    4. Test Adapter Devices 0.3.x
      wenn ich mir einen Alias anlegen möchte, erhalte ich folgende Warnungen, mache ich da etwas falsch, oder stimmt da etwas nicht?
      admin.0	2020-05-05 00:33:27.145	warn	(989) This object will not be created in future versions. Please report this to the developer.
      admin.0	2020-05-05 00:33:27.145	warn	(989) Object alias.0.Zaehler.Abwasser.ACTUAL is invalid: obj.common.type has an invalid value (state) but has to be one of number, string, boolean, array, object, mixed, file, json
      admin.0	2020-05-05 00:29:49.974	warn	(989) This object will not be created in future versions. Please report this to the developer.
      admin.0	2020-05-05 00:29:49.972	warn	(989) Object alias.0.Zaehler.Abwasser.ACTUAL is invalid: obj.common.type has an invalid value (state) but has to be one of number, string, boolean, array, object, mixed, file, json
      iogo.0	2020-05-05 00:28:54.361	info	(1282) database initialized with 104 state values
      iogo.0	2020-05-05 00:28:54.220	info	(1282) database initialized with 104 state values
      iogo.0	2020-05-05 00:28:47.719	info	(1282) uploading state
      iogo.0	2020-05-05 00:28:47.696	info	(1282) uploading state
      influxdb.0	2020-05-05 00:28:47.652	warn	(1233) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
      influxdb.2	2020-05-05 00:28:47.664	warn	(2240) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
      javascript.0	2020-05-05 00:28:47.654	warn	(1700) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
      iogo.0	2020-05-05 00:28:47.658	warn	(1282) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
      javascript.1	2020-05-05 00:28:47.655	warn	(1707) Alias alias.0.Zaehler.Abwasser.ACTUAL has no target 12
      admin.0	2020-05-05 00:28:47.628	warn	(989) This object will not be created in future versions. Please report this to the developer.
      admin.0	2020-05-05 00:28:47.624	warn	(989) Object alias.0.Zaehler.Abwasser.ACTUAL is invalid: obj.common.type has an invalid value (state) but has to be one of number, string, boolean, array, object, mixed, file, json
      influxdb.2	2020-05-05 00:28:47.346	warn	(2240) Alias alias.0.Zaehler.Abwasser has no target 12
      iogo.0	2020-05-05 00:28:47.355	warn	(1282) Alias alias.0.Zaehler.Abwasser has no target 12
      javascript.1	2020-05-05 00:28:47.348	warn	(1707) Alias alias.0.Zaehler.Abwasser has no target 12
      javascript.0	2020-05-05 00:28:47.349	warn	(1700) Alias alias.0.Zaehler.Abwasser has no target 12
      influxdb.0	2020-05-05 00:28:47.342	warn	(1233) Alias alias.0.Zaehler.Abwasser has no target 12
      59eec708-8438-4dbf-82e1-fd0bc1993187-image.png 52489ea1-30f2-4c00-85b3-d08a98b3f61b-image.png
      Unit habe ich nachträglich eingetragen, role hab ich geändert von "state" auf "value"
      die Raw vom Original
       "type": "state",
       "common": {
         "read": true,
         "write": false,
         "desc": "w_counter_3",
         "unit": "m3",
         "role": "value",
         "id": "w_counter_3",
         "name": "15",
         "type": "number",
         "custom": {
           "sourceanalytix.0": {
             "enabled": true,
             "alias": "Wasser",
             "state_type": "water_m3",
             "state_unit": "m3",
             "costs": true,
             "consumption": true,
             "meter_values": true,
             "start_day": 301.899,
             "start_week": 301.638,
             "start_month": 301.309,
             "start_quarter": 294.02,
             "start_year": 275.744
           "influxdb.0": {
             "enabled": true,
             "changesOnly": true,
             "debounce": "1000",
             "retention": "31536000",
             "changesRelogInterval": "3600",
             "changesMinDelta": 0,
             "storageType": "Number",
             "aliasId": ""
       "native": {},
       "from": "system.adapter.sourceanalytix.0",
       "user": "system.user.admin",
       "ts": 1588629600677,
       "_id": "wiffi-wz.0.root.10_1_30_10.w_counter_3",
       "acl": {
         "object": 1636,
         "state": 1636,
         "owner": "system.user.admin",
      nächste Frage, wenn ich diesen Alias wieder lösche
      kommen sämtliche Warnmeldungen im LOG
      iogo.0	2020-05-05 00:52:56.464	info	(1282) database initialized with 104 state values
      iogo.0	2020-05-05 00:52:55.815	info	(1282) database initialized with 104 state values
      iogo.0	2020-05-05 00:52:48.985	info	(1282) uploading state
