muss man aber nicht).
                                  Über den Datenpunkt kann man das Skript steuern (Scan starten oder stoppen), z.B. über VIS.
                                  Wenn die Voraussetzungen nicht gegeben sind, wird der Datenpunkt automatisch auf false gesetzt. Ich dachte, es macht keinen Sinn, dass dort ein true drin steht, wenn der Scan nicht läuft. Durch das Update vom Javascript-Adpater fehlte Dir das Module Noble. Das Skript hat es erkannt und sich selbst gestoppt.
                                    Danke und Gute N8
                                    Rainer
                                    2774
