    4. [gelöst]NPM Module bei Javascript-Adapter Update nicht mitgespeichert
    • ruhr70
      ruhr70 last edited by
      @Bluefox:
      Sollte mit 2.1.6 gefixt sein. `
      Verhält sich jetzt anders:
      javascript.0 29 21:34:21.663 error javascript.0 Cannot install npm packet: w
      javascript.0 29 21:34:21.663 error javascript.0 Cannot install w: 1
      javascript.0 29 21:34:21.659 error javascript.0 /npm-debug.log
      javascript.0 29 21:34:21.659 error javascript.0 ERR!
      javascript.0 29 21:34:21.658 error javascript.0
      javascript.0 29 21:34:21.658 error javascript.0 npm
      javascript.0 29 21:34:21.658 error javascript.0 Please include the following file with any support request:
      javascript.0 29 21:34:21.658 error javascript.0 ERR!
      javascript.0 29 21:34:21.657 error javascript.0 npm
      javascript.0 29 21:34:21.638 error javascript.0 There is likely additional logging output above.
      javascript.0 29 21:34:21.636 error javascript.0 ERR!
      javascript.0 29 21:34:21.636 error javascript.0 npm ERR! npm owner ls w npm
      javascript.0 29 21:34:21.635 error javascript.0
      javascript.0 29 21:34:21.635 error javascript.0 ERR!
      javascript.0 29 21:34:21.635 error javascript.0 npm
      javascript.0 29 21:34:21.634 error javascript.0 Exit status 1 npm ERR! npm ERR! Failed at the w@0.0.1 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the w package, npm ERR! not with npm itself. npm ERR
      javascript.0 29 21:34:21.633 error javascript.0 ERR!
      javascript.0 29 21:34:21.632 error javascript.0 ERR! node v4.4.5 npm ERR! npm v2.15.5 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm
      javascript.0 29 21:34:21.631 error javascript.0 npm
      javascript.0 29 21:34:21.630 error javascript.0 npm ERR! Linux 4.4.0-22-generic npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
      javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! not ok
      javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! node-gyp -v v3.3.1
      javascript.0 29 21:34:21.624 error javascript.0 cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/w gyp ERR! node -v v4.4.5
      javascript.0 29 21:34:21.624 error javascript.0 ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR!
      javascript.0 29 21:34:21.624 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic
      javascript.0 29 21:34:21.624 error javascript.0 ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js
      javascript.0 29 21:34:21.623 error javascript.0 ERR! stack Error: make failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      javascript.0 29 21:34:21.623 error javascript.0 gyp
      javascript.0 29 21:34:21.622 error javascript.0 build error
      javascript.0 29 21:34:21.622 error javascript.0 ERR!
      javascript.0 29 21:34:21.622 error javascript.0 gyp
      javascript.0 29 21:34:21.622 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1
      javascript.0 29 21:34:21.622 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird verlassen
      javascript.0 29 21:34:21.621 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte
      javascript.0 29 21:34:21.617 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
      javascript.0 29 21:34:21.600 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
      javascript.0 29 21:34:21.600 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
      javascript.0 29 21:34:21.226 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
      javascript.0 29 21:34:20.684 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
      javascript.0 29 21:34:20.684 error javascript.0 Cannot install w: 1
      javascript.0 29 21:34:20.676 error javascript.0 npm ERR! Please include the following file with any support request: npm ERR! /npm-debug.log
      javascript.0 29 21:34:20.673 error javascript.0
      javascript.0 29 21:34:20.654 error javascript.0 ERR! There is likely additional logging output above.
      javascript.0 29 21:34:20.653 error javascript.0 npm ERR! npm ERR! npm owner ls w npm
      javascript.0 29 21:34:20.653 error javascript.0 npm ERR! npm ERR! Failed at the w@0.0.1 install script 'node-gyp rebuild'. npm ERR! This is most likely a problem with the w package, npm ERR! not with npm itself. npm ERR! Tell the auth
      javascript.0 29 21:34:20.651 error javascript.0 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm ERR! Exit status 1
      javascript.0 29 21:34:20.651 error javascript.0 ERR! node v4.4.5 npm ERR! npm v2.15.5
      javascript.0 29 21:34:20.650 error javascript.0 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
      javascript.0 29 21:34:20.650 error javascript.0 ERR! Linux 4.4.0-22-generic
      javascript.0 29 21:34:20.643 error javascript.0 /opt/iobroker/node_modules/iobroker.javascript/node_modules/w gyp ERR! node -v v4.4.5 gyp ERR! node-gyp -v v3.3.1 gyp ERR! not ok
      javascript.0 29 21:34:20.642 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd
      javascript.0 29 21:34:20.641 error javascript.0 stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:1
      javascript.0 29 21:34:20.640 error javascript.0
      javascript.0 29 21:34:20.638 error javascript.0 ERR!