      iogo.0	2020-05-05 00:52:48.968	info	(1282) uploading state
      javascript.1	2020-05-05 00:52:48.954	warn	at process.topLevelDomainCallback (domain.js:126:23)
      javascript.1	2020-05-05 00:52:48.954	warn	at processImmediate (timers.js:658:5)
      javascript.1	2020-05-05 00:52:48.954	warn	at tryOnImmediate (timers.js:676:5)
      javascript.1	2020-05-05 00:52:48.954	warn	at runCallback (timers.js:705:18)
      javascript.1	2020-05-05 00:52:48.954	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
      javascript.1	2020-05-05 00:52:48.954	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
      javascript.1	2020-05-05 00:52:48.954	warn	(1707) TypeError: Cannot read property '_id' of null
      influxdb.2	2020-05-05 00:52:48.952	warn	at process.topLevelDomainCallback (domain.js:126:23)
      influxdb.2	2020-05-05 00:52:48.952	warn	at processImmediate (timers.js:658:5)
      influxdb.2	2020-05-05 00:52:48.952	warn	at tryOnImmediate (timers.js:676:5)
      influxdb.2	2020-05-05 00:52:48.952	warn	at runCallback (timers.js:705:18)
      influxdb.2	2020-05-05 00:52:48.952	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
      influxdb.2	2020-05-05 00:52:48.952	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
      influxdb.2	2020-05-05 00:52:48.952	warn	(2240) TypeError: Cannot read property '_id' of null
      influxdb.0	2020-05-05 00:52:48.940	warn	at process.topLevelDomainCallback (domain.js:126:23)
      influxdb.0	2020-05-05 00:52:48.940	warn	at processImmediate (timers.js:658:5)
      influxdb.0	2020-05-05 00:52:48.940	warn	at tryOnImmediate (timers.js:676:5)
      influxdb.0	2020-05-05 00:52:48.940	warn	at runCallback (timers.js:705:18)
      influxdb.0	2020-05-05 00:52:48.940	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
      influxdb.0	2020-05-05 00:52:48.940	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
      influxdb.0	2020-05-05 00:52:48.940	warn	(1233) TypeError: Cannot read property '_id' of null
      javascript.0	2020-05-05 00:52:48.933	warn	at process.topLevelDomainCallback (domain.js:126:23)
      javascript.0	2020-05-05 00:52:48.933	warn	at processImmediate (timers.js:658:5)
      javascript.0	2020-05-05 00:52:48.933	warn	at tryOnImmediate (timers.js:676:5)
      javascript.0	2020-05-05 00:52:48.933	warn	at runCallback (timers.js:705:18)
      javascript.0	2020-05-05 00:52:48.933	warn	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
      javascript.0	2020-05-05 00:52:48.933	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
      javascript.0	2020-05-05 00:52:48.933	warn	(1700) TypeError: Cannot read property '_id' of null
      iogo.0	2020-05-05 00:52:48.931	warn	at processImmediate (timers.js:658:5)
      iogo.0	2020-05-05 00:52:48.931	warn	at tryOnImmediate (timers.js:676:5)
      iogo.0	2020-05-05 00:52:48.931	warn	at runCallback (timers.js:705:18)
      iogo.0	2020-05-05 00:52:48.931	warn	at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:30045)
      iogo.0	2020-05-05 00:52:48.931	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1620:151)
      iogo.0	2020-05-05 00:52:48.931	warn	(1282) TypeError: Cannot read property '_id' of null
      javascript.1	2020-05-05 00:52:48.915	warn	(1707) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
      iogo.0	2020-05-05 00:52:48.915	warn	(1282) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
      influxdb.2	2020-05-05 00:52:48.927	warn	(2240) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
      javascript.0	2020-05-05 00:52:48.922	warn	(1700) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
      influxdb.0	2020-05-05 00:52:48.914	warn	(1233) Objects Cannot process system pmessage alias.0.Zaehler.Abwasser - null: Cannot read property '_id' of null
        apollon77 @crunchip last edited by
        @crunchip Der eine Teil der meldungen kam wegen dem falschen typ (state anstelle einem datentyp). Der andere teil das auch "Stukturobjekte" Fehlermekdungen werden wird in der nächsten Controller Version gefixt sein. Der andere Fehler auch Danke!
          martinschm @apollon77 last edited by
          @apollon77 said in Test Adapter Devices 0.3.x:
          LowBat ist eher als Boolean gedacht, ja einen Volt Wert würde ich dort nicht reinschreiben, aber mittelen read logik kannst Du ja eine grenze definieren und true setzen wenn dein Wert <3V oder so ist.
          Verzeih mir meine Unwissenheit, aber was ist den read logik ?
