    4. Test Adapter fb-checkpresence v1.0.x
    • afuerhoff
      afuerhoff Developer last edited by
      Hallo, bitte noch einmal updaten. Ich habe das Auslesen der externen IP-Adresse verändert.
      Ich hoffe, dass es jetzt funktioniert.
      Negalein ? 2 Replies Last reply Reply Quote 0
      • Negalein
        Negalein Global Moderator @afuerhoff last edited by
        @afuerhoff sagte in Test Adapter fb-checkpresence v1.0.x:
        gerade neu über GIT installiert.
        Die 2 Error-Meldungen bleiben.
        fb-checkpresence.0	2020-05-24 17:53:12.097	debug	(9965) checkPresence scheduled
        fb-checkpresence.0	2020-05-24 17:53:12.096	error	(9965) checkPresence: TypeError: Cannot read property 'NewExternalIPAddress' of null
        fb-checkpresence.0	2020-05-24 17:53:12.096	error	(9965) soapAction GetInfo status=500 errNo=4 401 Invalid Action
        fb-checkpresence.0	2020-05-24 17:53:11.755	debug	(9965) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
        fb-checkpresence.0	2020-05-24 17:53:11.493	debug	(9965) getDeviceInfo blCnt: 14
        fb-checkpresence.0	2020-05-24 17:53:11.493	debug	(9965) getDeviceInfo activeCnt: 46
        fb-checkpresence.0	2020-05-24 17:53:11.442	debug	(9965) getDeviceList: [{"Index":"1","IPAddress":"10.0.1.88","MACAddress":"08:84:9D:8E:B9:A6","Active":"1","HostName":"Amazon-Echo-Kinderzimmer","InterfaceType":"802.11","X_AVM-DE_Port":"0","X_AVM-DE_S
        fb-checkpresence.0	2020-05-24 17:53:11.206	debug	(9965) response: 1 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChalle
        fb-checkpresence.0	2020-05-24 17:53:11.074	debug	(9965) chCount 0
        fb-checkpresence.0	2020-05-24 17:53:11.073	debug	(9965) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:Challenge
        fb-checkpresence.0	2020-05-24 17:52:58.969	debug	(9965) system.adapter.admin.0: logging true
        fb-checkpresence.0	2020-05-24 17:52:12.092	debug	(9965) checkPresence scheduled
        fb-checkpresence.0	2020-05-24 17:52:12.091	error	(9965) checkPresence: TypeError: Cannot read property 'NewExternalIPAddress' of null
        fb-checkpresence.0	2020-05-24 17:52:12.091	error	(9965) soapAction GetInfo status=500 errNo=4 401 Invalid Action
        fb-checkpresence.0	2020-05-24 17:52:11.755	debug	(9965) response: 0 "<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n<s:Header>\n<h:NextChall
        fb-checkpresence.0	2020-05-24 17:52:11.519	debug	(9965) getDeviceInfo blCnt: 14
        fb-checkpresence.0	2020-05-24 17:52:11.519	debug	(9965) getDeviceInfo activeCnt: 46
        afuerhoff 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @Negalein last edited by
          @Negalein
          Wie ist Deine Fritzbox ans Internet angebunden?
          • Negalein
            Negalein Global Moderator @afuerhoff last edited by Negalein
            DSL-Box vom Anbieter ---> Fritz (vorhandener Zugang über WAN).
            Als ext. IP wird mir in der Fritz dann nicht die "echte" externe, sondern die IP der DSL-Box angezeigt.
            UPNP liest die ext. IP auch als 10.0.0.1 aus.
              A Former User @afuerhoff last edited by
              @afuerhoff Meldung sieht nun so aus
              fb-checkpresence.0	2020-05-24 18:30:18.693	error	(20287) soapAction GetInfo status=500 errNo=4 401 Invalid Action
              • afuerhoff
                @Negalein, @Brainbug
                Bitte nochmal updaten. Ich hatte einen Schreibfehler übersehen.
                • Negalein
                  ext. IP funktioniert
                  Der andere Fehler besteht noch.
                  fb-checkpresence.0	2020-05-24 19:00:45.697	error	(14560) soapAction GetInfo status=500 errNo=4 401 Invalid Action
                  • afuerhoff
                    @Negalein sagte in Test Adapter fb-checkpresence v1.0.x:
                    Und noch etwas übersehen. Bitte noch einmal updaten
                    • Negalein
                      Perfekt
                      Läuft 🙂
                      • afuerhoff
                        Perfekt
                        Läuft
                        endlich 🙂
                        • afuerhoff
                          @ilovegym , @Brainbug
                          Sind eure gemeldeten Auffälligkeiten auch so weit gelöst?
                          ? Neuschwansteini 2 Replies Last reply Reply Quote 0
                            @afuerhoff
                            fb-checkpresence.0	2020-05-24 22:37:19.708	error	(20287) soapAction GetInfo status=500 errNo=4 401 Invalid Action
                            • afuerhoff
                              afuerhoff Developer @Guest last edited by
                              @Brainbug
                              Hast du auch den letzten Stand geladen. Ich habe mehrere Updates auf Github hochgeladen?
                                @afuerhoff ja Katze und per GitHub den fb-... Installiert
                                afuerhoff 2 Replies Last reply Reply Quote 0
                                • afuerhoff
                                  @Brainbug
                                  Kannst Du mal den Loglevel auf debug setzen und dann das Log posten.
                                  • afuerhoff
                                    @Brainbug sagte in Test Adapter fb-checkpresence v1.0.x:
                                    Was mich wundert, das die Prozess-Id in deinem Log, die gleiche ist wie um 18:31.
                                    Hast Du wirklich danach nochmal ein Update gemacht und neu gestartet?
                                    • Neuschwansteini
                                      Neuschwansteini @afuerhoff last edited by
                                      Ja, Dankeschön 👍
                                        @afuerhoff Update ja und nicht neu gestartet. Sorry. Nach dem Neustart ist die Meldung weg.
                                        • afuerhoff
                                          @Brainbug
                                          Danke für die schnelle Rückmeldung.
                                          Dann kommt der Stand jetzt ins Latest.
                                          ? 1 Reply Last reply Reply Quote 1
                                            @afuerhoff ich danke dir für deinen Einsatz am Sonntag Nachmittag und späten Abend!
                                            31.7k
                                            79.9k
                                            avm fritzbox soap tr-064
                                            23
                                            248
                                            25468