      javascript.0 29 21:34:20.638 error javascript.0 gyp
      javascript.0 29 21:34:20.637 error javascript.0 ERR! build error gyp ERR! stack Error: make failed with exit code: 2 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      javascript.0 29 21:34:20.637 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1 gyp
      javascript.0 29 21:34:20.637 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird
      javascript.0 29 21:34:20.632 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
      javascript.0 29 21:34:20.613 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
      javascript.0 29 21:34:20.612 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
      javascript.0 29 21:34:20.233 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
      javascript.0 29 21:34:19.683 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
      javascript.0 29 21:34:19.681 error javascript.0 Cannot install w: 1
      javascript.0 29 21:34:19.673 error javascript.0 /npm-debug.log
      javascript.0 29 21:34:19.672 error javascript.0 ERR!
      javascript.0 29 21:34:19.670 error javascript.0
      javascript.0 29 21:34:19.669 error javascript.0 npm
      javascript.0 29 21:34:19.667 error javascript.0 Please include the following file with any support request:
      javascript.0 29 21:34:19.666 error javascript.0 ERR!
      javascript.0 29 21:34:19.664 error javascript.0
      javascript.0 29 21:34:19.662 error javascript.0 npm
      javascript.0 29 21:34:19.660 error javascript.0
      javascript.0 29 21:34:19.639 error javascript.0 npm ERR! node v4.4.5 npm ERR! npm v2.15.5 npm ERR! code ELIFECYCLE npm ERR! w@0.0.1 install: node-gyp rebuild npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the w@0.0.1 install s
      javascript.0 29 21:34:19.639 error javascript.0 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "w" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.javascript"
      javascript.0 29 21:34:19.634 error javascript.0 ERR! Linux 4.4.0-22-generic
      javascript.0 29 21:34:19.634 error javascript.0 npm
      javascript.0 29 21:34:19.629 error javascript.0 gyp ERR! System Linux 4.4.0-22-generic gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modul
      javascript.0 29 21:34:19.628 error javascript.0 gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at Child
      javascript.0 29 21:34:19.627 error javascript.0 ERR! build error gyp ERR! stack Error: make failed with exit code: 2
      javascript.0 29 21:34:19.626 error javascript.0 gyp
      javascript.0 29 21:34:19.624 error javascript.0 make: *** [Release/obj.target/windows/src/windows.o] Fehler 1
      javascript.0 29 21:34:19.624 info javascript.0 windows.target.mk:88: die Regel für Ziel „Release/obj.target/windows/src/windows.o“ scheiterte make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird
      javascript.0 29 21:34:19.622 error javascript.0 ../src/windows.cc:3:19: fatal error: Psapi.h: Datei oder Verzeichnis nicht gefunden compilation terminated.
      javascript.0 29 21:34:19.603 info javascript.0 CXX(target) Release/obj.target/windows/src/windows.o
      javascript.0 29 21:34:19.602 info javascript.0 make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/w/build“ wird betreten
      javascript.0 29 21:34:19.232 info javascript.0 > w@0.0.1 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/w > node-gyp rebuild
      javascript.0 29 21:34:18.510 info javascript.0 npm install w --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
      javascript.0 29 21:34:18.510 info javascript.0 starting. Version 2.1.6 in /opt/iobroker/node_modules/iobroker.javascript
      Nach dem Update auf 2.1.6 gab es erst keinen Unterschied.
      dewpoint war noch eingetragen.
      gelöscht und wieder eingetragen und dann kamen die Fehler oben.
      • ruhr70
        @Homoran:
        javascript Instanz neu gestartet - scan off! `
        Was heisst "scan off"?
        Meinst Du den Datenpunkt:
        javascript.0.Bluetooth.Control_ScanOn
        Wenn ja, einfach auf true setzen, damit der Scan gestartet wird.
        Ansonsten… was steht im Datenpunkt:
        javascript.0.Bluetooth.InfoSkript.Status_noble
        • ruhr70
          @ruhr70:
          @Bluefox:
          gelöscht und wieder eingetragen und dann kamen die Fehler oben. `
          Nachtrag:
          in /opt/iobroker/node_modules/iobroker.javascript/node_modules/ wurden mit der Version 2.1.16 und dem Eintrag "dewpoint" nun folgende Unterverzeichnisse installiert:
          /d
          /e
          /i
          /n
          /o
          /p
          /t
          Bis auf das w ergibt das ja "dewpoint". :lol:
          [EDIT] die Verzeichnisse sind nicht leer. Jedes Verzeichnis hat aber einen anderen Inhalt.