          • Garfonso
            Garfonso Developer @martinschm last edited by
            @martinschm
            Man kann dem alias sagen er soll die Daten noch manipulieren, bevor er sie in den Alias State schreibt (read logik) oder aus dem alias state in den original state (write logik). Soweit ich weiß geht das bisher nur über die RAW Ansicht des Objekts. Dort dann sowas eintragen:
              "common": {
                "name": "Buero batteryWarning",
                "role": "indicator.lowbat",
                "type": "boolean",
                "read": true,
                "write": false,
                "smartName": false,
                "alias": {
                  "id": "zigbee.0.00158d0003f3cea3.battery",
                  "read": "val < 20"
            Also wichtig die Zeile "read". Hier wird aus einer Batterie % Anzeige eine Batteriewarnung, wenn die Batterie unter 20% fällt. Damit kann man relativ lustige Sachen machen. "val" ist dabei in read der Wert des target state (also hier zigbee.0.00158d0003f3cea3.battery) und bei write der Wert des alias state.
            M M 2 Replies Last reply Reply Quote 1
              muuulle last edited by
              mein Alias.0 Ordner ist verschwunden. Mögliches versehentliches löschen nicht auszuschließen 😲
              Was kann ich tun?
              BBTown Garfonso 2 Replies Last reply Reply Quote 0
              • BBTown
                BBTown @muuulle last edited by
                @muuulle
                1. ein aktuelles Backup anlegen
                2. ein altes Backup zurückspielen
                3. die Objekte aus dem Knoten alias.0 sichern (exportieren)
                4. das zuvor angelegte Backup zurückspielen
                5. die alias.0 Objekte importieren
                  muuulle @BBTown last edited by
                  @BBTown
                  Danke für die Rückmeldung.
                  Muss ich das große Rad auch drehen, wenn ich keinen Bedarf an den alten Alias habe? Ich könnte die paar Alias auch flott händisch anlegen...
                    paul53 @muuulle last edited by paul53
                    @muuulle sagte:
                    Dann mache es.
                    const id = 'alias.0';
                    const obj = {
                        type: 'meta',
                        common: {
                        native: {}
                    if(!existsObject(id)) setObject(id, obj);
                    M apollon77 2 Replies Last reply Reply Quote 1
                      muuulle @paul53 last edited by
                      Moin Paul,
                      meine Programmierkenntnisse sind äußerst limitiert. Wo muss ich den Code einfügen? 👷‍♂️
                        @muuulle sagte:
                        als neues Javascript, starten und wieder beenden.
                        • Garfonso
                          Garfonso Developer @muuulle last edited by
                          @muuulle said in Test Adapter Devices 0.3.x:
                          Was kann ich tun?
                          Bist du sicher, dass er gelöscht wurde? Wenn keine Elemente darin sind, wird er nicht als "Ordner" angezeigt und landet im Admin in der Objekt-Ansicht ganz unten bei den States.
                            Alles geklappt. Danke!
                              apollon77 @paul53 last edited by
                              @paul53 Ein "iobroker setup first" sollte auch reichen
                                paul53 @apollon77 last edited by
                                @apollon77 sagte:
                                Danke. Das hatte ich zwar vermutet, war mir aber nicht sicher.
                                  muuulle @Garfonso last edited by
                                  @Garfonso said in Test Adapter Devices 0.3.x:
                                  @martinschm
                                    "common": {
                                      "type": "boolean",
                                      "read": true,
                                      "write": false,
                                      "smartName": false,
                                      "alias": {
                                        "read": "val < 20"
                                  Moin @Garfonso
                                  LOWBAT hat mit deiner Anleitung super funktioniert.
                                  Meine aqara Sensoren kennen nur reachable. Kann man den Wert invertieren, dass ich UNREACH richtig füttern kann?
                                    @muuulle sagte:
                                          "read": "!val" // Alias read invertieren
                                    M 1 Reply Last reply Reply Quote 2
                                      Super.
                                      Ich habe jetzt alle meine unterschiedlichen Geräte vom Output vereinheitlicht.
                                      Könnte ich jetzt auch alle LOWBAT/UNREACH mit nur einer Abfrage (Blockly?) anfragen?
                                      Vielen Dank
                                      K paul53 Garfonso 3 Replies Last reply Reply Quote 0
                                        Kueppert @muuulle last edited by
                                        @muuulle schau mal hier rein:
                                        https://forum.iobroker.net/topic/23370/fenster-und-andere-geräte-zählen-opt-alexa-ansagen/627
                                        Für Hoematic wurde da schon was umgesetzt. Ich bin auch auf Xiaomi-Sensoren unterwegs und @dslraser baut dafür ggf. auch etwas. Wenn das nicht klappt, geh ich ggf auch über Alias.
                                          @muuulle sagte:
                                          Ja, jeweils für LOWBAT bzw. UNREACH mittels $Selector().
                                          • Garfonso
                                            @muuulle
                                            Wenn sie alle gleich heißen, dann mit Javascript z.B. so:
                                            //wenn struktur alias.0.Gerät.Unreach. Wenn noch mehr "Ordner" noch öfter .* einfügen.
                                            $('[id=alias.0.*.UNREACH]').each(id => {
                                                //was mit id machen, z.B. getState();
                                            79.9k
                                            devices
                                            27
                                            136
                                            10234