          Es wurden wirklich die npm Module:
          d, e, i, n, o, p und t installiert :lol: 😮 :shock:
            Nee läuft einfach nicht, weil:
            21:44:30.825	[info]	javascript.0 Stop script script.js.Anwesenheit.Bluetoothscanner
            21:44:30.920	[info]	javascript.0 Start javascript script.js.Anwesenheit.Bluetoothscanner
            21:44:30.922	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble' at script.js.Anwesenheit.Bluetoothscanner:350:15
            21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: --== script.js.Anwesenheit.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
            21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
            21:44:30.923	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: node.js Module "noble" steht nicht zur Verfügung
            21:44:30.923	[error]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Voraussetzung für noble: https://github.com/sandeepmistry/noble#prerequisites
            21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
            21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
            21:44:30.923	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: warn: Das Skript wurde nicht gestartet. Siehe Fehlermeldungen.
            Skript ist aber als aktiv markiert!
            Ich will jetzt die Instanz nicht noch löschen und neu installieren.
            Rainer
            • ruhr70
              Schau mal bitte unter:
              Findest Du dort noble?
              • ruhr70
                @ruhr70:
                @ruhr70:
                @Bluefox:
                Wie entsorgt man eigentlich am Besten Node Module, die man nicht benötigt?
                Für das Modul d einfach das Verzeichnis:
                /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                löschen?
                  bei mir sind die Verzeichnisse n,o,b,l und e angelegt worden :mrgreen:
                  • Bluefox
                    Bluefox last edited by
                    @ruhr70:
                    @ruhr70:
                    @ruhr70:
                    löschen? `
                    Ja :lol:
                    Es gibt neue Version. :?
                    • ruhr70
                      @Bluefox:
                      @ruhr70:
                      löschen? `
                      Ja :lol:
                      Es gibt neue Version. :? `
                      Wir nähern uns der Version 3.0 :mrgreen:
                      Jetzt funktioniert es! Danke!
                      dewpoint wurde nach dem Update installiert, ohne das ich was tun musste und die einzelnen Module d,e,p,o,i,n,t sind auch alle automatisch verschwunden. Das lässt Rückschlüsse auf die Installation zu (zum Verständnis für mich). Danke!
                        Auch bei mir war noble dann von selbst drin.
                        Ich hatte nur vorher die anderen Verzeichnisse gelöscht.
                        Die Meldung des fehlenden noble ist jetzt weg, aber er fängt nicht mehr an zu scannen:
                        22:07:54.286	[info]	javascript.0 Start javascript script.js.Anwesenheit.Bluetoothscanner
                        22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: --== script.js.Anwesenheit.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: debug2
                        22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: Vars, Loglevel und Scriptname gesetzt
                        22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                        22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                        22:07:54.287	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: debug2: dpAnlegen() - Datenpunkte angelegt (createState) in javascript.0.Bluetooth.
                        22:07:54.288	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: registered 0 subscriptions and 0 schedules
                        22:07:55.314	[info]	javascript.0 script.js.Anwesenheit.Bluetoothscanner: Kommando Bluetooth Scanner an: false
                        Seltsamerweise war noble auch poweredOn, als noble gar nicht da war
                        Rainer
                        • ruhr70
                          Du musst den Datenpunkt hier auf true setzen:
                            Danke!
                            Aber warum, musste ich doch noch nie?
                            Auch neustart von script oder Instanz hatte den Scan nicht gestartet.
                            Rainer
                            • ruhr70
                              @Homoran:
                              Danke!
                              Rainer `
                              Das Skript ist so geschrieben, dass Du es komplett benutzen kannst, ohne im Skript was anzupassen. Ausser Du möchtest die Blacklists oder eigenen Geräte pflegen (muss man aber nicht).
                              Über den Datenpunkt kann man das Skript steuern (Scan starten oder stoppen), z.B. über VIS.
                              Wenn die Voraussetzungen nicht gegeben sind, wird der Datenpunkt automatisch auf false gesetzt. Ich dachte, es macht keinen Sinn, dass dort ein true drin steht, wenn der Scan nicht läuft. Durch das Update vom Javascript-Adpater fehlte Dir das Module Noble. Das Skript hat es erkannt und sich selbst gestoppt.
                                Danke und Gute N8
                                Rainer
                                2774
